  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.8k Aufrufe 9 Beobachtet
  • S SpeedyBlade
       Static hostname: RaspberryPi3B1GB
             Icon name: computer
            Machine ID: 0a3492672676440e91094afe51dc1729
               Boot ID: 014394ca8eed41a288a0b89111927ea2
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     15:25:26 up  1:24,  1 user,  load average: 1.04, 3.03, 1.99
    CPU threads: 4
    Raspberry only:
    throttled=0x50000
    Other values than 0x0 hint to temperature/voltage problems
    temp=63.9'C
    volt=1.3062V
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-01 15:25:27 CEST
               Universal time: Sun 2023-10-01 13:25:27 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    piuser
    /home/piuser
    piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        118M        586M        0.0K        204M        717M
    Swap:            99M         65M         34M
    Total:          1.0G        184M        620M
              909 M total memory
              118 M used memory
              154 M active memory
               71 M inactive memory
              586 M free memory
                8 M buffer memory
              195 M swap cache
               99 M total swap
               65 M used swap
               34 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      294G  2.8G  279G   1% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  968K  181M   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
    [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    570M    /var/
    234M    /var/cache
    228M    /var/cache/apt
    147M    /var/lib
    128M    /var/cache/apt/archives
    Archived and active journals take up 88.0M in the file system.
    /opt/iobroker/backups:
    1.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    45M     /opt/iobroker/iobroker-data/
    28M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.9M    /opt/iobroker/iobroker-data/objects.jsonl
    4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.4M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.d0deddb4.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          5.2.3
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
      system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
      system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
      system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
      system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 5.2.3  [Updatable]
    Adapter    "backitup"     : 2.8.1    , installed 2.2.3  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 2.7.3  [Updatable]
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
    Adapter    "node-red"     : 4.0.3    , installed 2.4.1  [Updatable]
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
    Adapter    "socketio"     : 6.5.5    , installed 3.1.5  [Updatable]
    Adapter    "web"          : 6.1.2    , installed 3.4.16 [Updatable]
    Objects and States
    Objects:        360
    States:         230
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37390      8921/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37385      8921/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
    udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
    udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
    2023-10-01 15:22:47.009  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: Rebuilding native modules done
    2023-10-01 15:22:48.051  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: exit 0
    2023-10-01 15:22:48.278  - info: host.RaspberryPi3B1GB instance system.adapter.admin.0 started with pid 10379
    2023-10-01 15:22:56.545  - error: host.RaspberryPi3B1GB Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-10-01 15:22:56.547  - error: host.RaspberryPi3B1GB Caught by controller[0]:   throw err;
    2023-10-01 15:22:56.548  - error: host.RaspberryPi3B1GB Caught by controller[0]:   ^
    2023-10-01 15:22:56.549  - error: host.RaspberryPi3B1GB Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    2023-10-01 15:22:56.550  - error: host.RaspberryPi3B1GB Caught by controller[0]: Require stack:
    2023-10-01 15:22:56.551  - error: host.RaspberryPi3B1GB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-10-01 15:22:56.553  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-10-01 15:22:56.554  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
    2023-10-01 15:22:56.555  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
    2023-10-01 15:22:56.556  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-10-01 15:22:56.557  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-10-01 15:22:56.558  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-10-01 15:22:56.560  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-10-01 15:22:56.563  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) {
    2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
    2023-10-01 15:22:56.565  - error: host.RaspberryPi3B1GB Caught by controller[0]: }
    2023-10-01 15:22:56.566  - error: host.RaspberryPi3B1GB Caught by controller[0]: Node.js v18.18.0
    2023-10-01 15:22:56.568  - error: host.RaspberryPi3B1GB instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-10-01 15:22:56.569  - info: host.RaspberryPi3B1GB Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    #394
    @speedyblade
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
      @speedyblade
      cd /opt/iobroker
      SpeedyBlade
      #395
      piuser@RaspberryPi3B1GB:~ $ cd /opt/iobroker
      npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
      npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
      npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
      npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
      up to date in 39s
      54 packages are looking for funding
        run `npm fund` for details
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        throttled=0x50000 Other values than 0x0 hint to temperature/voltage problems temp=63.9'C volt=1.3062V
        Der Kiste ist unwohl. Zu warm, zu viel Strom.
        Das Dateisystem hat 'nen Treffer.
        SpeedyBlade
        #396
        hab netzteil, welches ich spannung einstellen kann
        zeigt mir sauber 5V an
        zu warm, ist auch merkwürdig...liegt direkt vor mir auf dem Tisch
        • S SpeedyBlade
          #397
          @speedyblade
          Der Code 0X50005 zeigt jedenfalls Probleme in der Spannungsversorgung an.
          iob status
          sagt?
            @speedyblade
            iob status
            sagt?
            #398
            @thomas-braun sagte in Nach Update läuft nichts mehr!:
            @speedyblade
            iob status
            sagt?
            Möglicherweise sind auch hier schon
            zu wenig.
            Spätestens der Pi4 braucht mehr.
            Würde auch die Probleme im FS erklären, wenn es zu under-voltage gekommen war
              @speedyblade
              iob status
              sagt?
              zu wenig.
              SpeedyBlade
              #399
              es handelt sich hier um einen PI3plus
              piuser@RaspberryPi3B1GB:/opt/iobroker $ iob status
              Objects type: jsonl
              States  type: jsonl
              • S SpeedyBlade
                Objects type: jsonl
                States  type: jsonl
                #400
                Prima, läuft doch.
                  Prima, läuft doch.
                  SpeedyBlade
                  #401
                  jetzt wieder
                  hat mir aber nicht alle Adapter nach dem update installiert
                  Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                  • S SpeedyBlade
                    jetzt wieder
                    #402
                    @speedyblade
                    iob update
                    sagt? Besser noch die Langfassung von
                    iob diag
                      @speedyblade
                      iob update
                      iob diag
                      SpeedyBlade
                      #403
                      piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
                      Adapter    "admin"        : 6.10.1   , installed 6.10.1
                      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                      Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                      Adapter    "web"          : 6.1.2    , installed 6.1.2
                      Adapter    "ws"           : 2.5.5    , installed 2.5.5
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x50000
                      temp=62.3'C
                      volt=1.3062V
                                     Local time: Sun 2023-10-01 17:14:12 CEST
                                 Universal time: Sun 2023-10-01 15:14:12 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      piuser
                      /home/piuser
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            909M        387M        227M        0.0K        294M        458M
                      Swap:            99M         20M         79M
                      Total:          1.0G        407M        306M
                                909 M total memory
                                387 M used memory
                                445 M active memory
                                110 M inactive memory
                                227 M free memory
                                 16 M buffer memory
                                277 M swap cache
                                 99 M total swap
                                 20 M used swap
                                 79 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4      294G  2.9G  279G   2% /
                      tmpfs          tmpfs     182M  980K  181M   1% /run
                      /var:
                      570M    /var/
                      234M    /var/cache
                      228M    /var/cache/apt
                      147M    /var/lib
                      70M     /opt/iobroker/iobroker-data/
                      52M     /opt/iobroker/iobroker-data/files
                      30M     /opt/iobroker/iobroker-data/files/web.admin/static
                      29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                      6.5M    /opt/iobroker/iobroker-data/objects.jsonl
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.1
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
                      + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
                      + instance is alive
                      Objects and States
                      Objects:        832
                      States:         677
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
                      tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
                      udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
                      udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
                      udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
                      udp6       0      0 :::111                  :::*                                0          51300      1/init
                      2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
                      2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
                      2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
                      • S SpeedyBlade
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x50000
                        temp=62.3'C
                        volt=1.3062V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        piuser
                        /home/piuser
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M         20M         79M
                                  909 M total memory
                                  387 M used memory
                                  445 M active memory
                                  227 M free memory
                                   16 M buffer memory
                                  277 M swap cache
                                   99 M total swap
                                   20 M used swap
                                   79 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        570M    /var/
                        234M    /var/cache
                        228M    /var/cache/apt
                        147M    /var/lib
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        832
                        States:         677
                        Pending Updates: 0
                        #404
                        @speedyblade
                        Starte die Kiste mal ordentlich!!! neu.
                        sudo reboot
                        • S SpeedyBlade
                          jetzt wieder
                          #405
                          was fehlt?
                            was fehlt?
                            SpeedyBlade
                            #406
                            • S SpeedyBlade
                              jetzt wieder
                              #407
                              hastcdu während der rebuilds den iob in Ruhe gelassen?
                                SpeedyBlade
                                #408
                                jup...nichts daran gemacht
                                • S SpeedyBlade
                                  #409
                                  @speedyblade und sicher dass die alle im Backup drin sind?
                                  edit:
                                  klar! sonst sähest du sie nicht im admin
                                  edit2
                                  was macht enum zwischen den Instanzen?
                                  da ist wirklich was krumm
                                  W 1 Antwort Letzte Antwort
                                    edit:
                                    edit2
                                    W Offline
                                    W Offline
                                    Wildbill
                                    schrieb am zuletzt editiert von Wildbill
                                    #410
                                    @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                                    Gruss, Jürgen
                                    EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
                                    • W Wildbill
                                      Gruss, Jürgen
                                      #411
                                      @wildbill sagte in Nach Update läuft nichts mehr!:
                                      soweit zu abgeschnittenen Informationen!
                                      @SpeedyBlade
                                      bitte Instanzen zeigen.
                                      Vollständig, nichts abschneiden.
                                      S 2 Antworten Letzte Antwort
                                        @SpeedyBlade
                                        SpeedyBlade
                                        #412
                                        ich werde den neu aufsetzen...
                                        hab nun noch einmal das backup aufgespielt
                                        das war ein testgerät, aber gut zu wissen, dass ein backup nicht so sauber durchläuft, wie es soll
                                        danke euch dennoch
                                        • S SpeedyBlade
                                          danke euch dennoch
                                          #413
                                          Generell schon. Ist ein individuelles Problem.
