  4. Nach Update läuft nichts mehr!
    5.1k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 87.8k Aufrufe 9 Beobachtet
    @speedyblade sagte in Nach Update läuft nichts mehr!:
    Prima, läuft doch.
    SpeedyBlade
    #401
    jetzt wieder
    hat mir aber nicht alle Adapter nach dem update installiert
    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
    • S SpeedyBlade
      jetzt wieder
      #402
      @speedyblade
      iob update
      sagt? Besser noch die Langfassung von
      iob diag
        @speedyblade
        iob update
        iob diag
        SpeedyBlade
        #403
        piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        *** BASE SYSTEM ***
           Static hostname: RaspberryPi3B1GB
                 Icon name: computer
                Machine ID: 0a3492672676440e91094afe51dc1729
                   Boot ID: 014394ca8eed41a288a0b89111927ea2
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
        CPU threads: 4
        Raspberry only:
        throttled=0x50000
        Other values than 0x0 hint to temperature/voltage problems
        temp=62.3'C
        volt=1.3062V
        *** Time and Time Zones ***
                       Local time: Sun 2023-10-01 17:14:12 CEST
                   Universal time: Sun 2023-10-01 15:14:12 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        piuser
        /home/piuser
        piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            909M        387M        227M        0.0K        294M        458M
        Swap:            99M         20M         79M
        Total:          1.0G        407M        306M
                  909 M total memory
                  387 M used memory
                  445 M active memory
                  110 M inactive memory
                  227 M free memory
                   16 M buffer memory
                  277 M swap cache
                   99 M total swap
                   20 M used swap
                   79 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FILESYSTEM ***
        /dev/root      ext4      294G  2.9G  279G   2% /
        devtmpfs       devtmpfs  325M     0  325M   0% /dev
        tmpfs          tmpfs     455M     0  455M   0% /dev/shm
        tmpfs          tmpfs     182M  980K  181M   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
        [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
        [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        570M    /var/
        234M    /var/cache
        228M    /var/cache/apt
        147M    /var/lib
        128M    /var/cache/apt/archives
        Archived and active journals take up 88.0M in the file system.
        /opt/iobroker/backups:
        1.4M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        70M     /opt/iobroker/iobroker-data/
        52M     /opt/iobroker/iobroker-data/files
        30M     /opt/iobroker/iobroker-data/files/web.admin/static
        29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        6.5M    /opt/iobroker/iobroker-data/objects.jsonl
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.10.1
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
          system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
        + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
        + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
          system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
          system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
          system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Objects and States
        Objects:        832
        States:         677
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
        tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
        udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
        udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
        udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
        udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
        udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
        udp6       0      0 :::111                  :::*                                0          51300      1/init
        udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
        2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
        2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
        2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
        2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
        2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
        2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
        2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
        2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
        2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
        2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
        2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
        2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
        2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
        2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
        2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
        2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
        2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
        2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
        2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
        2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
        2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
        2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
        2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
        2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
        2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
        • S SpeedyBlade
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Raspberry only:
          throttled=0x50000
          temp=62.3'C
          volt=1.3062V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          piuser
          /home/piuser
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         20M         79M
                    909 M total memory
                    387 M used memory
                    445 M active memory
                    227 M free memory
                     16 M buffer memory
                    277 M swap cache
                     99 M total swap
                     20 M used swap
                     79 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          570M    /var/
          234M    /var/cache
          228M    /var/cache/apt
          147M    /var/lib
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.10.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        832
          States:         677
          Pending Updates: 0
          #404
          @speedyblade
          Starte die Kiste mal ordentlich!!! neu.
          sudo reboot
          • S SpeedyBlade
            jetzt wieder
            #405
            was fehlt?
              was fehlt?
              SpeedyBlade
              #406
              • S SpeedyBlade
                jetzt wieder
                #407
                hastcdu während der rebuilds den iob in Ruhe gelassen?
                  SpeedyBlade
                  #408
                  jup...nichts daran gemacht
                  • S SpeedyBlade
                    #409
                    @speedyblade und sicher dass die alle im Backup drin sind?
                    edit:
                    klar! sonst sähest du sie nicht im admin
                    edit2
                    was macht enum zwischen den Instanzen?
                    da ist wirklich was krumm
                    W 1 Antwort Letzte Antwort
                      edit:
                      edit2
                      W Online
                      W Online
                      Wildbill
                      schrieb am zuletzt editiert von Wildbill
                      #410
                      @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                      Gruss, Jürgen
                      EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                      • W Wildbill
                        Gruss, Jürgen
                        #411
                        @wildbill sagte in Nach Update läuft nichts mehr!:
                        soweit zu abgeschnittenen Informationen!
                        @SpeedyBlade
                        bitte Instanzen zeigen.
                        Vollständig, nichts abschneiden.
                        S 2 Antworten Letzte Antwort
                          @SpeedyBlade
                          SpeedyBlade
                          #412
                          ich werde den neu aufsetzen...
                          hab nun noch einmal das backup aufgespielt
                          das war ein testgerät, aber gut zu wissen, dass ein backup nicht so sauber durchläuft, wie es soll
                          danke euch dennoch
                          • S SpeedyBlade
                            danke euch dennoch
                            #413
                            Generell schon. Ist ein individuelles Problem.
                            • S SpeedyBlade
                              danke euch dennoch
                              #414
                              hey
                              @thomas-braun sagte in Nach Update läuft nichts mehr!:
                              Das Dateisystem hat 'nen Treffer.
                              und die letzten Fragen sind auch noch unbeantwortet
                                @SpeedyBlade
                                SpeedyBlade
                                #415
                                • S SpeedyBlade
                                  #416
                                  @speedyblade danke!
                                  dann bleibt doch wieder die Frage was im Backup drin ist.
                                  (und der Header fehlt immer noch)
