  4. neu installierter ioBroker über Browser nicht erreichbar
browserjs controller update
62 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • C C3PO
    @C3PO
    und Danke schon mal für deine Zeit
    @C3PO
    curl -sL https://iobroker.net/fix.sh | bash -
    C 1 Antwort Letzte Antwort
      @C3PO
      C3PO
      schrieb am zuletzt editiert von C3PO
      @Thomas-Braun
      library: loaded
      Library version=2020-04-12
          Welcome to the ioBroker installation fixer!
          Script version: 2020-04-12
          Installing prerequisites (1/3)
      Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
      Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
      Get:3 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Err:3 https://dl.yarnpkg.com/debian stable InRelease
        The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      Reading package lists... Done
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      same :-(
      iobroker status
      Socket.io Server detected. Please update to js-controller 2.0 or higher!
      No iobroker host is running.
      Objects type: file
      States  type: file
      • C C3PO
        @Thomas-Braun
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        same :-(
        iobroker status
        Objects type: file
        States  type: file
        @C3PO
        curl -sS https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
          @C3PO
          C3PO
          @Thomas-Braun
          curl -sS https://dl-yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
          curl: (6) Could not resolve host: dl-yarnpkg.com
          gpg: no valid OpenPGP data found.
          • C C3PO
            @Thomas-Braun
            @C3PO
            Okay, dann ist der key für yarnpkg halt nicht signiert... Ist auch eigentlich die Baustelle von LoxBerry...
            curl -sL https://iobroker.net/install.sh | bash -
            • C C3PO
              @Thomas-Braun
              @C3PO
                @C3PO
                C3PO
                @Thomas-Braun
                library: loaded
                    Welcome to the ioBroker installer!
                    Installer version: 2020-04-12
                    Installing prerequisites (1/4)
                Hit:1 https://deb.nodesource.com/node_12.x buster InRelease
                Get:2 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
                Hit:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease
                Err:2 https://dl.yarnpkg.com/debian stable InRelease
                Changing npm registry to https://registry.npmjs.org
                Installed gcc-c++
                    Creating ioBroker user and directory (2/4)
                Directory /opt/iobroker created
                    Installing ioBroker (3/4)
                    Finalizing installation (4/4)
                Autostart enabled!
                    ioBroker was installed successfully
                    Open http://xxx.xxx.xxx.xxx:8081 in a browser and start configuring!
                  @C3PO
                  C3PO
                  @Thomas-Braun
                  curl -sS https://dl.yarnpkg.com/debia/pubkey.gpg | sudo apt-key add -
                  • C C3PO
                    @Thomas-Braun
                    @C3PO
                    Da fehlt dir ein 'n'. Kopier die Befehle doch rein.
                      @C3PO
                      C3PO
                      @Thomas-Braun
                      OK
                      • C C3PO
                        @Thomas-Braun
                        OK
                        @C3PO Jetzt sollte die Meldung von apt auch weg sein.
                        apt update && apt upgrade
                          C3PO
                          @Thomas-Braun
                          done
                          Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                          Building dependency tree
                          1 package can be upgraded. Run 'apt list --upgradable' to see it.
                          Calculating upgrade... Done
                          The following packages will be upgraded:
                            yarn
                          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 891 kB of archives.
                          After this operation, 8,192 B of additional disk space will be used.
                          Do you want to continue? [Y/n] Y
                          Get:1 https://dl.yarnpkg.com/debian stable/main armhf yarn all 1.22.4-1 [891 kB]
                          Fetched 891 kB in 0s (2,805 kB/s)
                          (Reading database ... 83280 files and directories currently installed.)
                          Preparing to unpack .../archives/yarn_1.22.4-1_all.deb ...
                          Unpacking yarn (1.22.4-1) over (1.19.1-1) ...
                          Setting up yarn (1.22.4-1) ...
                          • C C3PO
                            @Thomas-Braun
                            done
                              yarn
                            @C3PO Siehste, jetzt funktioniert das yarn-Repo auch wieder.
                            iobroker version
                            iobroker start
                            whoami
                            sudo -u iobroker whoami
                            ls -la /etc/sudoers.d/
                              iobroker version
                              iobroker start
                              whoami
                              C3PO
                              @Thomas-Braun
                              muss ich wohl wieder als root machen
                              loxberry@loxberry:~ $ iobroker version
                              2.2.9
                              loxberry@loxberry:~ $ iobroker start
                              loxberry@loxberry:~ $ whoami
                              loxberry
                              loxberry@loxberry:~ $ sudo -u iobroker whoami
                              [sudo] password for loxberry:
                              Sorry, user loxberry is not allowed to execute '/usr/bin/whoami' as iobroker on loxberry.
                              Thomas BraunT C 2 Antworten Letzte Antwort
                              • C C3PO
                                @Thomas-Braun
                                2.2.9
                                loxberry
                                @C3PO
                                Als root
                                apt install sudo
                                • C C3PO
                                  @Thomas-Braun
                                  2.2.9
                                  loxberry
                                  C3PO
                                  @C3PO
                                  root@loxberry:~# whoami
                                  root
                                  root@loxberry:~# sudo -u iobroker whoami
                                  iobroker
                                  root@loxberry:~# ls -la /etc/sudoers.d/
                                  total 28
                                  dr-xr-xr-x  2 root     root     4096 May 15 23:17 .
                                  drwxr-xr-x 21 loxberry loxberry 4096 Sep 24  2019 ..
                                  -r--r-----  1 root     root     1145 May 15 23:17 iobroker
                                  -rw-rw-r--  1 root     root     1684 Oct 25  2019 lbdefaults
                                  -rw-r--r--  1 root     root      586 May 15 15:54 mqttgateway
                                  -r--r-----  1 root     root      958 Apr  1  2018 README
                                  -rw-r--r--  1 root     root      158 May 15 15:59 weather4lox
                                    @C3PO
                                    Als root
                                    apt install sudo
                                    C3PO
                                    @Thomas-Braun
                                    apt install sudo
                                    sudo is already the newest version (1.8.27-1+deb10u2).
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    root@loxberry:~#
                                    hatte ich schon mal probiert, sudo geht trotzdem nicht
                                    • C C3PO
                                      @C3PO
                                      root
                                      iobroker
                                      total 28
                                      @C3PO
                                      usermod -aG sudo loxberry
                                        @C3PO
                                        C3PO
                                        @Thomas-Braun
                                        root@loxberry:~# usermod -aG sudo loxberry
                                        root@loxberry:~# exit
                                        logout
                                        loxberry@loxberry:~ $ sudo nodejs -v
                                        Sorry, user loxberry is not allowed to execute '/usr/bin/nodejs -v' as root on loxberry.
                                        • C C3PO
                                          @Thomas-Braun
                                          logout
                                          @C3PO
                                          Als loxberry
                                          groups
