  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.0k Aufrufe 147 Beobachtet
  • Marko1974M Marko1974
    @thomas-braun der web adapter bleibt mit nem gelben ausrufezeichen auf funktioniert nicht. und eufy sec auf rot. brauche ich vielleicht die cloud?
    #427
    @marko1974 sagte in [Neuer Adapter] EuSec:
    Warum nicht? Startvorgang des Adapters?
    Welche cloud?
    Marko1974M 1 Antwort Letzte Antwort
      Welche cloud?
      Marko1974M Offline
      Marko1974M Offline
      Marko1974
      schrieb am zuletzt editiert von Marko1974
      #428
      @thomas-braun die eufy cloud.
      2022-03-06 17:06:08.141 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
      2022-03-06 17:06:08.142 - error: host.openhab Caught by controller[0]: throw err;
      2022-03-06 17:06:08.143 - error: host.openhab Caught by controller[0]: ^
      2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
      2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
      2022-03-06 17:06:08.145 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
      2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
      2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      2022-03-06 17:06:08.147 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:31:32)
      2022-03-06 17:06:08.149 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
      2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
      2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
      2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: }
      2022-03-06 17:06:08.153 - error: host.openhab instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-03-06 17:06:08.154 - info: host.openhab Rebuild for adapter system.adapter.eufy-security.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2022-03-06 17:06:13.925 - info: web.0 (20195) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
      2022-03-06 17:06:14.710 - info: web.0 (20195) socket.io server listening on port 8112
      2022-03-06 17:06:14.767 - info: web.0 (20195) Connect extension "eufy-security/build/lib/web.js"
      2022-03-06 17:06:14.790 - info: web.0 (20195) http server listening on port 8112
        #429
        @marko1974
        Ja, klar. Der Adapter kommuniziert ausschließlich mit der eufy-Cloud, wenn ich das richtig gelesen habe. Deswegen kam ja bei mir auch die Fehlermeldung mit dem falschen Token (siehe mein Install-Log oben).
          @marko1974
          Marko1974M Offline
          Marko1974M Offline
          Marko1974
          #430
          @thomas-braun die cloud habe ich nicht, sondern nur die lokalen geräte....der lief aber vorher zumindest mit dem adapter eufy security
            #431
            @marko1974
            Schaust du in die ReadMe:
            You need to provide your Cloud login credentials. The adapter connects to your cloud account and polls for all device data via HTTPS. Now a local or remote P2P connection to the Eufy stations/devices is also supported.
            However, a connection to the Eufy Cloud is always a prerequisite.
              @marko1974
              Marko1974M Offline
              Marko1974M Offline
              Marko1974
              #432
              @thomas-braun said in [Neuer Adapter] EuSec:
                #433
                @marko1974
                Ja, aber erst nach dem Login in der eufy-Cloud.
                  @marko1974
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #434
                  @thomas-braun beim eufy-security hat das funktioniert. beim eu-sec von bropat nie.
                  der web adapter läuft aber auch nicht für vis.
                  und im eufy-security kann ich meine userdaten gar nicht richtig eingeben, da die passwort eingabe beim anklicken immer verschwindet. das ist im eu-sec gefixed. im anderen adapter nicht...
                    #435
                    @marko1974
                    Hast du die jetzt noch beide installiert?
                      @marko1974
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      #436
                      @thomas-braun nein, nur noch einen
                        #437
                        @marko1974
                        Gut. Und wie sehen die (Neu)-Starts der Adapter nun aus?
                        Zuerst mal den web-Adapter ans schwingen bringen.
                          @marko1974
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          #438
                          @thomas-braun ein weiteres phänomen ist nun langsame verbindung erkannt im browser
                          2022-03-06 17:21:39.171 - info: host.openhab instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2022-03-06 17:21:42.219 - info: host.openhab "system.adapter.web.0" enabled
                          2022-03-06 17:21:42.586 - info: host.openhab instance system.adapter.web.0 started with pid 29774
                          2022-03-06 17:21:50.102 - info: web.0 (29774) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                          2022-03-06 17:21:50.814 - info: web.0 (29774) socket.io server listening on port 8112
                          2022-03-06 17:21:50.831 - info: web.0 (29774) http server listening on port 8112
                          ist jedoch gelb
                            ist jedoch gelb
                            #439
                            Das darf nicht zeitgleich auf dem gleichen Port laufen. Der web-Adapter läuft default auf 8082.
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              #440
                              @thomas-braun auf 8082 läuft bei mir homebridge
                                #441
                                @marko1974
                                Mag ja sein. Trotzdem darf ein Port nicht doppelt verwendet werden.
                                  @marko1974
                                  Marko1974M Offline
                                  Marko1974M Offline
                                  Marko1974
                                  #442
                                  @thomas-braun hab ich aber gar nicht so hinterlegt...man kann den port ja nur einmal hinterlegen
                                    #443
                                    @marko1974
                                    Dann schieb den halt irgendwo anders hin. Gibt ja 65535 davon.
                                      @marko1974
                                      Marko1974M Offline
                                      Marko1974M Offline
                                      Marko1974
                                      #444
                                      @thomas-braun hab ich ja schon...vis läuft...und das ausrufezeichen in gelb kommt bestimmt daher da eufy nicht läuft. verbunden mit host und lebenszeichen funktioniert. verbindung ist rot.
                                        #445
                                        @marko1974
                                        iobroker list instances
                                          @marko1974
                                          Marko1974M Offline
                                          Marko1974M Offline
                                          Marko1974
                                          #446
                                          [16:41:35] openhabian@openhab:~$ iobroker list instances
                                          + system.adapter.admin.0                  : admin                 : openhab                                  -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alarm.0                  : alarm                 : openhab                                  -  enabled
                                          + system.adapter.alexa2.0                 : alexa2                : openhab                                  -  enabled
                                            system.adapter.amazon-dash.0            : amazon-dash           : openhab                                  - disabled
                                            system.adapter.backitup.0               : backitup              : openhab                                  - disabled
                                          + system.adapter.cul.0                    : cul                   : openhab                                  -  enabled, port: 23
                                          + system.adapter.deconz.0                 : deconz                : openhab                                  -  enabled, port: 80
                                          + system.adapter.device-reminder.0        : device-reminder       : openhab                                  -  enabled
                                          + system.adapter.device-reminder.1        : device-reminder       : openhab                                  -  enabled
                                          + system.adapter.discovery.0              : discovery             : openhab                                  -  enabled
                                          + system.adapter.email.0                  : email                 : openhab                                  -  enabled
                                            system.adapter.eufy-security.0          : eufy-security         : openhab                                  - disabled
                                          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : openhab                                  -  enabled
                                          + system.adapter.fritzdect.0              : fritzdect             : openhab                                  -  enabled
                                          + system.adapter.harmony.0                : harmony               : openhab                                  -  enabled
                                          + system.adapter.history.0                : history               : openhab                                  -  enabled
                                          + system.adapter.hue-extended.0           : hue-extended          : openhab                                  -  enabled
                                          + system.adapter.hue.0                    : hue                   : openhab                                  -  enabled, port: 443
                                            system.adapter.icons-material-png.0     : icons-material-png    : openhab                                  -  enabled
                                          + system.adapter.javascript.0             : javascript            : openhab                                  -  enabled
                                          + system.adapter.maxcube.0                : maxcube               : openhab                                  -  enabled, port: 62910, bind: 0.0.0.0
                                          + system.adapter.mihome.0                 : mihome                : openhab                                  -  enabled, port: 9898, bind: 192.168.178.72
                                          + system.adapter.node-red.0               : node-red              : openhab                                  -  enabled, port: 1880, bind: 0.0.0.0
                                            system.adapter.radar2.0                 : radar2                : openhab                                  - disabled
                                          + system.adapter.shelly.0                 : shelly                : openhab                                  -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.shuttercontrol.0         : shuttercontrol        : openhab                                  -  enabled
                                          + system.adapter.telegram.0               : telegram              : openhab                                  -  enabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.tr-064.0                 : tr-064                : openhab                                  - disabled
                                            system.adapter.vis.0                    : vis                   : openhab                                  -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : openhab                                  -  enabled
                                          + system.adapter.web.0                    : web                   : openhab                                  -  enabled, port: 8113, bind: 0.0.0.0, run as: admin
                                          + system.adapter.wled.0                   : wled                  : openhab                                  -  enabled
                                          + system.adapter.yahka.1                  : yahka                 : openhab                                  -  enabled
                                          + system.adapter.yahka.2                  : yahka                 : openhab                                  -  enabled
