  3. Entwicklung
  4. [Major Update] UniFi Adapter v0.5.0
    6.1k
unifi
510 Beiträge 54 Kommentatoren 149.7k Aufrufe 51 Beobachtet
  • ChaotC Chaot
    @braindead Ist der Rest auch schon Testfähig?
    braindeadB Offline
    braindeadB Offline
    braindead
    #181
    @Chaot Natürlich. :-)
    • braindeadB braindead
      ChaotC Offline
      ChaotC Offline
      Chaot
      schrieb am zuletzt editiert von Chaot
      #182
      @braindead Na dann ..... Ich bin schon 24 Stunden ohne Fehlermeldung 😊
      Edit:
      Sieh an:
      host.ioBroker	2020-05-20 19:26:18.262	info	Restart adapter system.adapter.unifi.0 because enabled
      host.ioBroker	2020-05-20 19:26:18.262	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
      host.ioBroker	2020-05-20 19:26:18.262	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:347:21
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at Unifi.processClients (/opt/iobroker/node_modules/iobroker.unifi/main.js:376:13)
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:881:33)
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:820:36)
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at Unifi.extendObjectAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1584:16)
      host.ioBroker	2020-05-20 19:26:18.261	error	Caught by controller[0]: at new Promise (<anonymous>)
      host.ioBroker	2020-05-20 19:26:18.260	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1585:16
      host.ioBroker	2020-05-20 19:26:18.260	error	Caught by controller[0]: at Unifi.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2015:17)
      host.ioBroker	2020-05-20 19:26:18.260	error	Caught by controller[0]: at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:518:23)
      host.ioBroker	2020-05-20 19:26:18.260	error	Caught by controller[0]: Error: The "default.clients." is invalid. Ids are not allowed to end in "."
      host.ioBroker	2020-05-20 19:26:18.259	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
      unifi.0	2020-05-20 19:26:17.716	error	at /opt/iobroker/node_modules/iobroker.unifi/main.js:347:21
      unifi.0	2020-05-20 19:26:17.716	error	at Unifi.processClients (/opt/iobroker/node_modules/iobroker.unifi/main.js:376:13)
      unifi.0	2020-05-20 19:26:17.716	error	at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:881:33)
      unifi.0	2020-05-20 19:26:17.716	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      unifi.0	2020-05-20 19:26:17.716	error	at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:820:36)
      unifi.0	2020-05-20 19:26:17.716	error	at Unifi.extendObjectAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1584:16)
      unifi.0	2020-05-20 19:26:17.716	error	at new Promise (<anonymous>)
      unifi.0	2020-05-20 19:26:17.716	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1585:16
      unifi.0	2020-05-20 19:26:17.716	error	at Unifi.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2015:17)
      unifi.0	2020-05-20 19:26:17.716	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:518:23)
      unifi.0	2020-05-20 19:26:17.716	error	(2418) Error: The "default.clients." is invalid. Ids are not allowed to end in "."
      unifi.0	2020-05-20 19:26:17.703	error	(2418) unhandled promise rejection: The "default.clients." is invalid. Ids are not allowed to end in "."
      Unhandled	2020-05-20 19:26:17.701	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.ioBroker	2020-05-20 19:26:14.400	info	instance system.adapter.unifi.0 started with pid 2418
      Edit2:
      Zurück auf 5.0 Fehler weg.
      braindeadB 1 Antwort Letzte Antwort
      • ChaotC Chaot
        Edit:
        Sieh an:
        Edit2:
        braindeadB Offline
        braindeadB Offline
        braindead
        #183
        @Chaot Ich guck mir das später mal an. Jetzt geht's erstmal mit der Holden ins Autokino. 😎
          dslraserD Offline
          dslraserD Offline
          dslraser
          #184
          @braindead
          Ich habe jetzt mal die 0.5.1-beta.2 drauf. Der Punkt is_online funktioniert bei mir auf 30 Sekunden Intervall hervorragend. 👍
          Ich habe mal bis auf mein Handy alles geblacklistet (war ne schöne klickerei😕 )
          Wenn nur ein Gerät da ist, dann schmiert der Adapter erstmal ab. Mit zwei Geräten passiert das bei mir nicht. Wenn ich dann mit nur einem Gerät neu starte, dann bleibt der Adapter ohne Fehler. Ich werde den Adapter mal ne Weile laufen lassen und mir mal Telegram Nachrichten schicken lassen, mal sehen ob die Handys brav online bleiben (auch im Ruhemodes)
          Vielen Dank für Deine Arbeit.👍
          2020-05-20 20:41:31.369 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2020-05-20 20:41:31.374 - error: host.iobroker Caught by controller[1]: Error: The "default.clients." is invalid. Ids are not allowed to end in "."
          2020-05-20 20:41:31.374 - error: host.iobroker Caught by controller[1]: at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:518:23)
          2020-05-20 20:41:31.374 - error: host.iobroker Caught by controller[1]: at Unifi.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2015:17)
          2020-05-20 20:41:31.375 - error: host.iobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1585:16
          2020-05-20 20:41:31.375 - error: host.iobroker Caught by controller[1]: at new Promise ()
          2020-05-20 20:41:31.375 - error: host.iobroker Caught by controller[1]: at Unifi.extendObjectAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1584:16)
          2020-05-20 20:41:31.375 - error: host.iobroker Caught by controller[1]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:820:36)
          2020-05-20 20:41:31.376 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
          2020-05-20 20:41:31.376 - error: host.iobroker Caught by controller[1]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:881:33)
          2020-05-20 20:41:31.376 - error: host.iobroker Caught by controller[1]: at Unifi.processClients (/opt/iobroker/node_modules/iobroker.unifi/main.js:376:13)
          2020-05-20 20:41:31.376 - error: host.iobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.unifi/main.js:347:21
          EDIT: bei is_online wird der Wert ganz kurz von null auf true/false geändert ? Das Gerät ist aber dauerhaft online.
          20.5.2020, 21:05:17.350	[info ]: javascript.0 (2548) Stop script script.js.13_Anwesenheit.Test_Unifi_Anwesenheit
          20.5.2020, 21:05:17.474	[info ]: javascript.0 (2548) Start javascript script.js.13_Anwesenheit.Test_Unifi_Anwesenheit
          20.5.2020, 21:05:17.488	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: registered 1 subscription and 0 schedules
          20.5.2020, 21:05:26.968	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: null
          20.5.2020, 21:05:26.991	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: false
          20.5.2020, 21:05:56.924	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: null
          20.5.2020, 21:05:56.986	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: true
          20.5.2020, 21:06:27.013	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: null
          20.5.2020, 21:06:27.036	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: false
          20.5.2020, 21:06:56.868	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: null
          20.5.2020, 21:06:56.893	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: true
          20.5.2020, 21:07:26.803	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: null
          20.5.2020, 21:07:26.824	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 30 Sekunden Intervall: false
          60 Sekunden Update
          20.5.2020, 21:14:13.077	[info ]: javascript.0 (2548) Stop script script.js.13_Anwesenheit.Test_Unifi_Anwesenheit
          20.5.2020, 21:14:13.201	[info ]: javascript.0 (2548) Start javascript script.js.13_Anwesenheit.Test_Unifi_Anwesenheit
          20.5.2020, 21:14:13.214	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: registered 1 subscription and 0 schedules
          20.5.2020, 21:15:04.892	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: null
          20.5.2020, 21:15:04.978	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: true
          20.5.2020, 21:16:04.922	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: null
          20.5.2020, 21:16:04.953	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: true
          20.5.2020, 21:17:05.025	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: null
          20.5.2020, 21:17:05.099	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Test_Unifi_Anwesenheit: 60 Sekunden Intervall: true
          • dslraserD dslraser
            @braindead
            60 Sekunden Update
            braindeadB Offline
            braindeadB Offline
            braindead
            #185
            @dslraser said in [Major Update] UniFi Adapter v0.5.0:
            @braindead
            30 Sekunden? Welche Scheingenauigkeit möchtest Du damit erreichen?
            Das habe ich ehrlich gesagt bisher nicht getestet, aber ich könnte mir vorstellen, dass das evtl. mit dem 30 Sekunden Intervall zu tun hat. Technisch logst Du Dich damit jedesmal ein, fragst ein paar Daten ab und meldest Dich wieder ab. Ich werde das mal bei mir testen.
            Gut beobachtet. Hintergrund ist, dass auch ein Client, der offline ist, erstmal in der Liste der Clients vorhanden ist. Ich guck mal, ob ich hier noch etwas verbessern kann.
              @braindead
              dslraserD Offline
              dslraserD Offline
              dslraser
              #186
              @braindead sagte in [Major Update] UniFi Adapter v0.5.0:
              Das war nur zum testen. Und was meinst Du mit Scheingenauigkeit ? Standard ist 60 Sekunden eingestellt, da logge ich mich auch jedes Mal ein und aus. Ich bin ja nur am probieren welcher Wert für eine An/Abwesenheitserkennung Sinn macht.
              braindeadB 2 Antworten Letzte Antwort
                braindeadB Offline
                braindeadB Offline
                braindead
                #187
                @dslraser Einige User erhoffen sich, dass sie sofort merken, ob ein Client on-/offline ist. Ich dachte Du wärst einer davon. Sorry. :-)
                Ich habe Deinen Test gerade bei mir nachgestellt: 30 Sekunden sind kein Problem. Nur ein Client funktioniert solange, wie dieser Client online ist. Geht dieser Client offline, bekomme ich die selbe Fehlermeldung wie Du. Das sollte sich leicht fixen lassen.
                  braindeadB Offline
                  braindeadB Offline
                  braindead
                  #188
                  @dslraser Ich habe gerade v0.5.1-beta.3 auf GitHub veröffentlicht. Der Fehler sollte gefixt sein. Kannst Du das mal bei Dir probieren?
                  dslraserD ChaotC 2 Antworten Letzte Antwort
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #189
                    Mache ich, aber nicht mehr jetzt.✌
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #190
                      @braindead Beta3 scheint bei mir jetzt zu klappen.
                      Keine Fehlermeldung bisher. Mal Abwarten bis morgen.
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #191
                        Der Fehler ist nun weg, jedenfalls kann ich ihn nicht mehr nachstellen.
                        Danke auf jeden Fall.
                          braindeadB Offline
                          braindeadB Offline
                          braindead
                          schrieb am zuletzt editiert von braindead
                          #192
                          @dslraser und @Chaot v0.5.1-beta.5 ist gerade auf GitHub online gegangen. Das switchen von is_online zwischen null und dem richtigen Wert sollte behoben sein.
                            ChaotC Offline
                            ChaotC Offline
                            Chaot
                            #193
                            @braindead Beta5 ist installiert. Bisher wieder ohne Fehlermeldungen. Es scheint auch alles zu funktionieren wie gewohnt.
                            • crunchipC Offline
                              crunchipC Offline
                              #194
                              hab das nun mal mit dem unifi.0.default.clients.XYZ.is_online getestet, habe mir Telegram über den Schraubenschlüssel aktiviert.
                              Problem jedoch Zeitstempel und letzte Änderung, somit kommt bei jedem Abfrageintervall eine Nachricht, da sich letzte Änderung fortlaufend mit aktualisiert,
                              selbiges betrifft auch is_wired
                              in der History sieht .is_online so aus, funktioniert mit beta 5
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #195
                                @crunchip
                                ich mache es so und es funktioniert. (für is_online habe ich keinen vernünftigen Trigger hinbekommen, da letzter Wert und vorletzer Wert auch nicht funktioniert, auf Grund null/false oder null/true und der von Dir beschriebenen Aktualisierung)
                                  <variables>
                                    <variable type="" id=";k,Ihk0[-)fmYrQXm8m^">anlegen_in</variable>
                                    <variable type="" id="nTXOZ!3I{zM-7hg^DXcc">last_seen_by_uap</variable>
                                    <variable type="undefined" id="schedule">schedule</variable>
                                  </variables>
                                  <block type="procedures_defcustomnoreturn" id="eZsGA^2r{c%G,YpuLp]K" x="13" y="13">
                                    <mutation statements="false">
                                      <arg name="anlegen_in" varid=";k,Ihk0[-)fmYrQXm8m^"></arg>
                                    </mutation>
                                    <field name="NAME">Datenpunkte_anlegen</field>
                                    <field name="SCRIPT">LyoqCiAqIENyZWF0ZSBzdGF0ZXMgdW5kZXIgMF91c2VyZGF0YS4wIG9yIGphdmFzY3JpcHQueAogKiBDdXJyZW50IFZlcnNpb246ICAgICBodHRwczovL2dpdGh1Yi5jb20vTWljLU0vaW9icm9rZXIuY3JlYXRlVXNlclN0YXRlcwogKiBTdXBwb3J0OiAgICAgICAgICAgICBodHRwczovL2ZvcnVtLmlvYnJva2VyLm5ldC90b3BpYy8yNjgzOS8KICogQXV0b3I6ICAgICAgICAgICAgICAgTWljIChpb0Jyb2tlcikgfCBNaWMtTSAoZ2l0aHViKQogKiBWZXJzaW9uOiAgICAgICAgICAgICAxLjEgKDI2IEphbnVhcnkgMjAyMCkKICogRXhhbXBsZTogICAgICAgICAgICAgc2VlIGh0dHBzOi8vZ2l0aHViLmNvbS9NaWMtTS9pb2Jyb2tlci5jcmVhdGVVc2VyU3RhdGVzI2JlaXNwaWVsCiAqIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tCiAqIFBMRUFTRSBOT1RFOiBQZXIgaHR0cHM6Ly9naXRodWIuY29tL2lvQnJva2VyL2lvQnJva2VyLmphdmFzY3JpcHQvaXNzdWVzLzQ3NCwgdGhlIHVzZWQgZnVuY3Rpb24gc2V0T2JqZWN0KCkgCiAqICAgICAgICAgICAgICBleGVjdXRlcyB0aGUgY2FsbGJhY2sgUFJJT1IgdG8gY29tcGxldGluZyB0aGUgc3RhdGUgY3JlYXRpb24uIFRoZXJlZm9yZSwgd2UgdXNlIGEgc2V0VGltZW91dCBhbmQgY291bnRlci4gCiAqIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tCiAqIEBwYXJhbSB7c3RyaW5nfSB3aGVyZSAgICAgICAgICBXaGVyZSB0byBjcmVhdGUgdGhlIHN0YXRlOiAnMF91c2VyZGF0YS4wJyBvciAnamF2YXNjcmlwdC54Jy4KICogQHBhcmFtIHtib29sZWFufSBmb3JjZSAgICAgICAgIEZvcmNlIHN0YXRlIGNyZWF0aW9uIChvdmVyd3JpdGUpLCBpZiBzdGF0ZSBpcyBleGlzdGluZy4KICogQHBhcmFtIHthcnJheX0gc3RhdGVzVG9DcmVhdGUgIFN0YXRlKHMpIHRvIGNyZWF0ZS4gc2luZ2xlIGFycmF5IG9yIGFycmF5IG9mIGFycmF5cwogKiBAcGFyYW0ge29iamVjdH0gW2NhbGxiYWNrXSAgICAgT3B0aW9uYWw6IGEgY2FsbGJhY2sgZnVuY3Rpb24gLS0gVGhpcyBwcm92aWRlZCBmdW5jdGlvbiB3aWxsIGJlIGV4ZWN1dGVkIGFmdGVyIGFsbCBzdGF0ZXMgYXJlIGNyZWF0ZWQuCiAqLwoKCmZ1bmN0aW9uIGNyZWF0ZVVzZXJTdGF0ZXMod2hlcmUsIGZvcmNlLCBzdGF0ZXNUb0NyZWF0ZSwgY2FsbGJhY2sgPSB1bmRlZmluZWQpIHsKIAogICAgY29uc3QgV0FSTiA9IGZhbHNlOyAvLyBPbmx5IGZvciAwX3VzZXJkYXRhLjA6IFRocm93cyB3YXJuaW5nIGluIGxvZywgaWYgc3RhdGUgaXMgYWxyZWFkeSBleGlzdGluZyBhbmQgZm9yY2U9ZmFsc2UuIERlZmF1bHQgaXMgZmFsc2UsIHNvIG5vIHdhcm5pbmcgaW4gbG9nLCBpZiBzdGF0ZSBleGlzdHMuCiAgICBjb25zdCBMT0dfREVCVUcgPSBmYWxzZTsgLy8gVG8gZGVidWcgdGhpcyBmdW5jdGlvbiwgc2V0IHRvIHRydWUKICAgIC8vIFBlciBpc3N1ZSAjNDc0IChodHRwczovL2dpdGh1Yi5jb20vaW9Ccm9rZXIvaW9Ccm9rZXIuamF2YXNjcmlwdC9pc3N1ZXMvNDc0KSwgdGhlIHVzZWQgZnVuY3Rpb24gc2V0T2JqZWN0KCkgZXhlY3V0ZXMgdGhlIGNhbGxiYWNrIAogICAgLy8gYmVmb3JlIHRoZSBzdGF0ZSBpcyBhY3R1YWwgY3JlYXRlZC4gVGhlcmVmb3JlLCB3ZSB1c2UgYSBzZXRUaW1lb3V0IGFuZCBjb3VudGVyIGFzIGEgd29ya2Fyb3VuZC4KICAgIGNvbnN0IERFTEFZID0gNTA7IC8vIERlbGF5IGluIG1pbGxpc2Vjb25kcyAobXMpLiBJbmNyZWFzZSB0aGlzIHRvIDEwMCwgaWYgaXQgaXMgbm90IHdvcmtpbmcuCgogICAgLy8gVmFsaWRhdGUgIndoZXJlIgogICAgaWYgKHdoZXJlLmVuZHNXaXRoKCcuJykpIHdoZXJlID0gd2hlcmUuc2xpY2UoMCwgLTEpOyAvLyBSZW1vdmUgdHJhaWxpbmcgZG90CiAgICBpZiAoICh3aGVyZS5tYXRjaCgvXigoamF2YXNjcmlwdFwuKFsxLTldWzAtOV18WzAtOV0pKSR8MF91c2VyZGF0YVwuMCQpLykgPT0gbnVsbCkgKSB7CiAgICAgICAgbG9nKCdUaGlzIHNjcmlwdCBkb2VzIG5vdCBzdXBwb3J0IHRvIGNyZWF0ZSBzdGF0ZXMgdW5kZXIgWycgKyB3aGVyZSArICddJywgJ2Vycm9yJyk7CiAgICAgICAgcmV0dXJuOwogICAgfQoKICAgIC8vIFByZXBhcmUgInN0YXRlc1RvQ3JlYXRlIiBzaW5jZSB3ZSBhbHNvIGFsbG93IGEgc2luZ2xlIHN0YXRlIHRvIGNyZWF0ZQogICAgaWYoIUFycmF5LmlzQXJyYXkoc3RhdGVzVG9DcmVhdGVbMF0pKSBzdGF0ZXNUb0NyZWF0ZSA9IFtzdGF0ZXNUb0NyZWF0ZV07IC8vIHdyYXAgaW50byBhcnJheSwgaWYganVzdCBvbmUgYXJyYXkgYW5kIG5vdCBpbnNpZGUgYW4gYXJyYXkKCiAgICAvLyBBZGQgIndoZXJlIiB0byBTVEFURVNfVE9fQ1JFQVRFCiAgICBmb3IgKGxldCBpID0gMDsgaSA8IHN0YXRlc1RvQ3JlYXRlLmxlbmd0aDsgaSsrKSB7CiAgICAgICAgbGV0IGxwUGF0aCA9IHN0YXRlc1RvQ3JlYXRlW2ldWzBdLnJlcGxhY2UoL1wuKlwuL2csICcuJyk7IC8vIHJlcGxhY2UgYWxsIG11bHRpcGxlIGRvdHMgbGlrZSAnLi4nLCAnLi4uJyB3aXRoIGEgc2luZ2xlICcuJwogICAgICAgIGxwUGF0aCA9IGxwUGF0aC5yZXBsYWNlKC9eKChqYXZhc2NyaXB0XC4oWzEtOV1bMC05XXxbMC05XSlcLil8MF91c2VyZGF0YVwuMFwuKS8sJycpIC8vIHJlbW92ZSBhbnkgamF2YXNjcmlwdC54LiAvIDBfdXNlcmRhdGEuMC4gZnJvbSBiZWdpbm5pbmcKICAgICAgICBscFBhdGggPSB3aGVyZSArICcuJyArIGxwUGF0aDsgLy8gYWRkIHdoZXJlIHRvIGJlZ2lubmluZyBvZiBzdHJpbmcKICAgICAgICBzdGF0ZXNUb0NyZWF0ZVtpXVswXSA9IGxwUGF0aDsKICAgIH0KCiAgICBpZiAod2hlcmUgIT0gJzBfdXNlcmRhdGEuMCcpIHsKICAgICAgICAvLyBDcmVhdGUgU3RhdGVzIHVuZGVyIGphdmFzY3JpcHQueAogICAgICAgIGxldCBudW1TdGF0ZXMgPSBzdGF0ZXNUb0NyZWF0ZS5sZW5ndGg7CiAgICAgICAgc3RhdGVzVG9DcmVhdGUuZm9yRWFjaChmdW5jdGlvbihsb29wUGFyYW0pIHsKICAgICAgICAgICAgaWYgKExPR19ERUJVRykgbG9nKCdbRGVidWddIE5vdyB3ZSBhcmUgY3JlYXRpbmcgbmV3IHN0YXRlIFsnICsgbG9vcFBhcmFtWzBdICsgJ10nKTsKICAgICAgICAgICAgbGV0IGxvb3BJbml0ID0gKGxvb3BQYXJhbVsxXVsnZGVmJ10gPT0gdW5kZWZpbmVkKSA/IG51bGwgOiBsb29wUGFyYW1bMV1bJ2RlZiddOyAvLyBtaW1pYyBzYW1lIGJlaGF2aW9yIGFzIGNyZWF0ZVN0YXRlIGlmIG5vIGluaXQgdmFsdWUgaXMgcHJvdmlkZWQKICAgICAgICAgICAgY3JlYXRlU3RhdGUobG9vcFBhcmFtWzBdLCBsb29wSW5pdCwgZm9yY2UsIGxvb3BQYXJhbVsxXSwgZnVuY3Rpb24oKSB7CiAgICAgICAgICAgICAgICBudW1TdGF0ZXMtLTsKICAgICAgICAgICAgICAgIGlmIChudW1TdGF0ZXMgPT09IDApIHsKICAgICAgICAgICAgICAgICAgICBpZiAoTE9HX0RFQlVHKSBsb2coJ1tEZWJ1Z10gQWxsIHN0YXRlcyBwcm9jZXNzZWQuJyk7CiAgICAgICAgICAgICAgICAgICAgaWYgKHR5cGVvZiBjYWxsYmFjayA9PT0gJ2Z1bmN0aW9uJykgeyAvLyBleGVjdXRlIGlmIGEgZnVuY3Rpb24gd2FzIHByb3ZpZGVkIHRvIHBhcmFtZXRlciBjYWxsYmFjawogICAgICAgICAgICAgICAgICAgICAgICBpZiAoTE9HX0RFQlVHKSBsb2coJ1tEZWJ1Z10gRnVuY3Rpb24gdG8gY2FsbGJhY2sgcGFyYW1ldGVyIHdhcyBwcm92aWRlZCcpOwogICAgICAgICAgICAgICAgICAgICAgICByZXR1cm4gY2FsbGJhY2soKTsKICAgICAgICAgICAgICAgICAgICB9IGVsc2UgewogICAgICAgICAgICAgICAgICAgICAgICByZXR1cm47CiAgICAgICAgICAgICAgICAgICAgfQogICAgICAgICAgICAgICAgfQogICAgICAgICAgICB9KTsKICAgICAgICB9KTsKICAgIH0gZWxzZSB7CiAgICAgICAgLy8gQ3JlYXRlIFN0YXRlcyB1bmRlciAwX3VzZXJkYXRhLjAKICAgICAgICBsZXQgbnVtU3RhdGVzID0gc3RhdGVzVG9DcmVhdGUubGVuZ3RoOwogICAgICAgIGxldCBjb3VudGVyID0gLTE7CiAgICAgICAgc3RhdGVzVG9DcmVhdGUuZm9yRWFjaChmdW5jdGlvbihsb29wUGFyYW0pIHsKICAgICAgICAgICAgY291bnRlciArPSAxOwogICAgICAgICAgICBpZiAoTE9HX0RFQlVHKSBsb2cgKCdbRGVidWddIEN1cnJlbnRseSBwcm9jZXNzaW5nIGZvbGxvd2luZyBzdGF0ZTogWycgKyBsb29wUGFyYW1bMF0gKyAnXScpOwogICAgICAgICAgICBpZiggKCQobG9vcFBhcmFtWzBdKS5sZW5ndGggPiAwKSAmJiAoZXhpc3RzU3RhdGUobG9vcFBhcmFtWzBdKSkgKSB7IC8vIFdvcmthcm91bmQgZHVlIHRvIGh0dHBzOi8vZ2l0aHViLmNvbS9pb0Jyb2tlci9pb0Jyb2tlci5qYXZhc2NyaXB0L2lzc3Vlcy80NzgKICAgICAgICAgICAgICAgIC8vIFN0YXRlIGlzIGV4aXN0aW5nLgogICAgICAgICAgICAgICAgaWYgKFdBUk4gJiYgIWZvcmNlKSBsb2coJ1N0YXRlIFsnICsgbG9vcFBhcmFtWzBdICsgJ10gaXMgYWxyZWFkeSBleGlzdGluZyBhbmQgd2lsbCBubyBsb25nZXIgYmUgY3JlYXRlZC4nLCAnd2FybicpOwogICAgICAgICAgICAgICAgaWYgKCFXQVJOICYmIExPR19ERUJVRykgbG9nKCdbRGVidWddIFN0YXRlIFsnICsgbG9vcFBhcmFtWzBdICsgJ10gaXMgYWxyZWFkeSBleGlzdGluZy4gT3B0aW9uIGZvcmNlICg9b3ZlcndyaXRlKSBpcyBzZXQgdG8gWycgKyBmb3JjZSArICddLicpOwogICAgICAgICAgICAgICAgaWYoIWZvcmNlKSB7CiAgICAgICAgICAgICAgICAgICAgLy8gU3RhdGUgZXhpc3RzIGFuZCBzaGFsbCBub3QgYmUgb3ZlcndyaXR0ZW4gc2luY2UgZm9yY2U9ZmFsc2UKICAgICAgICAgICAgICAgICAgICAvLyBTbywgd2UgZG8gbm90IHByb2NlZWQuCiAgICAgICAgICAgICAgICAgICAgbnVtU3RhdGVzLS07CiAgICAgICAgICAgICAgICAgICAgaWYgKG51bVN0YXRlcyA9PT0gMCkgewogICAgICAgICAgICAgICAgICAgICAgICBpZiAoTE9HX0RFQlVHKSBsb2coJ1tEZWJ1Z10gQWxsIHN0YXRlcyBzdWNjZXNzZnVsbHkgcHJvY2Vzc2VkIScpOwogICAgICAgICAgICAgICAgICAgICAgICBpZiAodHlwZW9mIGNhbGxiYWNrID09PSAnZnVuY3Rpb24nKSB7IC8vIGV4ZWN1dGUgaWYgYSBmdW5jdGlvbiB3YXMgcHJvdmlkZWQgdG8gcGFyYW1ldGVyIGNhbGxiYWNrCiAgICAgICAgICAgICAgICAgICAgICAgICAgICBpZiAoTE9HX0RFQlVHKSBsb2coJ1tEZWJ1Z10gQW4gb3B0aW9uYWwgY2FsbGJhY2sgZnVuY3Rpb24gd2FzIHByb3ZpZGVkLCB3aGljaCB3ZSBhcmUgZ29pbmcgdG8gZXhlY3V0ZSBub3cuJyk7CiAgICAgICAgICAgICAgICAgICAgICAgICAgICByZXR1cm4gY2FsbGJhY2soKTsKICAgICAgICAgICAgICAgICAgICAgICAgfQogICAgICAgICAgICAgICAgICAgIH0gZWxzZSB7CiAgICAgICAgICAgICAgICAgICAgICAgIC8vIFdlIG5lZWQgdG8gZ28gb3V0IGFuZCBjb250aW51ZSB3aXRoIG5leHQgZWxlbWVudCBpbiBsb29wLgogICAgICAgICAgICAgICAgICAgICAgICByZXR1cm47IC8vIGh0dHBzOi8vc3RhY2tvdmVyZmxvdy5jb20vcXVlc3Rpb25zLzE4NDUyOTIwL2NvbnRpbnVlLWluLWN1cnNvci1mb3JlYWNoCiAgICAgICAgICAgICAgICAgICAgfQogICAgICAgICAgICAgICAgfSAvLyBpZighZm9yY2UpCiAgICAgICAgICAgIH0KCiAgICAgICAgICAgIC8vIFN0YXRlIGlzIG5vdCBleGlzdGluZyBvciBmb3JjZSA9IHRydWUsIHNvIHdlIGFyZSBjb250aW51aW5nIHRvIGNyZWF0ZSB0aGUgc3RhdGUgdGhyb3VnaCBzZXRPYmplY3QoKS4KICAgICAgICAgICAgbGV0IG9iaiA9IHt9OwogICAgICAgICAgICBvYmoudHlwZSA9ICdzdGF0ZSc7CiAgICAgICAgICAgIG9iai5uYXRpdmUgPSB7fTsKICAgICAgICAgICAgb2JqLmNvbW1vbiA9IGxvb3BQYXJhbVsxXTsKICAgICAgICAgICAgc2V0T2JqZWN0KGxvb3BQYXJhbVswXSwgb2JqLCBmdW5jdGlvbiAoZXJyKSB7CiAgICAgICAgICAgICAgICBpZiAoZXJyKSB7CiAgICAgICAgICAgICAgICAgICAgbG9nKCdDYW5ub3Qgd3JpdGUgb2JqZWN0IGZvciBzdGF0ZSBbJyArIGxvb3BQYXJhbVswXSArICddOiAnICsgZXJyKTsKICAgICAgICAgICAgICAgIH0gZWxzZSB7CiAgICAgICAgICAgICAgICAgICAgaWYgKExPR19ERUJVRykgbG9nKCdbRGVidWddIE5vdyB3ZSBhcmUgY3JlYXRpbmcgbmV3IHN0YXRlIFsnICsgbG9vcFBhcmFtWzBdICsgJ10nKQogICAgICAgICAgICAgICAgICAgIGxldCBpbml0ID0gbnVsbDsKICAgICAgICAgICAgICAgICAgICBpZihsb29wUGFyYW1bMV0uZGVmID09PSB1bmRlZmluZWQpIHsKICAgICAgICAgICAgICAgICAgICAgICAgaWYobG9vcFBhcmFtWzFdLnR5cGUgPT09ICdudW1iZXInKSBpbml0ID0gMDsKICAgICAgICAgICAgICAgICAgICAgICAgaWYobG9vcFBhcmFtWzFdLnR5cGUgPT09ICdib29sZWFuJykgaW5pdCA9IGZhbHNlOwogICAgICAgICAgICAgICAgICAgICAgICBpZihsb29wUGFyYW1bMV0udHlwZSA9PT0gJ3N0cmluZycpIGluaXQgPSAnJzsKICAgICAgICAgICAgICAgICAgICB9IGVsc2UgewogICAgICAgICAgICAgICAgICAgICAgICBpbml0ID0gbG9vcFBhcmFtWzFdLmRlZjsKICAgICAgICAgICAgICAgICAgICB9CiAgICAgICAgICAgICAgICAgICAgc2V0VGltZW91dChmdW5jdGlvbigpIHsKICAgICAgICAgICAgICAgICAgICAgICAgc2V0U3RhdGUobG9vcFBhcmFtWzBdLCBpbml0LCB0cnVlLCBmdW5jdGlvbigpIHsKICAgICAgICAgICAgICAgICAgICAgICAgICAgIGlmIChMT0dfREVCVUcpIGxvZygnW0RlYnVnXSBzZXRTdGF0ZSBkdXJjaGdlZsO8aHJ0OiAnICsgbG9vcFBhcmFtWzBdKTsKICAgICAgICAgICAgICAgICAgICAgICAgICAgIG51bVN0YXRlcy0tOwogICAgICAgICAgICAgICAgICAgICAgICAgICAgaWYgKG51bVN0YXRlcyA9PT0gMCkgewogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIGlmIChMT0dfREVCVUcpIGxvZygnW0RlYnVnXSBBbGwgc3RhdGVzIHByb2Nlc3NlZC4nKTsKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICBpZiAodHlwZW9mIGNhbGxiYWNrID09PSAnZnVuY3Rpb24nKSB7IC8vIGV4ZWN1dGUgaWYgYSBmdW5jdGlvbiB3YXMgcHJvdmlkZWQgdG8gcGFyYW1ldGVyIGNhbGxiYWNrCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIGlmIChMT0dfREVCVUcpIGxvZygnW0RlYnVnXSBGdW5jdGlvbiB0byBjYWxsYmFjayBwYXJhbWV0ZXIgd2FzIHByb3ZpZGVkJyk7CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIHJldHVybiBjYWxsYmFjaygpOwogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIH0KICAgICAgICAgICAgICAgICAgICAgICAgICAgIH0KICAgICAgICAgICAgICAgICAgICAgICAgfSk7CiAgICAgICAgICAgICAgICAgICAgfSwgREVMQVkgKyAoMjAgKiBjb3VudGVyKSApOwogICAgICAgICAgICAgICAgfQogICAgICAgICAgICB9KTsKICAgICAgICB9KTsKICAgIH0KfQoKCmxldCBzdGF0ZXNUb0NyZWF0ZSA9IFsKICAgIC8vQW53ZXNlbmhlaXQgUGVyc29uZW4vSGFuZHlzCiAgICBbJ0Fud2VzZW5oZWl0LkhlaWtvJywgeyduYW1lJzonSGVpa28gQW53ZXNlbmhlaXQnLCAndHlwZSc6J3N0cmluZycsICdyZWFkJzp0cnVlLCAnd3JpdGUnOnRydWUsICdyb2xlJzonc3RyaW5nJywgJ2RlZic6J25vY2ggbGVlcicgfV0sCiAgICBbJ0Fud2VzZW5oZWl0LktlcnN0aW4nLCB7J25hbWUnOidLZXJzdGluIEFud2VzZW5oZWl0JywgJ3R5cGUnOidzdHJpbmcnLCAncmVhZCc6dHJ1ZSwgJ3dyaXRlJzp0cnVlLCAncm9sZSc6J3N0cmluZycsICdkZWYnOidub2NoIGxlZXInIH1dLAogICAKXTsKCmNyZWF0ZVVzZXJTdGF0ZXMoYW5sZWdlbl9pbiwgZmFsc2UsIHN0YXRlc1RvQ3JlYXRlLCBmdW5jdGlvbigpezsKICAgIG1haW4oKTsKfSk7CgoK</field>
                                    <comment pinned="false" h="80" w="160">Datenpunkte erstellen</comment>
                                  </block>
                                  <block type="procedures_callcustomnoreturn" id="(4(-f$1VS~CwO}P[R@.6" x="13" y="63">
                                    <mutation name="Datenpunkte_anlegen">
                                      <arg name="anlegen_in"></arg>
                                    </mutation>
                                    <value name="ARG0">
                                      <block type="text" id="4)/(kKqpd^/S.|-%(%s!">
                                        <field name="TEXT">javascript.0</field>
                                      </block>
                                    </value>
                                  </block>
                                  <block type="procedures_defnoreturn" id="SSMy$1MUVX,GQsbb[2*m" x="13" y="138">
                                    <field name="NAME">main</field>
                                    <statement name="STACK">
                                      <block type="variables_set" id="x/A;x*nKgX6!*YEVG!tq">
                                        <field name="VAR" id="nTXOZ!3I{zM-7hg^DXcc" variabletype="">last_seen_by_uap</field>
                                        <value name="VALUE">
                                          <block type="field_oid" id="K-7W*}@_6*8kH(w#3=u0">
                                            <field name="oid">unifi.0.default.clients.8c:b8:4a:34:ac:85.last_seen_by_uap</field>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="schedule_create" id="S/j#m7!^1%Nt=iNwzRS-">
                                            <field name="NAME">schedule</field>
                                            <value name="SCHEDULE">
                                              <shadow type="field_cron" id=";r[9Exo]CQHPwtqLrQZQ">
                                                <field name="CRON">* * * * *</field>
                                              </shadow>
                                            </value>
                                            <statement name="STATEMENT">
                                              <block type="variables_set" id="o|V8!@#=5R+|*I`05TB4">
                                                  <block type="field_oid" id="b,nG5]~+E^QmVj}^OLHK">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="controls_if" id="_z?rO3%XvQmDU%U1=lon">
                                                    <value name="IF0">
                                                      <block type="logic_compare" id="/$w3`9Ff5xYiel|?K5Az">
                                                        <field name="OP">LTE</field>
                                                        <value name="A">
                                                          <block type="math_arithmetic" id="VZ6IF-gK]$)JS9mN{`YK">
                                                            <value name="A">
                                                              <shadow type="math_number" id="QkfPH}!i3jgK?TzPhTe%">
        <field name="NUM">1</field>
                                                              </shadow>
                                                              <block type="time_get" id="a[3B]W)o~qbg7R,|dJ7b">
        <mutation format="false" language="false"></mutation>
        <field name="OPTION">m</field>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="fw{ZJArB^VS):u6pli(T">
                                                              </shadow>
                                                              <block type="convert_from_date" id="h@3O[Rmjr1W_;=7DZ:i`">
        <block type="get_value_var" id="7Eq~kIl^~FZt/42Sm`V@">
        <value name="OID">
        <shadow type="text" id="y/6*Cdpp{jB70^`7!Yz+">
        <field name="TEXT"></field>
        </shadow>
        <block type="variables_get" id="]6E|f-t0Ik)68zsY9^!g">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="math_number" id="-aa6)TlDt;0}DX3miju8">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO0">
                                                      <block type="control_ex" id="q8DK@_{T^+trL5u?goV]" inline="true">
                                                        <field name="TYPE">true</field>
                                                        <value name="OID">
                                                          <shadow type="field_oid" id="oI~m.j|.S**Jp#2.s;,j">
                                                            <field name="oid">javascript.0.Anwesenheit.Heiko</field>
                                                          </shadow>
                                                        </value>
                                                          <shadow type="logic_boolean" id="onH/zg_lwNY;i9[%)$^d">
                                                          </shadow>
                                                          <block type="text" id="Ec6r1EfG`xz73%/NnY!k">
                                                            <field name="TEXT">Heiko ist online ✅</field>
                                                          </block>
                                                        </value>
                                                        <value name="DELAY_MS">
                                                          <shadow type="math_number" id="yqWXH0g:VUZYAU{*-Lwk">
                                                            <field name="NUM">0</field>
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                    <statement name="ELSE">
                                                      <block type="control_ex" id="~m81/itJLw]L5+x.f9j(" inline="true">
                                                        <value name="OID">
                                                          <shadow type="field_oid" id="Q|$,f:2fvqDb-qr(b.[Y">
                                                          </shadow>
                                                        </value>
                                                          </shadow>
                                                          <block type="text" id="e:z5Xl{@]xk_kF5Zt#I1">
                                                            <field name="TEXT">Heiko ist offline ❌</field>
                                                          </block>
                                                        </value>
                                                          <shadow type="math_number" id="w7Yo75yEr6SeiQTojkXq">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                            <next>
                                              <block type="on_ext" id="B9:ea#4L(Oy)Bn!/1XDs">
                                                <value name="OID0">
                                                  <shadow type="field_oid" id="+{|4+_:MEg}y(8j4):jk">
                                                  </shadow>
                                                </value>
                                                  <block type="controls_if" id="89X)lg$MSzz$I)(L[.@R">
                                                    <value name="IF0">
                                                      <block type="logic_compare" id="bic_/sHb4(u+:*T{HBaI">
                                                        <field name="OP">EQ</field>
                                                        <value name="A">
                                                          <block type="get_value" id="WIl,L_Tr4-jPC9#bj!LS">
                                                            <field name="OID">javascript.0.Anwesenheit.Heiko</field>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="text" id="Zrc,Gsx.Rl-VpL5{1FTH">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                      <block type="telegram" id="54*y/hkmyWndQBH{h#)V">
                                                        <field name="LOG"></field>
                                                        <field name="PARSEMODE">Markdown</field>
                                                        <value name="MESSAGE">
                                                          <shadow type="text" id="F8`_}5Ls0W8c7x2c+hZa">
                                                          </shadow>
                                                          <block type="text" id="@W?c;cM+bwA__@R-$2Ex">
                                                          </block>
                                                        </value>
                                                        <value name="USERNAME">
                                                          <block type="text" id="e%4Xn,W12]|0tv_IN1s{">
                                                            <field name="TEXT">Heiko</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                      <block type="telegram" id="gONL!Ak:KiDx*lp_)..%">
                                                          <shadow type="text" id="=nQH.TsZSn{lfpy^dbYY">
                                                          </shadow>
                                                          <block type="text" id="MzWy_rxy3nBlUY?~nN9r">
                                                          </block>
                                                        </value>
                                                          <block type="text" id="WR[xJSy`G(s0Y):xgWwf">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                • braindeadB Offline
                                  braindeadB Offline
                                  braindead
                                  #196
                                  @crunchip Ich bin mir nicht ganz sicher, ob ich Deinen Text richtig verstehe, deshalb habe ich das bei mir mit v0.5.1-beta.5 nachgestellt und is_online und is_wired von meinem Handy werden geloggt und Änderungen werden mir per Telegram geschickt.
                                  Ich habe für die beiden DPs genau eine Telegram Nachricht bekommen, als das Handy offline gegangen ist. Genauso gab es jeweils nur einen Eintrag in der Historie. Selbiges ist passiert, als ich 30 Minuten später wieder online gegangen bin. Bei mir funktioniert die Aktualisierung der DPs also genau wie es sein soll.
                                  Die Tatsache, dass is_wired sich ändert, wenn der Client offline geht, ist ein Bug des UniFi Controllers. Ich habe versucht das abzufangen, es ist mir bisher aber nicht gelungen.
                                  @dslraser In v0.5.1-beta.5 gibt es die null/false bzw. null/true Problematik nicht mehr. Kannst Du das bitte einmal testen und bestätigen?
                                  dslraserD crunchipC 4 Antworten Letzte Antwort
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #197
                                    probiere ich aus.
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #198
                                      Top 👍 scheint zu funktionieren (kurz getestet)
                                      einmal abgemeldet und einige Minuten später wieder angemeldet.
                                      22.5.2020, 13:14:33.823	[info ]: javascript.0 (2548) Stop script script.js.13_Anwesenheit.Beta_5
                                      22.5.2020, 13:14:33.948	[info ]: javascript.0 (2548) Start javascript script.js.13_Anwesenheit.Beta_5
                                      22.5.2020, 13:14:33.959	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Beta_5: registered 1 subscription and 0 schedules
                                      22.5.2020, 13:15:54.114	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Beta_5: 60 Sekunden: false
                                      22.5.2020, 13:18:54.007	[info ]: javascript.0 (2548) script.js.13_Anwesenheit.Beta_5: 60 Sekunden: true
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #199
                                        @crunchip
                                        Zum Thema Anwesenheit:
                                        Ich habe mal schnell was mit Blockly zusammengeklöppelt und werde damit mal ne Weile probieren. Ich habe bei mir erstmal nur zwei Personen zur Anwesenheit drinn. Bisher sieht das ganz gut aus, danke @braindead Mal sehen wie sich die Handys im Ruhemodus schlagen (zwei x Samsung)
                                        Hier in der Funktion die Namen der Personen eintragen. In die Funktion klicken und zuden Zeilen 129/130 scrollen
                                        Da die Namen eintragen
                                        und im Blockly vor dem ersten Start auf die eigenen Daten anpassen
                                        Nach dem ersten Blockly Start werden die Datenpunkte erstellt und der aktuelle Zustand der beiden Geräte eingelesen.
                                          <variables>
                                            <variable type="" id="fyVM({2.Ubq}R7hxFVRc">speicherort</variable>
                                            <variable type="" id="nTXOZ!3I{zM-7hg^DXcc">person_1_is_online_DP</variable>
                                            <variable type="" id="lvz.2`K]e8c1*JEc-vJu">anwesenheit_person_1</variable>
                                            <variable type="" id="@i-nl2q|$|OFpK!Yx+CC">anwesenheit_person_2</variable>
                                            <variable type="" id="yB(N?#)zIjYIo%.B@UT(">person_2_is_online_DP</variable>
                                            <variable type="" id=";^euFaDvC/jHl4C^!SUw">person_1</variable>
                                            <variable type="undefined" id="start">start</variable>
                                            <variable type="" id="sgYRW3,@::dC5Ux]x;8|">person_2</variable>
                                            <variable type="" id="![EW]9b!hQ9S[MT.q}6-">telegram_benutzer</variable>
                                          </variables>
                                            </mutation>
                                            <field name="SCRIPT">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</field>
                                          </block>
                                          <block type="variables_set" id="oODt+HYM*+ptP0jLnPoN" x="13" y="62">
                                            <field name="VAR" id="fyVM({2.Ubq}R7hxFVRc" variabletype="">speicherort</field>
                                              <block type="text" id="^a2)}wPt=s[~]UsHJqvr">
                                                <field name="TEXT">0_userdata.0</field>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="comment" id="@hJky?+Qv5OpJOJa;Tl6">
                                                <field name="COMMENT">Unifi Adapter Client DP is_online</field>
                                                <next>
                                                  <block type="variables_set" id="Y?6=|YzWSeM4LOdF5$XM">
                                                    <field name="VAR" id="nTXOZ!3I{zM-7hg^DXcc" variabletype="">person_1_is_online_DP</field>
                                                      <block type="field_oid" id="knG,[`=1g+b,s{kx1EP,">
                                                        <field name="oid">unifi.0.default.clients.8c:b8:4a:34:ac:85.is_online</field>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="comment" id="/R=ulymL%~caLxh2Ilfo">
                                                        <next>
                                                          <block type="variables_set" id="Vx9vV3Sg8kY@H?;zDw@(">
                                                            <field name="VAR" id="yB(N?#)zIjYIo%.B@UT(" variabletype="">person_2_is_online_DP</field>
                                                              <block type="field_oid" id="!feFu(z:sKBl~0nK`eGu">
        <field name="oid">unifi.0.default.clients.04:d6:aa:76:06:53.is_online</field>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="variables_set" id="9m,K[:2^)KFEl|00rZQ7">
        <field name="VAR" id=";^euFaDvC/jHl4C^!SUw" variabletype="">person_1</field>
        <block type="text" id="pJ}1(u|}l3lA7~[z+Wg5">
        </block>
        </value>
        <next>
        <block type="variables_set" id="k`L|~6i[HzfGD|D*L^Z[">
        <field name="VAR" id="sgYRW3,@::dC5Ux]x;8|" variabletype="">person_2</field>
        <block type="text" id="$^o6%]+%A^W3{Txo4Yds">
        <field name="TEXT">Kerstin</field>
        </block>
        </value>
        <next>
        <block type="variables_set" id="bEu?$N6,|qbfd8h2t;xr">
        <field name="VAR" id="![EW]9b!hQ9S[MT.q}6-" variabletype="">telegram_benutzer</field>
        <block type="text" id="@AJ19!Lch7=H%ib(sX@`">
        </block>
        </value>
        <next>
        <block type="procedures_callcustomnoreturn" id="(4(-f$1VS~CwO}P[R@.6" collapsed="true">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="!74)L93;^_?DR0pALJ9f">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                          <block type="procedures_defnoreturn" id="SSMy$1MUVX,GQsbb[2*m" x="12" y="313">
                                              <block type="timeouts_cleartimeout" id="TZP~F0nTRJ5tX).DDSa`" collapsed="true">
                                                <field name="NAME">start</field>
                                                <next>
                                                  <block type="variables_set" id=",U2@|cXpD(cMh/t+?6ch" collapsed="true">
                                                    <field name="VAR" id="lvz.2`K]e8c1*JEc-vJu" variabletype="">anwesenheit_person_1</field>
                                                      <block type="text_join" id="!1[II16BPGnRh-7=6hz[">
                                                        <value name="ADD0">
                                                          <block type="variables_get" id="xK5Ij}90B8}K(46SJ?nI">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          <block type="text" id="j|:+t7a^%@D?7F{x85Vu">
                                                            <field name="TEXT">.Unifi.Anwesenheit.</field>
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          <block type="variables_get" id="/d9dG48mWBBOwwOV|b7q">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="variables_set" id="!b3P0hupqzO)$LYY_96G" collapsed="true">
                                                        <field name="VAR" id="@i-nl2q|$|OFpK!Yx+CC" variabletype="">anwesenheit_person_2</field>
                                                          <block type="text_join" id="j^1|XvQ;,bZdK7j*e[W]">
                                                            <value name="ADD0">
                                                              <block type="variables_get" id="{e5Na0l3aK]%yCR.A^B{">
                                                              </block>
                                                            </value>
                                                            <value name="ADD1">
                                                              <block type="text" id="IVD:VEYV~yR=s_-/Xf!N">
                                                              </block>
                                                            </value>
                                                            <value name="ADD2">
                                                              <block type="variables_get" id="Aty5L{S^6krr(,SAac[M">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="timeouts_settimeout" id=".|_m4*n~bGC)tC]M]!E^" collapsed="true">
                                                            <field name="DELAY">1</field>
                                                              <block type="controls_if" id="@IdN-@8]b19pM5K:RKAV">
        <value name="IF0">
        <block type="logic_compare" id="mOtoF5ZD{_J6ssks0m)y">
        <value name="A">
        <block type="get_value_var" id="P=ub#}lCd=k9sU(YPcg:">
        <value name="OID">
        <shadow type="text" id="+?=%oVJ6|*ti.6j6/Wxj">
        </shadow>
        <block type="variables_get" id="l+hT5v.Pk.O2J$/Iaqt,">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="9{xgUNQr|Jen;~u_$)6d">
        </block>
        </value>
        </block>
        </value>
        <block type="control_ex" id=".V]CdR(,WY/[gHi[+RLy" inline="true">
        <value name="OID">
        <shadow type="field_oid" id="hRVN~;8VstUL/pd4KSAZ">
        <field name="oid">Object ID</field>
        </shadow>
        <block type="variables_get" id="3%^DGT`3E`2/0p:w3{4^">
        </block>
        </value>
        <shadow type="logic_boolean" id="bbVKs5v:Ert)PYdo!`!i">
        </shadow>
        <block type="text_join" id="f8$xC!VB#l1J#2YIx60!">
        <value name="ADD0">
        <block type="variables_get" id="1oBT:?uj_zr?Mgi+#WM`">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="SWk`f2QCt@7CE*{M9F=y">
        <field name="TEXT"> </field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="Gh(!zydv3Jh_{d7dIKNr">
        <field name="TEXT">ist online ✅</field>
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="I7CJ`-|pTzVbPm]Rm~#j">
        </shadow>
        </value>
        </block>
        </statement>
        <block type="control_ex" id="Rm7t|TP;p?8IkYCVTFYf" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="rh!@7z?k=8.uZbxF?DoI">
        </block>
        </value>
        </shadow>
        <block type="text_join" id=";.n,Hn*I2XhhSW85o_Q2">
        <value name="ADD0">
        <block type="variables_get" id="tu5-.4UIt2~I(onp}L$P">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="`*!Euh8@c0Kv1`dL)`|]">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="OP@O9n8`%s$i4iu!qalG">
        <field name="TEXT">ist offline ❌</field>
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="?QJBHR?P%=ONW9U|7bz~">
        </shadow>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="CW7PDI-i5$*GOj_KJb4Q">
        <value name="IF0">
        <block type="logic_compare" id="-!aPk*oy9xC5J=ysP)7=">
        <value name="A">
        <block type="get_value_var" id="n+Ps:J5qI;GEdiv{)E?z">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="!|b(=p?G65~q+jglAR8w">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="!(SIj5PDvV$R:iUQ*(LP">
        </block>
        </value>
        </block>
        </value>
        <block type="control_ex" id="4VEiHKIjpLMpRX2h?+MR" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="MTibw$-yf66T#p]`3z?r">
        </block>
        </value>
        </shadow>
        <block type="text_join" id=":iT@UQ1eLTq{?.Nc0-Ob">
        <value name="ADD0">
        <block type="variables_get" id=")vF^Rbw,2,7/)$D8gF};">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="23zE8haiF=Z5L.H#Pk7i">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="+0!/qeY$7F8aH-xnRR*0">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="l4gI%#`:C=?(4rd|p`^.">
        </shadow>
        </value>
        </block>
        </statement>
        <block type="control_ex" id="W?x]+MW|=5vu@Uj(3,75" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="VV1Lj`Qf^tQkmc+x.maW">
        </block>
        </value>
        </shadow>
        <block type="text_join" id="ll.R;kcidI|hRLwDFVB{">
        <value name="ADD0">
        <block type="variables_get" id="WD$^uCEDqYwF6:QS*F]j">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="wR$`1P`CT=B)$/YSN(~J">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="4c(~/}V#~bT!jwy2iB}J">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="!d5FRdKZAaU7?)=#m4%_">
        </shadow>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </statement>
                                                            <next>
                                                              <block type="on_ext" id="SX%6!fqcVoVlD@SU-7Y4" collapsed="true">
        <value name="OID0">
        <shadow type="field_oid" id=";0_S:)AqTJF$]lRUv@gx">
        </shadow>
        <block type="variables_get" id="UKe(AmN7{4GdYH(3_`O#">
        </block>
        </value>
        <value name="IF0">
        <block type="on_source" id="_(Fal+8L^ATHe#Hq|y+9">
        </block>
        </value>
        <block type="control_ex" id="LM-KIX/g(V6Tuik9CLF/" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="7,y}skvg#u?n$OT[5K=S">
        </block>
        </value>
        </shadow>
        <block type="text_join" id="l|J80x/T-`0?9M^7b]:N">
        <value name="ADD0">
        <block type="variables_get" id=".qiA1:)|eFl9@:8-b6*`">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="G0=0Fc~I_fA]0O)}g3W(">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="]N,+4OnsaC~Lw_.k0/hh">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="1:S1**dQmdnwe.l7.Z-b">
        </shadow>
        </value>
        <next>
        </shadow>
        <block type="text_join" id="IGB?:md|3ZD;,sYcS|bg">
        <value name="ADD0">
        <block type="variables_get" id="/tAT/wS-)[}+6m*I4~g8">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="fFlUO))aCIA!f=Yag|;M">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="V[o?yVyX~D{w{(:^NNVr">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_get" id="41ZPm5?AKrt.cqhBg3{2">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <block type="control_ex" id="YN=l|7.)+2WVOGMcg!/`" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="4.t^B;y;~YJA^DTb;gyE">
        </block>
        </value>
        </shadow>
        <block type="text_join" id="o}K:*wP8{onf4yKv=4YT">
        <value name="ADD0">
        <block type="variables_get" id="941ISD`abMu2l=]8Y(/m">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="ZM+pW%,1k!o2Vf?t0R?l">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="S__OPp))@Dgo/JTcf}ax">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="f6RJ7!swO;Le1Bfko;L2">
        </shadow>
        </value>
        <next>
        </shadow>
        <block type="text_join" id="z,us3C]4=+L0DA.p_}lp">
        <value name="ADD0">
        <block type="variables_get" id="i3Q4|n~53-sQ?^T*H.TC">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="QFr-g%mo//Sg8;:roRfA">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id=")0nYWe-N-O.,_Jrn${Vm">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_get" id="vm,}kUg}PwBi!:PsGM,{">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <block type="on_ext" id="~ObZs=5%-:^CnQuYO(z=" collapsed="true">
        <value name="OID0">
        </shadow>
        <block type="variables_get" id="Olbu@Xq[MZTK?j4d_a#g">
        </block>
        </value>
        <block type="controls_if" id="!K2H`_FR~oD9eh*@T1|w">
        <value name="IF0">
        <block type="on_source" id="*I8C7_{s9`7I(Zx#@%|2">
        </block>
        </value>
        <block type="control_ex" id="mFAN(dDUr6q/gR6UwBVZ" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="$UftmC*.f}ze-ab-ys,Q">
        </block>
        </value>
        </shadow>
        <block type="text_join" id="P3N04_kX]?qG{Xs2[(fH">
        <value name="ADD0">
        <block type="variables_get" id="P5IAcPBtd#@dS,*2B@fW">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="r7@)j/8/+({|VPB=@6%r">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="xxE=NzJgw3NYsn-%!LPx">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="p/d5]r.~2%E#lqUZ+Zzo">
        </shadow>
        </value>
        <next>
        <block type="telegram" id="G/k/uD]_e{FwK|;oni_9">
        </shadow>
        <block type="text_join" id="EwI{:V.W#KbT~#,))hp4">
        <value name="ADD0">
        <block type="variables_get" id="rXJ#~l_SmSueR^}c}c+2">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="{++h2{_?][DK]_UJQ!1;">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="+T~B`e5Yo89(P:rS[eXJ">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_get" id="SIP/Bn3+q.?-|~fP{|mj">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <block type="control_ex" id="L{2Dp(q220seA@K)H~:9" inline="true">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="37B(F$tlde-Bt#u.;L~#">
        </block>
        </value>
        </shadow>
        <block type="text_join" id="eFy4q-cPhD:xWFQ|LO1f">
        <value name="ADD0">
        <block type="variables_get" id=";$UrDWF]KPE{L^K`r/hr">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="wwJ^.~7}z9=7(BjXQ.p)">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="lM_E)oJ#UCr|#hxu*pAT">
        </block>
        </value>
        </block>
        </value>
        <shadow type="math_number" id="~ECK]+XM?KdV2JNU{|2O">
        </shadow>
        </value>
        <next>
        <block type="telegram" id="QrG*QsVt38c~9UI4H1.U">
        </shadow>
        <block type="text_join" id="i*RxzVi!*A==)}IS5C}S">
        <value name="ADD0">
        <block type="variables_get" id="}%!^~Qa|-+l=w6[91@*f">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="nE0K73Q(?EJwI52FCdl@">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="zQ8F1qC^L?*7c#hE}z_A">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_get" id="M|AZ+FjOe.JP3wkCCbbC">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </xml>
                                        crunchipC dslraserD 2 Antworten Letzte Antwort
                                          crunchipC Offline
                                          crunchipC Offline
                                          #200
                                          @braindead siehe meines screens von oben
                                          Zeitstempel und letzte Änderung haben die gleiche Uhrzeit, das Handy ist aber bereits 5 Min aus gewesen, was bedeutet, letzte Änderung(wechsel von true auf false) war um Uhrzeit 09:41Uhr und müsste dann folglich, da der Wert auf false bleibt, bei der Uhrzeit stehen bleiben, da ja keine Änderung mehr statt findet, die Uhrzeit wird aber mit jeder Intevall Abfrage, mit aktualisiert, folglich kommen kontinuierlich die Telegram Meldungen
                                          Hoffe, es war nun verständlich
