  5. Mit Blockly zwei Werte addieren und neu in DB schreiben
    6.1k
157 Beiträge 14 Kommentatoren 44.7k Aufrufe 13 Beobachtet
  • G guergen
    @goetschhofer Ich sehe da was anderes: ba189493-64ba-4573-8b17-ffe3523cc2bf-grafik.png
    Hier ist das Script:
    <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="**{}]7ei59`(N*|ou37v" x="-137" y="-1512">
      <field name="SCHEDULE">*/2 * * * * *</field>
      <statement name="STATEMENT">
        <block type="variables_set" id="04CEwCi/(d1*/(^%z-|X">
          <field name="VAR" id="+yyUBft,kRI{oX,sCC0E">summe</field>
          <value name="VALUE">
            <block type="math_arithmetic" id="O)XOn2w+2MEYKh+_i^T6" inline="false">
              <field name="OP">ADD</field>
              <value name="A">
                <shadow type="math_number" id="Vv3iW}5G,a%,hF?iO4dq">
                  <field name="NUM">1</field>
                </shadow>
                <block type="get_value" id="1MV.[J[?Vxe;s2g@VT9`">
                  <field name="OID">0_userdata.0.AMIS.170</field>
                </block>
              </value>
              <value name="B">
                <shadow type="math_number" id="aNx(u#^_(su!4Pyla9C!">
                </shadow>
                <block type="get_value" id="0W[V_Lxj$oW6%y|FyPon">
                  <field name="OID">0_userdata.0.AMIS.270</field>
                </block>
              </value>
            </block>
          </value>
          <next>
            <block type="controls_if" id="oFc2#are5W}sv^Kg9mbu">
              <value name="IF0">
                <block type="logic_compare" id="0]%B[Qg$Ymx_dz!muAe{">
                  <field name="OP">LT</field>
                  <value name="A">
                    <block type="variables_get" id="Rxg$Aa9AEbMX(jekLw#W">
                    </block>
                  </value>
                  <value name="B">
                    <block type="math_number" id="7o]@zP)1F-Tx6-lTKC/)">
                      <field name="NUM">0</field>
                    </block>
                  </value>
                </block>
              </value>
              <statement name="DO0">
                <block type="comment" id="97rKiTzh+`j-w.@+Ej}i">
                  <field name="COMMENT">negative Summe</field>
                  <next>
                    <block type="update" id="_})C8E`6PiI3|I8Wg=$9">
                        <block type="variables_get" id="a@R-S-1p@S[@|#0UwguI">
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </statement>
              <statement name="ELSE">
                <block type="comment" id="c2p=K0}J1Z!9~oFQg!G(">
                  <next>
                    <block type="update" id="+Rg3Ho,}}V7g+Rb-t;eY">
                        <block type="variables_get" id="9#m9S/jEKqqM3q`fpA^K">
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </statement>
              <next>
                <block type="update" id=",]R8%D@+}|rm/}OUVPer">
                  <field name="OID">0_userdata.0.AMIS.SUMME_170_270</field>
                    <block type="variables_get" id="QWFsuL1-Xs)gB#NnSAC?">
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </next>
        </block>
      </statement>
    </block>
    GOETSCHHOFER
    #61
    @guergen
    Danke für den Hinweis, nur soweit bin ich noch gar nicht.
    G 1 Antwort Letzte Antwort
    • G guergen
                <value name="A">
                  </shadow>
                  </block>
                </value>
                <value name="B">
                  </shadow>
                  </block>
                </value>
              </block>
            </value>
            <next>
                <value name="IF0">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                      </block>
                    </value>
                  </block>
                </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      GOETSCHHOFER
      #62
      @guergen
      Beim Importieren mit copy & paste über rechts oben-importieren, bekomme ich folgende Fehlermeldung ?
      • G GOETSCHHOFER
        @guergen
        G Online
        G Online
        guergen
        #63
        @goetschhofer Wenn ich das richtig verstehe, ist es bei Dir doch viel einfacher, die Zählerwerte (kWh) bei SA einzubinden um die Tageswerte zu erfahren. Mache ich genauso.
        Und die Summe läuft bei mir mit dem o.g. Script.
        G 2 Antworten Letzte Antwort
        • G guergen
          GOETSCHHOFER
          #64
          @guergen
          Ja, dies glaube ich auch, aber noch braucht es bis es klappt. 😕
          • G GOETSCHHOFER
            @guergen
            G Online
            G Online
            guergen
            #65
            @goetschhofer Ich kann es importieren, grade selbst getestet
            Welche Version von Java-Script hast du ? Ich bin bei 5.2.8
            • G GOETSCHHOFER
              @guergen
              G Online
              G Online
              guergen
              #66
              @goetschhofer kann ich nicht verstehen... könnte dir ja per Teamviewer helfen, muss aber jetzt leider arbeiten....
              • G guergen
                GOETSCHHOFER
                #67
                @guergen said in Mit Blockly zwei Werte addieren und neu in DB schreiben:
                Kein Problem, trotzdem danke.
                • G guergen
                  @rudolfn Das ist aber seltsam, bei mir läuft das seit März durchgehend und ohne Fehler!
                  Konvertieren brauchst Du nicht (normal), weil es ja Zahlen sind
                  RudolfN
                  #68
                  @guergen
                  Kannst Du mir noch sagen/schreiben, wie Du bei Dir die Variable "Verbrauch" angelegt hast, kann ja eigentlich nur mehr dort das Problem sein?
                  Browser habe ich schon x-mal aktualisiert!
                  Lg
                  • R RudolfN
                    @guergen
                    Lg
                    GOETSCHHOFER
                    #69
                    @guergen @dslraser
                    Da ich kein neues blockly anlegen konnte und beim Import eine Fehlermeldung hatte, habe ich das alte blockly einfach ergänzt. Funktioniert soweit, dank der Vorlage von euch.
                    Ein Problem hatte ich noch, er musste den anderen Wert dann auf null setzen, hier hatte er den alten Wert einfach stehen gelassen.
                    Hier habe ich ihm nochmals eine Funktion, aktualisiere den anderen Werte auf null, eingebaut.
                    Wie kann ich die Werte mit der Bezeichnung W (Watt) ergänzen ?
                    In den Einstellungen habe ich schon auf value.power geändert.
                    Ich denke, damit kann ich den Wert in W, in SA aktivieren und freigeben.
                    Danke nochmals für eure Hilfe.
                      <variables>
                        <variable id="5k}(y]MVDRUNbOxECkJt">summe</variable>
                      </variables>
                      <block type="schedule" id="**{}]7ei59`(N*|ou37v" x="-212" y="-1362">
                            <field name="VAR" id="5k}(y]MVDRUNbOxECkJt">summe</field>
                                <value name="A">
                                  </shadow>
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                  <block type="comment" id="4DYxTs/C!iUnSa6-`k/_">
                                    <field name="COMMENT">Positiver Saldo = BEZUG:  1.7.0 + (-)2.7.0 &gt;0</field>
                                    <next>
                                      <block type="controls_if" id="8zbXYVm0}s=QnE=v:77[">
                                        <value name="IF0">
                                          <block type="logic_compare" id="D*Fx%^xShdM9Pu;L@Ahl">
                                            <field name="OP">GT</field>
                                            <value name="A">
                                              <block type="variables_get" id="2u[OL@uB6dK%HS#@]1*j">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="math_number" id="0o._sWu/g~JgC2Y:2!R)">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="update" id="_e.hWhkcBFf:XJC+_7Tx">
                                            <field name="OID">0_userdata.0.AMIS.SUMME_170_270_+</field>
                                              <block type="variables_get" id="kUdx$9hAck0M7pw`JM.A">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="update" id="21a.`nyEyg+|qz`#Zq^%">
                                                <field name="OID">0_userdata.0.AMIS.SUMME_170_270_-</field>
                                                  <block type="math_number" id="uj$;dI3bc6[~|;qY!UaM">
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="comment" id="LmYu;egZ=y]/lUN}J%Aq">
                                            <field name="COMMENT">Negativer Saldo = EINSPEIS.:  1.7.0 + (-)2.7.0 &lt;0</field>
                                            <next>
                                              <block type="controls_if" id=";HAm$Sqa4[({BH4i;D`S">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="th+%T3f4K%/3tFBWg(xd">
                                                    <value name="A">
                                                      <block type="variables_get" id="?;j-RwSm+Vao(r]}uJyk">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="math_number" id="Jsx#h?Ttx!vT5GVP{hcU">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="update" id="3ge#`3!wvdBO$8!h)?%p">
                                                      <block type="variables_get" id="I7Wr/ggQT|l$Avqg~JQt">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="update" id="m5xv07hzh^D$h3K|;,5^">
                                                          <block type="math_number" id="C7%azoZ@V38KF+6!6sTy">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    • G GOETSCHHOFER
                      @guergen @dslraser
                        <variables>
                        </variables>
                                  <value name="A">
                                    </shadow>
                                    </block>
                                  </value>
                                  <value name="B">
                                    </shadow>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                  <next>
                                      <next>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                              <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </xml>
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      #70
                      @goetschhofer
                      Zu lang, deshalb als .zip
                      Blockly Export.zip
                      EDIT:
                      Der Haken muß drinn sein. Datenpunkte legt das Blockly an.
                      Hier stellst Du den "Ort" ein, z.B. javascript.0(1 o. 2 usw.) oder 0_userdata.0
                      Das wird dann der Pfad/Ordner
                      EDIT2: Blockly Export nochmal geändert
                      In diesem Blockly ist kein Zeitplan, kannst Du aber tauschen wenn Du willst
                      Sieht dann so aus (habe ich von Deinem Screenshot abgeschrieben)
                      • dslraserD dslraser
                        @rudolfn
                        Nimm im Javascript Adapter den Haken unten rechts raus.
                        Nicht alle Zustände beim Start abonnieren (Haken raus)
                        GOETSCHHOFER
                        #71
                        @dslraser said in Mit Blockly zwei Werte addieren und neu in DB schreiben:
                        @rudolfn
                        Wenn ich deine Einstellungen in javaskript mit meinen vergleiche, fehlen bei mir einige Hacken.
                        Sollte ich diese setzen ?
                        Vielleicht war dies der Grund warum ich das blockly von @guergen nicht importieren oder die Objekte nicht mehrmals anklicken konnte ?
                        • G GOETSCHHOFER
                          @rudolfn
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #72
                          @goetschhofer
                          ich habe hier noch editiert. https://forum.iobroker.net/post/671869
                          • G GOETSCHHOFER
                            @guergen @dslraser
                              <variables>
                              </variables>
                                        <value name="A">
                                          </shadow>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                          </block>
                                        </value>
                                        <next>
                                            <next>
                                                <value name="IF0">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                                <next>
                                                    <next>
                                                        <value name="IF0">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                              </block>
                                                            </value>
                                                            <next>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </xml>
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #73
                            @goetschhofer sagte in Mit Blockly zwei Werte addieren und neu in DB schreiben:
                            den Datenpunkt mit unit ergänzen
                              @goetschhofer
                              GOETSCHHOFER
                              schrieb am zuletzt editiert von GOETSCHHOFER
                              #74
                              @dslraser
                              1. Datenpunkte:
                                Dies war auch der Grund warum er die Datenpunkte nicht automatisch angelegt hat.
                                Ich habe dies nicht unter javaskript angelegt, sondern unter 0_userdata händisch.
                                Diese Vorangsweise habe ich von einem anderen Benutzer des AMIS-Zählers.
                              Siehst du hier ein Problem ?
                              Wenn ich jetzt alle Hacken setze, legt er wahrscheinlich nochmals alle Datenpunkte in javaskript an oder nur wenn ich ihm dies in JS wie oben gezeigt mitgebe ?
                              Für die Zukunft weiß ich, dass dies JS selbständig macht, war ja auch bei allen anderen Skripts so.
                              1. Zeitplan:
                                Ich habe schon einen Zeitplan, alle 2 Sekunden.
                              Dein neues Skript ist natürlich für mich "high level" ! 👍 😀
                              Aber dient mir vom Ablauf und Logik als Vorlage für weitere blocklies.
                              Was mir vorhin schon aufgefallen ist, dass du Logikfunktionen in blockly hast, welche ich nicht habe ?
                              Was ist hier der Grund ? Versionsabhängig ? Ich finde bei Logik nur diese mit anderen Bezeichnungen.
                              Wo finde ich dies ?
                              • G GOETSCHHOFER
                                @dslraser
                                1. Datenpunkte:
                                1. Zeitplan:
                                Wo finde ich dies ?
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #75
                                welche denn ?
                                Wo finde ich dies ?
                                da rechts in den Objekten auf den Stift klicken, dann auf das blaue + und unit auswählen, da schreibst Du Deine Einheit rein
                                paul53P G 2 Antworten Letzte Antwort
                                  welche denn ?
                                  Wo finde ich dies ?
                                  #76
                                  @dslraser sagte: da rechts in den Objekten auf den Stift klicken, dann auf das blaue +
                                  Das ist aber die "alte" Oberfläche (Admin 4)?
                                  G dslraserD 2 Antworten Letzte Antwort
                                    welche denn ?
                                    Wo finde ich dies ?
                                    GOETSCHHOFER
                                    #77
                                    @dslraser
                                    Du hast die Logikfunktion falls, mache, sonst und ich habe ähnliche Funktion:
                                    Ja, bei meinem alten Version des iobroker war dies auch so, bei der neuen Version finde ich diese einfache Möglichkeit nicht mehr ?
                                    • G GOETSCHHOFER
                                      @dslraser
                                      #78
                                      @goetschhofer sagte: Du hast die Logikfunktion falls, mache, sonst
                                      Die hast Du auch (ganz oben):
                                        GOETSCHHOFER
                                        #79
                                        @paul53 said in Mit Blockly zwei Werte addieren und neu in DB schreiben:
                                        @dslraser
                                          GOETSCHHOFER
                                          #80
                                          Diese Funktion ist eine einzelne Funktion.
