  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.0k Aufrufe 147 Beobachtet
    @marko1974 sagte in [Neuer Adapter] EuSec:
    der web adapter bleibt mit nem gelben ausrufezeichen auf funktioniert nicht.
    Warum nicht? Startvorgang des Adapters?
    brauche ich vielleicht die cloud?
    Welche cloud?
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    schrieb am zuletzt editiert von Marko1974
    #428
    @thomas-braun die eufy cloud.
    2022-03-06 17:06:08.141 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
    2022-03-06 17:06:08.142 - error: host.openhab Caught by controller[0]: throw err;
    2022-03-06 17:06:08.143 - error: host.openhab Caught by controller[0]: ^
    2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
    2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
    2022-03-06 17:06:08.145 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
    2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
    2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    2022-03-06 17:06:08.147 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:31:32)
    2022-03-06 17:06:08.149 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
    2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
    2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
    2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: }
    2022-03-06 17:06:08.153 - error: host.openhab instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-03-06 17:06:08.154 - info: host.openhab Rebuild for adapter system.adapter.eufy-security.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2022-03-06 17:06:13.925 - info: web.0 (20195) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
    2022-03-06 17:06:14.710 - info: web.0 (20195) socket.io server listening on port 8112
    2022-03-06 17:06:14.767 - info: web.0 (20195) Connect extension "eufy-security/build/lib/web.js"
    2022-03-06 17:06:14.790 - info: web.0 (20195) http server listening on port 8112
    • Marko1974M Marko1974
      #429
      @marko1974
      Ja, klar. Der Adapter kommuniziert ausschließlich mit der eufy-Cloud, wenn ich das richtig gelesen habe. Deswegen kam ja bei mir auch die Fehlermeldung mit dem falschen Token (siehe mein Install-Log oben).
      Marko1974M 1 Antwort Letzte Antwort
        @marko1974
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        #430
        @thomas-braun die cloud habe ich nicht, sondern nur die lokalen geräte....der lief aber vorher zumindest mit dem adapter eufy security
          #431
          @marko1974
          Schaust du in die ReadMe:
          You need to provide your Cloud login credentials. The adapter connects to your cloud account and polls for all device data via HTTPS. Now a local or remote P2P connection to the Eufy stations/devices is also supported.
          However, a connection to the Eufy Cloud is always a prerequisite.
            @marko1974
            Marko1974M Offline
            Marko1974M Offline
            Marko1974
            #432
            @thomas-braun said in [Neuer Adapter] EuSec:
              #433
              @marko1974
              Ja, aber erst nach dem Login in der eufy-Cloud.
                @marko1974
                Marko1974M Offline
                Marko1974M Offline
                Marko1974
                #434
                @thomas-braun beim eufy-security hat das funktioniert. beim eu-sec von bropat nie.
                der web adapter läuft aber auch nicht für vis.
                und im eufy-security kann ich meine userdaten gar nicht richtig eingeben, da die passwort eingabe beim anklicken immer verschwindet. das ist im eu-sec gefixed. im anderen adapter nicht...
                  #435
                  @marko1974
                  Hast du die jetzt noch beide installiert?
                    @marko1974
                    Marko1974M Offline
                    Marko1974M Offline
                    Marko1974
                    #436
                    @thomas-braun nein, nur noch einen
                      #437
                      @marko1974
                      Gut. Und wie sehen die (Neu)-Starts der Adapter nun aus?
                      Zuerst mal den web-Adapter ans schwingen bringen.
                        @marko1974
                        Marko1974M Offline
                        Marko1974M Offline
                        Marko1974
                        #438
                        @thomas-braun ein weiteres phänomen ist nun langsame verbindung erkannt im browser
                        2022-03-06 17:21:39.171 - info: host.openhab instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2022-03-06 17:21:42.219 - info: host.openhab "system.adapter.web.0" enabled
                        2022-03-06 17:21:42.586 - info: host.openhab instance system.adapter.web.0 started with pid 29774
                        2022-03-06 17:21:50.102 - info: web.0 (29774) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                        2022-03-06 17:21:50.814 - info: web.0 (29774) socket.io server listening on port 8112
                        2022-03-06 17:21:50.831 - info: web.0 (29774) http server listening on port 8112
                        ist jedoch gelb
                          ist jedoch gelb
                          #439
                          Das darf nicht zeitgleich auf dem gleichen Port laufen. Der web-Adapter läuft default auf 8082.
                            Marko1974M Offline
                            Marko1974M Offline
                            Marko1974
                            #440
                            @thomas-braun auf 8082 läuft bei mir homebridge
                              #441
                              @marko1974
                              Mag ja sein. Trotzdem darf ein Port nicht doppelt verwendet werden.
                                @marko1974
                                Marko1974M Offline
                                Marko1974M Offline
                                Marko1974
                                #442
                                @thomas-braun hab ich aber gar nicht so hinterlegt...man kann den port ja nur einmal hinterlegen
                                  #443
                                  @marko1974
                                  Dann schieb den halt irgendwo anders hin. Gibt ja 65535 davon.
                                    @marko1974
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    #444
                                    @thomas-braun hab ich ja schon...vis läuft...und das ausrufezeichen in gelb kommt bestimmt daher da eufy nicht läuft. verbunden mit host und lebenszeichen funktioniert. verbindung ist rot.
                                      #445
                                      @marko1974
                                      iobroker list instances
                                        @marko1974
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        #446
                                        [16:41:35] openhabian@openhab:~$ iobroker list instances
                                        + system.adapter.admin.0                  : admin                 : openhab                                  -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alarm.0                  : alarm                 : openhab                                  -  enabled
                                        + system.adapter.alexa2.0                 : alexa2                : openhab                                  -  enabled
                                          system.adapter.amazon-dash.0            : amazon-dash           : openhab                                  - disabled
                                          system.adapter.backitup.0               : backitup              : openhab                                  - disabled
                                        + system.adapter.cul.0                    : cul                   : openhab                                  -  enabled, port: 23
                                        + system.adapter.deconz.0                 : deconz                : openhab                                  -  enabled, port: 80
                                        + system.adapter.device-reminder.0        : device-reminder       : openhab                                  -  enabled
                                        + system.adapter.device-reminder.1        : device-reminder       : openhab                                  -  enabled
                                        + system.adapter.discovery.0              : discovery             : openhab                                  -  enabled
                                        + system.adapter.email.0                  : email                 : openhab                                  -  enabled
                                          system.adapter.eufy-security.0          : eufy-security         : openhab                                  - disabled
                                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : openhab                                  -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : openhab                                  -  enabled
                                        + system.adapter.harmony.0                : harmony               : openhab                                  -  enabled
                                        + system.adapter.history.0                : history               : openhab                                  -  enabled
                                        + system.adapter.hue-extended.0           : hue-extended          : openhab                                  -  enabled
                                        + system.adapter.hue.0                    : hue                   : openhab                                  -  enabled, port: 443
                                          system.adapter.icons-material-png.0     : icons-material-png    : openhab                                  -  enabled
                                        + system.adapter.javascript.0             : javascript            : openhab                                  -  enabled
                                        + system.adapter.maxcube.0                : maxcube               : openhab                                  -  enabled, port: 62910, bind: 0.0.0.0
                                        + system.adapter.mihome.0                 : mihome                : openhab                                  -  enabled, port: 9898, bind: 192.168.178.72
                                        + system.adapter.node-red.0               : node-red              : openhab                                  -  enabled, port: 1880, bind: 0.0.0.0
                                          system.adapter.radar2.0                 : radar2                : openhab                                  - disabled
                                        + system.adapter.shelly.0                 : shelly                : openhab                                  -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shuttercontrol.0         : shuttercontrol        : openhab                                  -  enabled
                                        + system.adapter.telegram.0               : telegram              : openhab                                  -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.tr-064.0                 : tr-064                : openhab                                  - disabled
                                          system.adapter.vis.0                    : vis                   : openhab                                  -  enabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : openhab                                  -  enabled
                                        + system.adapter.web.0                    : web                   : openhab                                  -  enabled, port: 8113, bind: 0.0.0.0, run as: admin
                                        + system.adapter.wled.0                   : wled                  : openhab                                  -  enabled
                                        + system.adapter.yahka.1                  : yahka                 : openhab                                  -  enabled
                                        + system.adapter.yahka.2                  : yahka                 : openhab                                  -  enabled
                                          Stefan 1
                                          #447
                                          @marko1974
                                          Nabend,
                                          ist dein System denn jetzt aktuell?
                                          Zu dem Eufy Adapter, ich würde sagen du hast den falschen installiert. Du brauchst nur den EuSec Adapter. Und nein du brauchst keine direkte Cloud.
                                          Erstmal musst du den eufy-security adapter löschen und die dazugehörigen Ordner auf deinem pi oder wo du den iobroker drauf installiert hast. da gibt es ein problem, dass die sich gegenseitig blockieren. hatte ich auch.
