  4. Adapter für Buderus KM200 (und eventuell auch anderen KMxxx)
    6.7k
686 Beiträge 99 Kommentatoren 289.2k Aufrufe 56 Beobachtet
  • T tp1de
    @mwolle Die States-Attribute z.B. read only oder writable kommen von der jeweiligen API.
    In meinem Adapter werden diese nur dann neu geschrieben, wenn ein Neustart mit Löschen der Zustände erfolgt. Dann sollten auch keine ems-States mehr da sein.
    Mach das bitte mal und poste die States Details:
    "type": "state",
    "id": "heatingCircuits.hc1.activeSwitchProgram",
    "common": {
    "name": "km200:heatingCircuits.hc1.activeSwitchProgram",
    "type": "number",
    "unit": "",
    "read": true,
    "write": true,
    "role": "level",
    "states": {
    "0": "A",
    "1": "B"
    "min": 0,
    "max": 1
    "native": {
    "km200": {
    "id": "/heatingCircuits/hc1/activeSwitchProgram",
    "type": "stringValue",
    "writeable": 1,
    "recordable": 0,
    "value": "A",
    "allowedValues": [
    "A",
    "B"
    "valIs": "states"
    "ems_km200": "heatingCircuits.hc1.activeSwitchProgram"
    "_id": "ems-esp.0.heatingCircuits.hc1.activeSwitchProgram",
    "from": "system.adapter.ems-esp.0",
    "user": "system.user.admin",
    "ts": 1647545350374,
    "acl": {
    "object": 1636,
    "state": 1636,
    "owner": "system.user.admin",
    mwolle
    #621
    @tp1de sieht eigentlich vernünftig aus:
      "common": {
        "name": "heatingCircuits.hc2.activeSwitchProgram",
        "read": true,
        "write": true,
        "state": "state",
        "role": "level",
        "type": "number",
        "unit": "",
        "states": "0:A;1:B;2:C;3:D;4:E;5:F",
        "min": 0,
        "max": 5
      "type": "state",
      "_id": "km200.0.heatingCircuits.hc2.activeSwitchProgram",
      "native": {
        "km200": {
          "id": "/heatingCircuits/hc2/activeSwitchProgram",
          "writeable": 1,
          "recordable": 1,
          "value": "F",
          "allowedValues": [
            "A",
            "B",
            "C",
            "D",
            "E",
            "F"
          "valIs": "states"
      "from": "system.adapter.km200.0",
      "ts": 1646935809160,
      "acl": {
        "object": 1636,
        "state": 1636,
    Dein EMS Adapter sagt:
      "type": "state",
      "id": "heatingCircuits.hc2.activeSwitchProgram",
      "common": {
        "name": "km200:heatingCircuits.hc2.activeSwitchProgram",
        "type": "number",
        "unit": "",
        "read": true,
        "write": true,
        "role": "level",
        "min": 0,
        "max": 5
      "native": {
        "km200": {
          "writeable": 1,
          "recordable": 1,
          "value": "D",
          "allowedValues": [
            "A",
            "B",
            "C",
            "D",
            "E",
            "F"
          "valIs": "states"
        "ems_km200": "heatingCircuits.hc2.activeSwitchProgram"
      "_id": "ems-esp.0.heatingCircuits.hc2.activeSwitchProgram",
      "ts": 1645340442038,
      "acl": {
        "object": 1636,
        "state": 1636,
    Dennoch
    km200.0
    2022-04-04 20:26:47.780	info	Could not find state for heatingCircuits.hc2.activeSwitchProgram
    km200.0
    2022-04-04 20:26:45.770	info	Set km200.0.heatingCircuits.hc2.activeSwitchProgram to 3
    • M mwolle
        "common": {
          "read": true,
          "write": true,
          "state": "state",
          "role": "level",
          "type": "number",
          "unit": "",
          "min": 0,
          "max": 5
        "type": "state",
        "native": {
          "km200": {
            "writeable": 1,
            "recordable": 1,
            "value": "F",
            "allowedValues": [
              "A",
              "B",
              "C",
              "D",
              "E",
              "F"
            "valIs": "states"
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "type": "number",
          "unit": "",
          "read": true,
          "write": true,
          "role": "level",
          "min": 0,
          "max": 5
        "native": {
          "km200": {
            "writeable": 1,
            "recordable": 1,
            "value": "D",
            "allowedValues": [
              "A",
              "B",
              "C",
              "D",
              "E",
              "F"
            "valIs": "states"
        "acl": {
          "object": 1636,
          "state": 1636,
      Dennoch
      km200.0
      km200.0
      tp1de
      #622
      @mwolle wenn die States neu angelegt wurden und das Schreiben nicht geht, dann ist das ein Fehler im Gateway.
      • T tp1de
        mwolle
        #623
        @tp1de danke für den Tipp, Neu angelegt, ich habe den mal gelöscht und neu anlegen lassen...nun geht es wieder...verrückt.
        • M mwolle
          tp1de
          #624
          @mwolle ne nicht verrückt... nach meiner Erfahrung notwendig nach Firmware Updates.
          • T tp1de
            mwolle
            schrieb am zuletzt editiert von mwolle
            #625
            @tp1de : Anbei mal meine Config um die Statistiken zu bekommen mit dem KM200:
            Im EMS-ESP:
            Protokoll:
            ems-esp.0
            2022-04-06 21:49:27.115	error	error read efficiency:TypeError: Cannot read property 'val' of null
            sql.0
            2022-04-06 21:49:27.114	info	No Data
            sql.0
            2022-04-06 21:49:27.111	info	No Data
            sql.0
            2022-04-06 21:49:27.109	info	No Data
            Ich würde das tatsächlich gerne komplett zum Laufen bekommen.
            • M mwolle
              Im EMS-ESP:
              Protokoll:
              ems-esp.0
              sql.0
              sql.0
              sql.0
              tp1de
              #626
              @mwolle
              So wie es aussieht benutzt Du nicht die letzte Version 1.4.0. Dann sollte die States-Struktur so aussehen:
              Aber unabhängig davon, sollten mySQL-Datensätze im dem _Months, _Days, _Hours States da sein. Die könntest Du mit Flot oder Grafana darstellen. Überprüfe mal die Monatswerte _Months in den benutzerdefinierten Einstellungen im Objekt-Browser .
              Das sollte dann so aussehen:
              • T tp1de
                @mwolle
                mwolle
                #627
                @tp1de also die 1.4.0 Version ist installiert und ich habe auch die gleiche State Struktur wie du. Ich glaube was mir noch fehlt, welche Werte müssen in die SQL DB rein, damit die Berechnung klappt. Sind das die km200 recordings (die allesamt in die SQL DB müssen)? Oder welche müssen in der SQL Datenbank historisiert werden?
                Die Statistics über Brennerstarts etc. läuft wie? Da habe ich auch nur 0 Werte.
                • M mwolle
                  tp1de
                  schrieb am zuletzt editiert von tp1de
                  #628
                  @mwolle
                  wir sollten die Diskussion im ems-esp Forum weiterführen:
                  https://forum.iobroker.net/topic/45862/neuer-adapter-ems-esp-für-bosch-heizungen/180?_=1649329552411
                  Torsten SchwaarT 1 Antwort Letzte Antwort
                  • T tp1de
                    @mwolle
                    Torsten SchwaarT Offline
                    Torsten Schwaar
                    #629
                    Hallo Kann mir jemand sagen wie ich im blockly dem Wert "km200.0.heatingCircuits.hc1.temporaryRoomSetpoint" den Wert 0,-1 oder off setzen kann?
                    bei den Zahlen 0 und -1 wird der Wert 5 gesetzt, bei "off" als string bekomme ich auch einen Fehler:
                    • Torsten SchwaarT Torsten Schwaar
                      tp1de
                      #630
                      @torsten-schwaar sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                      Ändere den erlaubten Minimalwert des States auf -1.
                      • T tp1de
                        Torsten Schwaar
                        #631
                        @tp1de
                        Das Problem ist wenn der adapter neu Startet ist der Wert auch zurück gesetzt. Wenn ich den Wert in Objekte auf -1 setzte steht sofort "off" da. Wird das selbe im Skript gemacht kommt ein Fehler....
                          @tp1de
                          tp1de
                          #632
                          @torsten-schwaar und du hast im common Bereich des States min: auf -1 gesetzt?
                          • T tp1de
                            Torsten Schwaar
                            #633
                            @tp1de im common würde ich gerne die 5 drin stehen lassen. Weil wenn ich den Adapter neu starte wieder 5 drin steht. Drehe ich an der Heizung am Rad auf "off" steht im Iobroker eine -1 drin. Also muss doch die -1 erlaubt sein. Ich bekomme Sie nur nicht per skript rein...
                              tp1de
                              #634
                              @torsten-schwaar genau im Script wird auf den Wertebereich geprüft. Das ist einer der Gründe warum ich den km200-Adapter nicht mehr verwende. Kannst ja meinen ems-esp Adapter mal probieren ...
                              Torsten SchwaarT 2 Antworten Letzte Antwort
                              • T tp1de
                                Torsten Schwaar
                                #635
                                @tp1de Danke! probiere ich.
                                OmnedonO 1 Antwort Letzte Antwort
                                  OmnedonO Online
                                  OmnedonO Online
                                  Omnedon
                                  #636
                                  @frankjoke
                                  wie sieht es mit der Kompatibilität mit js-controller 4 aus?
                                  Ist das geplant?
                                  Zur Zeit ist das Issue auf Github noch offen.
                                  Viele Grüße
                                  • T tp1de
                                    Torsten Schwaar
                                    #637
                                    @tp1de Vielen Dank für den Tip, sieht so aus als ob es jetzt geht.
                                      tp1de
                                      #638
                                      Ja ich setzte im Adapter für diese States den Minimalwert auf -1 !
                                      Ich musste im ems-esp Adapter Einiges anpassen für den js-contoller 4.x, da nun Wertebereiche strikt geprüft werden.
                                      Diese Anpassungen sind z.T. für den km200 Adapter noch offen.
                                      • BostilB Bostil
                                        Noch eine Frage an die Experten: Ist es möglich über den Adapter die Anlage auch zu steuern, um so z. B. auch Extra-Warmwasser zu aktivieren (wie es auch in der App möglich ist) ?
                                        Danke euch und auch Danke für den tollen Adapter @frankjoke
                                        Henry 1
                                        schrieb am zuletzt editiert von Henry 1
                                        #639
                                        @bostil
                                        Hast du das mit dem Extrawasser hinbekommen?
                                        Ich sitzte momentan genau an der gleichen Stelle
                                          Rosi8818
                                          schrieb am zuletzt editiert von Rosi8818
                                          #640
                                          ich habe jetzt auch endlich meine neue Bosch Heizung Cerapur_ZSB_14-5.2c mit dem MB LAN 2 und dem Adapter zum laufen gebracht.
                                          War super leicht einzurichten, vorab über EasyRemote von Bosch Zugang geholt und persönliches Passwort festgelet. Danach ging es erst im Adapter.
                                          Etwas Geduld und der Erfolg war sichtbar :)
                                          Warum ich das hier vorab schreibe, damit es in der Suche gefunden wird, ich tat mich echt schwer damit etwas passendes zu finden.
                                          Jetzt zur eigentlichen Frage:
                                          Ein wenig tu ich mich schwer mit den Objektbaum, gibt es da eine Art Aufstellung/ Übersetzung wofür was ist?
                                          Bspw.
                                          • würde ich gerne wie andere Punkte schon im Einsatz sind mit SourceAnaltytix den Verbrauch messen (ich hab Grafana und influxdb im Einsatz)
                                          • Verlauf wann das Warmwasser aufheizt und wie lange
                                          • Verlauf wann die Heizung aufheizt und wie lange
                                          • Heizung von Nachtmodus/ Nachtabsenkung auf Dauer einschalten (bspw. bei Besuch der länger bleibt)
                                          • Heizung manuell ein/ aus
                                          hat da jemand eine Idee?
                                          Ralf
