  4. HS100 Adapter Fehlermeldungen
    2.7k
    4.8k
    4.0k
hs100 adapterfehler im log
190 Beiträge 23 Kommentatoren 35.3k Aufrufe 22 Beobachtet
    PatrickFro
    #121
    @arteck
    Das ist das Ergebnis:
    hs100.0	2020-06-02 14:50:51.761	info	(10957) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.1.4
    host.Linux	2020-06-02 14:50:51.014	info	instance system.adapter.hs100.0 started with pid 10957
    host.Linux	2020-06-02 14:50:21.000	info	Restart adapter system.adapter.hs100.0 because enabled
    host.Linux	2020-06-02 14:50:21.000	info	instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: at TCP.<anonymous> (net.js:672:12)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: at Socket.emit (events.js:310:20)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:119:151)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: at replaceControlCharacters (/opt/iobroker/node_modules/tplink-smarthome-api/lib/utils.js:112:16)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[1]: TCP 192.168.178.70:9999 TypeError: Cannot read property 'replace' of undefined
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[0]: at TCP.<anonymous> (net.js:672:12)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:119:151)
    host.Linux	2020-06-02 14:50:20.999	error	Caught by controller[0]: at replaceControlCharacters (/opt/iobroker/node_modules/tplink-smarthome-api/lib/utils.js:112:16)
    host.Linux	2020-06-02 14:50:20.997	error	Caught by controller[0]: TCP 192.168.178.70:9999 TypeError: Cannot read property 'replace' of undefined
      stenmic
      schrieb am zuletzt editiert von stenmic
      #122
      Die (Watt) Diagramme von 3 Steckdosen zeigen schön meine Probleme.
      Alle 3 sind 2m von meiner Fritzbox entfernt und sollten keine Probleme mit der Verbindung haben.
      Am Sonntag habe ich das Update auf JS 3.1.4 gemacht und zwei mal neu gebootet.
      Soweit alles ok. Am Sonntag dann das Update der Script Engine auf 4.6.17
      Seitdem spinnen sporadisch alle 15 Steckdosen.
      Durch das jetzige häufige abfallen auf 0 Watt spinnen viele meiner Skripte und lösen falschen Alarm aus. Den HS-Adapter habe ich am Montag von 1.1.5 auf 1.1.6 aktualisiert. Brachte aber auch keine Besserung.
      • P PatrickFro
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        #123
        @PatrickFro sagte in HS100 Adapter Fehlermeldungen:
        1.1.5
        falsche version
        • arteckA Offline
          arteckA Offline
          arteck
          #124
          ich schau mal die Tage, dass ich die Verarbeitung mal ändere (komplett neu schreibe) ..auf asynchron.. vielleicht wirds dann besser
          • arteckA Offline
            arteckA Offline
            arteck
            #125
            so bin dran
            test läuft
            • arteckA arteck
              so bin dran
              test läuft
              stenmic
              #126
              @arteck
              Super 👍🏻
              • arteckA Offline
                arteckA Offline
                arteck
                #127
                ok mal zum Testen
                der alte Adapter muss nicht gelöscht werden...diesen einfach drüber isntallieren
                https://github.com/arteck/ioBroker.hs100/tarball/vers2
                das einzige was ihr anpassen müsst ist
                ich habs auf sekunden umgestellt... also die Zeit in Sekunden angeben
                bei timeout sollte es jetzt so aussehen
                sigi234S O 2 Antworten Letzte Antwort
                • arteckA arteck
                  ok mal zum Testen
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  #128
                  @arteck sagte in HS100 Adapter Fehlermeldungen:
                  ok mal zum Testen
                  Läuft. 👍
                  Immer Daten sichern!
                  • surfer09S Offline
                    surfer09S Offline
                    surfer09
                    #129
                    Bei mir klappt die Version von GitHub leider nicht. Der Adapter startet nicht mehr...
                    2020-06-07 12:10:08.895 - error: hs100.0 (4288) [create_state] : TCP Timeout, stack: Error: TCP Timeout
                    at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                    at listOnTimeout (internal/timers.js:549:17)
                    at processTimers (internal/timers.js:492:7)
                    2020-06-07 12:10:12.645 - info: host.IO-Broker-Server stopInstance system.adapter.hs100.0 (force=false, process=true)
                    2020-06-07 12:10:12.645 - info: host.IO-Broker-Server stopInstance system.adapter.hs100.0 send kill signal
                    2020-06-07 12:10:12.641 - info: hs100.0 (4288) Got terminate signal TERMINATE_YOURSELF
                    2020-06-07 12:10:12.642 - info: hs100.0 (4288) cleaned everything up...
                    2020-06-07 12:10:12.643 - info: hs100.0 (4288) terminating
                    2020-06-07 12:10:12.643 - info: hs100.0 (4288) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2020-06-07 12:10:13.184 - info: host.IO-Broker-Server instance system.adapter.hs100.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2020-06-07 12:10:15.665 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 8208
                    2020-06-07 12:10:16.236 - info: hs100.0 (8208) starting. Version 2.0.0 in I:/iobroker/node_modules/iobroker.hs100, node: v12.16.1, js-controller: 3.1.5
                    2020-06-07 12:10:26.254 - error: hs100.0 (8208) [create_state] : TCP Timeout, stack: Error: TCP Timeout
                    2020-06-07 12:10:36.265 - warn: hs100.0 (8208) getDevice Socket connection Timeout : 192.168.1.240
                    • surfer09S surfer09
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #130
                      @surfer09 sind alle Dosen erreichbar und am Strom ???
                      wenn nicht soltest du diese auf disable setzten ..
                      zeigmal deine konfuguration Seite
                      surfer09S 1 Antwort Letzte Antwort
                      • arteckA arteck
                        surfer09S Offline
                        surfer09S Offline
                        surfer09
                        schrieb am zuletzt editiert von surfer09
                        #131
                        @arteck: Ja, sind definitiv alle erreichbar. Bei mir tauchen auch immer wieder in unregelmäßigen Abständen diese Meldungen im LOG auf:
                        2020-06-07 21:26:29.030 - info: hs100.0 (3664) terminating
                        2020-06-07 21:26:29.031 - info: hs100.0 (3664) Terminated (NO_ERROR): Without reason
                        2020-06-07 21:26:29.562 - error: host.IO-Broker-Server Caught by controller[1]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.564 - error: host.IO-Broker-Server Caught by controller[1]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[1]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[2]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[2]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[2]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[3]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[3]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[3]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[3]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[4]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.565 - error: host.IO-Broker-Server Caught by controller[4]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[4]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[4]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[5]: TCP 192.168.1.182:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[5]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[5]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[5]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[6]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[6]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[6]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[6]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[7]: TCP 192.168.1.182:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[7]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[7]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[7]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[8]: TCP 192.168.1.240:9999 Error: TCP Timeout
                        2020-06-07 21:26:29.566 - error: host.IO-Broker-Server Caught by controller[8]: at Timeout._onTimeout (I:\iobroker\node_modules\tplink-smarthome-api\lib\network\tcp-socket.js:62:22)
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[8]: at listOnTimeout (internal/timers.js:549:17)
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[8]: at processTimers (internal/timers.js:492:7)
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: TCP 192.168.1.182:9999 Error: read ECONNRESET
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: at TCP.onStreamRead (internal/stream_base_commons.js:205:27) {
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: errno: 'ECONNRESET',
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: code: 'ECONNRESET',
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: syscall: 'read'
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[9]: }
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: TCP 192.168.1.182:9999 Error: read ECONNRESET
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: at TCP.onStreamRead (internal/stream_base_commons.js:205:27) {
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: errno: 'ECONNRESET',
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: code: 'ECONNRESET',
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: syscall: 'read'
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[10]: }
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[11]: TCP 192.168.1.182:9999 Error: read ECONNRESET
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[11]: at TCP.onStreamRead (internal/stream_base_commons.js:205:27) {
                        2020-06-07 21:26:29.567 - error: host.IO-Broker-Server Caught by controller[11]: errno: 'ECONNRESET',
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[11]: code: 'ECONNRESET',
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[11]: syscall: 'read'
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[11]: }
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: TCP 192.168.1.182:9999 Error: read ECONNRESET
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: at TCP.onStreamRead (internal/stream_base_commons.js:205:27) {
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: errno: 'ECONNRESET',
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: code: 'ECONNRESET',
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: syscall: 'read'
                        2020-06-07 21:26:29.568 - error: host.IO-Broker-Server Caught by controller[12]: }
                        2020-06-07 21:26:29.568 - info: host.IO-Broker-Server instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR
                        Den Screenshot habe ich mit angehangen.
                        Und wie schon beschrieben, deinen Adapter von GitHub bekomme ich bei mir nicht auf „grün“. Ich bin aktuell auf Version 1.1.5 zurück gegangen.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #132
                          @surfer09 ok puss uff
                          installiere nochmal die 2.0.. mach bitte die .240 und die .182 im Adapter aus..
                          läuft der dann ?
                          wenn nicht mach den bitte mal auf Debug und poste das LOG
                          • arteckA arteck
                            läuft der dann ?
                            surfer09S Offline
                            surfer09S Offline
                            surfer09
                            #133
                            @arteck Gerade den Adapter in Version 2.0 installiert und die beiden Geräte deaktiviert - siehe da - der Status wird grün. Was ist denn mit den beiden Steckdosen?
                              surfer09S Offline
                              surfer09S Offline
                              surfer09
                              #134
                              @arteck : Ich glaub' ich weiß, woran es liegen könnte! Er hat mit der einen Steckdose ein Problem, wo die Firmware noch nicht auf Version 1.5.6 ist. Diese Steckdose ist noch auf der 1.5.4. Sobald ich diese im Adapter aktiviere, bleibt der Status auf gelb und der Adapter startet nicht.
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #135
                                @surfer09
                                versuchmal folgendes
                                adapter stoppen
                                lösche nur den einen Datenpunkt (zb _240)
                                der wird dann neu erstellt bei adapter start
                                aktiviere die _240 dose und starte den adapter
                                • arteckA arteck
                                  @surfer09
                                  adapter stoppen
                                  surfer09S Offline
                                  surfer09S Offline
                                  surfer09
                                  #136
                                  @arteck Geht nicht. Ich habe den kompletten Datenpunkt gelöscht, sobald ich das Gerät wieder aktiviere, startet der Adapter nicht mehr.
                                  Er erzeugt aber auch den Datenpunkt nicht mehr.
                                    stenmic
                                    #137
                                    ich konnte heute problemlos auf 2.0 aktualisieren. Melde mich wieder wenn ich Ergebnisse habe.
                                      stenmic
                                      #138
                                      bisher sieht alles gut aus, kein einziger Fehler im LOG.
                                        skokarl
                                        #139
                                        hab gerade auch mal aktualisiert, Update lief schonmal fehlerfrei.
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #140
                                          @surfer09 dann mach alles aus nur den einen _240 an.. und debug infos an.. vielleicht bekommen wir das so raus
                                          sonst update der Dose auf neue Firmware
