  4. neu installierter ioBroker über Browser nicht erreichbar
browserjs controller update
62 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • C C3PO
    @Thomas-Braun
     apt update
    Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
    Get:3 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Err:3 https://dl.yarnpkg.com/debian stable InRelease
      The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Rest kommt gleich, muss ich nochmal ausführen, hatte Putty aus versehen geschlossen.
    C3PO
    @C3PO
    apt dist-upgrade
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    • C C3PO
      @C3PO
      apt dist-upgrade
      @C3PO
      cd /opt/iobroker
      ls -la
      LoxBerry nutzt offenbar yarn als JS-Paketmanager, iobroker setzt auf node.
      Kann auch von der Seite her zu Problemen kommen. So wie die drauf sind installieren die Module global.
      Ich würde fast beahupten, es wäre klüger beide Systeme auf getrennten Maschinenen zu fahren.
      C 1 Antwort Letzte Antwort
        @C3PO
        cd /opt/iobroker
        ls -la
        C3PO
        @Thomas-Braun
        ls -la
        total 156
        drwx------  10 root root  4096 May 15 22:22 .
        drwxr-xr-x  21 root root  4096 May 15 22:35 ..
        -rw-------   1 root root  1311 May 15 22:35 .bash_history
        -rw-r--r--   1 root root   684 May 15 21:22 .bashrc
        drwxr-xr-x   3 root root  4096 May 15 20:40 .cache
        drwx------   3 root root  4096 May 15 20:26 .config
        drwx------   3 root root  4096 May 15 15:47 .gnupg
        -rwxr-xr--   1 root root    93 May 15 22:22 iob
        drwxr-xr-x   2 root root  4096 May 15 20:41 .iobroker
        -rwxr-xr--   1 root root    93 May 15 22:22 iobroker
        drwxr-xr-x   3 root root  4096 May 15 22:22 iobroker-data
        drwxr-xr-x   2 root root  4096 May 15 22:22 log
        drwxr-xr-x 243 root root 12288 May 15 22:22 node_modules
        drwxr-xr-x   5 root root  4096 May 15 22:22 .npm
        -rw-------   1 root root    36 May 15 20:37 .npmrc
        -rw-r--r--   1 root root 74419 May 15 22:22 package-lock.json
        -rw-r--r--   1 root root   148 Jul 28  2017 .profile
        -rw-r--r--   1 root root  5738 May 15 22:22 reinstall.js
        • C C3PO
          @Thomas-Braun
          ls -la
          total 156
          C3PO
          @C3PO
          und Danke schon mal für deine Zeit
          • C C3PO
            @C3PO
            @C3PO
              @C3PO
              C3PO
              schrieb am zuletzt editiert von C3PO
              @Thomas-Braun
              library: loaded
              Library version=2020-04-12
                  Welcome to the ioBroker installation fixer!
                  Script version: 2020-04-12
                  Installing prerequisites (1/3)
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/3)
              Created /etc/sudoers.d/iobroker
                  Checking autostart (3/3)
              Enabling autostart...
              Autostart enabled!
              same :-(
              iobroker status
              Socket.io Server detected. Please update to js-controller 2.0 or higher!
              No iobroker host is running.
              Objects type: file
              States  type: file
              • C C3PO
                @Thomas-Braun
                library: loaded
                Installed gcc-c++
                Autostart enabled!
                same :-(
                iobroker status
                Objects type: file
                States  type: file
                @C3PO
                curl -sS https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                  @C3PO
                  C3PO
                  @Thomas-Braun
                  curl -sS https://dl-yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                  curl: (6) Could not resolve host: dl-yarnpkg.com
                  gpg: no valid OpenPGP data found.
                  • C C3PO
                    @Thomas-Braun
                    @C3PO
                    Okay, dann ist der key für yarnpkg halt nicht signiert... Ist auch eigentlich die Baustelle von LoxBerry...
                    curl -sL https://iobroker.net/install.sh | bash -
                    • C C3PO
                      @Thomas-Braun
                      @C3PO
                        @C3PO
                        C3PO
                        @Thomas-Braun
                        library: loaded
                            Welcome to the ioBroker installer!
                            Installer version: 2020-04-12
                            Installing prerequisites (1/4)
                        Hit:1 https://deb.nodesource.com/node_12.x buster InRelease
                        Get:2 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
                        Hit:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
                        Err:2 https://dl.yarnpkg.com/debian stable InRelease
                        Changing npm registry to https://registry.npmjs.org
                        Installed gcc-c++
                            Creating ioBroker user and directory (2/4)
                        Directory /opt/iobroker created
                            Installing ioBroker (3/4)
                            Finalizing installation (4/4)
                        Autostart enabled!
                            ioBroker was installed successfully
                            Open http://xxx.xxx.xxx.xxx:8081 in a browser and start configuring!
                          @C3PO
                          C3PO
                          @Thomas-Braun
                          curl -sS https://dl.yarnpkg.com/debia/pubkey.gpg | sudo apt-key add -
                          • C C3PO
                            @Thomas-Braun
                            @C3PO
                            Da fehlt dir ein 'n'. Kopier die Befehle doch rein.
                              @C3PO
                              C3PO
                              @Thomas-Braun
                              OK
                              • C C3PO
                                @Thomas-Braun
                                OK
                                @C3PO Jetzt sollte die Meldung von apt auch weg sein.
                                apt update && apt upgrade
                                  C3PO
                                  @Thomas-Braun
                                  done
                                  Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                  The following packages will be upgraded:
                                    yarn
                                  1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  Need to get 891 kB of archives.
                                  After this operation, 8,192 B of additional disk space will be used.
                                  Do you want to continue? [Y/n] Y
                                  Get:1 https://dl.yarnpkg.com/debian stable/main armhf yarn all 1.22.4-1 [891 kB]
                                  Fetched 891 kB in 0s (2,805 kB/s)
                                  (Reading database ... 83280 files and directories currently installed.)
                                  Preparing to unpack .../archives/yarn_1.22.4-1_all.deb ...
                                  Unpacking yarn (1.22.4-1) over (1.19.1-1) ...
                                  Setting up yarn (1.22.4-1) ...
                                  • C C3PO
                                    @Thomas-Braun
                                    done
                                      yarn
                                    @C3PO Siehste, jetzt funktioniert das yarn-Repo auch wieder.
                                    iobroker version
                                    iobroker start
                                    whoami
                                    sudo -u iobroker whoami
                                    ls -la /etc/sudoers.d/
                                      iobroker version
                                      iobroker start
                                      whoami
                                      C3PO
                                      @Thomas-Braun
                                      muss ich wohl wieder als root machen
                                      loxberry@loxberry:~ $ iobroker version
                                      2.2.9
                                      loxberry@loxberry:~ $ iobroker start
                                      loxberry@loxberry:~ $ whoami
                                      loxberry
                                      loxberry@loxberry:~ $ sudo -u iobroker whoami
                                      [sudo] password for loxberry:
                                      Sorry, user loxberry is not allowed to execute '/usr/bin/whoami' as iobroker on loxberry.
                                      Thomas BraunT C 2 Antworten Letzte Antwort
                                      • C C3PO
                                        @Thomas-Braun
                                        2.2.9
                                        loxberry
                                        @C3PO
                                        Als root
                                        apt install sudo
                                        • C C3PO
                                          @Thomas-Braun
                                          2.2.9
                                          loxberry
                                          C3PO
                                          @C3PO
                                          root@loxberry:~# whoami
                                          root
                                          root@loxberry:~# sudo -u iobroker whoami
                                          iobroker
                                          root@loxberry:~# ls -la /etc/sudoers.d/
                                          total 28
                                          dr-xr-xr-x  2 root     root     4096 May 15 23:17 .
                                          drwxr-xr-x 21 loxberry loxberry 4096 Sep 24  2019 ..
                                          -r--r-----  1 root     root     1145 May 15 23:17 iobroker
                                          -rw-rw-r--  1 root     root     1684 Oct 25  2019 lbdefaults
                                          -rw-r--r--  1 root     root      586 May 15 15:54 mqttgateway
                                          -r--r-----  1 root     root      958 Apr  1  2018 README
                                          -rw-r--r--  1 root     root      158 May 15 15:59 weather4lox
