  4. Adapter lassen sich nicht mehr updaten ?
updateerrorlog
66 Beiträge 5 Kommentatoren 8.0k Aufrufe 5 Beobachtet
  • tr1plxT tr1plx
    @Thomas-Braun
    Konsolenoutput ist zu viel für einen Post. Aber Quasi die gleichen Meldungen wie bekannt. Hier ein Auszug:
    Adapter "tinker"         is not installed.
    Adapter "tino"           is not installed.
    Adapter "tinyrx4"        is not installed.
    Update tr-064 from @4.0.1 to @4.0.3
    NPM version: 6.14.5
    npm install iobroker.tr-064@4.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,
                     from ../../../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
    In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,
                     from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’
                     Local<String> ToString(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
       v8::Local<v8::Object> options = info[1]->ToObject();
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’
                     Local<Object> ToObject(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    ../../../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
                     bool Set(Local<Value> key, Local<Value> value));
    ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                        tzset
    In file included from ../../../../nan/nan.h:54,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
    make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.0-9-amd64
    gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.wm-bus/node_modules/serialport
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-13T20_16_09_878Z-debug.log
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
    Adapter "tr-064" updated
    Adapter "tradfri"        is not installed.
    Adapter "trashschedule"  is not installed.
    Adapter "tunnelbroker-endpoint-updater" is not installed.
    Adapter "tuya"           is not installed.
    Adapter "tvspielfilm"    is not installed.
    Adapter "unifi"          is up to date.
    Adapter "unifi-protect"  is not installed.
    Adapter "upnp"           is up to date.
    Adapter "vaillant"       is not installed.
    Adapter "valloxmv"       is not installed.
    Adapter "vcard"          is not installed.
    Adapter "vedirect"       is not installed.
    Adapter "velux"          is not installed.
    Adapter "viessmann"      is not installed.
    Adapter "viessmannapi"   is not installed.
    Adapter "virtualpowermeter" is not installed.
    Adapter "vis"            is up to date.
    Adapter "vis-bars"       is up to date.
    Adapter "vis-canvas-gauges" is up to date.
    Adapter "vis-colorpicker" is up to date.
    Adapter "vis-fancyswitch" is up to date.
    Adapter "vis-google-fonts" is up to date.
    Adapter "vis-history"    is up to date.
    Adapter "vis-hqwidgets"  is up to date.
    Adapter "vis-inventwo"   is not installed.
    Adapter "vis-jqui-mfd"   is up to date.
    Adapter "vis-justgage"   is up to date.
    Adapter "vis-keyboard"   is up to date.
    Adapter "vis-lcars"      is up to date.
    Adapter "vis-map"        is up to date.
    Adapter "vis-material"   is up to date.
    Adapter "vis-material-webfont" is not installed.
    Adapter "vis-materialdesign" is up to date.
    Adapter "vis-metro"      is up to date.
    Adapter "vis-players"    is up to date.
    Adapter "vis-plumb"      is up to date.
    Adapter "vis-rgraph"     is up to date.
    Adapter "vis-timeandweather" is up to date.
    Adapter "vis-weather"    is up to date.
    Adapter "vodafone-speedtest" is not installed.
    Adapter "volvo"          is not installed.
    Adapter "vr200"          is not installed.
    Adapter "vw-connect"     is not installed.
    Adapter "weatherunderground" is not installed.
    Adapter "web"            is up to date.
    Adapter "web-speedy"     is up to date.
    Adapter "weishaupt-wem"  is not installed.
    Adapter "wiffi-wz"       is not installed.
    Adapter "wifilight"      is not installed.
    Adapter "windows-control" is not installed.
    Adapter "wlanthermo-nano" is not installed.
    Adapter "wled"           is not installed.
    Adapter "wm-bus"         is not installed.
    Adapter "wolf"           is not installed.
    Adapter "worx"           is not installed.
    Adapter "xbox"           is not installed.
    Adapter "xs1"            is not installed.
    Adapter "yahka"          is not installed.
    Adapter "yamaha"         is up to date.
    Adapter "yeelight-2"     is not installed.
    Adapter "youtube"        is not installed.
    Adapter "yr"             is not installed.
    Adapter "zigbee"         is not installed.
    Adapter "zoneminder"     is not installed.
    Adapter "zont"           is not installed.
    Adapter "zwave"          is not installed.
    Adapter "zwave2"         is not installed.
    harrymH Offline
    harrymH Offline
    harrym
    schrieb am zuletzt editiert von harrym
    #41
    @tr1plx ja ... der will was mim serialport .... sein aber alles nur warnings bzw. infos ....
    lösch mal den adapter .... ist ja schnell wieder eingerichtet ;)
    serialport fragt nach node v8 ab ..... ?????
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    tr1plxT 2 Antworten Letzte Antwort
    • harrymH harrym
      tr1plxT Offline
      tr1plxT Offline
      tr1plx
      #42
      @harrym said in Adapter lassen sich nicht mehr updaten ?:
      ok, aber ich glaube das bringt nichts. Denn als Update wird auch Philips Hue Bridge angeboten, ich hatte den mal installiert, es gibt aber keine Instanz. Wie also löschen wenn nicht da?
      harrymH 2 Antworten Letzte Antwort
      • tr1plxT tr1plx
        harrymH Offline
        harrymH Offline
        harrym
        #43
        @tr1plx hue aus git oder offiziell?
        tr1plxT 1 Antwort Letzte Antwort
        • harrymH harrym
          tr1plxT Offline
          tr1plxT Offline
          tr1plx
          #44
          Was ist denn serialport? Ist damit wirklich eine serielle Schnittstelle gemeint?
          harrymH 1 Antwort Letzte Antwort
          • tr1plxT tr1plx
            harrymH Offline
            harrymH Offline
            harrym
            #45
            @tr1plx ja
            • harrymH harrym
              tr1plxT Offline
              tr1plxT Offline
              tr1plx
              #46
              @harrym
              alles offiziel. aus dem "latest" release. Nix über Git...
              um den Seriellen Schnittstellen Fehler mal weg zu haben. Soll ich der VM mal eine spendieren?
              • tr1plxT tr1plx
                harrymH Offline
                harrymH Offline
                harrym
                #47
                @tr1plx MOMENT! da gabs nen thread im Forum ..... wie man das beheben kann .... "leichen" von adaptern beseitigen ......
                • harrymH harrym
                  Thomas BraunT Offline
                  #48
                  @harrym
                  iobroker upload VERWAISTER_ADAPTER
                  war das glaube ich.
                    @harrym
                    war das glaube ich.
                    harrymH Offline
                    harrymH Offline
                    harrym
                    #49
                    @Thomas-Braun ne .... da gings um json files .....
                    • harrymH harrym
                      #50
                      @harrym
                      Nee, mit V8 ist die Javascriptengine gemeint.
                      • harrymH harrym
                        crunchipC Offline
                        crunchipC Offline
                        #51
                        @harrym so viel ich weiss, war das in /opt/iobroker/iobroker-data/files/, da müssten die "Überbleibsel" zu finden sein
                          harrymH Offline
                          harrymH Offline
                          harrym
                          #52
                          @crunchip und darin dann verwaiste jsons .... soweit ich das noch im kopf habe .....
                          • tr1plxT tr1plx
                            @harrym
                            #53
                            @tr1plx
                            iobroker list adapters
                              @tr1plx
                              tr1plxT Offline
                              tr1plxT Offline
                              tr1plx
                              #54
                              @Thomas-Braun said in Adapter lassen sich nicht mehr updaten ?:
                              Also um die "Problemkinder" geht es ja. von "DWD" habe ich auch eine Instanz - diese habe ich deinstalliert und neuinstalliert, da man am wenigsten konfigurieren muss. -> kein Erfolg, nach kurzer Zeit wieder im Update drin.
                              max@iobroker:~$ iobroker list adapters
                              system.adapter.admin                   : admin          - v4.1.1
                              system.adapter.alexa2                  : alexa2         - v3.1.2
                              system.adapter.backitup                : backitup       - v1.5.7
                              system.adapter.ble                     : ble            - v0.11.6
                              system.adapter.cloud                   : cloud          - v3.0.3
                              system.adapter.daswetter               : daswetter      - v3.0.1
                              system.adapter.digitalstrom            : digitalstrom   - v1.0.2
                              system.adapter.discovery               : discovery      - v2.3.5
                              system.adapter.dwd                     : dwd            - v2.4.9
                              system.adapter.email                   : email          - v1.0.6
                              system.adapter.enigma2                 : enigma2        - v1.2.9
                              system.adapter.feiertage               : feiertage      - v1.0.19
                              system.adapter.flot                    : flot           - v1.9.2
                              system.adapter.fritzdect               : fritzdect      - v0.3.2
                              system.adapter.fullybrowser            : fullybrowser   - v1.0.3
                              system.adapter.harmony                 : harmony        - v1.2.2
                              system.adapter.history                 : history        - v1.9.6
                              system.adapter.hm-rega                 : hm-rega        - v2.6.7
                              system.adapter.hm-rpc                  : hm-rpc         - v1.14.2
                              system.adapter.homeconnect             : homeconnect    - v0.0.28
                              system.adapter.hue                     : hue            - v3.2.9
                              system.adapter.ical                    : ical           - v1.7.0
                              system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
                              system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
                              system.adapter.icons-material-png      : icons-material-png - v0.1.0
                              system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                              system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                              system.adapter.info                    : info           - v1.7.2
                              system.adapter.innogy-smarthome        : innogy-smarthome - v0.3.4
                              system.adapter.javascript              : javascript     - v4.5.1
                              system.adapter.nut                     : nut            - v1.1.3
                              system.adapter.pi-hole                 : pi-hole        - v1.2.3
                              system.adapter.ping                    : ping           - v1.4.7
                              system.adapter.plex                    : plex           - v0.8.11
                              system.adapter.pollenflug              : pollenflug     - v1.0.6
                              system.adapter.pushover                : pushover       - v2.0.2
                              system.adapter.radar2                  : radar2         - v1.2.5
                              system.adapter.roomba                  : roomba         - v1.1.1
                              system.adapter.rpi2                    : rpi2           - v1.2.0
                              system.adapter.smartmeter              : smartmeter     - v3.1.1
                              system.adapter.snmp                    : snmp           - v0.5.0
                              system.adapter.socketio                : socketio       - v3.0.7
                              system.adapter.sql                     : sql            - v1.12.5
                              system.adapter.synology                : synology       - v0.1.10
                              system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
                              system.adapter.tr-064                  : tr-064         - v4.0.3
                              system.adapter.unifi                   : unifi          - v0.5.0
                              system.adapter.upnp                    : upnp           - v1.0.16
                              system.adapter.vis                     : vis            - v1.2.6
                              system.adapter.vis-bars                : vis-bars       - v0.1.4
                              system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                              system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                              system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                              system.adapter.vis-google-fonts        : vis-google-fonts - v0.1.0
                              system.adapter.vis-history             : vis-history    - v1.0.0
                              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                              system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                              system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
                              system.adapter.vis-lcars               : vis-lcars      - v1.0.4
                              system.adapter.vis-map                 : vis-map        - v1.0.4
                              system.adapter.vis-material            : vis-material   - v0.1.3
                              system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.6
                              system.adapter.vis-metro               : vis-metro      - v1.1.2
                              system.adapter.vis-players             : vis-players    - v0.1.6
                              system.adapter.vis-plumb               : vis-plumb      - v1.0.2
                              system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                              system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                              system.adapter.vis-weather             : vis-weather    - v2.5.2
                              system.adapter.vuplus                  : vuplus         - v0.1.1
                              system.adapter.weatherunderground      : weatherunderground - v3.2.0
                              system.adapter.web                     : web            - v3.0.8
                              system.adapter.web-speedy              : web-speedy     - v0.2.0
                              system.adapter.yamaha                  : yamaha         - v0.3.19
                              system.adapter.deconz                  : deconz         - v1.3.7
                              system.adapter.cul                     : cul            - v1.2.1
                              system.adapter.fhem                    : fhem           - v1.4.1
                              system.adapter.wm-bus                  : wm-bus         - v0.3.1
                              system.adapter.wmbus                   : wmbus          - v0.5.2
                              system.adapter.iot                     : iot            - v1.4.18
                              system.adapter.scenes                  : scenes         - v1.1.0
                              system.adapter.simple-api              : simple-api     - v2.4.5
                              system.adapter.broadlink2              : broadlink2     - v2.0.3
                              system.adapter.sonoff                  : sonoff         - v2.3.3
                              system.adapter.habpanel                : habpanel       - v0.4.1
                              • harrymH harrym
                                crunchipC Offline
                                crunchipC Offline
                                #55
                                @harrym da müsste dann eigentlich ganze Ordner zu finden sein, wenn Reste übrig bleiben beim Instanz/Adapter löschen und das nicht sauber deinstalliert wurde.
                                Oder bei "Älteren" Adapter, bei denen eine "Neue" Version herausgebracht wurde( tr-64 als Beispiel), müsste ein ganzer Ordner vorliegen, nicht nur eine Json
                                • tr1plxT Offline
                                  tr1plxT Offline
                                  tr1plx
                                  #56
                                  Wäre es vielleicht am sinnvollsten eine frische Debian-VM aufzusetzen und iobroker aus dem Backup wiederherzustellen?
                                  Langsam glaube ich, dass diese Installation "verpfuscht" ist.
                                  Wichtig wäre mir halt, dass alle Adaptereinstellungen erhalten bleiben. Das ist doch bei einem Backup wiederherstellen so?
                                  • tr1plxT tr1plx
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    #57
                                    @tr1plx wäre sinnvoll. und ja ... eigentlich sollte eine rücksicherung via backitup stressfrei funktionieren.
                                    • harrymH harrym
                                      tr1plxT Offline
                                      tr1plxT Offline
                                      tr1plx
                                      #58
                                      @harrym
                                      Habe ich noch nie gemacht, aber wenn ich die VM parallel aufziehe und die alte erst mal zur Sicherheit behalte, wird das vermutlich der sauberste Weg sein. Ich habe nun schon zwei Abende in die fehlersuche gesteckt und ich denke die neue VM ist am saubersten und macht nun am meisten Sinn. Hoffen wir, dass der Fehler nicht aus dem Backup wiederkommt :-)
                                      Ich danke euch schon mal ganz herzlich für eure Hilfe. Hab einiges gelernt und melde mich wieder wenn die neue VM aufgesetzt ist.
                                      harrymH Thomas BraunT 2 Antworten Letzte Antwort
                                      • tr1plxT tr1plx
                                        @harrym
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        #59
                                        @tr1plx ja klar! setzt ne neue VM auf .... und gerne geholfen ;)
                                        • tr1plxT tr1plx
                                          @harrym
                                          #60
                                          @tr1plx
                                          Aber vermeide den 'root'...
