  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 650.7k Aufrufe 118 Beobachtet
  • S Spampunk
    @Thomas-Braun
    So, neuer Token, neues Glück. Die DP füllen sich fleißig, nur in der Map wird weiterhin nichts angezeigt. Der Sauger taucht weiterhin nicht im Adapter auf.
    Log-Update:
    mihome-vacuum.0	2020-12-04 19:20:12.512	info	(5381) create state for carpet_mode
    mihome-vacuum.0	2020-12-04 19:20:10.084	info	(5381) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-12-04 19:20:09.758	info	(5381) New generation or new fw detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-12-04 19:20:09.674	warn	(5381) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.0	2020-12-04 19:20:09.672	warn	(5381) Object mihome-vacuum.0.info.water_box is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.0	2020-12-04 19:20:09.608	info	(5381) create states for water box filter
    mihome-vacuum.0	2020-12-04 19:20:09.607	info	(5381) create states for water box
    mihome-vacuum.0	2020-12-04 19:20:09.575	info	(5381) Connected
    mihome-vacuum.0	2020-12-04 19:20:09.494	info	(5381) Disconnect
    mihome-vacuum.0	2020-12-04 19:20:09.474	info	(5381) Cloud control disabled
    mihome-vacuum.0	2020-12-04 19:20:09.472	info	(5381) Expert mode enabled, states created
    mihome-vacuum.0	2020-12-04 19:20:09.361	info	(5381) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.0, js-controller: 3.1.6
    mihome-vacuum.0	2020-12-04 19:20:08.614	warn	(5381) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.0	2020-12-04 19:20:08.609	warn	(5381) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.0	2020-12-04 19:20:02.490	info	(2336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0	2020-12-04 19:20:02.488	info	(2336) terminating
    mihome-vacuum.0	2020-12-04 19:20:02.486	info	(2336) Got terminate signal TERMINATE_YOURSELF
    Das heißt, dass man dem Sauger mal lieber eine feste IP zuordnen sollte, damit der Token nicht eines Tages vom DHCP zerschossen wird?
    #1241
    @Spampunk sagte in Test Adapter mihome-vacuum v2.0.x:
    ? Du bekommst doch Daten von dem Ding.
    cd /opt/iobroker
    npm list canvas
    • S Spampunk
      @Thomas-Braun
      Log-Update:
      #1242
      Das hat mit dem DHCP nix zu tun. Wenn du auf dem Sauger das WLAN resettest, dann ändert sich das Token. Nicht wenn der DHCP-Server da lustige Dinge tut.
        Spampunk
        schrieb am zuletzt editiert von Spampunk
        #1243
        iobroker.inst@2.0.3 /opt/iobroker
        ├─┬ iobroker.iot@1.5.3
        │ └── canvas@2.6.1
        └─┬ iobroker.mihome-vacuum@2.0.7
          └── canvas@2.6.1  deduped
        timo@iota:/opt/iobroker$
        Ich übe fleissig :)
        • S Spampunk
          │ └── canvas@2.6.1
          Ich übe fleissig :)
          #1244
          @Spampunk
          Passt soweit. In CodeTags wäre es noch schöner. :-)
          Hast du in den Einstellungen des Adapters jetzt auch mal mit den Einstellungen zur Map rumgespielt? Insbesondere mit dem 'Enable map from Xiaomi'-Punkt?
            @Spampunk
            Spampunk
            #1245
            @Thomas-Braun
            Ja, das habe ich.
            • S Spampunk
              @Thomas-Braun
              Ja, das habe ich.
              #1246
              @Spampunk Dann weiß ich dazu auch nix weiter.
              Einen Datenpunkt zu der Map hast du aber in den Objekten?
                Spampunk
                #1247
                @Thomas-Braun
                Ja, der ist angelegt, aber halt leer.
                Macht es Sinn, eine Adapter-Version von Github zu wählen?
                Meines Erachtens gibt es leider noch nichts Spezielles für die Modelle, die auch mit der Roborock-App funktionieren, oder?
                Auf jeden Fall danke ich Dir für Deine Zeit und Hilfe!
                Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
                • S Spampunk
                  @Thomas-Braun
                  #1248
                  @Spampunk
                  Kann sein, dass sich der DP erst bei laufendem Sauger füllt.
                  Und bevor du auf git springst würde ich es eher mit der Version aus 'Beta/Latest' probieren. Temporär den Verwahrort umstellen, nur den einen Adapter hochziehen und dann wieder auf 'default' zurückstellen.
                  Eigentlich meine ich aber, dass auch deine 2.0.7 das mit den Maps können sollte.
                  • S Spampunk
                    @Thomas-Braun
                    da_WoodyD Online
                    da_WoodyD Online
                    da_Woody
                    #1249
                    @Spampunk hast du den lauser schon mal die bude abdüsen lassen? wenn nicht, woher soll er dann eine map haben?
                    soweit ich mich erinnere hat mein robrockS6 dann erst die map aufgebaut.
                    gruß vom Woody
                      @Spampunk
                      Spampunk
                      #1250
                      @Thomas-Braun
                      Ich habe jetzt mal auf Adapter Version 2.1.1 gewechselt. Ich glaube, der braucht etwas Zeit, um die DPs einzulesen.
                      @da_Woody
                      ich hatte einen ähnlichen Gedanken, da ich die erste Map mit der Roborock App erzeugt hatte. Also habe ich diese gelöscht und dann noch einmal in der Mi Home App neu aufgebaut. Es kann natürlich sein, dass der Rocky tatsächlich mehr Zeit braucht. Daher denke ich, ich werde den Adapter in dieser Version mal mit dem Sauger laufen lassen uns etwas abwarten.
                      Ach Woody: kannst Du vielleicht schildern, wie Du vorgegangen bist, um Deinen S6 bei iobroker einzubinden?
                      Ich melde mich dann wieder hier.
                      Vielen Dank Euch beiden bis hierhin :)
                      • S Spampunk
                        @Thomas-Braun
                        @da_Woody
                        da_WoodyD Online
                        da_WoodyD Online
                        da_Woody
                        #1251
                        @Spampunk said in Test Adapter mihome-vacuum v2.0.x:
                        hmm, eigentlich nix besonderes. bis auf den fehler, das ich aus dummheit erstmal die roborock app am handy installiert hatte um dann festzustellen, das das mit adapter nicht tutet.
                        also xiaomi app, erkennen lassen, wie üblich eine IP an die MAC binden. natürlich vorher noch den cloudlogin bei xiaomi herstellen. mail, pass, server (germany), get devices, ip und token unten eingetragen.
                        hab dann noch eine fertige view gefunden die ich für mich angepasst hab. dank an denjenigen...
                        edith: achja, ich hab die 2.1.1 installiert.
                        gruß vom Woody
                        • Holger EtzelH Offline
                          Holger Etzel
                          #1252
                          Hallo, bekomme nach Eingabe der Zugangsdaten und des Servers und nach drücken des Buttons "get Device" keine Devices angezeigt. Das Auswahlfenster bleibt leer.
                          Ich arbeite aktuell mit der Roborock-App auf meinem Smartphone oder muss hier die xiaomi home app verwendet werden?
                          Mir scheint es so das keine Gerätedaten zum Server übertragen werden und ich deshalb keine TOken bekomme.
                          Kann mir hier jemand helfen, danke schon mal im vorraus.
                          LG
                          Holger
                          • Holger EtzelH Holger Etzel
                            LG
                            Holger
                            #1253
                            @Holger-Etzel Soweit ich weiß musst du dafür eine mi-ID von Xiaomi haben. Ich glaube über die Roborock-App gibt es die nicht, nur über die mihome-App von Xiaomi.
                            • da_WoodyD da_Woody
                              Spampunk
                              #1254
                              @da_Woody
                              Mich würde interessieren, ob Dein S6 im Reiter "Main" gefunden wurde.
                              Wenn ich mich auf der Website von Xiaomi anmelde, werden mir auch keine Geräte angezeigt. Hier müsste doch an sich der S5 Max hinterlegt sein, oder? Vielleicht erklärt das, warum er im Adapter kein Gerät findet.
                              Im Grunde ist mir das alles Wurst, denn ich kann meinen Rocky nun über die DPs steuern. Ich möchte halt nur noch die Karte zusätzlich haben...
                              • S Spampunk
                                @da_Woody
                                da_WoodyD Online
                                da_WoodyD Online
                                da_Woody
                                #1255
                                @Spampunk jop, wird er...
                                wo sollte ich sonst den token her haben?
                                gruß vom Woody
                                  Spampunk
                                  #1256
                                  @da_Woody
                                  ich habe den Token z.B. aus der russischen Xiaomi Home App und es gibt noch einige weitere Methoden.
                                  Wenn Du Dich bei https://account.xiaomi.com/ anmeldest (Anmeldedaten wie bei der XH App), wird da unter Einstellungen, Geräte Dein Sauger aufgeführt?
                                  • S Spampunk
                                    @da_Woody
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    da_Woody
                                    #1257
                                    @Spampunk dort seh ich keine einstellungen/geräte. ich seh meinen S6 nur in der APP.
                                    gruß vom Woody
                                    H 1 Antwort Letzte Antwort
                                      Henny112
                                      #1258
                                      Moin zusammen. Gibt es schon eine Möglichkeit den Xiaomi 1S einzubinden? Bisher habe ich es noch nicht hin bekomme. Lg
                                      C DiginixD 2 Antworten Letzte Antwort
                                      • H Henny112
                                        Cristian
                                        #1259
                                        @Henny112 bei mir läuft schon seit langem, nichts besonderes gemacht, einloggen, Token + IP eingeben, fertig. Nutze aber nur die Xiaomi Cloud, nicht Valetudo.
                                        • C Cristian
                                          Henny112
                                          #1260
                                          @Cristian Hallo. Was mache ich falsch habe noch einen Sauger drin. Habe im Iobroker den Port geändert kann ich das auch am Sauger? Bzw wie? Bei mir ist er nur gelb.
