  4. neu installierter ioBroker über Browser nicht erreichbar
browserjs controller update
62 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • C C3PO
    @Thomas-Braun
    curl -sS https://dl-yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
    curl: (6) Could not resolve host: dl-yarnpkg.com
    gpg: no valid OpenPGP data found.
    @C3PO
    curl -sS https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
    C 1 Antwort Letzte Antwort
      @C3PO
      Okay, dann ist der key für yarnpkg halt nicht signiert... Ist auch eigentlich die Baustelle von LoxBerry...
      curl -sL https://iobroker.net/install.sh | bash -
      C3PO
      @Thomas-Braun
      library: loaded
      Library version=2020-04-12
          Welcome to the ioBroker installer!
          Installer version: 2020-04-12
          Installing prerequisites (1/4)
      Hit:1 https://deb.nodesource.com/node_12.x buster InRelease
      Get:2 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
      Err:2 https://dl.yarnpkg.com/debian stable InRelease
        The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      Reading package lists... Done
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Changing npm registry to https://registry.npmjs.org
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
          ioBroker was installed successfully
          Open http://xxx.xxx.xxx.xxx:8081 in a browser and start configuring!
        @C3PO
        C3PO
        schrieb am zuletzt editiert von C3PO
        @Thomas-Braun
        curl -sS https://dl.yarnpkg.com/debia/pubkey.gpg | sudo apt-key add -
        • C C3PO
          @Thomas-Braun
          @C3PO
          Da fehlt dir ein 'n'. Kopier die Befehle doch rein.
            @C3PO
            C3PO
            @Thomas-Braun
            OK
            • C C3PO
              @Thomas-Braun
              OK
              @C3PO Jetzt sollte die Meldung von apt auch weg sein.
              apt update && apt upgrade
                C3PO
                @Thomas-Braun
                done
                Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
                Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                Building dependency tree
                1 package can be upgraded. Run 'apt list --upgradable' to see it.
                Calculating upgrade... Done
                The following packages will be upgraded:
                  yarn
                1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 891 kB of archives.
                After this operation, 8,192 B of additional disk space will be used.
                Do you want to continue? [Y/n] Y
                Get:1 https://dl.yarnpkg.com/debian stable/main armhf yarn all 1.22.4-1 [891 kB]
                Fetched 891 kB in 0s (2,805 kB/s)
                (Reading database ... 83280 files and directories currently installed.)
                Preparing to unpack .../archives/yarn_1.22.4-1_all.deb ...
                Unpacking yarn (1.22.4-1) over (1.19.1-1) ...
                Setting up yarn (1.22.4-1) ...
                • C C3PO
                  @Thomas-Braun
                  done
                    yarn
                  @C3PO Siehste, jetzt funktioniert das yarn-Repo auch wieder.
                  iobroker version
                  iobroker start
                  whoami
                  sudo -u iobroker whoami
                  ls -la /etc/sudoers.d/
                    iobroker version
                    iobroker start
                    whoami
                    C3PO
                    @Thomas-Braun
                    muss ich wohl wieder als root machen
                    loxberry@loxberry:~ $ iobroker version
                    2.2.9
                    loxberry@loxberry:~ $ iobroker start
                    loxberry@loxberry:~ $ whoami
                    loxberry
                    loxberry@loxberry:~ $ sudo -u iobroker whoami
                    [sudo] password for loxberry:
                    Sorry, user loxberry is not allowed to execute '/usr/bin/whoami' as iobroker on loxberry.
                    Thomas BraunT C 2 Antworten Letzte Antwort
                    • C C3PO
                      @Thomas-Braun
                      2.2.9
                      loxberry
                      @C3PO
                      Als root
                      apt install sudo
                      • C C3PO
                        @Thomas-Braun
                        2.2.9
                        loxberry
                        C3PO
                        @C3PO
                        root@loxberry:~# whoami
                        root
                        root@loxberry:~# sudo -u iobroker whoami
                        iobroker
                        root@loxberry:~# ls -la /etc/sudoers.d/
                        total 28
                        dr-xr-xr-x  2 root     root     4096 May 15 23:17 .
                        drwxr-xr-x 21 loxberry loxberry 4096 Sep 24  2019 ..
                        -r--r-----  1 root     root     1145 May 15 23:17 iobroker
                        -rw-rw-r--  1 root     root     1684 Oct 25  2019 lbdefaults
                        -rw-r--r--  1 root     root      586 May 15 15:54 mqttgateway
                        -r--r-----  1 root     root      958 Apr  1  2018 README
                        -rw-r--r--  1 root     root      158 May 15 15:59 weather4lox
                          @C3PO
                          Als root
                          apt install sudo
                          C3PO
                          @Thomas-Braun
                          apt install sudo
                          sudo is already the newest version (1.8.27-1+deb10u2).
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          root@loxberry:~#
                          hatte ich schon mal probiert, sudo geht trotzdem nicht
                          • C C3PO
                            @C3PO
                            root
                            iobroker
                            total 28
                            @C3PO
                            usermod -aG sudo loxberry
                              @C3PO
                              C3PO
                              @Thomas-Braun
                              root@loxberry:~# usermod -aG sudo loxberry
                              root@loxberry:~# exit
                              logout
                              loxberry@loxberry:~ $ sudo nodejs -v
                              Sorry, user loxberry is not allowed to execute '/usr/bin/nodejs -v' as root on loxberry.
                              • C C3PO
                                @Thomas-Braun
                                logout
                                @C3PO
                                Als loxberry
                                groups
                                  @C3PO
                                  Als loxberry
                                  groups
                                  C3PO
                                  @Thomas-Braun
                                  loxberry@loxberry:~ $ groups
                                  loxberry tty dialout sudo audio www-data gpio
                                  • C C3PO
                                    @Thomas-Braun
                                    @C3PO Dann klemmen die den user noch irgendwo anders ab.
                                    Soll mir jetzt auch egal sein...
                                    iobroker status
                                      iobroker status
                                      C3PO
                                      @Thomas-Braun
                                       iobroker status
                                      Socket.io Server detected. Please update to js-controller 2.0 or higher!
                                      No iobroker host is running.
                                      Objects type: file
                                      States  type: file
                                      • C C3PO
                                        @Thomas-Braun
                                         iobroker status
                                        Objects type: file
                                        States  type: file
                                        @C3PO
                                        Keine Ahnung wie die 'Kollegen' von LoxBerry da im System rumfuhrwerken.
                                        Sieht auf jedenfalls für mich äußerst schräg aus.
                                        In /opt/iobroker
                                        npm install iobroker.js-controller
                                          @C3PO
                                          In /opt/iobroker
                                          C3PO
                                          @Thomas-Braun
                                          root@loxberry:/opt/iobroker# npm install iobroker.js-controller
                                          > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                          > node lib/preinstallCheck.js
                                          NPM version: 6.14.4
                                          > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                                          > node iobroker.js setup first
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          + iobroker.js-controller@2.2.9
                                          updated 1 package in 32.054s
                                          3 packages are looking for funding
                                            run `npm fund` for details
