  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.3k Aufrufe 147 Beobachtet
  • L lustig29
    Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
    eusec.0
    2023-01-29 11:24:22.280	info	Connected to station T8010P23220312FE on host 192.168.0.70 and port 22316
    eusec.0
    2023-01-29 11:24:17.255	info	Disconnected from station T8010P23220312FE
    LongbowL Offline
    LongbowL Offline
    Longbow
    schrieb am zuletzt editiert von Longbow
    #622
    Guten Morgen... ich bekomme immer die Meldungen? Was ist hier das Problem?
    host.iobroker
    2023-01-31 09:35:39.875	info	Rebuild for adapter system.adapter.eusec.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker
    2023-01-31 09:35:39.875	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: }
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: requestPath: 'eufy-security-client'
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32) {
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:35:32)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:400:19)
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: ^
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: throw err;
    host.iobroker
    2023-01-31 09:35:39.874	error	Caught by controller[0]: node:internal/modules/cjs/loader:408![2023-01-31 09_37_27-instances - iobroker.png](/assets/uploads/files/1675154274282-2023-01-31-09_37_27-instances-iobroker.png)
    • LongbowL Longbow
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      #623
      @longbow sagte in [Neuer Adapter] EuSec:
      Das du Text nicht in CodeTags setzt.
      iob diag
      sagt?
      LongbowL 1 Antwort Letzte Antwort
        iob diag
        sagt?
        LongbowL Offline
        LongbowL Offline
        Longbow
        #624
        Was möchtest du mir sagen damit?
        • LongbowL Longbow
          #625
          @longbow
          Das du bitte die Meldungen in CodeTags setzen möchtest und die Ausgabe von
          iob diag
          in eben diese CodeTags eingebettet posten möchtest.
            @longbow
            iob diag
            LongbowL Offline
            LongbowL Offline
            Longbow
            #626
            @thomas-braun Danke, so wie jetzt?
            kommt dann auch gleich
            • LongbowL Offline
              LongbowL Offline
              Longbow
              #627
              @longbow Welchen Teil von dem iob Log möchtes Du sehen... habe es gestern nicht mehr geschafft und von Unterwegs ging es nicht so, wie ich es wollte.
              • LongbowL Longbow
                LongbowL Offline
                LongbowL Offline
                Longbow
                #628
                @Thomas-Braun
                • LongbowL Longbow
                  @Thomas-Braun
                  #629
                  @longbow
                  Alles.
                  LongbowL L 2 Antworten Letzte Antwort
                    @longbow
                    Alles.
                    LongbowL Offline
                    LongbowL Offline
                    Longbow
                    #630
                    Bitte:-)
                    Skript v.2023-01-02
                    *** BASE SYSTEM ***
                    Architecture:   x86_64
                    Docker:         false
                    Virtualization: lxc
                    Distributor ID: Ubuntu
                    Description:    Ubuntu 22.04.1 LTS
                    Release:        22.04
                    Codename:       jammy
                    PRETTY_NAME="Ubuntu 22.04.1 LTS"
                    NAME="Ubuntu"
                    VERSION_ID="22.04"
                    VERSION="22.04.1 LTS (Jammy Jellyfish)"
                    VERSION_CODENAME=jammy
                    ID=ubuntu
                    ID_LIKE=debian
                    HOME_URL="https://www.ubuntu.com/"
                    SUPPORT_URL="https://help.ubuntu.com/"
                    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                    UBUNTU_CODENAME=jammy
                    Systemuptime and Load:
                    06:35:50 up 1 day, 11:41,  2 users,  load average: 0.64, 0.55, 0.43
                    CPU threads: 4
                    *** Time and Time Zones ***
                    Wed Feb  1 06:35:50 UTC 2023
                    UTC +0000
                    Etc/UTC
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:            8.2G        3.3G        3.6G        0.0K        1.3G        4.9G
                    Swap:           512M          0B        512M
                    Total:          8.7G        3.3G        4.1G
                             8192 M total memory
                             3272 M used memory
                              568 M active memory
                             3792 M inactive memory
                             3584 M free memory
                                0 M buffer memory
                             1335 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    Filesystem                       Type   Size  Used Avail Use% Mounted on
                    /dev/mapper/pve-vm--200--disk--0 ext4    20G  7.6G   11G  42% /
                    none                             tmpfs  492K  4.0K  488K   1% /dev
                    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                    tmpfs                            tmpfs  3.2G   96K  3.2G   1% /run
                    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                    Messages in dmesg:
                    dmesg: read kernel buffer failed: Operation not permitted
                    TARGET SOURCE                           FSTYPE OPTIONS
                    /      /dev/mapper/pve-vm--200--disk--0 ext4   rw,relatime,stripe=16
                    /var:
                    2.6G    /var/
                    2.0G    /var/log/journal/678b65fc11864452957ca5b3828797d4
                    2.0G    /var/log
                    331M    /var/cache
                    /opt/iobroker/backups:
                    495M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    583M    /opt/iobroker/iobroker-data/
                    365M    /opt/iobroker/iobroker-data/files
                    74M     /opt/iobroker/iobroker-data/backup-objects
                    72M     /opt/iobroker/iobroker-data/files/telegram.admin
                    51M     /opt/iobroker/iobroker-data/files/javascript.admin
                    46M     /opt/iobroker/iobroker-data/states.jsonl
                    34M     /opt/iobroker/iobroker-data/objects.jsonl
                    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                    15M     /opt/iobroker/iobroker-data/files/vis.0/Iobroker/vis-views.json
                    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v16.19.0
                    /root/.nvm/versions/node/v16.18.0/bin/node              v16.18.0
                    /root/.nvm/versions/node/v16.18.0/bin/npm               9.4.0
                    /root/.nvm/versions/node/v16.18.0/bin/npx               9.4.0
                    nodejs:
                      Installed: 16.19.0-deb-1nodesource1
                      Candidate: 16.19.0-deb-1nodesource1
                      Version table:
                    *** 16.19.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                         12.22.9~dfsg-1ubuntu3 500
                            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  4.0.24
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapters from github:   3
                    Adapter State
                      system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                      system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                      system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
                    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      system.adapter.klf200.0                 : klf200                : iobroker                                 - disabled
                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                    + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                      system.adapter.operating-hours.0        : operating-hours       : iobroker                                 - disabled
                      system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
                      system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                      system.adapter.places.0                 : places                : iobroker                                 - disabled
                    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                      system.adapter.rtspstream.0             : rtspstream            : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
                    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                      system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
                    + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 192.168.178.200
                      system.adapter.youtube.0                : youtube               : iobroker                                 - disabled
                      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "alpha-ess"    : 0.2.0    , installed 0.2.0
                    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
                    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
                    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
                    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
                    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                    Adapter    "email"        : 1.1.4    , installed 1.1.4
                    Adapter    "eusec"        : 0.9.9    , installed 0.9.9
                    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                    Adapter    "followthesun" : 0.4.0    , installed 0.4.0
                    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                    Adapter    "hid-community": 0.3.0    , installed 0.3.0
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                    Adapter    "hue"          : 3.7.1    , installed 3.7.1
                    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                    Adapter    "iot"          : 1.14.2   , installed 1.14.2
                    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                    Adapter    "klf200"       : 1.0.1    , installed 1.0.1
                    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                    Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                    Adapter    "operating-hours": 0.0.19 , installed 0.0.19
                    Adapter    "parcel"       : 0.0.23   , installed 0.0.23
                    Adapter    "parser"       : 1.1.8    , installed 1.1.8
                    Adapter    "places"       : 1.1.2    , installed 1.1.2
                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                    Adapter    "synology"     : 2.1.13   , installed 2.1.13
                    Adapter    "tankerkoenig" : 3.3.6    , installed 3.3.6
                    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                    Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                    Adapter    "wolf"         : 1.5.0    , installed 1.5.0
                    Adapter    "wolf-smartset": 1.0.0    , installed 1.0.0
                    Adapter    "youtube"      : 4.1.0    , installed 4.1.0
                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                    Objects and States
                    Objects:        51213
                    States:         41765
                    Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                    • LongbowL Longbow
                      Bitte:-)
                      Skript v.2023-01-02
                      *** BASE SYSTEM ***
                      Docker:         false
                      Virtualization: lxc
                      Release:        22.04
                      Codename:       jammy
                      NAME="Ubuntu"
                      VERSION_ID="22.04"
                      ID=ubuntu
                      ID_LIKE=debian
                      CPU threads: 4
                      UTC +0000
                      Etc/UTC
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:           512M          0B        512M
                               8192 M total memory
                               3272 M used memory
                                568 M active memory
                               3584 M free memory
                                  0 M buffer memory
                               1335 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      *** FILESYSTEM ***
                      Messages in dmesg:
                      /var:
                      2.6G    /var/
                      2.0G    /var/log
                      331M    /var/cache
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        51213
                      States:         41765
                      #631
                      @longbow
                      Zeitzone setzen und nodejs gescheit installieren.
                        @longbow
                        LongbowL Offline
                        LongbowL Offline
                        Longbow
                        #632
                        wie mache ich das bitte, bin neu Neuling auf dem Gebiet ioborker...
                        • LongbowL Longbow
                          #633
                          @longbow
                          Das hat mit iobroker nix zu tun, das hat damit zu tun wie du deinen Container administrierst. Mit den Dingern hab ich aber nix mit am Hut.
                          Schau in die Anleitung, vielleicht steht da was drin:
                          https://www.iobroker.net/#de/documentation/install/proxmox.md
                          Zur NodeJS-Installation:
                          Wo stand denn, das man nodejs als root per nvm installiert?
                          Das ist nämlich Murks.
                            @longbow
                            LongbowL Offline
                            LongbowL Offline
                            Longbow
                            #634
                            wie kann ich das mit dem nodejs beheben? Oder ist es besser das man Iobroker neu installiert?
                            • LongbowL Longbow
                              #635
                              Schau in meiner Signatur, da wird das mit den falschen Pfaden bei nodejs erklärt.
                                @longbow
                                Alles.
                                lustig29
                                #636
                                @thomas-braun Kannst du mir auch bei meinem Problem vom Post weiter oben helfen?
                                • L lustig29
                                  #637
                                  @lustig29
                                  Bei welchem?
                                    @lustig29
                                    Bei welchem?
                                    lustig29
                                    #638
                                    @thomas-braun Seit geraumer Zeit läuft der Adapter nicht mehr richtig. Die Verbindung wird immer wieder getrennt und wieder hergestellt. Hatte sowas schon mal jemand?
                                    eusec.0
                                    eusec.0
                                    • L lustig29
                                      #639
                                      @lustig29 sagte in [Neuer Adapter] EuSec:
                                      Nein. Keine Ahnung.
                                      Ist halt auch was dünn, so'n Zweizeiler.
                                        LongbowL Offline
                                        LongbowL Offline
                                        Longbow
                                        #640
                                        guten Morgen, habe es alles gemacht wie es dort beschrieben ist, eine Abhilfe hat es leider nicht gebracht.
                                        Hab ein neues System nach den Anleitungen gemacht.
                                        Habe es mit auch alles angeschaut mit Nodejs, aber ich bekomme nur Fehlermeldungen. Der Adpater bleibt ohne Daten und Verbindung rot
                                        Debian GNU/Linux 11 iobroker-Test tty1
                                        iobroker-Test login: root
                                        Password:
                                        Linux iobroker-Test 5.15.30-2-pve #1 SMP PVE 5.15.30-3 (Fri, 22 Apr 2022 18:08:27 +0200) x86_64
                                        permitted by applicable law.
                                        Last login: Thu Feb  2 08:28:34 CET 2023 on tty1
                                        root@iobroker-Test:~# apt install sudo curl
                                        Reading package lists... Done
                                        The following additional packages will be installed:
                                          libcurl4
                                        The following NEW packages will be installed:
                                          curl libcurl4 sudo
                                        0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 1673 kB of archives.
                                        After this operation, 5895 kB of additional disk space will be used.
                                        Do you want to continue? [Y/n] y
                                        Err:1 http://deb.debian.org/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u3
                                          Temporary failure resolving 'deb.debian.org'
                                        Err:2 http://deb.debian.org/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u3
                                        Err:3 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                                        E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                        E: Failed to fetch http://deb.debian.org/debian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                        E: Failed to fetch http://deb.debian.org/debian/pool/main/s/sudo/sudo_1.9.5p2-3_amd64.deb  Temporary failure resolving 'deb.debian.org'
                                        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                        root@iobroker-Test:~# curl libcurl4 sudo
                                        -bash: curl: command not found
                                        root@iobroker-Test:~# apt install curl
                                          libcurl4
                                          curl libcurl4
                                        0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 615 kB of archives.
                                        After this operation, 1196 kB of additional disk space will be used.
                                          sudo
                                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 1059 kB of archives.
                                        After this operation, 4699 kB of additional disk space will be used.
                                        Err:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3
                                        root@iobroker-Test:~# apt-get update
                                        Err:1 http://deb.debian.org/debian bullseye InRelease
                                        Err:2 http://security.debian.org bullseye-security InRelease
                                          Temporary failure resolving 'security.debian.org'
                                        Err:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
                                        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
                                        W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
                                        W: Some index files failed to download. They have been ignored, or old ones used instead.
                                        root@iobroker-Test:~# apt update && apt upgrade
                                        All packages are up to date.
                                        Calculating upgrade... Done
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        LongbowL Thomas BraunT 2 Antworten Letzte Antwort
                                        • LongbowL Longbow
                                          Password:
                                            libcurl4
                                            curl libcurl4 sudo
                                            libcurl4
                                            curl libcurl4
                                            sudo
                                          LongbowL Offline
                                          LongbowL Offline
                                          Longbow
                                          #641
                                          @Thomas-Braun
                                          das war bei mir mit dem Befehl cd /opt/iobroker
                                          npm ls | grep -E 'github|ERR'
                                          cliffkirchhof@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
                                          +-- eufy-security-client@2.4.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#7fc2a45a75ee1bf69ced36d351d1ec6d623896f6)
                                          +-- iobroker.klf200@1.0.1 (git+ssh://git@github.com/MiSchroe/ioBroker.klf200.git#c0799c01cca44762617b9fa5e709d60a83a80f24)
                                          +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspstream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)e_text
