  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 652.1k Aufrufe 118 Beobachtet
  • MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    #481
    Ihr Glückspilze!
    ich bekomme die nicht mal installiert.
    $ ./iobroker upgrade mihome-vacuum
    Update mihome-vacuum from @1.1.5 to @2.0.7
    NPM version: 6.13.4npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error gyp
    ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR!
    cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR!
     code
     ELIFECYCLE
    npm
    ERR!
    errno 1
    npm
    ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm
    ERR! Exit status 1
    npm ERR!
     npm
     ERR!
     Failed at the canvas@2.6.1 install script.npm
     ERR!
     This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-03T05_40_34_693Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.mihome-vacuum@2.0.7: 1
    IObroker auf dem NUC als VM.
    • MathiasJM MathiasJ
      Ihr Glückspilze!
      gyp
      node-pre-gyp
       ERR! build error
      npm
       ERR!
       code
       ELIFECYCLE
      npm
      ERR!
      errno 1
      npm
      npm
      ERR! Exit status 1
      npm ERR!
       npm
       ERR!
       ERR!
      D Nicht stören
      D Nicht stören
      dirkhe
      #482
      @MathiasJ Readme!
      MathiasJM 1 Antwort Letzte Antwort
      • D dirkhe
        @MathiasJ Readme!
        MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        schrieb am zuletzt editiert von MathiasJ
        #483
        @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
        @MathiasJ Readme!
        ist installiert... muß mich erst mal einlesen, um die Karte ins VIS übertragen zu können.
        • K Online
          K Online
          K_o_bold
          #484
          @Meistertr ,
          ich bekomme immer wieder diesen error, obwohl er die Karte richtig lädt:
          (1462) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Tue, 03 Mar 2020 10:51:09 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6b964dae-6380-8e
          mihome-vacuum.0	2020-03-03 11:50:41.160	error	(
          Adapter Version 2.0.7
          Roborock S50
          • K K_o_bold
            @Meistertr ,
            Roborock S50
            DiginixD Offline
            DiginixD Offline
            Diginix
            #485
            @K_o_bold Liest sich für mich nach einem 403 Forbidden welches der Adapter vom Xiaomi Server bekommt.
            Stell mal die Instanz auf Loglevel debug und schau mal im Log nach "Xiaomi Cloud: Login successful".
            Ansonsten wird sich @Meistertr schon dazu melden.
            ..:: So long! Tom ::..
              tombox
              schrieb am zuletzt editiert von tombox
              #486
              Gelöst nach 10min warten kamen die ersten Daten rein.
              Keine Verbindung zu S50 mit 2008 firmware mit Adapter 2.0.7 installiert via github
              mihome-vacuum.0	2020-03-03 14:04:16.825	debug	(1481) requesting params every: 60 Sec
              mihome-vacuum.0	2020-03-03 14:04:16.825	silly	(1481) sendMsg[1] >>> {"id":9,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:04:16.822	info	(1481) Connected
              mihome-vacuum.0	2020-03-03 14:04:16.820	silly	(1481) Receive <<< Helo <<< *************ffffffffffffffffffffffffffffffff
              mihome-vacuum.0	2020-03-03 14:04:16.815	info	(1481) Disconnect
              mihome-vacuum.0	2020-03-03 14:04:11.823	debug	(1481) no answer for get_status(id:8) received, giving up
              mihome-vacuum.0	2020-03-03 14:04:06.821	silly	(1481) sendMsg[3] >>> {"id":8,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:04:01.816	silly	(1481) sendMsg[2] >>> {"id":8,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:03:56.812	silly	(1481) sendMsg[1] >>> {"id":8,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:03:54.843	debug	(1481) no answer for get_room_mapping(id:7) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:54.839	debug	(1481) no answer for get_carpet_mode(id:6) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:52.551	debug	(1481) no answer for get_sound_volume(id:5) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:52.352	debug	(1481) no answer for get_clean_summary(id:4) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:52.149	debug	(1481) no answer for get_consumable(id:3) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:51.971	warn	(1481) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
              mihome-vacuum.0	2020-03-03 14:03:51.969	debug	(1481) no answer for miIO.info(id:2) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:51.948	debug	(1481) no answer for get_status(id:1) received, giving up
              mihome-vacuum.0	2020-03-03 14:03:49.840	silly	(1481) sendMsg[3] >>> {"id":7,"method":"get_room_mapping"}
              mihome-vacuum.0	2020-03-03 14:03:49.837	silly	(1481) sendMsg[3] >>> {"id":6,"method":"get_carpet_mode"}
              mihome-vacuum.0	2020-03-03 14:03:47.549	silly	(1481) sendMsg[3] >>> {"id":5,"method":"get_sound_volume"}
              mihome-vacuum.0	2020-03-03 14:03:47.350	silly	(1481) sendMsg[3] >>> {"id":4,"method":"get_clean_summary"}
              mihome-vacuum.0	2020-03-03 14:03:47.148	silly	(1481) sendMsg[3] >>> {"id":3,"method":"get_consumable"}
              mihome-vacuum.0	2020-03-03 14:03:46.966	silly	(1481) sendMsg[3] >>> {"id":2,"method":"miIO.info"}
              mihome-vacuum.0	2020-03-03 14:03:46.946	silly	(1481) sendMsg[3] >>> {"id":1,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:03:44.837	silly	(1481) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
              mihome-vacuum.0	2020-03-03 14:03:44.834	silly	(1481) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
              mihome-vacuum.0	2020-03-03 14:03:42.545	silly	(1481) sendMsg[2] >>> {"id":5,"method":"get_sound_volume"}
              mihome-vacuum.0	2020-03-03 14:03:42.347	silly	(1481) sendMsg[2] >>> {"id":4,"method":"get_clean_summary"}
              mihome-vacuum.0	2020-03-03 14:03:42.144	silly	(1481) sendMsg[2] >>> {"id":3,"method":"get_consumable"}
              mihome-vacuum.0	2020-03-03 14:03:41.962	silly	(1481) sendMsg[2] >>> {"id":2,"method":"miIO.info"}
              mihome-vacuum.0	2020-03-03 14:03:41.941	silly	(1481) sendMsg[2] >>> {"id":1,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:03:39.834	silly	(1481) sendMsg[1] >>> {"id":7,"method":"get_room_mapping"}
              mihome-vacuum.0	2020-03-03 14:03:39.831	silly	(1481) sendMsg[1] >>> {"id":6,"method":"get_carpet_mode"}
              mihome-vacuum.0	2020-03-03 14:03:39.820	debug	(1481) Xiaomi Cloud: Login successful
              mihome-vacuum.0	2020-03-03 14:03:37.542	silly	(1481) sendMsg[1] >>> {"id":5,"method":"get_sound_volume"}
              mihome-vacuum.0	2020-03-03 14:03:37.345	silly	(1481) sendMsg[1] >>> {"id":4,"method":"get_clean_summary"}
              mihome-vacuum.0	2020-03-03 14:03:37.341	info	(1481) set nächster Timer: Nicht verfügbar
              mihome-vacuum.0	2020-03-03 14:03:37.142	silly	(1481) sendMsg[1] >>> {"id":3,"method":"get_consumable"}
              mihome-vacuum.0	2020-03-03 14:03:37.003	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.rooms.addRoom:{"val":"Kartenindex oder Zonenkoordinaten einfügen","ack":true,"ts":1583240616994,"q":0,"from":"system.adapter.mihome-
              mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","
              mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.queue:{"val":0,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1583
              mihome-vacuum.0	2020-03-03 14:03:36.981	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
              mihome-vacuum.0	2020-03-03 14:03:36.980	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.wifi_signal:{"val":"unavailable","ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.use
              mihome-vacuum.0	2020-03-03 14:03:36.979	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616898,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
              mihome-vacuum.0	2020-03-03 14:03:36.975	silly	(1481) States system redis pmessage system.adapter.mihome-vacuum.0.logLevel/system.adapter.mihome-vacuum.0.logLevel:{"val":"silly","ack":true,"ts":1583240616891,"q":0,"from":"system.adapter.mihome-vac
              mihome-vacuum.0	2020-03-03 14:03:36.958	silly	(1481) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
              mihome-vacuum.0	2020-03-03 14:03:36.940	debug	(1481) requesting params every: 60 Sec
              mihome-vacuum.0	2020-03-03 14:03:36.938	silly	(1481) sendMsg[1] >>> {"id":1,"method":"get_status"}
              mihome-vacuum.0	2020-03-03 14:03:36.928	info	(1481) Connected
              mihome-vacuum.0	2020-03-03 14:03:36.925	silly	(1481) Receive <<< Helo <<< *****************************ffffffffffffffffffffffffffffffff
              mihome-vacuum.0	2020-03-03 14:03:36.819	debug	(1481) server started on 0.0.0.0:53421
              mihome-vacuum.0	2020-03-03 14:03:36.807	info	(1481) Disconnect
              mihome-vacuum.0	2020-03-03 14:03:36.781	info	(1481) Cloud control disabled
              mihome-vacuum.0	2020-03-03 14:03:36.778	info	(1481) Expert mode disabled, states deleted
              mihome-vacuum.0	2020-03-03 14:03:36.761	debug	(1481) Xiaomi Cloud: Logging in
              mihome-vacuum.0	2020-03-03 14:03:36.758	debug	(1481) load Map creator... true
              mihome-vacuum.0	2020-03-03 14:03:36.659	info	(1481) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
              • MeistertrM Meistertr
                @ilovegym bitte nochmal von git dann sollte alles wieder gehen aber bitte geräte neu einlesen, da sich was geändert hat
                #487
                @Meistertr Hi, ja, läuft alles jetzt, keine Fehler 👍🙂
                Dankeschön
                • J Offline
                  jensus11
                  #488
                  ich habe bei mir Valetudo installiert und einige Zonen angelegt.
                  Die online Anbindung habe ich per Firewall unterbunden, da ich schon 2x das Vergnügen hatte das sich der Gen1 auf eine neue FW geupdatet hat oder wie auch immer sich selber resetet hat.
                  Adapter 2.0.8 ist installiert, FW 3.3.9-003468 und Valetudo in 0.4.0.
                  Mir werden auch alle Daten und Infos angezeigt, nur leider die Karten oder Zonen nicht.
                  Was kann ich machen, würde so gerne über Alexa die einzelnen Zonen steuern.
                  • J jensus11
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    #489
                    @jensus11 bitte auf debug stellen und mal Log hier posten
                    • J Offline
                      jensus11
                      schrieb am zuletzt editiert von jensus11
                      #490
                      mihome-vacuum.0	2020-03-03 19:48:03.714	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3338,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
                      mihome-vacuum.0	2020-03-03 19:48:03.708	debug	(15538) sendMsg[1] >>> {"id":29,"method":"get_status"}
                      mihome-vacuum.0	2020-03-03 19:47:50.191	warn	(15538) Could not receive Mappointer, giving up
                      mihome-vacuum.0	2020-03-03 19:47:50.191	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":28}
                      mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) 9. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:49.681	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":27}
                      mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) 8. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) sendMsg[1] >>> {"id":27,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:49.160	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":26}
                      mihome-vacuum.0	2020-03-03 19:47:49.156	debug	(15538) 7. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:49.155	debug	(15538) sendMsg[1] >>> {"id":26,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:48.654	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":25}
                      mihome-vacuum.0	2020-03-03 19:47:48.642	debug	(15538) 6. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:48.641	debug	(15538) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:48.141	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":24}
                      mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) 5. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:47.616	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":23}
                      mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) 4. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) sendMsg[1] >>> {"id":23,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:47.109	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":22}
                      mihome-vacuum.0	2020-03-03 19:47:47.105	debug	(15538) 3. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:47.104	debug	(15538) sendMsg[1] >>> {"id":22,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:46.607	debug	(15538) CLEAN_LOGGING[{"Datum":"3.3","Start":"19:02","Saugzeit":"4 min","Fläche":"7.17 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"16:15","Saugzeit":"10 min","Fläche":"8.27 m²","Error":0,"Ende
                      mihome-vacuum.0	2020-03-03 19:47:46.600	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":21}
                      mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) 2. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:46.434	debug	(15538) Receive <<< {"result":[[1577275556,1577275612,14,0,0,0]],"id":20}
                      mihome-vacuum.0	2020-03-03 19:47:46.405	debug	(15538) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1577275556]}
                      mihome-vacuum.0	2020-03-03 19:47:46.210	debug	(15538) Receive <<< {"result":[[1577705584,1577707390,1705,27040000,0,1]],"id":19}
                      mihome-vacuum.0	2020-03-03 19:47:46.204	debug	(15538) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1577705584]}
                      mihome-vacuum.0	2020-03-03 19:47:46.086	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":18}
                      mihome-vacuum.0	2020-03-03 19:47:46.024	debug	(15538) Receive <<< {"result":[[1577707998,1577708227,229,4305000,0,1]],"id":17}
                      mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) 1. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) sendMsg[1] >>> {"id":18,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:46.004	debug	(15538) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1577707998]}
                      mihome-vacuum.0	2020-03-03 19:47:45.830	debug	(15538) Receive <<< {"result":[[1577708513,1577708756,243,3115000,0,1]],"id":16}
                      mihome-vacuum.0	2020-03-03 19:47:45.803	debug	(15538) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1577708513]}
                      mihome-vacuum.0	2020-03-03 19:47:45.617	debug	(15538) Receive <<< {"result":[[1581150811,1581153929,3118,44420000,0,1]],"id":15}
                      mihome-vacuum.0	2020-03-03 19:47:45.602	debug	(15538) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1581150811]}
                      mihome-vacuum.0	2020-03-03 19:47:45.508	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":14}
                      mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) 0. Mappointer_nomap___map_upload_handler
                      mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:45.416	debug	(15538) Receive <<< {"result":[[1582118288,1582120675,2387,39517500,0,1]],"id":13}
                      mihome-vacuum.0	2020-03-03 19:47:45.401	debug	(15538) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1582118288]}
                      mihome-vacuum.0	2020-03-03 19:47:45.223	debug	(15538) Receive <<< {"result":[[1583060389,1583063854,3465,54702500,0,1]],"id":12}
                      mihome-vacuum.0	2020-03-03 19:47:45.201	debug	(15538) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583060389]}
                      mihome-vacuum.0	2020-03-03 19:47:45.012	debug	(15538) Receive <<< {"result":[[1583244883,1583245887,1004,17005000,0,1]],"id":11}
                      mihome-vacuum.0	2020-03-03 19:47:44.999	debug	(15538) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1583244883]}
                      mihome-vacuum.0	2020-03-03 19:47:44.990	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":10}
                      mihome-vacuum.0	2020-03-03 19:47:44.984	debug	(15538) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-03 19:47:44.804	debug	(15538) Receive <<< {"result":[[1583248554,1583249170,616,8267500,0,1]],"id":9}
                      mihome-vacuum.0	2020-03-03 19:47:44.799	debug	(15538) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1583248554]}
                      mihome-vacuum.0	2020-03-03 19:47:44.794	debug	(15538) Receive <<< {"result":"unknown_method","id":8}
                      mihome-vacuum.0	2020-03-03 19:47:44.791	info	(15538) create state for carpet_mode
                      mihome-vacuum.0	2020-03-03 19:47:44.791	debug	(15538) Receive <<< {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":7}
                      mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                      mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                      mihome-vacuum.0	2020-03-03 19:47:44.615	debug	(15538) Receive <<< {"result":[[1583258556,1583258934,224,7165000,0,0]],"id":6}
                      mihome-vacuum.0	2020-03-03 19:47:44.598	debug	(15538) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1583258556]}
                      mihome-vacuum.0	2020-03-03 19:47:44.597	debug	(15538) Receive <<< {"result":[397771,6147175000,265,[1583258556,1583248554,1583244883,1583060389,1582118288,1581150811,1577708513,1577707998,1577705584,1577275556]],"id":5}
                      mihome-vacuum.0	2020-03-03 19:47:44.585	debug	(15538) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                      mihome-vacuum.0	2020-03-03 19:47:44.416	debug	(15538) Receive <<< {"result":[{"main_brush_work_time":398002,"side_brush_work_time":398002,"filter_work_time":182552,"sensor_dirty_time":12991}],"id":4}
                      mihome-vacuum.0	2020-03-03 19:47:44.384	debug	(15538) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                      mihome-vacuum.0	2020-03-03 19:47:44.238	info	(15538) set nächster Timer: Nicht verfügbar
                      mihome-vacuum.0	2020-03-03 19:47:44.192	debug	(15538) Receive <<< {"result":[90],"id":3}
                      mihome-vacuum.0	2020-03-03 19:47:44.185	debug	(15538) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                      mihome-vacuum.0	2020-03-03 19:47:44.157	error	(15538) TypeError: Cannot read property 'id' of undefined
                      mihome-vacuum.0	2020-03-03 19:47:44.128	debug	(15538) 25444
                      mihome-vacuum.0	2020-03-03 19:47:44.011	debug	(15538) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Wlan","bssid":"21:9B:C2:F5:08:F7","rssi":-50},"netif":{"l
                      mihome-vacuum.0	2020-03-03 19:47:43.986	debug	(15538) Next WiFi check: 03.03 19:48
                      mihome-vacuum.0	2020-03-03 19:47:43.985	debug	(15538) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                      mihome-vacuum.0	2020-03-03 19:47:43.783	info	(15538) Connected
                      mihome-vacuum.0	2020-03-03 19:47:43.755	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-03 19:47:43.754	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3337,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
                      mihome-vacuum.0	2020-03-03 19:47:43.740	debug	(15538) sendMsg[1] >>> {"id":1,"method":"get_status"}
                      mihome-vacuum.0	2020-03-03 19:47:43.732	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-03 19:47:43.731	info	(15538) connecting, This can take up to 5 minutes ...
                      mihome-vacuum.0	2020-03-03 19:47:43.731	warn	(15538) Time difference between Mihome Vacuum and ioBroker: -90 sec
                      mihome-vacuum.0	2020-03-03 19:47:43.730	debug	(15538) Receive <<< Helo <<< 21310020000
                      mihome-vacuum.0	2020-03-03 19:47:43.720	info	(15538) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                      mihome-vacuum.0	2020-03-03 19:47:43.711	debug	(15538) server started on 0.0.0.0:53421
                      mihome-vacuum.0	2020-03-03 19:47:43.707	info	(15538) Disconnect
                      mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Create state clean_home for controlling by cloud adapter
                      mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Expert mode enabled, states created
                      mihome-vacuum.0	2020-03-03 19:47:43.696	debug	(15538) load Map creator... true
                      mihome-vacuum.0	2020-03-03 19:47:43.669	info	(15538) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                      mihome-vacuum.0	2020-03-03 19:47:39.709	info	(10066) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) terminating
                      mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) Got terminate signal TERMINATE_YOURSELF
                      Nach Neustart des Adapters.
                      • J jensus11
                        D Nicht stören
                        D Nicht stören
                        dirkhe
                        #491
                        @jensus11 Hmmm, ich glaube, da muss @Meistertr meistertmal einen Blick drauf werfen. Aber das ist aktuell der Adapter von mir, nehme zur Sicherheit hat 2.0.7 vom offiziellen Community github.
                        • J Offline
                          jensus11
                          #492
                          Hatte 2.0.6 dann 2.0.7 und jetzt die von dir. Bei den anderen ging das auch nicht.
                          MeistertrM 1 Antwort Letzte Antwort
                          • J jensus11
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #493
                            @jensus11 hast du valetudo in der config angeklickt? auf jedenfall hast du Xiaomi map mit angeklickt, was nicht sollte wenn du valetudo installiert hast
                            • J Offline
                              jensus11
                              #494
                              So habe ich das eingestellt.
                                D Nicht stören
                                D Nicht stören
                                dirkhe
                                #495
                                @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                                Sollten wir dann da Radio Buttons von machen?
                                • D dirkhe
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  #496
                                  @dirkhe jep wollte da noch ein deselect mit einbauen das nur eins geht
                                    dehein2
                                    #497
                                    Hallo nochmal,
                                    ich habe nun Valetudo installiert und das webinterface funktioniert. Leider klappt die Bedienung über iobroker nicht. Es hat kurz funktioniert nun aber wieder nicht. Weder reagiert der Roboter zuverflässig auf Tastendrücke noch bekomme ich eine Karte angezeigt. Hier einmal ein Log:
                                    mihome-vacuum.0	2020-03-03 21:32:51.728	debug	(9962) requesting params every: 60 Sec
                                    mihome-vacuum.0	2020-03-03 21:32:43.764	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                                    mihome-vacuum.0	2020-03-03 21:32:43.759	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                    mihome-vacuum.0	2020-03-03 21:32:43.758	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267563751,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                                    mihome-vacuum.0	2020-03-03 21:32:42.738	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267562734,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                                    mihome-vacuum.0	2020-03-03 21:32:39.365	debug	(9962) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583267559362,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066074377}
                                    mihome-vacuum.0	2020-03-03 21:32:33.774	debug	(9962) no answer for get_consumable(id:19) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:33.575	warn	(9962) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                    mihome-vacuum.0	2020-03-03 21:32:33.574	debug	(9962) no answer for miIO.info(id:18) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:33.572	debug	(9962) no answer for get_status(id:17) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:30.061	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267550058,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                    mihome-vacuum.0	2020-03-03 21:32:29.391	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267549384,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                    mihome-vacuum.0	2020-03-03 21:32:28.387	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267548380,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                    mihome-vacuum.0	2020-03-03 21:32:24.506	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267544500,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                    mihome-vacuum.0	2020-03-03 21:32:23.564	debug	(9962) no answer for get_status(id:16) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:22.574	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267542571,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                                    mihome-vacuum.0	2020-03-03 21:32:18.567	debug	(9962) requesting params every: 60 Sec
                                    mihome-vacuum.0	2020-03-03 21:32:18.565	info	(9962) Connected
                                    mihome-vacuum.0	2020-03-03 21:32:18.561	info	(9962) Disconnect
                                    mihome-vacuum.0	2020-03-03 21:32:16.356	debug	(9962) no answer for get_status(id:15) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:14.354	debug	(9962) no answer for undefined(id:14) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:09.741	debug	(9962) no answer for get_room_mapping(id:13) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:09.730	debug	(9962) no answer for get_carpet_mode(id:12) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:09.679	debug	(9962) system.adapter.admin.0: logging true
                                    mihome-vacuum.0	2020-03-03 21:32:08.412	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                                    mihome-vacuum.0	2020-03-03 21:32:08.210	debug	(9962) no answer for get_clean_record(id:11) received, giving up
                                    mihome-vacuum.0	2020-03-03 21:32:06.558	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                                    mihome-vacuum.0	2020-03-03 21:32:06.555	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                    mihome-vacuum.0	2020-03-03 21:32:06.554	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267526551,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                                    mihome-vacuum.0	2020-03-03 21:32:03.410	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                                    mihome-vacuum.0	2020-03-03 21:31:59.347	info	(9962) trigger cleaning all null
                                    VG
                                      root_
                                      schrieb am zuletzt editiert von root_
                                      #498
                                      Hab seit dem update auf die neusste Version auch so 1-2 Probleme.
                                      Bei mir startet der Sauger über ein js. das hat heut nicht mehr funktioniert.
                                      9Uhr sollte er loslegen:
                                      mihome-vacuum.0	2020-03-04 09:00:00.029	info	(13716) trigger cleaning all null
                                      Das js löst den mihome-vacuum.0.control.start button aus.
                                      Jetzt hab ich den Button per hand ausgelöst und da ging es dann.
                                      Zum anderen bekomme ich diese Meldungen:
                                      mihome-vacuum.0	2020-03-04 09:37:13.736	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:35:53.774	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:27.812	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:24.708	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:20.458	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:17.147	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:13.814	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:10.498	error	(13716) Error: IndexSizeError: The source width is 0.
                                      mihome-vacuum.0	2020-03-04 09:34:07.335	error	(13716) Error: IndexSizeError: The source width is 0.
                                      Es handelt sich um einen Gen1 mit Xiaomi FW und Cloudanbindung im Adapter.
                                      • R root_
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        #499
                                        @root_ bitte Mal loglevel auf debug setzen.
                                        Wie triggerst du denn per ja?
                                        R 1 Antwort Letzte Antwort
                                        • D dehein2
                                          Hallo nochmal,
                                          VG
                                          D Nicht stören
                                          D Nicht stören
                                          dirkhe
                                          #500
                                          @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
