  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.8k Aufrufe 9 Beobachtet
    @speedyblade
    iob update
    sagt? Besser noch die Langfassung von
    iob diag
    SpeedyBlade
    #403
    piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    *** BASE SYSTEM ***
       Static hostname: RaspberryPi3B1GB
             Icon name: computer
            Machine ID: 0a3492672676440e91094afe51dc1729
               Boot ID: 014394ca8eed41a288a0b89111927ea2
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
    CPU threads: 4
    Raspberry only:
    throttled=0x50000
    Other values than 0x0 hint to temperature/voltage problems
    temp=62.3'C
    volt=1.3062V
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-01 17:14:12 CEST
               Universal time: Sun 2023-10-01 15:14:12 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    piuser
    /home/piuser
    piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        387M        227M        0.0K        294M        458M
    Swap:            99M         20M         79M
    Total:          1.0G        407M        306M
              909 M total memory
              387 M used memory
              445 M active memory
              110 M inactive memory
              227 M free memory
               16 M buffer memory
              277 M swap cache
               99 M total swap
               20 M used swap
               79 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      294G  2.9G  279G   2% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  980K  181M   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    570M    /var/
    234M    /var/cache
    228M    /var/cache/apt
    147M    /var/lib
    128M    /var/cache/apt/archives
    Archived and active journals take up 88.0M in the file system.
    /opt/iobroker/backups:
    1.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    70M     /opt/iobroker/iobroker-data/
    52M     /opt/iobroker/iobroker-data/files
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    6.5M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
      system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
    + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
    + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
      system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
      system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
      system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Objects and States
    Objects:        832
    States:         677
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
    tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
    udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
    udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
    udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
    udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
    udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
    udp6       0      0 :::111                  :::*                                0          51300      1/init
    udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
    2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
    2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
    2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
    2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
    2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
    2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
    2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
    2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
    2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
    2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
    2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
    2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
    2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
    2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
    2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
    2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
    2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
    2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
    2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
    2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
    2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
    2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
    2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
    2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
    2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
    • S SpeedyBlade
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Raspberry only:
      throttled=0x50000
      temp=62.3'C
      volt=1.3062V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      piuser
      /home/piuser
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         20M         79M
                909 M total memory
                387 M used memory
                445 M active memory
                227 M free memory
                 16 M buffer memory
                277 M swap cache
                 99 M total swap
                 20 M used swap
                 79 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      570M    /var/
      234M    /var/cache
      228M    /var/cache/apt
      147M    /var/lib
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        832
      States:         677
      Pending Updates: 0
      #404
      @speedyblade
      Starte die Kiste mal ordentlich!!! neu.
      sudo reboot
      • S SpeedyBlade
        jetzt wieder
        hat mir aber nicht alle Adapter nach dem update installiert
        #405
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        was fehlt?
          was fehlt?
          SpeedyBlade
          #406
          • S SpeedyBlade
            jetzt wieder
            #407
            hastcdu während der rebuilds den iob in Ruhe gelassen?
              SpeedyBlade
              #408
              jup...nichts daran gemacht
              • S SpeedyBlade
                #409
                @speedyblade und sicher dass die alle im Backup drin sind?
                edit:
                klar! sonst sähest du sie nicht im admin
                edit2
                was macht enum zwischen den Instanzen?
                da ist wirklich was krumm
                W 1 Antwort Letzte Antwort
                  edit:
                  edit2
                  W Online
                  W Online
                  Wildbill
                  schrieb am zuletzt editiert von Wildbill
                  #410
                  @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                  Gruss, Jürgen
                  EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                  • W Wildbill
                    Gruss, Jürgen
                    #411
                    @wildbill sagte in Nach Update läuft nichts mehr!:
                    soweit zu abgeschnittenen Informationen!
                    @SpeedyBlade
                    bitte Instanzen zeigen.
                    Vollständig, nichts abschneiden.
                    S 2 Antworten Letzte Antwort
                      @SpeedyBlade
                      SpeedyBlade
                      #412
                      ich werde den neu aufsetzen...
                      hab nun noch einmal das backup aufgespielt
                      das war ein testgerät, aber gut zu wissen, dass ein backup nicht so sauber durchläuft, wie es soll
                      danke euch dennoch
                      • S SpeedyBlade
                        danke euch dennoch
                        #413
                        Generell schon. Ist ein individuelles Problem.
                        • S SpeedyBlade
                          danke euch dennoch
                          #414
                          hey
                          @thomas-braun sagte in Nach Update läuft nichts mehr!:
                          Das Dateisystem hat 'nen Treffer.
                          und die letzten Fragen sind auch noch unbeantwortet
                            @SpeedyBlade
                            SpeedyBlade
                            #415
                            • S SpeedyBlade
                              #416
                              @speedyblade danke!
                              dann bleibt doch wieder die Frage was im Backup drin ist.
                              (und der Header fehlt immer noch)
