  4. Yet another HomeKit adapter
    2.8k
    4.8k
    4.0k
1.8k Beiträge 206 Kommentatoren 1.0m Aufrufe 68 Beobachtet
  • wendy2702W wendy2702
    @minki Führe doch mal bitte das ffmpeg kommando aus und zeige das log davon. Laut den Einstellungen im Adapter versucht er AAC als Codec.
    Müsste man mal im ffmpeg befehl schauen und zum testen ersetzen.
    MINKI
    schrieb am zuletzt editiert von MINKI
    #1541
    @wendy2702
    Das schmeißt der Log raus wenn der Stream mit Ton ausgeführt wird.
    Session Request:{ "sessionID": "14c4a5bf-d742-4daf-b34e-bef2745dd025", "type": "start", "video": { "codec": 0, "profile": 2, "level": 2, "packetizationMode": 0, "width": 1280, "height": 720, "fps": 30, "pt": 99, "ssrc": 3828249404, "max_bit_rate": 299, "rtcp_interval": 0.5, "mtu": 1378 }, "audio": { "codec": "AAC-eld", "channel": 1, "bit_rate": 0, "sample_rate": 16, "packet_time": 30, "pt": 110, "ssrc": 420990154, "max_bit_rate": 24, "rtcp_interval": 5, "comfort_pt": 13, "comfortNoiseEnabled": false } }
    Meine Audio Stream Config aus dem Adapter sieht wie folgt aus (UNVERÄNDERT):
      "-vn",
      "-sn",
      "-dn",
      "-codec:a",
      "libfdk_aac",
      "-profile:a",
      "aac_eld",
      "-flags",
      "+global_header",
      "-f",
      "null",
      "-ar",
      "${samplerate}k",
      "-b:a",
      "${bitrate}k",
      "-bufsize:a",
      "${bitrate}k",
      "-ac",
      "${channel}",
      "-payload_type",
      "${payloadtype}",
      "-ssrc",
      "${targetAudioSsrc}",
      "-f",
      "rtp",
      "-srtp_out_suite",
      "AES_CM_128_HMAC_SHA1_80",
      "-srtp_out_params",
      "${audiokey}",
      "srtp://${targetAddress}:${targetAudioPort}?rtcpport=${targetAudioPort}&localrtcpport=${targetAudioPort}&pkt_size=188"
    • M MINKI
      @wendy2702
        "-vn",
        "-sn",
        "-dn",
        "-codec:a",
        "libfdk_aac",
        "-profile:a",
        "aac_eld",
        "-flags",
        "+global_header",
        "-f",
        "null",
        "-ar",
        "${samplerate}k",
        "-b:a",
        "${bitrate}k",
        "-bufsize:a",
        "${bitrate}k",
        "-ac",
        "${channel}",
        "-payload_type",
        "${payloadtype}",
        "-ssrc",
        "-f",
        "rtp",
        "-srtp_out_suite",
        "-srtp_out_params",
        "${audiokey}",
      wendy2702W Online
      wendy2702W Online
      wendy2702
      #1542
      @minki Wie sieht der vollständige FFMPEG Befehl aus?
      Login daten der Kamera kannst du ersetzen.
      Steht da was von
      - quiet
      drin?
      füge mal
      - loglevel verbose
      direkt hinter das "ffmpeg" ein.
        Steht da was von
        - quiet
        drin?
        füge mal
        - loglevel verbose
        MINKI
        #1543
        @wendy2702 Sorry, was meinst du mit FFMPEG Befehl? Ich habe unter stream properties in yahka "ADD CAMERA" den rtsp stream eingegeben. Ich rufe selber keinen FFMPEG Befehl auf. Muss ich das tun?
        • M MINKI
          wendy2702W Online
          wendy2702W Online
          wendy2702
          #1544
          @minki Kannst du mal die Yahka Instanz auf "Debug" stellen und dann schauen ob im iob log der "FFMPEG" Befehl kommt wenn du den Stream startest.
            MINKI
            #1545
            @wendy2702
            yahka.0
            2023-03-22 22:09:37.344	debug	Session Request:{ "sessionID": "e230bf3a-9312-43ba-bbd8-1417ed069f24", "type": "start", "video": { "codec": 0, "profile": 2, "level": 2, "packetizationMode": 0, "width": 1280, "height": 720, "fps": 30, "pt": 99, "ssrc": 281489091, "max_bit_rate": 299, "rtcp_interval": 0.5, "mtu": 1378 }, "audio": { "codec": "AAC-eld", "channel": 1, "bit_rate": 0, "sample_rate": 16, "packet_time": 30, "pt": 110, "ssrc": 2212050935, "max_bit_rate": 24, "rtcp_interval": 5, "comfort_pt": 13, "comfortNoiseEnabled": false } }
            yahka.0
            2023-03-22 22:09:33.541	debug	Snapshot run: ffmpeg -re -i rtsp://XXX:XXX@XXX:554/live/stream1 -t 1 -s 1280x720 -f image2 -
            • M MINKI
              @wendy2702
              yahka.0
              yahka.0
              wendy2702W Online
              wendy2702W Online
              wendy2702
              #1546
              @minki sagte in Yet another HomeKit adapter:
              "codec": "AAC-eld",
              Ist ja der Falsche.
              Kannst mal versuchen in den Erweiterten Einstellungen das zu ändern:
              und da anstelle des AAC das einsetzen:
              pcm_alaw
              Sonst muss man sich tiefer mit der Syntax beschäftigen und testen. Ich habe aber keine Audio Kamera.
                "codec": "AAC-eld",
                Ist ja der Falsche.
                pcm_alaw
                MINKI
                #1547
                @wendy2702 said in Yet another HomeKit adapter:
                pcm_alaw
                Fehlermeldung bleibt gleich! Muss ich evtl auch den -codec:a ändern? Falls ja, was müsste da rein?
                  "-vn",
                  "-sn",
                  "-dn",
                  "-codec:a",
                  "libfdk_aac",
                  "-profile:a",
                  "pcm_alaw",
                  "-flags",
                  "+global_header",
                  "-f",
                  "null",
                  "-ar",
                  "${samplerate}k",
                  "-b:a",
                  "${bitrate}k",
                  "-bufsize:a",
                  "${bitrate}k",
                  "-ac",
                  "${channel}",
                  "-payload_type",
                  "${payloadtype}",
                  "-ssrc",
                  "-f",
                  "rtp",
                  "-srtp_out_suite",
                  "-srtp_out_params",
                  "${audiokey}",
                • M MINKI
                  pcm_alaw
                    "-vn",
                    "-sn",
                    "-dn",
                    "-codec:a",
                    "libfdk_aac",
                    "-profile:a",
                    "pcm_alaw",
                    "-flags",
                    "+global_header",
                    "-f",
                    "null",
                    "-ar",
                    "${samplerate}k",
                    "-b:a",
                    "${bitrate}k",
                    "-bufsize:a",
                    "${bitrate}k",
                    "-ac",
                    "${channel}",
                    "-payload_type",
                    "${payloadtype}",
                    "-ssrc",
                    "-f",
                    "rtp",
                    "-srtp_out_suite",
                    "-srtp_out_params",
                    "${audiokey}",
                  wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  #1548
                  @minki Dafür würde ich gerne das FFMPEG LOG sehen.
                  Welche Version YAHKA und FFMPEG hast du installiert?
                  Wenn ich einen Livestream bei mir starte bekomme ich nur diese Einträge im log:
                  2023-03-23 08:17:15.109  - debug: yahka.4 (45656) Session Request:{
                  2023-03-23 08:17:15.292  - debug: yahka.4 (45656) FFMPEG: received first frame
                  2023-03-23 08:17:25.213  - debug: yahka.4 (45656) Stopped streaming session!
                  2023-03-23 08:17:25.225  - debug: yahka.4 (45656) [Video] ffmpeg exited with code: null and signal: SIGKILL (Video stream stopped!)
                    MINKI
                    #1549
                    @wendy2702
                    Yahka --> 0.17.0
                    ffmpeg --> 4.4.2
                    Falls du was anderes brauchst, dann versteh ich leider nicht genau was du brauchst. Kannst du mir vielleicht sagen was ich dann tun müsste um dir die Info zur Verfügung zu stellen? Danke dir!
                    • HiltexH Offline
                      HiltexH Offline
                      Hiltex
                      #1550
                      Ich habe vom vielen Testen noch zwei Kamera-Relikte in yahka. Kann mir jemand sagen, wie man die löscht?
                      Der Button "Gerät entfernen" funktioniert dafür leider nicht.
                      Blog: indibit.de
                      • M MINKI
                        @wendy2702
                        Yahka --> 0.17.0
                        ffmpeg --> 4.4.2
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        #1551
                        @minki Das wollte ich wissen, kann aber mangels Audio kamera nicht weiter testen.
                        • L Offline
                          loverz
                          #1552
                          Seit gestern ist die Aqara Doorbell G4 erhältlich.
                          Die kann HKSV nativ. Vielleicht eine Alternative zu den Bastellösungen hier.
                            TDCroPower
                            schrieb am zuletzt editiert von TDCroPower
                            #1553
                            Kann es sein das durch ein Update von 0.17.0 auf die 1.0.0 alle Geräte verloren gehen?
                            Habe eben ein Update versucht und alles war weg.
                            Bin daher zurück vor dem Update und wollte daher erstmal nachfragen bevor ich den Sprung erneut versuche.
                            edit:
                            sehe gerade gibt ja schon einen PullRequest dazu, wird wohl in 1.0.1 gefixt oder?
                            https://github.com/jensweigele/ioBroker.yahka/pull/413
                            • HiltexH Hiltex
                              MINKI
                              #1554
                              @wendy2702
                              WEnn du noch weitere Infos brauchst, lass es mich einfach wissen.
                              • L Offline
                                loverz
                                #1555
                                Wer traut sich das Update auf iOS 16.4 und das Homekit Architektur Update?
                                Möchte wissen, ob YAHKA und der Rest weiterhin wie bisher läuft.
                                haselchenH E 2 Antworten Letzte Antwort
                                • L loverz
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #1556
                                  @loverz
                                  Update kann ich gerne machen, was hat es mit der Homekit.....auf sich?
                                  • haselchenH haselchen
                                    @loverz
                                    TDCroPower
                                    #1557
                                    @haselchen die 16.4 bringt den 2ten Versuch mit auf die neue HomeKit Architektur zu wechseln.
                                    Der Versuch mit der 16.2 ging ja bekannterweise total in die Hose.
                                    Aber das Update fürs HomeKit muss sowieso über die Home App manuell angestoßen werden, daher kann man unabhängig davon auf die 16.4 updaten und nach einigen Tagen ruhe das HomeKit Update starten, falls das Feedback positiv bleibt.
                                    • T TDCroPower
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #1558
                                      @tdcropower
                                      @loverz
                                      Okay, Iphone 12 hat 16.4, der HomePod Mini ebenso jetzt.
                                      Yakha hat bei mir die 1.0.2 und in der HomeApp ist alles noch vorhanden und lässt sich alles steuern wie vorher.
                                      Edit: "Zuhause" muss , wie schon erwähnt, manuell aktualisiert werden. Das mache ich gerade. Hängt von vielen Faktoren ab.
                                      AppleWatch und Haushaltsmitglieder müssen auch erst 16.4 haben.
                                      Edit 2: Update ist durch. Hab nen paar Lichter geschaltet, funktioniert.
                                      Also in der Hinsicht, alles okay.
                                      Einzig aufgefallen ist mir, dass der HomePod nicht mehr die Temperatur und Luftfeuchtigkeit anzeigt. Bei Klima stehen jetzt --- °
                                      Eventuell hat man das Update wieder zurückgenommen, was mit 16.3 freigeschaltet wurde.
                                        @tdcropower
                                        @loverz
                                        TDCroPower
                                        #1559
                                        @haselchen bin auch schon brav am aktualisieren meiner ganzen iOS Geräte.
                                        Wichtig wäre für mich zu wissen, ob die "Zuhause angekommen" Funktion endlich wieder funktioniert.
                                        Noch verwende ich als alternative Life360, will aber endlich die HomeKit eigene Funktion dafür nutzen und per ioBroker/Yahka Datenpunkt dies an den ioBroker übergeben.
                                        Hoffe das geht mit der neuen Architektur!
                                        haselchenH L 2 Antworten Letzte Antwort
                                        • T TDCroPower
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #1560
                                          @tdcropower
                                          Da biste mehr drinnen in der Materie als ich.
                                          Ich hab Yakha nur damit ich im Garten über die Apple Watch Lichter und Rollläden steuern kann.
