  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.8k Aufrufe 9 Beobachtet
  • S SpeedyBlade
    nachdem ich ein Backup aufgespielt habe und nun den fixer drüber laufen lassen habe, läuft der Pi3 nicht mehr :(
                         v.2023-06-20
       Static hostname: RaspberryPi3B1GB
             Icon name: computer
            Machine ID: 0a3492672676440e91094afe51dc1729
               Boot ID: 014394ca8eed41a288a0b89111927ea2
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    8
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                            /usr/bin/node           v18.18.0
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            909M        205M        466M        0.0K        237M        639M
    Swap:            99M         67M         32M
    Total:          1.0G        273M        498M
    Active iob-Instances:   2
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   5.2.3
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : RaspberryPi3B1GB                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                360
    States:                 230
    Size of iob-Database:
    8.2M    /opt/iobroker/iobroker-data/objects.jsonl
    4.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    164K    /opt/iobroker/iobroker-data/states.jsonl
    68K     /opt/iobroker/iobroker-data/states.json.bak.migrated
    64K     /opt/iobroker/iobroker-data/states.json.migrated
    === Mark text until here for copying ===
    piuser@RaspberryPi3B1GB:~ $ npm ERR! code ELSPROBLEMS
    Unknown command: "ERR!"
    To see a list of supported npm commands, run:
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: async-retry@1.3.3 /opt/iobroker/node_modules/async-retry
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: button-events@1.1.0 /opt/iobroker/node_modules/button-events
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: epoll@2.0.10 /opt/iobroker/node_modules/epoll
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: iobroker.rpi2@1.3.1 /opt/iobroker/node_modules/iobroker.rpi2
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: node-addon-api@1.7.2 /opt/iobroker/node_modules/node-addon-api
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: node-dht-sensor@0.4.3 /opt/iobroker/node_modules/node-dht-sensor
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: rpi-gpio-buttons@2.0.1 /opt/iobroker/node_modules/rpi-gpio-buttons
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: rpi-gpio@2.1.7 /opt/iobroker/node_modules/rpi-gpio
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: sync-exec@0.6.2 /opt/iobroker/node_modules/sync-exec
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: retry@0.13.1 /opt/iobroker/node_modules/async-retry/node_modules/retry
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: debug@3.2.7 /opt/iobroker/node_modules/rpi-gpio/node_modules/debug
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! extraneous: ms@2.1.3 /opt/iobroker/node_modules/rpi-gpio/node_modules/ms
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/chokidar/node_modules/fsevents
      npm help
    piuser@RaspberryPi3B1GB:~ $ npm ERR! A complete log of this run can be found in: /home/piuser/.npm/_logs/2023-10-01T12_10_00_677Z-debug-0.log
      npm help
    piuser@RaspberryPi3B1GB:~ $ Errors in npm tree: 0
    -bash: Errors: command not found
    #391
    @speedyblade
    Poste die Langfassung.
      @speedyblade
      SpeedyBlade
      #392
               Icon name: computer
            Architecture: arm64
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       15:25:26 up  1:24,  1 user,  load average: 1.04, 3.03, 1.99
      CPU threads: 4
      Raspberry only:
      throttled=0x50000
      Other values than 0x0 hint to temperature/voltage problems
      temp=63.9'C
      volt=1.3062V
      *** Time and Time Zones ***
                     Local time: Sun 2023-10-01 15:25:27 CEST
                 Universal time: Sun 2023-10-01 13:25:27 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      piuser
      /home/piuser
      piuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            909M        118M        586M        0.0K        204M        717M
      Swap:            99M         65M         34M
      Total:          1.0G        184M        620M
                909 M total memory
                118 M used memory
                154 M active memory
                 71 M inactive memory
                586 M free memory
                  8 M buffer memory
                195 M swap cache
                 99 M total swap
                 65 M used swap
                 34 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      294G  2.8G  279G   1% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M  968K  181M   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Sun Oct  1 14:00:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=86e36461-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): recovery complete
      [Sun Oct  1 14:00:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Oct  1 14:00:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Oct  1 14:00:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      570M    /var/
      234M    /var/cache
      228M    /var/cache/apt
      147M    /var/lib
      128M    /var/cache/apt/archives
      Archived and active journals take up 88.0M in the file system.
      /opt/iobroker/backups:
      1.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      45M     /opt/iobroker/iobroker-data/
      28M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/objects.jsonl
      4.4M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.d0deddb4.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          5.2.3
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.backitup.0               : backitup              : RaspberryPi3B1GB                         -  enabled
        system.adapter.discovery.0              : discovery             : RaspberryPi3B1GB                         - disabled
        system.adapter.mqtt.0                   : mqtt                  : RaspberryPi3B1GB                         - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : RaspberryPi3B1GB                         - disabled, port: 1885, bind: 0.0.0.0
        system.adapter.rpi2.0                   : rpi2                  : RaspberryPi3B1GB                         - disabled
        system.adapter.socketio.0               : socketio              : RaspberryPi3B1GB                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 5.2.3  [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.2.3  [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 2.7.3  [Updatable]
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
      Adapter    "node-red"     : 4.0.3    , installed 2.4.1  [Updatable]
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
      Adapter    "socketio"     : 6.5.5    , installed 3.1.5  [Updatable]
      Adapter    "web"          : 6.1.2    , installed 3.4.16 [Updatable]
      Objects and States
      Objects:        360
      States:         230
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37390      8921/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37385      8921/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14409      517/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14411      517/sshd: /usr/sbin
      udp        0      0 0.0.0.0:44571           0.0.0.0:*                           108        14352      388/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1767       574/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14350      388/avahi-daemon: r
      udp6       0      0 :::56729                :::*                                108        14353      388/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14351      388/avahi-daemon: r
      2023-10-01 15:22:47.009  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: Rebuilding native modules done
      2023-10-01 15:22:48.051  - info: host.RaspberryPi3B1GB iobroker npm-rebuild: exit 0
      2023-10-01 15:22:48.278  - info: host.RaspberryPi3B1GB instance system.adapter.admin.0 started with pid 10379
      2023-10-01 15:22:56.545  - error: host.RaspberryPi3B1GB Caught by controller[0]: node:internal/modules/cjs/loader:1080
      2023-10-01 15:22:56.547  - error: host.RaspberryPi3B1GB Caught by controller[0]:   throw err;
      2023-10-01 15:22:56.548  - error: host.RaspberryPi3B1GB Caught by controller[0]:   ^
      2023-10-01 15:22:56.549  - error: host.RaspberryPi3B1GB Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
      2023-10-01 15:22:56.550  - error: host.RaspberryPi3B1GB Caught by controller[0]: Require stack:
      2023-10-01 15:22:56.551  - error: host.RaspberryPi3B1GB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
      2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      2023-10-01 15:22:56.552  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
      2023-10-01 15:22:56.553  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-10-01 15:22:56.554  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
      2023-10-01 15:22:56.555  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
      2023-10-01 15:22:56.556  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-10-01 15:22:56.557  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-10-01 15:22:56.558  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-10-01 15:22:56.560  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
      2023-10-01 15:22:56.563  - error: host.RaspberryPi3B1GB Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) {
      2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2023-10-01 15:22:56.564  - error: host.RaspberryPi3B1GB Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
      2023-10-01 15:22:56.565  - error: host.RaspberryPi3B1GB Caught by controller[0]: }
      2023-10-01 15:22:56.566  - error: host.RaspberryPi3B1GB Caught by controller[0]: Node.js v18.18.0
      2023-10-01 15:22:56.568  - error: host.RaspberryPi3B1GB instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-10-01 15:22:56.569  - info: host.RaspberryPi3B1GB Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      • S SpeedyBlade
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x50000
        temp=63.9'C
        volt=1.3062V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        piuser
        /home/piuser
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         65M         34M
                  909 M total memory
                  118 M used memory
                  154 M active memory
                  586 M free memory
                    8 M buffer memory
                  195 M swap cache
                   99 M total swap
                   65 M used swap
                   34 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        570M    /var/
        234M    /var/cache
        228M    /var/cache/apt
        147M    /var/lib
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          5.2.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        360
        States:         230
        Pending Updates: 0
        #393
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        throttled=0x50000 Other values than 0x0 hint to temperature/voltage problems temp=63.9'C volt=1.3062V
        Der Kiste ist unwohl. Zu warm, zu viel Strom.
        Das Dateisystem hat 'nen Treffer.
        • S SpeedyBlade
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Raspberry only:
          throttled=0x50000
          temp=63.9'C
          volt=1.3062V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          piuser
          /home/piuser
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         65M         34M
                    909 M total memory
                    118 M used memory
                    154 M active memory
                    586 M free memory
                      8 M buffer memory
                    195 M swap cache
                     99 M total swap
                     65 M used swap
                     34 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          570M    /var/
          234M    /var/cache
          228M    /var/cache/apt
          147M    /var/lib
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          5.2.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        360
          States:         230
          Pending Updates: 0
          #394
          @speedyblade
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            @speedyblade
            cd /opt/iobroker
            SpeedyBlade
            #395
            piuser@RaspberryPi3B1GB:~ $ cd /opt/iobroker
            npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
            npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
            npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
            npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
            up to date in 39s
            54 packages are looking for funding
              run `npm fund` for details
              SpeedyBlade
              #396
              hab netzteil, welches ich spannung einstellen kann
              zeigt mir sauber 5V an
              zu warm, ist auch merkwürdig...liegt direkt vor mir auf dem Tisch
              • S SpeedyBlade
                #397
                @speedyblade
                Der Code 0X50005 zeigt jedenfalls Probleme in der Spannungsversorgung an.
                iob status
                sagt?
                  @speedyblade
                  iob status
                  sagt?
                  HomoranH Offline
                  HomoranH Offline
                  #398
                  @thomas-braun sagte in Nach Update läuft nichts mehr!:
                  @speedyblade
                  iob status
                  sagt?
                  Möglicherweise sind auch hier schon
                  zu wenig.
                  Spätestens der Pi4 braucht mehr.
                  Würde auch die Probleme im FS erklären, wenn es zu under-voltage gekommen war
                    @speedyblade
                    iob status
                    sagt?
                    zu wenig.
                    SpeedyBlade
                    #399
                    es handelt sich hier um einen PI3plus
                    piuser@RaspberryPi3B1GB:/opt/iobroker $ iob status
                    Objects type: jsonl
                    States  type: jsonl
                    • S SpeedyBlade
                      Objects type: jsonl
                      States  type: jsonl
                      #400
                      Prima, läuft doch.
                        Prima, läuft doch.
                        SpeedyBlade
                        #401
                        jetzt wieder
                        hat mir aber nicht alle Adapter nach dem update installiert
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • S SpeedyBlade
                          jetzt wieder
                          #402
                          @speedyblade
                          iob update
                          sagt? Besser noch die Langfassung von
                          iob diag
                            @speedyblade
                            iob update
                            iob diag
                            SpeedyBlade
                            #403
                            piuser@RaspberryPi3B1GB:/opt/iobroker $ iob update
                            Adapter    "admin"        : 6.10.1   , installed 6.10.1
                            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                            Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             17:14:12 up  3:13,  1 user,  load average: 0.61, 0.57, 0.66
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x50000
                            temp=62.3'C
                            volt=1.3062V
                                           Local time: Sun 2023-10-01 17:14:12 CEST
                                       Universal time: Sun 2023-10-01 15:14:12 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            piuser
                            /home/piuser
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            909M        387M        227M        0.0K        294M        458M
                            Swap:            99M         20M         79M
                            Total:          1.0G        407M        306M
                                      909 M total memory
                                      387 M used memory
                                      445 M active memory
                                      110 M inactive memory
                                      227 M free memory
                                       16 M buffer memory
                                      277 M swap cache
                                       99 M total swap
                                       20 M used swap
                                       79 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4      294G  2.9G  279G   2% /
                            tmpfs          tmpfs     182M  980K  181M   1% /run
                            /var:
                            570M    /var/
                            234M    /var/cache
                            228M    /var/cache/apt
                            147M    /var/lib
                            70M     /opt/iobroker/iobroker-data/
                            52M     /opt/iobroker/iobroker-data/files
                            30M     /opt/iobroker/iobroker-data/files/web.admin/static
                            29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                            6.5M    /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : RaspberryPi3B1GB                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.doorbird.0               : doorbird              : RaspberryPi3B1GB                         -  enabled
                            + system.adapter.harmony.0                : harmony               : RaspberryPi3B1GB                         -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        832
                            States:         677
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:58193           0.0.0.0:*               LISTEN      107        52343      14782/rpc.statd
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50821      14679/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50816      14679/iobroker.js-c
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          52321      1/init
                            tcp6       0      0 :::39761                :::*                    LISTEN      107        52347      14782/rpc.statd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49916      14706/io.admin.0
                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       52553      15043/io.harmony.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          51296      1/init
                            udp        0      0 127.0.0.1:966           0.0.0.0:*                           0          52337      14782/rpc.statd
                            udp        0      0 0.0.0.0:38950           0.0.0.0:*                           107        52341      14782/rpc.statd
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       52554      15043/io.harmony.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51292      1/init
                            udp6       0      0 :::41434                :::*                                107        52345      14782/rpc.statd
                            udp6       0      0 :::111                  :::*                                0          51300      1/init
                            2023-10-01 17:09:12.284  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.WOHNZIMMER.Off" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.287  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PowerOff" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.289  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionDown" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.292  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionLeft" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.294  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionRight" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.296  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.DirectionUp" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.298  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Select" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.301  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Stop" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.303  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Play" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.306  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Rewind" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.308  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Pause" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.311  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.FastForward" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.327  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Back" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.329  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Search" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.333  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Cross" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.336  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Circle" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.339  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Square" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.342  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Triangle" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.345  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Info" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.348  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Next_Video" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.351  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Options" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.354  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Previous_Video" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.356  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.PS" has to be type "number" but received type "string"
                            2023-10-01 17:09:12.359  - info: harmony.0 (15043) State value to set for "harmony.0.Wohnzimmer.Sony_PS4.Share" has to be type "number" but received type "string"
                            2023-10-01 17:13:46.508  - error: host.RaspberryPi3B1GB cannot call visUtils: Not exists
                            • S SpeedyBlade
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x50000
                              temp=62.3'C
                              volt=1.3062V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              piuser
                              /home/piuser
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M         20M         79M
                                        909 M total memory
                                        387 M used memory
                                        445 M active memory
                                        227 M free memory
                                         16 M buffer memory
                                        277 M swap cache
                                         99 M total swap
                                         20 M used swap
                                         79 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              570M    /var/
                              234M    /var/cache
                              228M    /var/cache/apt
                              147M    /var/lib
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        832
                              States:         677
                              Pending Updates: 0
                              #404
                              @speedyblade
                              Starte die Kiste mal ordentlich!!! neu.
                              sudo reboot
                              • S SpeedyBlade
                                jetzt wieder
                                HomoranH Offline
                                HomoranH Offline
                                #405
                                was fehlt?
                                  was fehlt?
                                  SpeedyBlade
                                  #406
                                  • S SpeedyBlade
                                    jetzt wieder
                                    HomoranH Offline
                                    HomoranH Offline
                                    #407
                                    hastcdu während der rebuilds den iob in Ruhe gelassen?
                                      SpeedyBlade
                                      #408
                                      jup...nichts daran gemacht
                                      • S SpeedyBlade
                                        HomoranH Offline
                                        HomoranH Offline
                                        #409
                                        @speedyblade und sicher dass die alle im Backup drin sind?
                                        edit:
                                        klar! sonst sähest du sie nicht im admin
                                        edit2
                                        was macht enum zwischen den Instanzen?
                                        da ist wirklich was krumm
                                        W 1 Antwort Letzte Antwort
                                          edit:
                                          edit2
                                          W Offline
                                          W Offline
                                          Wildbill
                                          schrieb am zuletzt editiert von Wildbill
                                          #410
                                          @homoran enum taucht bei den Objekten auf, wenn man den Expertenmodus aktiviert.
                                          Gruss, Jürgen
                                          EDIT: Denn der Screenshot zeigt einen Ausschnitt aus der Objektseite, nicht der Instanzenseite.
