  4. [Vorstellung] Meine dritte VIS
    2.2k
    4.1k
visvis projekte
640 Beiträge 83 Kommentatoren 229.4k Aufrufe 117 Beobachtet
  • K Offline
    Kuddel
    #201
    @hofmannha
    CPU: info.0.sysinfo.cpu.currentLoad.currentload
    RAM: javascript.0.ressourcen.iobroker.iobroker_ram_usage
    Skript zum umrechen:
     <variables>
       <variable type="" id="O.j^v!]+^bg2::gZwGtK">ram_total</variable>
       <variable type="" id="7pyA@#Kp~LlnIk[brWNK">ram_usage</variable>
     </variables>
     <block type="comment" id="?B=ttbjkwQuxKt39J3FR" x="-562" y="-487">
       <field name="COMMENT">Iobroker RAM Nutzung</field>
       <next>
         <block type="variables_set" id="MR[RP)5PGL(?D3{_J^ZV">
           <field name="VAR" id="O.j^v!]+^bg2::gZwGtK" variabletype="">ram_total</field>
           <value name="VALUE">
             <block type="get_value" id="(~k.kk2Ym/]k1wlVUzfL">
               <field name="OID">info.0.sysinfo.memory.info.total</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="D){=B{N1D:@hKDX8IEE)" collapsed="true">
               <value name="OID0">
                 <shadow type="field_oid" id="!F8cVi!af9@O4ndgQ2Dy">
                   <field name="oid">info.0.sysinfo.memory.info.active</field>
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="variables_set" id="DqE?8a)v}]p](dvT5LJE">
                   <field name="VAR" id="7pyA@#Kp~LlnIk[brWNK" variabletype="">ram_usage</field>
                     <block type="math_arithmetic" id="dGE8$h_)T%@95z=EgK$|">
                       <field name="OP">MULTIPLY</field>
                       <value name="A">
                         <shadow type="math_number" id="@rLNGf@%a[-Nb5%qo]VI">
                           <field name="NUM">100</field>
                         </shadow>
                       </value>
                       <value name="B">
                         <shadow type="math_number" id="bmfleZldj$g`/dmoU6me">
                         </shadow>
                         <block type="math_arithmetic" id="D:0$i;Dk,i-7-t$upkmR" inline="false">
                           <field name="OP">DIVIDE</field>
                           <value name="A">
                             <shadow type="math_number" id="6qH+TvdFHfOos4m:IAD/">
                             </shadow>
                             <block type="get_value" id="l*m$n38G[LfM^|G1+~L_">
                               <field name="OID">info.0.sysinfo.memory.info.used</field>
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="4;sclejA}gIFJ,gBkbnB">
                             </shadow>
                             <block type="variables_get" id="dvctta$?gNNV#!?9N2S,">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="control" id="OPCg|}Ap[_^8V@2v2{NI">
                       <field name="OID">javascript.0.ressourcen.iobroker.iobroker_ram_usage</field>
                         <block type="variables_get" id="Se~R9^}TMu=:F7~kbL7J">
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    H 1 Antwort Letzte Antwort
    • K Kuddel
      @hofmannha
       <variables>
       </variables>
         <next>
               </block>
             </value>
             <next>
                 <value name="OID0">
                   </shadow>
                 </value>
                         <value name="A">
                           </shadow>
                         </value>
                         <value name="B">
                           </shadow>
                             <value name="A">
                               </shadow>
                               </block>
                             </value>
                             <value name="B">
                               </shadow>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      hofmannha
      #202
      @Kuddel
      Hallo Kuddel,
      vielen Dank für deine Antwort. Wie wird das Script aufgerufen. Irgendwie blicke ich da nicht durch.
      Ich kriege eine Ram Auslastung von 168%. Was muß ich da machen?
      Eine Linie sehe ich auch nicht im Diagramm.
      K 1 Antwort Letzte Antwort
      • H hofmannha
        @Kuddel
        Hallo Kuddel,
        Kuddel
        #203
        @hofmannha das aufzeichnen der werte mit dem History Adapter hast du aktiviert ?
        Das Skript wird jedes mal gestartet, wenn sich der Wert "Memory Active" vom Info Adapter ändert
        H 2 Antworten Letzte Antwort
        • K Kuddel
          hofmannha
          #204
          @Kuddel
          Die Aufzeichnung hatte ich aktiviert.
          • K Kuddel
            hofmannha
            #205
            @Kuddel
            Ich habe mal die Daten in den Objekten angehängt.
            • H hofmannha
              @Kuddel
              hofmannha
              #206
              @hofmannha sagte in [Vorstellung] Meine dritte VIS:
              @Kuddel
              Bei mir werden nur Werte aufgezeichnet, wenn der Wert sich ändert. Aber die Werte ändern sich nicht, das ist das Problem.
              • H hofmannha
                @Kuddel
                Kuddel
                #207
                @hofmannha wenn sie die Werte nicht ändern, dann läuft dein Info Adapter nicht korrekt
                • K Kuddel
                  hofmannha
                  #208
                  @Kuddel
                  Guten Morgen Kuddel,
                  könntest Du meine Einstellungen im Flot-Editor mal mit deinen vergleichen.
                  Ich bin kein Flot-Spezialist.
                  Gruß und Danke für die bisherige Info
                  • K Kuddel
                    hofmannha
                    #209
                    @Kuddel
                    hier ist standardmäßig ein Haken gesetzt.
                    Der muß doch sicherlich entfernt werden?
                    • V Offline
                      V Offline
                      vsa
                      #210
                      Hallo alle zusammen hier,
                      auch ich lerne hier almählich hinzu, jedoch mit der VIS habe ich mich leider nur minimal bisher beschäftigt. Vielleicht kann mir jemand von Euch auf die Sprünge helfen (voll Anfänger diesbezüglich, sorry.) Ganz am Anfang (vielleicht hilft das weiteren Beginnern dann auch...)
                      VIS_v3 vom 24.02.2020: VIS_V3.zip
                      Icons: Meine_Icons.rar
                      1. Meine_Icons.rar entpacken
                      2. VIS_v3.zip entpacken
                      3. Die beiden VIS-Datein und die den Icons Ordner zu einem neuen Zip Archiv >zusammefügen
                      4. Das neue Zip archiv importieren
                      5. Wie gewohnt im VIS Editor importieren
                      Punkt 3: Mein Zip ist gepackt. Sind die zwei Files von VIS_v3 innerhalb von "Meine Icons" Ordner oder außerhalb (oder ist das völlig egal?)
                      Punkt 4: Das neue Zip-Archiv dann via Dateibrowser importieren geht (so war es wohl gemeint, oder?). -> In welchem Verzeichnis soll es dann liegen? vis.0?
                      Punkt5: Ich denke, es ist schon unter Punkt 4 via Dateibrwoser importiert worden... wie ist das hier gemeint? Es muss ja irgendwie wohl entpackt werden?
                      Wäre toll, wenn jmd von Euch diese völligen Anfängerfragen beantworten könnte (mit den Javascipts/Blockys komme ich deutlich besser zurecht...)
                      Danke, vsa
                      • V vsa
                        Danke, vsa
                        Kuddel
                        #211
                        @vsa mach mal einen Screenshot von deinem Archiv, ob die Struktur so richtig ist.
                        Du sollst das Archiv im VIS Editor importieren. Habe ich vllt. ein wenig unglücklich formuliert;
                        • V Offline
                          V Offline
                          vsa
                          #212
                          Hallo Kuddel,
                          danke schon mal. So sieht bei mir das zusammengefügte ZIP aus.
                          • K Kuddel
                            hofmannha
                            #213
                            @Kuddel
                            Hallo Kuddel,
                            ich hoffe, dass ich diesmal eine Antwort von Dir bekomme.
                            In welchem Script befindet sich diese Berrechnung ccu.ccu_cpu_usage.
                            Bei mir läuft Homematic auf einem anderen Raspberry.
                            • H hofmannha
                              @Kuddel
                              Kuddel
                              #214
                              @Kuddel
                              ja genau, ich habe den haken auch nicht gesetzt
                              • V vsa
                                Hallo Kuddel,
                                Kuddel
                                #215
                                @vsa bei mir sieht der Export so aus:
                                • H hofmannha
                                  @Kuddel
                                  Hallo Kuddel,
                                  Kuddel
                                  #216
                                  @hofmannha remote_abfragen heißt das Skript:
                                  • C Offline
                                    Corallus
                                    schrieb am zuletzt editiert von Corallus
                                    #217
                                    Hallo Kuddel
                                    zuerst mal vielen dank das du deine Arbeit Online stellst, du hilfst mir damit sehr.
                                    Ich habe dein Projekt Importiert das einzige was ich momentan nicht finde ist der Speedtest.
                                    Ich habe hier keine Objekte mit den Namen Speedtest drin
                                    Kannst du mir bitte weiterhelfen
                                    javascript.0.Speed-Test.data.speeds.upload
                                    Vielen dank
                                    GlasfaserG K 2 Antworten Letzte Antwort
                                    • C Corallus
                                      Hallo Kuddel
                                      Vielen dank
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      #218
                                      @Corallus
                                      Du mußt das Skript Speedtest einmal starten , dann werden auch die Datenpunkte erzeugt !
                                      • K Kuddel
                                        hofmannha
                                        #219
                                        @Kuddel
                                        vielen vielen Dank für deine Info.
                                        Hast Du ioBroker auf zwei unterschiedlichen Systemen laufen?
                                        • C Corallus
                                          Hallo Kuddel
                                          Vielen dank
                                          Kuddel
                                          #220
                                          @Corallus dir fehlt der speed-test Adapter
