  5. [Vorlage] LightControl
javascripttemplate
224 Beiträge 25 Kommentatoren 56.2k Aufrufe 36 Beobachtet
  • P passuff
    Vielen Dank für dieses tolle Skript. Leider habe ich ein paar Probleme damit:
    2022-01-18 23:32:43.694 - info: javascript.0 (32839) script.js.common.Licht.LightControl: adaptiveCtLinear=0 adaptiveCtSolar=0 adaptiveCtSolarInterpolated=0 adaptiveCtTimed=0
    2022-01-18 23:32:50.285 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Triggered linked Sensor mihome.0.devices.sensor_motion_aq2_158d0004aca6b9.state new value is true
    2022-01-18 23:32:50.286 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Reaching SummarizeSensors, Group=0
    2022-01-18 23:32:50.286 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Gruppe=0 Sensor 2 with target mihome.0.devices.sensor_motion_aq2_158d0004aca6b9.state has value true
    2022-01-18 23:32:50.287 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Summarized IsMotion for Group 0 = true
    2022-01-18 23:32:50.287 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Reaching Controller, Group=0 Property1=isMotion NewVal=true OldVal=false
    2022-01-18 23:32:50.287 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Motion for Group 0 (Flur ) detected, switching on
    2022-01-18 23:32:50.288 - info: javascript.0 (32839) script.js.common.Licht.LightControl: Reaching GroupPowerOnOff for Group 0 (Flur), OnOff=true rampOn=false - {"enabled":false,"time":10,"switchOutletsLast":true} rampOff=false - {"enabled":false,"time":10,"switchOutletsLast":false}
    2022-01-18 23:32:50.288 - info: javascript.0 (32839) script.js.common.Licht.LightControl: SimpleGroupPowerOnOff: Normales anschalten ohne Ramping für Flur
    2022-01-18 23:32:50.312 - error: javascript.0 (32839) script.js.common.Licht.LightControl: TypeError: Cannot read property 'val' of null
    2022-01-18 23:32:50.315 - error: javascript.0 (32839) at SimpleGroupPowerOnOff (script.js.common.Licht.LightControl:707:83)
    2022-01-18 23:32:50.315 - error: javascript.0 (32839) at GroupPowerOnOff (script.js.common.Licht.LightControl:736:9)
    2022-01-18 23:32:50.315 - error: javascript.0 (32839) at AutoOnMotion (script.js.common.Licht.LightControl:965:9)
    2022-01-18 23:32:50.316 - error: javascript.0 (32839) at Controller (script.js.common.Licht.LightControl:1166:17)
    Ich kann die Fehlermeldungen nicht nachvollziehen und würde mich freuen, wenn mir jemand dabei helfen könnte.
    Ich habe lediglich zwei Shelly Dimmer und drei mihome BWM in Betrieb:
    const praefix = "0_userdata.0.LightControl2" // Skriptordner
    const LuxSensor = 'wiffi-wz.0.root.192_168_1_155.w_lux'; // Datenpunkt des globalen Luxsensors, wird verwendet wenn in der Gruppe kein gesonderter definiert wird
    const IsPresenceDp = ""; // Datenpunkt für Anwesenheit (true/false)
    const PresenceCountDp = ""; // Datenpunkt für Anwesenheitszähler
    const logging = true; // Logging an/aus
    const RampSteps = 10; //Wieviele Schritte zum dimmen? Bitte nicht zu hoch setzen, wird zwar smoother, kann aber zu timing Problemen führen wenn gleichzeitig eine kurze Zeit in den Objekten gewählt.
    const minCt = 2700; //Regelbereich für Farbtemperatur in Kelvin für Adaptive Ct
    const maxCt = 6500;//Regelbereich für Farbtemperatur in Kelvin für Adaptive Ct
    const minBri = 10; //Mindesthelligkeit für AdaptiveBri
    const LightGroups = {
        0: {
            description: "Flur",
            lights: {
                0: {
                    description: "StrahlerOG1",
                    power: { oid: "shelly.0.SHDM-2#C45BBE5645E3#1.lights.Switch", onVal: true, offVal: false },
                    bri: { oid: "shelly.0.SHDM-2#C45BBE5645E3#1.lights.brightness", minVal: 0, maxVal: 100, defaultVal: 100 },
                    ct: { oid: "", minVal: null, maxVal: null },
                    sat: { oid: "", minVal: null, maxVal: null },
                    modeswitch: { oid: "", whiteModeVal: false, colorModeVal: true },
                    color: { oid: "", type: "", default: "" }
                1: {
                    description: "StrahlerEG",
                    power: { oid: "shelly.0.SHDM-2#E0980694DB0C#1.lights.Switch", onVal: true, offVal: false },
                    bri: { oid: "shelly.0.SHDM-2#E0980694DB0C#1.lights.brightness", minVal: 0, maxVal: 100, defaultVal: 100 },
            sensors: {
                0: { id: 'mihome.0.devices.sensor_motion_aq2_158d0002ea1b58.state', motionVal: true, noMotionVal: false },
                1: { id: 'mihome.0.devices.sensor_motion_aq2_158d0002ebffca.state', motionVal: true, noMotionVal: false },
                2: { id: 'mihome.0.devices.sensor_motion_aq2_158d0004aca6b9.state', motionVal: true, noMotionVal: false }
    folgend noch das vollständige Skript:
    LightControl_20220119.txt
    SchmakusS Offline
    SchmakusS Offline
    Schmakus
    #181
    @passuff Zeig mal die Datenpunkte "Switch" von deinen 2 Shelly Dimmern.
    Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
    P 1 Antwort Letzte Antwort
    • SchmakusS Schmakus
      passuff
      #182
      @schmakus sagte in [Vorlage] LightControl:
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": true,
          "name": "Switch",
          "role": "switch",
          "def": false
        "native": {},
        "from": "system.adapter.shelly.0",
        "user": "system.user.admin",
        "ts": 1641885787418,
        "_id": "shelly.0.SHDM-2#C45BBE5645E3#1.lights.Switch",
        "acl": {
          "object": 0,
          "state": 0,
          "owner": "system.user.admin",
      SchmakusS 1 Antwort Letzte Antwort
      • ? Offline
        #183
        Hallo, ich habe das Skript erfolgreich eingefügt und meine Lampen eingetragen. Es funktioniert alles super BWM etc. funktioniert alles. Mir ist aber eine Sache aufgefallen, wenn ich über Google Home sage: Wohnzimmer Decke auf 80% dann wird zwar der Wert bei bri geändert aber die Lampen gehen nicht mit an. Sonst (vor dem Skript) war es so, dass das Licht bei bri Änderung angegangen ist. Gibt es da eine Funktion in dem Skript? Jetzt muss ich immer zwei Befehle absetzen, einmal Lichthelligkeit und Licht anschalten.
          Pittini
          #184
          @kilian-z Its not a bug, its a feature. Hintergrund ist der, das bei der adaptiven Helligkeit, permanent die Helligkeit gesetzt wird damit das beim einschalten passt. Und wäre es so, wie Du es gern hättest, dann würde alle paar Sekunden das Licht angehen ;).
          ? 1 Antwort Letzte Antwort
          • P Pittini
            #185
            @pittini Danke @pittini. Ja das macht Sinn. Nutze bis jetzt noch nicht die adaptive Helligkeit.
              SchmakusS Offline
              SchmakusS Offline
              Schmakus
              #186
              @kilian-z said in [Vorlage] LightControl:
              Du vielleicht nicht, aber das Script intern.
              Wie hast du GoogleHome eingebunden? Per iot? Wenn ja, einfach beide Datenpunkte, Power und Bri als ein Gerät anlegen.
                #187
                @schmakus Danke für die Antwort. Ich habe alle drei Datenpunkte in einem Gerät über iot eingebunden.
                • P passuff
                    "type": "state",
                    "common": {
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "name": "Switch",
                      "role": "switch",
                      "def": false
                    "native": {},
                    "acl": {
                      "object": 0,
                      "state": 0,
                  SchmakusS Offline
                  SchmakusS Offline
                  Schmakus
                  schrieb am zuletzt editiert von Schmakus
                  #188
                  @Pittini Die Fehlermeldung im log von @passuff deutet doch darauf hin, dass der Wert des Switch nicht gelesen werden kann, weil entweder kein Wert vorhanden ist, oder der Pfad zum DP nicht stimmt, oder?
                    SchmakusS Offline
                    SchmakusS Offline
                    Schmakus
                    #189
                    👍 Ich habe immer Power, Bri, ct und color eingebunden.
                      #190
                      @schmakus Du musst aber trotzdem zwei Befehle absenden oder? Wenn Lampe aus ist: Helligkeit einstellen und dann Lampe anschalten. Habe ich das richtig verstanden?
                        Dragon
                        #191
                        In deinem Skript muss ein Datenpunkt mit einer Anzahl an anwesenden Personen angegeben werden. Darf ich fragen wofür er benötigt wird? Ich habe tatsächlich keinen Datenpunkt, da ich auch andere Geräte auf Presence checke...
                          SchmakusS Offline
                          SchmakusS Offline
                          Schmakus
                          #192
                          Genau. Beim schalten per "power" Datenpunkt wird die Helligkeit, welche zuvor bei "bri" gesetzt ist an die Lampe gesendet.
                          • D Dragon
                            SchmakusS Offline
                            SchmakusS Offline
                            Schmakus
                            #193
                            @dragon said in [Vorlage] LightControl:
                            Es gibt ja quasi 2 Variablen dafür. Einmal An- und Abwesenheit und dann den von dir beschriebenen.
                            Dieser wird benötigt, wenn du auch "AutoOn bei Anwesenheitszählererhöhung ab bestimmter Helligkeit (Begrüßungslicht bei heimkommen)" verwenden möchtest. einfach leer lassen, wenn du keinen Zähler hast.
                              Rudi-Ment
                              #194
                              Hallo.
                              Auch ich habe das Script zum Laufen gebracht und schon ein paar Lampen eingebunden.
                              Nun habe ich aber mehrere RGBWW LED Streifen in der Stube, die ich gerne gruppieren möchte.
                              Da gibt es aber zwei mal Power und zwei mal Dimmer. Außerdem haben die Colorwerte mit #00000000 bis #FFFFFFFF. Wie binde ich die ein ?
                              • R Rudi-Ment
                                Hallo.
                                SchmakusS Offline
                                SchmakusS Offline
                                Schmakus
                                #195
                                @rudi-ment Um welche LED Streifen handelt es sich genau? Ich habe z.b. Shelly RGBW2 eingebunden. Das mit dem Hex klappt jedoch nur für die RGB Farben. Den Weißkanal steuere ich über die Farbtemperatur.
                                R 1 Antwort Letzte Antwort
                                  Rudi-Ment
                                  #196
                                  @schmakus Das ist eine gute Idee. Bei den Shelly kann ich das so machen.
                                  Bei den mit Tasmota geflashten LED Treibern gibt es aber zwei mal Power. Einmal bunt und einmal weiß.
                                  Da weiß ich nicht weiter.
                                  Aber in der nächsten Zeit werden die Tasmota-Teile wohl eh rausfliegen.
                                  Die Verbindung ist so unzuverlässig...
                                  Vielleicht hat sich das damit schon erledigt.
                                    Rudi-Ment
                                    #197
                                    Das mit dem Weissabgleich bekomme ich nicht hin.
                                    Magst du mir vielleicht mal ein Beispiel zeigen ?
                                    • P Pittini
                                      Thread zum Skript LightControl: https://github.com/Pittini/iobroker-LightControl
                                      iobroker-LightControl - ALPHAVERSION
                                      Lichtsteuerung für Leuchtmittel unterschiedlicher Hersteller
                                      Features
                                      • Gruppierung beliebig vieler Lampen/Leuchtmittel
                                      • Verwendung gemischter Lampen/Farbsystemen und Umrechnung der Farbsysteme (Hex,Rgb,Hsl,Xy)
                                      • Möglichkeit der Zuweisung von defaultwerten zu jedem Leuchtmittel
                                      • Ramping (langsame Änderung der Helligkeit bis Zielwert) für on und off
                                      • AutoOff nach Zeit / Kein off bei Bewegung
                                      • AutoOn bei Bewegung
                                      • Override on (Putzlicht)
                                      • Adaptive Helligkeit
                                      • Adaptive Farbtemperatur
                                      fischi87F Offline
                                      fischi87F Offline
                                      fischi87
                                      #198
                                      @pittini hallo, wird es davon mal einen Adapter geben oder wird es lediglich als Skript bleiben?
                                      grüße
                                        Rudi-Ment
                                        #199
                                        Hat noch jemand das Problem, dass das Licht zu unbestimmter Zeit wieder ausgeht ?
                                        Trotz Bewegung und "bei Bewegung eingeschaltet bleiben" ?
                                        • R Rudi-Ment
                                          Rudi-Ment
                                          #200
                                          @rudi-ment said in [Vorlage] LightControl:
                                          Ausserdem scheint die Zeit auch gar nicht zu passen.
                                          Die steht auf 30 min.
                                          Trotzdem schaltet die Lampe gefühlt - wann sie will aus.
