  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    5.4k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 422.8k Aufrufe 101 Beobachtet
  • premoP Online
    premoP Online
    premo
    #761
    Danke für die bisherige Hilfe.
    @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
    Passwort, Username, API Key kontrollieren
    Passen alle soweit
    API's verknüpft?
    GARDENA smart system API ist verknüpft
    Und was ist das?
    authentication_host: https://ssp.dss.husqvarnagroup.com
    Habe so im Adapter stehen lassen.
    Neuer Log :
    2022-04-08 17:27:39.139  - info: smartgarden.0 (6652) Got terminate signal TERMINATE_YOURSELF
    2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) 3/ cleaned everything up...
    2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) terminating
    2022-04-08 17:27:39.142  - info: smartgarden.0 (6652) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-08 17:27:39.720  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2022-04-08 17:27:41.665  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 started with pid 11592
    2022-04-08 17:27:43.593  - info: smartgarden.0 (11592) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
    2022-04-08 17:27:43.626  - info: smartgarden.0 (11592) 3/ getConnection...
    2022-04-08 17:27:43.627  - info: smartgarden.0 (11592) 3/ connectToGardena...
    2022-04-08 17:27:43.630  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
    2022-04-08 17:27:43.632  - info: smartgarden.0 (11592) 3/ connecting to Gardena Smart System Service ...
    2022-04-08 17:27:43.633  - info: smartgarden.0 (11592) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://api.authentication.husqvarnagroup.dev
    2022-04-08 17:27:43.713  - info: smartgarden.0 (11592) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
    2022-04-08 17:27:43.720  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    2022-04-08 17:27:43.726  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
    2022-04-08 17:27:43.727  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
    2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    2022-04-08 17:27:44.063  - info: smartgarden.0 (11592) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXX-XXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    2022-04-08 17:27:44.064  - info: smartgarden.0 (11592) 3/ get_locations ...
    2022-04-08 17:27:44.271  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
    2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure: response.statusCode/Message=400/Bad Request
    2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure:..return with error
    2022-04-08 17:27:44.273  - error: smartgarden.0 (11592) Error: request returned 400 Bad Request
    2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
    2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ getConnection: returned connection error: request returned 400 Bad Request
    2022-04-08 17:27:44.274  - info: smartgarden.0 (11592) 3/ getConnection: trying to connect again in 300 seconds
    2022-04-08 17:27:44.372  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    2022-04-08 17:27:44.374  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    jpgorganizerJ 1 Antwort Letzte Antwort
    • premoP premo
      Passen alle soweit
      API's verknüpft?
      Und was ist das?
      Neuer Log :
      jpgorganizerJ Offline
      jpgorganizer
      #762
      @premo sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      vergleich mal deine Eingaben der Webadressen mit den Angaben in der Doku
      smartgarden Adapter für GARDENA smart system
      Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
      premoP 1 Antwort Letzte Antwort
      • jpgorganizerJ jpgorganizer
        premoP Online
        premoP Online
        premo
        #763
        Danke, jetzt läuft es .
        • P Pino72
          Ich denke es hat sich erledigt, hatte den Ping auf 200 statt 150 Sekunden gesetzt...jetzt mit 150 Sekunden scheint es durch zu laufen.
          Pino72
          #764
          @pino72 said in [neuer Adapter] smartgarden adapter for Gardena smart system:
          Hab mich zu früh gefreut, seit gestern wieder die regelmäßigen Abbrüche wie vorher, Ping ist auf 150. Hab es jetzt mal auf 100 gesetzt mal sehen ob das was ändert.
          Scheint ja irgendwie noch nicht klar warum Gardena die Verbindung einfach so trennt ohne ersichtlichen Grund.
          B 1 Antwort Letzte Antwort
            berndpehome
            #765
            Bei mir auch Gelb, Ping auf 200 brachte gestern Grün und Heute wieder Gelb.
            Letztes Jahr lief der Adapter ohne Probleme
            • B berndpehome
              jpgorganizer
              #766
              Lässt sich eigentlich die Verbindung dann sofort wieder aufbauen? Oder geht das nicht?
              B 2 Antworten Letzte Antwort
              • P Pino72
                BlueBook
                #767
                same here. Über den Winter hatte ich den Adapter aus.
                Seit 2-3 Wochen nun diese Probleme.
                Die Verbindung wird nach (ich weiß es noch nicht genau) irgendwas zwischen 3-5 Stunden gekappt.
                Der Adapter geht dann auf gelb.
                Ping hatte ich 150, dann auf 200 - nach dem oberen Forumseintrag.
                Jetzt auf 100 - mal schauen, ob es hilft.
                  BlueBook
                  schrieb am zuletzt editiert von BlueBook
                  #768
                  @jpgorganizer Fehler wird durch einen Neustart bei mir direkt behoben.
                  Wobei ich den bisher immer erst deutlich später machen - weil mir der Fehler erst später auffällt.
                  Leider ist das log dann meist schon wieder leer geräumt, daher kann ich es nicht genau sagen
                  Btw: Danke für den tollen Adapter!! :)
                  • B BlueBook
                    stevie77
                    #769
                    @bluebook Genau das Problem habe ich auch seit ein paar Tagen. Läuft ein paar Stunden und dann geht die Instanz auf gelb. Log muss ich nachreichen, heute Nacht sah es so aus, als hätte ich einen Restart gemacht, bin mir aber nicht mehr ganz sicher.
                      BlueBook
                      #770
                      Folgendes konnte ich gerade aus dem lo fischen.
                      Ping bei 100
                      smartgarden.0 2022-04-10 13:35:13.281 info (2029) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                      smartgarden.0 2022-04-10 13:35:13.260 info (2029) 3/ sgSetState: info.connection value=false ack=true
                      smartgarden.0 2022-04-10 13:35:13.259 info (2029) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
                      • B BlueBook
                        Ping bei 100
                        stevie77
                        schrieb am zuletzt editiert von stevie77
                        #771
                        Kann ich bestätigen. Ich hatte das heruntergeladene Logfile anfangs falschherum gelesen. ;-)
                        2022-04-10 04:12:35.352  - info: smartgarden.0 (16350) 2/ get_locations: successful / response.statusMessage: OK
                        2022-04-10 04:12:35.353  - info: smartgarden.0 (16350) 2/ get_locations ... locations={"data":[{"id":"5feeadcd-2e5a[xyz]48f082f6","type":"LOCATION","attributes":{"name":"My Garden"}}]}
                        2022-04-10 04:12:35.355  - info: smartgarden.0 (16350) 2/ get_websocket ...
                        2022-04-10 04:12:35.694  - info: smartgarden.0 (16350) 2/ get_websocket successful: response.statusCode/Message=201/Created
                        2022-04-10 04:12:35.707  - info: smartgarden.0 (16350) 2/ get_websocket ... websocket ok
                        2022-04-10 04:12:35.912  - info: smartgarden.0 (16350) 2/ on_open: ### connected ###
                        2022-04-10 04:12:36.459  - info: smartgarden.0 (16350) 2/ parseMessage: LOCATION found
                        2022-04-10 04:12:36.466  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                        2022-04-10 04:12:36.472  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                        2022-04-10 04:12:36.482  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                        2022-04-10 04:12:36.496  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                        2022-04-10 04:12:36.615  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                        2022-04-10 04:12:36.626  - info: smartgarden.0 (16350) 2/ parseMessage: POWER_SOCKET found
                        2022-04-10 04:12:36.642  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        2022-04-10 04:12:36.650  - info: smartgarden.0 (16350) 2/ parseMessage: SENSOR found
                        2022-04-10 04:12:36.658  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        2022-04-10 04:12:36.673  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                        2022-04-10 04:12:36.698  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        2022-04-10 04:12:36.723  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                        2022-04-10 04:12:36.729  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                        2022-04-10 04:12:36.736  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        2022-04-10 04:12:36.742  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                        2022-04-10 04:12:36.748  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                        2022-04-10 04:12:36.755  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        Danach wird gepongt und anderes...
                        2022-04-10 05:57:35.973  - info: smartgarden.0 (16350) 2/ on_pong: ++ pong'ed ++
                        2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                        2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                        2022-04-10 05:57:36.348  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                        2022-04-10 05:57:36.349  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                        Und dann exakt 2 Stunden nach dem Start nur die eine Zeile (und danach keine Pongs mehr):
                        2022-04-10 06:12:35.884  - info: smartgarden.0 (16350) 2/ on_close: ### closed ### close.code=1001 close.reason=Going away
                        • S stevie77
                          premoP Online
                          premoP Online
                          premo
                          schrieb am zuletzt editiert von premo
                          #772
                          @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          Hallo
                          Habe auch das Problem und bis es eine Lösung gibt ein Blockly angelegt
                          der den Datenpunkt Device or service connected von false auf true schaltet.
                          Mit der Eventlist Instanz sehe wann die Verbindung abbricht.
                          • premoP premo
                            Hallo
                            jpgorganizer
                            #773
                            Hallo
                            das nützt aber wohl nix, da hast du nur den Farbeimer rausgeholt.
                              Hallo
                              jpgorganizer
                              #774
                              schaut mal hier. Wäre hilfreich, wenn ihr mit-testen würdet
                              https://github.com/jpgorganizer/ioBroker.smartgarden/issues/43#issuecomment-1094299783
                                berndpehome
                                #775
                                Habe jetzt bei Version 1.0.5 die Api Version ausgetauscht, bleibt Gelb.
                                Downgrade auf Version auf 1.0.4 macht den Adapter wieder Grün, wenn ich auf Aktualisieren der Instanz gehe wird er wieder Gelb und bleibt auch Gelb,
                                neustarten macht ihn aber wieder Grün, das funktioniert bei Version 1.0.5 nicht.
                                • C Offline
                                  Cosmicbase
                                  schrieb am zuletzt editiert von Cosmicbase
                                  #776
                                  Hallo, in der Gardena Smart Garden App kann man doch die aktuelle Temperatur und Bodenfeuchte durch "Swipe to Refresh" aktualisieren.
                                  Damit wird auch der Timestamp im Adapter neu gesetzt.
                                  Kann ich das Szenario auch im Adapter durchführen.
                                  Ich will den manuellen Refresh nicht immer in der App machen.
                                  Vielen Dank für die Hilfe.
                                  • C Cosmicbase
                                    jpgorganizer
                                    #777
                                    @cosmicbase sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    da geht es um den Sensor? wenn ja, dann nein. Meines wissens hat der Sensor über die Public API keine Abfragemöglichkeit.
                                    C 1 Antwort Letzte Antwort
                                    • B berndpehome
                                      jpgorganizer
                                      #778
                                      @berndpehome sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                      sorry, aber das ist mir zu wirr
                                        Cosmicbase
                                        #779
                                        @jpgorganizer
                                        Ja ich meinte den Sensor. In der App kann man bei der Temp. und Bodenfeuchte einen refresh machen.
                                        Hätte gedacht das es im Adapter auch möglich ist. Wäre durchaus sinnvoll um kurzfristig neue Werte zu bekommen.
                                        • C Cosmicbase
                                          @jpgorganizer
                                          jpgorganizer
                                          schrieb am zuletzt editiert von jpgorganizer
                                          #780
                                          @jpgorganizer
                                          ob sinnvoll oder nicht sinnvoll. Darum geht es nicht. Es geht ums "möglich sein".
                                          Aktuell gibt es in der API kein Kommando für den Sensor.
                                          Bisher habe ich den Sensor auch immer so verstanden, dass er neue Werte schickt, wenn es neue Werte gibt. Wenn das so ist, dann braucht man nicht abfragen, bzw. man bekommt auch nichts anderes zurück als man schon weiß.
                                          Aber ich hab keinen Sensor, somit kann ich es nicht prüfen.
