  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 619.9k Aufrufe 147 Beobachtet
    @marko1974
    Ist der ioBroker jetzt zur Ruhe gekommen? Rebuilds durchgeführt?
    Ein (Neu)-Start des Adapters schaut jetzt wie aus?
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    #421
    @thomas-braun es rödelt noch...melde mich sofort wenn er fertig ist
    • Marko1974M Offline
      Marko1974M Offline
      Marko1974
      #422
      @thomas-braun habe da immer noch die gleichen dinge in schleife drin -.-
      2022-03-06 16:44:08.612 - info: shuttercontrol.0 (3401) starting. Version 1.4.10 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.19.0, js-controller: 4.0.18
      2022-03-06 16:44:12.273 - info: fb-checkpresence.0 (2760) History function for Konrads-IphoneX disabled. Please select a history adapter in the configuration dialog!
      2022-03-06 16:44:12.275 - info: fb-checkpresence.0 (2760) createMemberObjects finished successfully
      2022-03-06 16:44:18.723 - info: wled.0 (3495) Bonjour service started, new devices will be detected automatically
      2022-03-06 16:44:18.836 - info: wled.0 (3495) WLED connected
      2022-03-06 16:44:28.738 - info: wled.0 (3495) WLED initialisation finalized, ready to do my job have fun !
      2022-03-06 16:44:39.445 - info: host.openhab iobroker npm-rebuild: > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript> node scripts/postinstall
      2022-03-06 16:44:44.187 - info: host.openhab iobroker npm-rebuild: > iobroker.amazon-dash@1.1.0 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash> apt install libpcap-dev -y || true
      2022-03-06 16:44:44.559 - info: host.openhab iobroker npm-rebuild: > pcap@3.1.0 install /opt/iobroker/node_modules/pcap> node-gyp rebuild
      2022-03-06 16:44:51.608 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
      2022-03-06 16:44:51.623 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
      2022-03-06 16:45:05.248 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_session.o
      2022-03-06 16:45:08.420 - info: fb-checkpresence.0 (2760) createFbDeviceObjects finished successfully
      2022-03-06 16:45:08.424 - info: fb-checkpresence.0 (2760) states successfully subscribed
      2022-03-06 16:45:08.427 - info: fb-checkpresence.0 (2760) loop successfully started
      2022-03-06 16:45:15.730 - info: host.openhab iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
      2022-03-06 16:45:17.221 - info: host.openhab iobroker npm-rebuild: COPY Release/pcap_binding.nodemake: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
      2022-03-06 16:45:19.116 - info: host.openhab iobroker npm-rebuild: > @serialport/bindings@9.1.0 install /opt/iobroker/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      2022-03-06 16:45:21.629 - info: alexa2.0 (2498) Subscribing to states...
      2022-03-06 16:45:25.463 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
      2022-03-06 16:45:25.471 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport.o
      2022-03-06 16:45:34.388 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
      2022-03-06 16:45:34.470 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
      2022-03-06 16:45:34.529 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
      2022-03-06 16:45:34.568 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
      2022-03-06 16:45:34.578 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
      2022-03-06 16:45:34.585 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
      2022-03-06 16:45:35.204 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      2022-03-06 16:45:40.405 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
      2022-03-06 16:45:50.021 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node COPY Release/bindings.nodemake: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen> @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      2022-03-06 16:45:57.423 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird betreten CXX(target) Release/obj.target/bindings/src/serialport.o
      2022-03-06 16:46:07.980 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      2022-03-06 16:46:13.766 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
      2022-03-06 16:46:23.360 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node
      2022-03-06 16:46:23.864 - info: host.openhab iobroker npm-rebuild: COPY Release/bindings.node
      2022-03-06 16:46:23.960 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird verlassen
      2022-03-06 16:46:24.508 - info: host.openhab iobroker npm-rebuild:
      2022-03-06 16:46:24.510 - info: host.openhab iobroker npm-rebuild: > ffmpeg-static@4.4.0 install /opt/iobroker/node_modules/ffmpeg-static> node install.js
      • Marko1974M Marko1974
        #423
        @marko1974
        Da läuft noch diverses rebuild-Zeuch. Abwarten bis da Ruhe ist.
          Marko1974M Offline
          Marko1974
          schrieb am zuletzt editiert von Marko1974
          #424
          @thomas-braun yo...web adapter lüft noch nicht. bei eufy security geht immer noch die passwort eingabe weg...somit kann keins eingegeben werden und der eufy sec bleibt rot
          2022-03-06 16:53:33.472 - info: host.openhab Adapter system.adapter.eufy-security.0 needs rebuild and will be restarted afterwards.
          2022-03-06 16:53:33.473 - info: host.openhab system.adapter.eufy-security.0 will be rebuilt
          2022-03-06 16:53:33.474 - warn: host.openhab adapter "eufy-security" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
          2022-03-06 16:53:33.474 - info: host.openhab iobroker rebuild
          2022-03-06 16:53:33.548 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
          2022-03-06 16:53:33.549 - error: host.openhab Caught by controller[0]: throw err;
          2022-03-06 16:53:33.550 - error: host.openhab Caught by controller[0]: ^
          2022-03-06 16:53:33.551 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
          2022-03-06 16:53:33.552 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
          2022-03-06 16:53:33.553 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
          2022-03-06 16:53:33.553 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
          2022-03-06 16:53:33.554 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          2022-03-06 16:53:33.565 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
          2022-03-06 16:53:33.566 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
          2022-03-06 16:53:33.566 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:31:32)
          2022-03-06 16:53:33.567 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
          2022-03-06 16:53:33.568 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          2022-03-06 16:53:33.569 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
          2022-03-06 16:53:33.569 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2022-03-06 16:53:33.570 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
          2022-03-06 16:53:33.570 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
          2022-03-06 16:53:33.571 - error: host.openhab Caught by controller[0]: }
          2022-03-06 16:53:33.572 - error: host.openhab instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-03-06 16:53:33.573 - info: host.openhab Adapter system.adapter.eusec.0 needs rebuild and will be restarted afterwards.
          2022-03-06 16:53:33.574 - info: host.openhab system.adapter.eusec.0 will be rebuilt
          2022-03-06 16:53:37.432 - info: host.openhab iobroker npm-rebuild: Rebuilding native modules ...
          2022-03-06 16:53:40.823 - info: web.0 (11120) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
          2022-03-06 16:53:41.701 - info: web.0 (11120) socket.io server listening on port 8102
          2022-03-06 16:53:41.765 - info: web.0 (11120) Connect extension "eusec/build/lib/web.js"
          2022-03-06 16:53:41.826 - info: web.0 (11120) Connect extension "eufy-security/build/lib/web.js"
          2022-03-06 16:53:41.876 - info: web.0 (11120) http server listening on port 8102
          2022-03-06 16:53:42.712 - warn: web.0 (11120) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          2022-03-06 16:54:06.269 - info: host.openhab iobroker npm-rebuild:
          2022-03-06 16:54:06.272 - info: host.openhab iobroker npm-rebuild: > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript> node scripts/postinstall
          2022-03-06 16:54:09.558 - info: host.openhab iobroker npm-rebuild: > iobroker.amazon-dash@1.1.0 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash> apt install libpcap-dev -y || true
          2022-03-06 16:54:09.719 - info: host.openhab iobroker npm-rebuild: > pcap@3.1.0 install /opt/iobroker/node_modules/pcap> node-gyp rebuild
            #425
            @marko1974
            Ich denke es sollte nur einer der beiden eufy-Adapter installiert sein.
            Und der web-Adapter muss wohl laufen, wenn ich das richtig sehe.
            Marko1974M 1 Antwort Letzte Antwort
              @marko1974
              Marko1974M Offline
              Marko1974M Offline
              Marko1974
              #426
              @thomas-braun der web adapter bleibt mit nem gelben ausrufezeichen auf funktioniert nicht. und eufy sec auf rot. brauche ich vielleicht die cloud?
                #427
                @marko1974 sagte in [Neuer Adapter] EuSec:
                Warum nicht? Startvorgang des Adapters?
                Welche cloud?
                  Welche cloud?
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #428
                  @thomas-braun die eufy cloud.
                  2022-03-06 17:06:08.141 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
                  2022-03-06 17:06:08.142 - error: host.openhab Caught by controller[0]: throw err;
                  2022-03-06 17:06:08.143 - error: host.openhab Caught by controller[0]: ^
                  2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                  2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
                  2022-03-06 17:06:08.145 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
                  2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
                  2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                  2022-03-06 17:06:08.147 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                  2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                  2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:31:32)
                  2022-03-06 17:06:08.149 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                  2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                  2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
                  2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                  2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
                  2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: }
                  2022-03-06 17:06:08.153 - error: host.openhab instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2022-03-06 17:06:08.154 - info: host.openhab Rebuild for adapter system.adapter.eufy-security.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                  2022-03-06 17:06:13.925 - info: web.0 (20195) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                  2022-03-06 17:06:14.710 - info: web.0 (20195) socket.io server listening on port 8112
                  2022-03-06 17:06:14.767 - info: web.0 (20195) Connect extension "eufy-security/build/lib/web.js"
                  2022-03-06 17:06:14.790 - info: web.0 (20195) http server listening on port 8112
                    #429
                    @marko1974
                    Ja, klar. Der Adapter kommuniziert ausschließlich mit der eufy-Cloud, wenn ich das richtig gelesen habe. Deswegen kam ja bei mir auch die Fehlermeldung mit dem falschen Token (siehe mein Install-Log oben).
                      @marko1974
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      #430
                      @thomas-braun die cloud habe ich nicht, sondern nur die lokalen geräte....der lief aber vorher zumindest mit dem adapter eufy security
                        #431
                        @marko1974
                        Schaust du in die ReadMe:
                        You need to provide your Cloud login credentials. The adapter connects to your cloud account and polls for all device data via HTTPS. Now a local or remote P2P connection to the Eufy stations/devices is also supported.
                        However, a connection to the Eufy Cloud is always a prerequisite.
                          @marko1974
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          #432
                          @thomas-braun said in [Neuer Adapter] EuSec:
                            #433
                            @marko1974
                            Ja, aber erst nach dem Login in der eufy-Cloud.
                              @marko1974
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              #434
                              @thomas-braun beim eufy-security hat das funktioniert. beim eu-sec von bropat nie.
                              der web adapter läuft aber auch nicht für vis.
                              und im eufy-security kann ich meine userdaten gar nicht richtig eingeben, da die passwort eingabe beim anklicken immer verschwindet. das ist im eu-sec gefixed. im anderen adapter nicht...
                                #435
                                @marko1974
                                Hast du die jetzt noch beide installiert?
                                  @marko1974
                                  Marko1974M Offline
                                  Marko1974M Offline
                                  Marko1974
                                  #436
                                  @thomas-braun nein, nur noch einen
                                    #437
                                    @marko1974
                                    Gut. Und wie sehen die (Neu)-Starts der Adapter nun aus?
                                    Zuerst mal den web-Adapter ans schwingen bringen.
                                      @marko1974
                                      Marko1974M Offline
                                      Marko1974M Offline
                                      Marko1974
                                      #438
                                      @thomas-braun ein weiteres phänomen ist nun langsame verbindung erkannt im browser
                                      2022-03-06 17:21:39.171 - info: host.openhab instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2022-03-06 17:21:42.219 - info: host.openhab "system.adapter.web.0" enabled
                                      2022-03-06 17:21:42.586 - info: host.openhab instance system.adapter.web.0 started with pid 29774
                                      2022-03-06 17:21:50.102 - info: web.0 (29774) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                                      2022-03-06 17:21:50.814 - info: web.0 (29774) socket.io server listening on port 8112
                                      2022-03-06 17:21:50.831 - info: web.0 (29774) http server listening on port 8112
                                      ist jedoch gelb
                                        ist jedoch gelb
                                        #439
                                        Das darf nicht zeitgleich auf dem gleichen Port laufen. Der web-Adapter läuft default auf 8082.
                                          Marko1974M Offline
                                          Marko1974M Offline
                                          Marko1974
                                          #440
                                          @thomas-braun auf 8082 läuft bei mir homebridge
