  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.3k Aufrufe 118 Beobachtet
    tombox
    #486
    Gelöst nach 10min warten kamen die ersten Daten rein.
    Keine Verbindung zu S50 mit 2008 firmware mit Adapter 2.0.7 installiert via github
    mihome-vacuum.0	2020-03-03 14:04:16.825	debug	(1481) requesting params every: 60 Sec
    mihome-vacuum.0	2020-03-03 14:04:16.825	silly	(1481) sendMsg[1] >>> {"id":9,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:04:16.822	info	(1481) Connected
    mihome-vacuum.0	2020-03-03 14:04:16.820	silly	(1481) Receive <<< Helo <<< *************ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-03-03 14:04:16.815	info	(1481) Disconnect
    mihome-vacuum.0	2020-03-03 14:04:11.823	debug	(1481) no answer for get_status(id:8) received, giving up
    mihome-vacuum.0	2020-03-03 14:04:06.821	silly	(1481) sendMsg[3] >>> {"id":8,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:04:01.816	silly	(1481) sendMsg[2] >>> {"id":8,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:03:56.812	silly	(1481) sendMsg[1] >>> {"id":8,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:03:54.843	debug	(1481) no answer for get_room_mapping(id:7) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:54.839	debug	(1481) no answer for get_carpet_mode(id:6) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:52.551	debug	(1481) no answer for get_sound_volume(id:5) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:52.352	debug	(1481) no answer for get_clean_summary(id:4) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:52.149	debug	(1481) no answer for get_consumable(id:3) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:51.971	warn	(1481) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
    mihome-vacuum.0	2020-03-03 14:03:51.969	debug	(1481) no answer for miIO.info(id:2) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:51.948	debug	(1481) no answer for get_status(id:1) received, giving up
    mihome-vacuum.0	2020-03-03 14:03:49.840	silly	(1481) sendMsg[3] >>> {"id":7,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-03-03 14:03:49.837	silly	(1481) sendMsg[3] >>> {"id":6,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-03-03 14:03:47.549	silly	(1481) sendMsg[3] >>> {"id":5,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-03-03 14:03:47.350	silly	(1481) sendMsg[3] >>> {"id":4,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-03-03 14:03:47.148	silly	(1481) sendMsg[3] >>> {"id":3,"method":"get_consumable"}
    mihome-vacuum.0	2020-03-03 14:03:46.966	silly	(1481) sendMsg[3] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-03-03 14:03:46.946	silly	(1481) sendMsg[3] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:03:44.837	silly	(1481) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-03-03 14:03:44.834	silly	(1481) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-03-03 14:03:42.545	silly	(1481) sendMsg[2] >>> {"id":5,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-03-03 14:03:42.347	silly	(1481) sendMsg[2] >>> {"id":4,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-03-03 14:03:42.144	silly	(1481) sendMsg[2] >>> {"id":3,"method":"get_consumable"}
    mihome-vacuum.0	2020-03-03 14:03:41.962	silly	(1481) sendMsg[2] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-03-03 14:03:41.941	silly	(1481) sendMsg[2] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:03:39.834	silly	(1481) sendMsg[1] >>> {"id":7,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-03-03 14:03:39.831	silly	(1481) sendMsg[1] >>> {"id":6,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-03-03 14:03:39.820	debug	(1481) Xiaomi Cloud: Login successful
    mihome-vacuum.0	2020-03-03 14:03:37.542	silly	(1481) sendMsg[1] >>> {"id":5,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-03-03 14:03:37.345	silly	(1481) sendMsg[1] >>> {"id":4,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-03-03 14:03:37.341	info	(1481) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-03 14:03:37.142	silly	(1481) sendMsg[1] >>> {"id":3,"method":"get_consumable"}
    mihome-vacuum.0	2020-03-03 14:03:37.003	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.rooms.addRoom:{"val":"Kartenindex oder Zonenkoordinaten einfügen","ack":true,"ts":1583240616994,"q":0,"from":"system.adapter.mihome-
    mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","
    mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.queue:{"val":0,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1583
    mihome-vacuum.0	2020-03-03 14:03:36.981	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
    mihome-vacuum.0	2020-03-03 14:03:36.980	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.wifi_signal:{"val":"unavailable","ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.use
    mihome-vacuum.0	2020-03-03 14:03:36.979	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616898,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
    mihome-vacuum.0	2020-03-03 14:03:36.975	silly	(1481) States system redis pmessage system.adapter.mihome-vacuum.0.logLevel/system.adapter.mihome-vacuum.0.logLevel:{"val":"silly","ack":true,"ts":1583240616891,"q":0,"from":"system.adapter.mihome-vac
    mihome-vacuum.0	2020-03-03 14:03:36.958	silly	(1481) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-03-03 14:03:36.940	debug	(1481) requesting params every: 60 Sec
    mihome-vacuum.0	2020-03-03 14:03:36.938	silly	(1481) sendMsg[1] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-03-03 14:03:36.928	info	(1481) Connected
    mihome-vacuum.0	2020-03-03 14:03:36.925	silly	(1481) Receive <<< Helo <<< *****************************ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-03-03 14:03:36.819	debug	(1481) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-03-03 14:03:36.807	info	(1481) Disconnect
    mihome-vacuum.0	2020-03-03 14:03:36.781	info	(1481) Cloud control disabled
    mihome-vacuum.0	2020-03-03 14:03:36.778	info	(1481) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-03 14:03:36.761	debug	(1481) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-03-03 14:03:36.758	debug	(1481) load Map creator... true
    mihome-vacuum.0	2020-03-03 14:03:36.659	info	(1481) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
    • MeistertrM Meistertr
      @ilovegym bitte nochmal von git dann sollte alles wieder gehen aber bitte geräte neu einlesen, da sich was geändert hat
      #487
      @Meistertr Hi, ja, läuft alles jetzt, keine Fehler 👍🙂
      Dankeschön
      • J Offline
        jensus11
        #488
        ich habe bei mir Valetudo installiert und einige Zonen angelegt.
        Die online Anbindung habe ich per Firewall unterbunden, da ich schon 2x das Vergnügen hatte das sich der Gen1 auf eine neue FW geupdatet hat oder wie auch immer sich selber resetet hat.
        Adapter 2.0.8 ist installiert, FW 3.3.9-003468 und Valetudo in 0.4.0.
        Mir werden auch alle Daten und Infos angezeigt, nur leider die Karten oder Zonen nicht.
        Was kann ich machen, würde so gerne über Alexa die einzelnen Zonen steuern.
        • J jensus11
          dirkhe
          #489
          @jensus11 bitte auf debug stellen und mal Log hier posten
          • J Offline
            jensus11
            schrieb am zuletzt editiert von jensus11
            #490
            mihome-vacuum.0	2020-03-03 19:48:03.714	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3338,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
            mihome-vacuum.0	2020-03-03 19:48:03.708	debug	(15538) sendMsg[1] >>> {"id":29,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 19:47:50.191	warn	(15538) Could not receive Mappointer, giving up
            mihome-vacuum.0	2020-03-03 19:47:50.191	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":28}
            mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) 9. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:49.681	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":27}
            mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) 8. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) sendMsg[1] >>> {"id":27,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:49.160	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":26}
            mihome-vacuum.0	2020-03-03 19:47:49.156	debug	(15538) 7. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:49.155	debug	(15538) sendMsg[1] >>> {"id":26,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:48.654	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":25}
            mihome-vacuum.0	2020-03-03 19:47:48.642	debug	(15538) 6. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:48.641	debug	(15538) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:48.141	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":24}
            mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) 5. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:47.616	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":23}
            mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) 4. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) sendMsg[1] >>> {"id":23,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:47.109	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":22}
            mihome-vacuum.0	2020-03-03 19:47:47.105	debug	(15538) 3. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:47.104	debug	(15538) sendMsg[1] >>> {"id":22,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:46.607	debug	(15538) CLEAN_LOGGING[{"Datum":"3.3","Start":"19:02","Saugzeit":"4 min","Fläche":"7.17 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"16:15","Saugzeit":"10 min","Fläche":"8.27 m²","Error":0,"Ende
            mihome-vacuum.0	2020-03-03 19:47:46.600	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":21}
            mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) 2. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:46.434	debug	(15538) Receive <<< {"result":[[1577275556,1577275612,14,0,0,0]],"id":20}
            mihome-vacuum.0	2020-03-03 19:47:46.405	debug	(15538) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1577275556]}
            mihome-vacuum.0	2020-03-03 19:47:46.210	debug	(15538) Receive <<< {"result":[[1577705584,1577707390,1705,27040000,0,1]],"id":19}
            mihome-vacuum.0	2020-03-03 19:47:46.204	debug	(15538) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1577705584]}
            mihome-vacuum.0	2020-03-03 19:47:46.086	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":18}
            mihome-vacuum.0	2020-03-03 19:47:46.024	debug	(15538) Receive <<< {"result":[[1577707998,1577708227,229,4305000,0,1]],"id":17}
            mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) 1. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) sendMsg[1] >>> {"id":18,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:46.004	debug	(15538) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1577707998]}
            mihome-vacuum.0	2020-03-03 19:47:45.830	debug	(15538) Receive <<< {"result":[[1577708513,1577708756,243,3115000,0,1]],"id":16}
            mihome-vacuum.0	2020-03-03 19:47:45.803	debug	(15538) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1577708513]}
            mihome-vacuum.0	2020-03-03 19:47:45.617	debug	(15538) Receive <<< {"result":[[1581150811,1581153929,3118,44420000,0,1]],"id":15}
            mihome-vacuum.0	2020-03-03 19:47:45.602	debug	(15538) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1581150811]}
            mihome-vacuum.0	2020-03-03 19:47:45.508	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":14}
            mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) 0. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:45.416	debug	(15538) Receive <<< {"result":[[1582118288,1582120675,2387,39517500,0,1]],"id":13}
            mihome-vacuum.0	2020-03-03 19:47:45.401	debug	(15538) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1582118288]}
            mihome-vacuum.0	2020-03-03 19:47:45.223	debug	(15538) Receive <<< {"result":[[1583060389,1583063854,3465,54702500,0,1]],"id":12}
            mihome-vacuum.0	2020-03-03 19:47:45.201	debug	(15538) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583060389]}
            mihome-vacuum.0	2020-03-03 19:47:45.012	debug	(15538) Receive <<< {"result":[[1583244883,1583245887,1004,17005000,0,1]],"id":11}
            mihome-vacuum.0	2020-03-03 19:47:44.999	debug	(15538) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1583244883]}
            mihome-vacuum.0	2020-03-03 19:47:44.990	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":10}
            mihome-vacuum.0	2020-03-03 19:47:44.984	debug	(15538) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
            mihome-vacuum.0	2020-03-03 19:47:44.804	debug	(15538) Receive <<< {"result":[[1583248554,1583249170,616,8267500,0,1]],"id":9}
            mihome-vacuum.0	2020-03-03 19:47:44.799	debug	(15538) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1583248554]}
            mihome-vacuum.0	2020-03-03 19:47:44.794	debug	(15538) Receive <<< {"result":"unknown_method","id":8}
            mihome-vacuum.0	2020-03-03 19:47:44.791	info	(15538) create state for carpet_mode
            mihome-vacuum.0	2020-03-03 19:47:44.791	debug	(15538) Receive <<< {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":7}
            mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-03-03 19:47:44.615	debug	(15538) Receive <<< {"result":[[1583258556,1583258934,224,7165000,0,0]],"id":6}
            mihome-vacuum.0	2020-03-03 19:47:44.598	debug	(15538) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1583258556]}
            mihome-vacuum.0	2020-03-03 19:47:44.597	debug	(15538) Receive <<< {"result":[397771,6147175000,265,[1583258556,1583248554,1583244883,1583060389,1582118288,1581150811,1577708513,1577707998,1577705584,1577275556]],"id":5}
            mihome-vacuum.0	2020-03-03 19:47:44.585	debug	(15538) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-03-03 19:47:44.416	debug	(15538) Receive <<< {"result":[{"main_brush_work_time":398002,"side_brush_work_time":398002,"filter_work_time":182552,"sensor_dirty_time":12991}],"id":4}
            mihome-vacuum.0	2020-03-03 19:47:44.384	debug	(15538) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
            mihome-vacuum.0	2020-03-03 19:47:44.238	info	(15538) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-03-03 19:47:44.192	debug	(15538) Receive <<< {"result":[90],"id":3}
            mihome-vacuum.0	2020-03-03 19:47:44.185	debug	(15538) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-03-03 19:47:44.157	error	(15538) TypeError: Cannot read property 'id' of undefined
            mihome-vacuum.0	2020-03-03 19:47:44.128	debug	(15538) 25444
            mihome-vacuum.0	2020-03-03 19:47:44.011	debug	(15538) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Wlan","bssid":"21:9B:C2:F5:08:F7","rssi":-50},"netif":{"l
            mihome-vacuum.0	2020-03-03 19:47:43.986	debug	(15538) Next WiFi check: 03.03 19:48
            mihome-vacuum.0	2020-03-03 19:47:43.985	debug	(15538) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
            mihome-vacuum.0	2020-03-03 19:47:43.783	info	(15538) Connected
            mihome-vacuum.0	2020-03-03 19:47:43.755	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-03 19:47:43.754	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3337,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
            mihome-vacuum.0	2020-03-03 19:47:43.740	debug	(15538) sendMsg[1] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 19:47:43.732	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-03 19:47:43.731	info	(15538) connecting, This can take up to 5 minutes ...
            mihome-vacuum.0	2020-03-03 19:47:43.731	warn	(15538) Time difference between Mihome Vacuum and ioBroker: -90 sec
            mihome-vacuum.0	2020-03-03 19:47:43.730	debug	(15538) Receive <<< Helo <<< 21310020000
            mihome-vacuum.0	2020-03-03 19:47:43.720	info	(15538) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
            mihome-vacuum.0	2020-03-03 19:47:43.711	debug	(15538) server started on 0.0.0.0:53421
            mihome-vacuum.0	2020-03-03 19:47:43.707	info	(15538) Disconnect
            mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Create state clean_home for controlling by cloud adapter
            mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Expert mode enabled, states created
            mihome-vacuum.0	2020-03-03 19:47:43.696	debug	(15538) load Map creator... true
            mihome-vacuum.0	2020-03-03 19:47:43.669	info	(15538) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
            mihome-vacuum.0	2020-03-03 19:47:39.709	info	(10066) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) terminating
            mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) Got terminate signal TERMINATE_YOURSELF
            Nach Neustart des Adapters.
            • J jensus11
              dirkhe
              #491
              @jensus11 Hmmm, ich glaube, da muss @Meistertr meistertmal einen Blick drauf werfen. Aber das ist aktuell der Adapter von mir, nehme zur Sicherheit hat 2.0.7 vom offiziellen Community github.
              • J Offline
                jensus11
                #492
                Hatte 2.0.6 dann 2.0.7 und jetzt die von dir. Bei den anderen ging das auch nicht.
                MeistertrM 1 Antwort Letzte Antwort
                • J jensus11
                  MeistertrM Offline
                  MeistertrM Offline
                  Meistertr
                  #493
                  @jensus11 hast du valetudo in der config angeklickt? auf jedenfall hast du Xiaomi map mit angeklickt, was nicht sollte wenn du valetudo installiert hast
                  • J Offline
                    jensus11
                    #494
                    So habe ich das eingestellt.
                      dirkhe
                      #495
                      @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                      Sollten wir dann da Radio Buttons von machen?
                      • D dirkhe
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #496
                        @dirkhe jep wollte da noch ein deselect mit einbauen das nur eins geht
                          dehein2
                          #497
                          Hallo nochmal,
                          ich habe nun Valetudo installiert und das webinterface funktioniert. Leider klappt die Bedienung über iobroker nicht. Es hat kurz funktioniert nun aber wieder nicht. Weder reagiert der Roboter zuverflässig auf Tastendrücke noch bekomme ich eine Karte angezeigt. Hier einmal ein Log:
                          mihome-vacuum.0	2020-03-03 21:32:51.728	debug	(9962) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-03-03 21:32:43.764	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                          mihome-vacuum.0	2020-03-03 21:32:43.759	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-03-03 21:32:43.758	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267563751,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                          mihome-vacuum.0	2020-03-03 21:32:42.738	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267562734,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                          mihome-vacuum.0	2020-03-03 21:32:39.365	debug	(9962) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583267559362,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066074377}
                          mihome-vacuum.0	2020-03-03 21:32:33.774	debug	(9962) no answer for get_consumable(id:19) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:33.575	warn	(9962) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                          mihome-vacuum.0	2020-03-03 21:32:33.574	debug	(9962) no answer for miIO.info(id:18) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:33.572	debug	(9962) no answer for get_status(id:17) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:30.061	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267550058,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                          mihome-vacuum.0	2020-03-03 21:32:29.391	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267549384,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                          mihome-vacuum.0	2020-03-03 21:32:28.387	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267548380,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                          mihome-vacuum.0	2020-03-03 21:32:24.506	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267544500,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                          mihome-vacuum.0	2020-03-03 21:32:23.564	debug	(9962) no answer for get_status(id:16) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:22.574	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267542571,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                          mihome-vacuum.0	2020-03-03 21:32:18.567	debug	(9962) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-03-03 21:32:18.565	info	(9962) Connected
                          mihome-vacuum.0	2020-03-03 21:32:18.561	info	(9962) Disconnect
                          mihome-vacuum.0	2020-03-03 21:32:16.356	debug	(9962) no answer for get_status(id:15) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:14.354	debug	(9962) no answer for undefined(id:14) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:09.741	debug	(9962) no answer for get_room_mapping(id:13) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:09.730	debug	(9962) no answer for get_carpet_mode(id:12) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:09.679	debug	(9962) system.adapter.admin.0: logging true
                          mihome-vacuum.0	2020-03-03 21:32:08.412	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                          mihome-vacuum.0	2020-03-03 21:32:08.210	debug	(9962) no answer for get_clean_record(id:11) received, giving up
                          mihome-vacuum.0	2020-03-03 21:32:06.558	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                          mihome-vacuum.0	2020-03-03 21:32:06.555	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-03-03 21:32:06.554	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267526551,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                          mihome-vacuum.0	2020-03-03 21:32:03.410	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                          mihome-vacuum.0	2020-03-03 21:31:59.347	info	(9962) trigger cleaning all null
                          • R Offline
                            root_
                            schrieb am zuletzt editiert von root_
                            #498
                            Hab seit dem update auf die neusste Version auch so 1-2 Probleme.
                            Bei mir startet der Sauger über ein js. das hat heut nicht mehr funktioniert.
                            9Uhr sollte er loslegen:
                            mihome-vacuum.0	2020-03-04 09:00:00.029	info	(13716) trigger cleaning all null
                            Das js löst den mihome-vacuum.0.control.start button aus.
                            Jetzt hab ich den Button per hand ausgelöst und da ging es dann.
                            Zum anderen bekomme ich diese Meldungen:
                            mihome-vacuum.0	2020-03-04 09:37:13.736	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:35:53.774	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:27.812	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:24.708	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:20.458	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:17.147	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:13.814	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:10.498	error	(13716) Error: IndexSizeError: The source width is 0.
                            mihome-vacuum.0	2020-03-04 09:34:07.335	error	(13716) Error: IndexSizeError: The source width is 0.
                            Es handelt sich um einen Gen1 mit Xiaomi FW und Cloudanbindung im Adapter.
                            • R root_
                              dirkhe
                              #499
                              @root_ bitte Mal loglevel auf debug setzen.
                              Wie triggerst du denn per ja?
                              R 1 Antwort Letzte Antwort
                              • D dehein2
                                Hallo nochmal,
                                dirkhe
                                #500
                                @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
                                • D dirkhe
                                  root_
                                  #501
                                  @dirkhe
                                  Genau, per true. Ging bis jetzt 1a.
                                  Ob es notwendig ist bei einem Button weiss ich nicht aber ich setze ihn nach 1000ms wieder auf false.
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #502
                                    @dirkhe @Meistertr
                                    Mein 1S reagiert mit 2.0.7 und 2.0.8 auf "Home" nicht.
                                    Zwischen "Pause" und "Find Me" habe ich immer wieder den "Home" Button im Admin betätigt. Der Sauger stand pausiert im Raum rum, also nicht im Dock. In der MiHome App hat der "Dock" Button dann sofort funktioniert.
                                    Hier das Debug Log dazu:
                                    2020-03-04 19:13:03.749  - info: mihome-vacuum.0 (20921) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                    2020-03-04 19:13:03.846  - debug: mihome-vacuum.0 (20921) load Map creator... true
                                    2020-03-04 19:13:03.850  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Logging in
                                    2020-03-04 19:13:03.868  - info: mihome-vacuum.0 (20921) Expert mode enabled, states created
                                    2020-03-04 19:13:03.870  - info: mihome-vacuum.0 (20921) Create state clean_home for controlling by cloud adapter
                                    2020-03-04 19:13:03.884  - info: mihome-vacuum.0 (20921) Disconnect
                                    2020-03-04 19:13:03.896  - debug: mihome-vacuum.0 (20921) server started on 0.0.0.0:53422
                                    2020-03-04 19:13:03.968  - info: mihome-vacuum.0 (20921) change states from State control.fan_power
                                    2020-03-04 19:13:03.971  - info: mihome-vacuum.0 (20921) New generation or new fw(3.5.4,0948) detected, create new states goto and zoneclean
                                    2020-03-04 19:13:04.428  - info: mihome-vacuum.0 (20921) set nächster Timer: Nicht verfügbar
                                    2020-03-04 19:13:06.831  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Login successful
                                    2020-03-04 19:13:13.677  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345593672,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                                    2020-03-04 19:13:13.684  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":1,"method":"find_me"}
                                    2020-03-04 19:13:18.687  - debug: mihome-vacuum.0 (20921) sendMsg[2] >>> {"id":1,"method":"find_me"}
                                    2020-03-04 19:13:23.690  - debug: mihome-vacuum.0 (20921) sendMsg[3] >>> {"id":1,"method":"find_me"}
                                    2020-03-04 19:13:23.887  - info: mihome-vacuum.0 (20921) Disconnect
                                    2020-03-04 19:13:23.892  - debug: mihome-vacuum.0 (20921) Receive <<< Helo <<< 21310020000000000f92f23c5e5fefc3ffffffffffffffffffffffffffffffff
                                    2020-03-04 19:13:23.894  - info: mihome-vacuum.0 (20921) connecting, This can take up to 5 minutes ...
                                    2020-03-04 19:13:23.896  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                    2020-03-04 19:13:23.904  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":2,"method":"get_status"}
                                    2020-03-04 19:13:23.915  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5745,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                                    2020-03-04 19:13:23.918  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                    2020-03-04 19:13:23.922  - info: mihome-vacuum.0 (20921) Connected
                                    2020-03-04 19:13:24.125  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":3,"method":"miIO.info"}
                                    2020-03-04 19:13:24.133  - debug: mihome-vacuum.0 (20921) Next WiFi check: 04.03 19:14
                                    2020-03-04 19:13:24.136  - debug: mihome-vacuum.0 (20921) Receive <<< {"partner_id":"","id":3,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_0948","ap":{"ssid":"sparky","bssid":"CC:CE:1E:C2:11:17","rssi":-45},"netif":{"localIp":"192.168.2.122","mask":"255.255.255.0","gw":"192.168.2.4"},"model":"roborock.vacuum.m1s","mac":"50:EC:50:12:37:15","token":"59414c416c4246694b3048764435577a","life":55952}}
                                    2020-03-04 19:13:24.323  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":4,"method":"get_sound_volume"}
                                    2020-03-04 19:13:24.332  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[100],"id":4}
                                    2020-03-04 19:13:24.525  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":5,"method":"get_consumable"}
                                    2020-03-04 19:13:24.534  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"main_brush_work_time":75966,"side_brush_work_time":75966,"filter_work_time":75966,"sensor_dirty_time":74777}],"id":5}
                                    2020-03-04 19:13:24.724  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":6,"method":"get_clean_summary"}
                                    2020-03-04 19:13:24.733  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[74777,1474542500,91,[1583340758,1583339903,1583225954,1583180962,1583180261,1582735711,1582735619,1582735055,1582617128,1582571726,1582570856,1582570281,1582566875,1581790042,1581761962,1581629504,1581322645,1581244828,1581244266,1580840290]],"id":6}
                                    2020-03-04 19:13:24.737  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":7,"method":"get_clean_record","params":[1583340758]}
                                    2020-03-04 19:13:24.749  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583340758,1583341334,531,9650000,0,1,2,3]],"id":7}
                                    2020-03-04 19:13:24.924  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":8,"method":"get_carpet_mode"}
                                    2020-03-04 19:13:24.925  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":9,"method":"get_room_mapping"}
                                    2020-03-04 19:13:24.934  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":8}
                                    2020-03-04 19:13:24.936  - info: mihome-vacuum.0 (20921) create state for carpet_mode
                                    2020-03-04 19:13:24.939  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[16,"277001004452"],[17,"277001004448"],[18,"277001004451"],[19,"277001004453"],[20,"277001118019"],[21,"277001004449"]],"id":9}
                                    2020-03-04 19:13:24.943  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":10,"method":"get_clean_record","params":[1583339903]}
                                    2020-03-04 19:13:24.953  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583339903,1583340754,829,17177500,0,1,2,3]],"id":10}
                                    2020-03-04 19:13:25.124  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":11,"method":"get_map_v1"}
                                    2020-03-04 19:13:25.132  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":11}
                                    2020-03-04 19:13:25.146  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583225954]}
                                    2020-03-04 19:13:25.155  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583225954,1583227596,1642,34910000,0,1,2,3]],"id":12}
                                    2020-03-04 19:13:25.349  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1583180962]}
                                    2020-03-04 19:13:25.357  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180962,1583181066,104,1735000,0,1,2,3]],"id":13}
                                    2020-03-04 19:13:25.551  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1583180261]}
                                    2020-03-04 19:13:25.562  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180261,1583180956,695,14795000,0,1,2,3]],"id":14}
                                    2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":15,"method":"get_map_v1"}
                                    2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) 0. Mappointer_nomap___retry
                                    2020-03-04 19:13:25.669  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":15}
                                    2020-03-04 19:13:25.755  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1582735711]}
                                    2020-03-04 19:13:25.766  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735711,1582736153,442,9622500,0,1,2,3]],"id":16}
                                    2020-03-04 19:13:25.957  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1582735619]}
                                    2020-03-04 19:13:25.966  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735619,1582735640,18,0,0,0,2,1]],"id":17}
                                    2020-03-04 19:13:26.159  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1582735055]}
                                    2020-03-04 19:13:26.168  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735055,1582735619,504,9577500,0,0,2,3]],"id":18}
                                    2020-03-04 19:13:26.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":19,"method":"get_map_v1"}
                                    2020-03-04 19:13:26.172  - debug: mihome-vacuum.0 (20921) 1. Mappointer_nomap___retry
                                    2020-03-04 19:13:26.193  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ruby2%2F261288508%2F17"],"id":19}
                                    2020-03-04 19:13:26.195  - debug: mihome-vacuum.0 (20921) Mappointer_updated
                                    2020-03-04 19:13:26.197  - debug: mihome-vacuum.0 (20921) update_Map Mimap enabled
                                    2020-03-04 19:13:26.198  - debug: mihome-vacuum.0 (20921) update_Map need new mapurl
                                    2020-03-04 19:13:26.362  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1582617128]}
                                    2020-03-04 19:13:26.370  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582617128,1582618883,1755,35097500,0,1,2,3]],"id":20}
                                    2020-03-04 19:13:26.563  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1582571726]}
                                    2020-03-04 19:13:26.571  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582571726,1582571734,6,0,0,0,2,1]],"id":21}
                                    2020-03-04 19:13:26.766  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1582570856]}
                                    2020-03-04 19:13:26.773  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570856,1582571680,802,16392500,0,1,2,3]],"id":22}
                                    2020-03-04 19:13:26.968  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1582570281]}
                                    2020-03-04 19:13:26.975  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570281,1582570721,13,240000,0,0,2,3]],"id":23}
                                    2020-03-04 19:13:27.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1582566875]}
                                    2020-03-04 19:13:27.180  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582566875,1582567670,795,16565000,0,1,2,3]],"id":24}
                                    2020-03-04 19:13:27.375  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1581790042]}
                                    2020-03-04 19:13:27.384  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581790042,1581790663,621,9707500,0,1,2,3]],"id":25}
                                    2020-03-04 19:13:27.579  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1581761962]}
                                    2020-03-04 19:13:27.588  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581761962,1581765162,3200,68240000,0,1,2,3]],"id":26}
                                    2020-03-04 19:13:27.783  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1581629504]}
                                    2020-03-04 19:13:27.792  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581629504,1581629795,291,9602500,0,0,2,3]],"id":27}
                                    2020-03-04 19:13:27.986  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1581322645]}
                                    2020-03-04 19:13:27.993  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581322645,1581323442,797,17057500,0,1,2,3]],"id":28}
                                    2020-03-04 19:13:28.189  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1581244828]}
                                    2020-03-04 19:13:28.199  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244828,1581247475,2647,51210000,0,1,2,3]],"id":29}
                                    2020-03-04 19:13:28.395  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1581244266]}
                                    2020-03-04 19:13:28.404  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244266,1581244810,544,9777500,0,1,2,3]],"id":30}
                                    2020-03-04 19:13:28.599  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1580840290]}
                                    2020-03-04 19:13:28.606  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1580840290,1580840773,483,9737500,0,1,2,3]],"id":31}
                                    2020-03-04 19:13:28.690  - debug: mihome-vacuum.0 (20921) no answer for find_me(id:1) received, giving up
                                    2020-03-04 19:13:28.801  - debug: mihome-vacuum.0 (20921) CLEAN_LOGGING[{"Datum":"4.3","Start":"17:52","Saugzeit":"9 min","Fläche":"9.65 m²","Error":0,"Ende":true},{"Datum":"4.3","Start":"17:38","Saugzeit":"14 min","Fläche":"17.18 m²","Error":0,"Ende":true},{"Datum":"3.3","Start":"09:59","Saugzeit":"27 min","Fläche":"34.91 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:29","Saugzeit":"2 min","Fläche":"1.74 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:17","Saugzeit":"12 min","Fläche":"14.8 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:48","Saugzeit":"7 min","Fläche":"9.62 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:46","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"26.2","Start":"17:37","Saugzeit":"8 min","Fläche":"9.58 m²","Error":0,"Ende":false},{"Datum":"25.2","Start":"08:52","Saugzeit":"29 min","Fläche":"35.1 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"20:15","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"20:00","Saugzeit":"13 min","Fläche":"16.39 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"19:51","Saugzeit":"0 min","Fläche":"0.24 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"18:54","Saugzeit":"13 min","Fläche":"16.57 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"19:07","Saugzeit":"10 min","Fläche":"9.71 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"11:19","Saugzeit":"53 min","Fläche":"68.24 m²","Error":0,"Ende":true},{"Datum":"13.2","Start":"22:31","Saugzeit":"5 min","Fläche":"9.6 m²","Error":0,"Ende":false},{"Datum":"10.2","Start":"09:17","Saugzeit":"13 min","Fläche":"17.06 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:40","Saugzeit":"44 min","Fläche":"51.21 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:31","Saugzeit":"9 min","Fläche":"9.78 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"19:18","Saugzeit":"8 min","Fläche":"9.74 m²","Error":0,"Ende":true}]
                                    2020-03-04 19:13:30.421  - debug: mihome-vacuum.0 (20921) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/ruby2/261288508/17?Expires=1583347410000&GalaxyAccessKeyId=5271733786445&Signature=rnfZhuZbNi6QHn/Vkf7tvjbAqQE=
                                    2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new expires:1583347410
                                    2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new time:1583345606
                                    2020-03-04 19:13:32.381  - debug: mihome-vacuum.0 (20921) 25653
                                    2020-03-04 19:13:35.515  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345615511,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                                    2020-03-04 19:13:35.517  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":32,"method":"find_me"}
                                    2020-03-04 19:13:35.581  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":32}
                                    2020-03-04 19:13:38.489  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345618484,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:13:43.894  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":33,"method":"get_status"}
                                    2020-03-04 19:13:43.907  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5746,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":33}
                                    2020-03-04 19:13:44.860  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583345624788,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573587802676}
                                    2020-03-04 19:13:44.862  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":34,"method":"app_pause"}
                                    2020-03-04 19:13:44.868  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":34}
                                    2020-03-04 19:13:47.722  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345627719,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:13:49.408  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345629404,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                                    2020-03-04 19:13:49.409  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":35,"method":"find_me"}
                                    2020-03-04 19:13:49.415  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":35}
                                    2020-03-04 19:13:51.438  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345631434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:13:52.192  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345632186,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:13:53.210  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633204,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:13:53.664  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633658,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                                    2020-03-04 19:14:00.173  - info: mihome-vacuum.0 (20921) Got terminate signal TERMINATE_YOURSELF
                                    Hier die History für den Button "Home":
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:53.665
                                    true	false	admin.0	2020-03-04 19:13:53.658
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:53.213
                                    true	false	admin.0	2020-03-04 19:13:53.204
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:52.194
                                    true	false	admin.0	2020-03-04 19:13:52.186
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:51.440
                                    true	false	admin.0	2020-03-04 19:13:51.434
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:47.726
                                    true	false	admin.0	2020-03-04 19:13:47.719
                                    true	true	mihome-vacuum.0	2020-03-04 19:13:38.491
                                    true	false	admin.0	2020-03-04 19:13:38.484
                                    ..:: So long! Tom ::..
                                    • DiginixD Diginix
                                      @dirkhe @Meistertr
                                      dirkhe
                                      #503
                                      @Diginix Alles klar, Fehler gefunden. Ich löse bei home nur aus, wnn er gerade aktiv am Reinigen ist. Flasche Annahme, nehme ich gleich raus und melde mich
                                      • R root_
                                        @dirkhe
                                        dirkhe
                                        #504
                                        @root_ Also ich habe jetzt mal geschaut. Einen Button per true zu triggern funktioniert. ich habe dieselbe funktion hinter start und clean_home gepackt und damit akzeptierte start auch ein false, mit dem Ergebniss, dass sofort wieder angehalten wurde. Ist gefixt und wird gleich hochgeladen. Für den IndexSizeError brauche ich ein debug log
                                          dirkhe
                                          #505
                                          So für meine Version gibt es jetzt die 2.0.8-RC2
