  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.3k Aufrufe 118 Beobachtet
  • MathiasJM MathiasJ
    Ihr Glückspilze!
    ich bekomme die nicht mal installiert.
    $ ./iobroker upgrade mihome-vacuum
    Update mihome-vacuum from @1.1.5 to @2.0.7
    NPM version: 6.13.4npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error gyp
    ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR!
    cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR!
     code
     ELIFECYCLE
    npm
    ERR!
    errno 1
    npm
    ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm
    ERR! Exit status 1
    npm ERR!
     npm
     ERR!
     Failed at the canvas@2.6.1 install script.npm
     ERR!
     This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-03T05_40_34_693Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.mihome-vacuum@2.0.7: 1
    dirkhe
    #482
    @MathiasJ Readme!
    MathiasJM 1 Antwort Letzte Antwort
    • D dirkhe
      @MathiasJ Readme!
      MathiasJM Offline
      MathiasJM Offline
      MathiasJ
      schrieb am zuletzt editiert von MathiasJ
      #483
      @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
      @MathiasJ Readme!
      ist installiert... muß mich erst mal einlesen, um die Karte ins VIS übertragen zu können.
      IObroker auf dem NUC als VM.
        K_o_bold
        #484
        @Meistertr ,
        ich bekomme immer wieder diesen error, obwohl er die Karte richtig lädt:
        (1462) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Tue, 03 Mar 2020 10:51:09 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6b964dae-6380-8e
        mihome-vacuum.0	2020-03-03 11:50:41.160	error	(
        Adapter Version 2.0.7
        Roborock S50
        • K K_o_bold
          @Meistertr ,
          Roborock S50
          DiginixD Offline
          DiginixD Offline
          Diginix
          #485
          @K_o_bold Liest sich für mich nach einem 403 Forbidden welches der Adapter vom Xiaomi Server bekommt.
          Stell mal die Instanz auf Loglevel debug und schau mal im Log nach "Xiaomi Cloud: Login successful".
          Ansonsten wird sich @Meistertr schon dazu melden.
          ..:: So long! Tom ::..
            tombox
            #486
            Gelöst nach 10min warten kamen die ersten Daten rein.
            Keine Verbindung zu S50 mit 2008 firmware mit Adapter 2.0.7 installiert via github
            mihome-vacuum.0	2020-03-03 14:04:16.825	debug	(1481) requesting params every: 60 Sec
            mihome-vacuum.0	2020-03-03 14:04:16.825	silly	(1481) sendMsg[1] >>> {"id":9,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:04:16.822	info	(1481) Connected
            mihome-vacuum.0	2020-03-03 14:04:16.820	silly	(1481) Receive <<< Helo <<< *************ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-03 14:04:16.815	info	(1481) Disconnect
            mihome-vacuum.0	2020-03-03 14:04:11.823	debug	(1481) no answer for get_status(id:8) received, giving up
            mihome-vacuum.0	2020-03-03 14:04:06.821	silly	(1481) sendMsg[3] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:04:01.816	silly	(1481) sendMsg[2] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:03:56.812	silly	(1481) sendMsg[1] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:03:54.843	debug	(1481) no answer for get_room_mapping(id:7) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:54.839	debug	(1481) no answer for get_carpet_mode(id:6) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:52.551	debug	(1481) no answer for get_sound_volume(id:5) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:52.352	debug	(1481) no answer for get_clean_summary(id:4) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:52.149	debug	(1481) no answer for get_consumable(id:3) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:51.971	warn	(1481) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
            mihome-vacuum.0	2020-03-03 14:03:51.969	debug	(1481) no answer for miIO.info(id:2) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:51.948	debug	(1481) no answer for get_status(id:1) received, giving up
            mihome-vacuum.0	2020-03-03 14:03:49.840	silly	(1481) sendMsg[3] >>> {"id":7,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-03-03 14:03:49.837	silly	(1481) sendMsg[3] >>> {"id":6,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-03-03 14:03:47.549	silly	(1481) sendMsg[3] >>> {"id":5,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-03-03 14:03:47.350	silly	(1481) sendMsg[3] >>> {"id":4,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-03-03 14:03:47.148	silly	(1481) sendMsg[3] >>> {"id":3,"method":"get_consumable"}
            mihome-vacuum.0	2020-03-03 14:03:46.966	silly	(1481) sendMsg[3] >>> {"id":2,"method":"miIO.info"}
            mihome-vacuum.0	2020-03-03 14:03:46.946	silly	(1481) sendMsg[3] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:03:44.837	silly	(1481) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-03-03 14:03:44.834	silly	(1481) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-03-03 14:03:42.545	silly	(1481) sendMsg[2] >>> {"id":5,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-03-03 14:03:42.347	silly	(1481) sendMsg[2] >>> {"id":4,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-03-03 14:03:42.144	silly	(1481) sendMsg[2] >>> {"id":3,"method":"get_consumable"}
            mihome-vacuum.0	2020-03-03 14:03:41.962	silly	(1481) sendMsg[2] >>> {"id":2,"method":"miIO.info"}
            mihome-vacuum.0	2020-03-03 14:03:41.941	silly	(1481) sendMsg[2] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:03:39.834	silly	(1481) sendMsg[1] >>> {"id":7,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-03-03 14:03:39.831	silly	(1481) sendMsg[1] >>> {"id":6,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-03-03 14:03:39.820	debug	(1481) Xiaomi Cloud: Login successful
            mihome-vacuum.0	2020-03-03 14:03:37.542	silly	(1481) sendMsg[1] >>> {"id":5,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-03-03 14:03:37.345	silly	(1481) sendMsg[1] >>> {"id":4,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-03-03 14:03:37.341	info	(1481) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-03-03 14:03:37.142	silly	(1481) sendMsg[1] >>> {"id":3,"method":"get_consumable"}
            mihome-vacuum.0	2020-03-03 14:03:37.003	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.rooms.addRoom:{"val":"Kartenindex oder Zonenkoordinaten einfügen","ack":true,"ts":1583240616994,"q":0,"from":"system.adapter.mihome-
            mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","
            mihome-vacuum.0	2020-03-03 14:03:36.982	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.queue:{"val":0,"ack":true,"ts":1583240616966,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1583
            mihome-vacuum.0	2020-03-03 14:03:36.981	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
            mihome-vacuum.0	2020-03-03 14:03:36.980	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.wifi_signal:{"val":"unavailable","ack":true,"ts":1583240616899,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.use
            mihome-vacuum.0	2020-03-03 14:03:36.979	silly	(1481) States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":false,"ack":true,"ts":1583240616898,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin",
            mihome-vacuum.0	2020-03-03 14:03:36.975	silly	(1481) States system redis pmessage system.adapter.mihome-vacuum.0.logLevel/system.adapter.mihome-vacuum.0.logLevel:{"val":"silly","ack":true,"ts":1583240616891,"q":0,"from":"system.adapter.mihome-vac
            mihome-vacuum.0	2020-03-03 14:03:36.958	silly	(1481) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
            mihome-vacuum.0	2020-03-03 14:03:36.940	debug	(1481) requesting params every: 60 Sec
            mihome-vacuum.0	2020-03-03 14:03:36.938	silly	(1481) sendMsg[1] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-03 14:03:36.928	info	(1481) Connected
            mihome-vacuum.0	2020-03-03 14:03:36.925	silly	(1481) Receive <<< Helo <<< *****************************ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-03 14:03:36.819	debug	(1481) server started on 0.0.0.0:53421
            mihome-vacuum.0	2020-03-03 14:03:36.807	info	(1481) Disconnect
            mihome-vacuum.0	2020-03-03 14:03:36.781	info	(1481) Cloud control disabled
            mihome-vacuum.0	2020-03-03 14:03:36.778	info	(1481) Expert mode disabled, states deleted
            mihome-vacuum.0	2020-03-03 14:03:36.761	debug	(1481) Xiaomi Cloud: Logging in
            mihome-vacuum.0	2020-03-03 14:03:36.758	debug	(1481) load Map creator... true
            mihome-vacuum.0	2020-03-03 14:03:36.659	info	(1481) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
            • MeistertrM Meistertr
              @ilovegym bitte nochmal von git dann sollte alles wieder gehen aber bitte geräte neu einlesen, da sich was geändert hat
              #487
              @Meistertr Hi, ja, läuft alles jetzt, keine Fehler 👍🙂
              Dankeschön
              • J Offline
                jensus11
                #488
                ich habe bei mir Valetudo installiert und einige Zonen angelegt.
                Die online Anbindung habe ich per Firewall unterbunden, da ich schon 2x das Vergnügen hatte das sich der Gen1 auf eine neue FW geupdatet hat oder wie auch immer sich selber resetet hat.
                Adapter 2.0.8 ist installiert, FW 3.3.9-003468 und Valetudo in 0.4.0.
                Mir werden auch alle Daten und Infos angezeigt, nur leider die Karten oder Zonen nicht.
                Was kann ich machen, würde so gerne über Alexa die einzelnen Zonen steuern.
                • J jensus11
                  dirkhe
                  #489
                  @jensus11 bitte auf debug stellen und mal Log hier posten
                  • J Offline
                    jensus11
                    schrieb am zuletzt editiert von jensus11
                    #490
                    mihome-vacuum.0	2020-03-03 19:48:03.714	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3338,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
                    mihome-vacuum.0	2020-03-03 19:48:03.708	debug	(15538) sendMsg[1] >>> {"id":29,"method":"get_status"}
                    mihome-vacuum.0	2020-03-03 19:47:50.191	warn	(15538) Could not receive Mappointer, giving up
                    mihome-vacuum.0	2020-03-03 19:47:50.191	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":28}
                    mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) 9. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:49.681	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":27}
                    mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) 8. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) sendMsg[1] >>> {"id":27,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:49.160	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":26}
                    mihome-vacuum.0	2020-03-03 19:47:49.156	debug	(15538) 7. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:49.155	debug	(15538) sendMsg[1] >>> {"id":26,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:48.654	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":25}
                    mihome-vacuum.0	2020-03-03 19:47:48.642	debug	(15538) 6. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:48.641	debug	(15538) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:48.141	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":24}
                    mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) 5. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:47.616	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":23}
                    mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) 4. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) sendMsg[1] >>> {"id":23,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:47.109	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":22}
                    mihome-vacuum.0	2020-03-03 19:47:47.105	debug	(15538) 3. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:47.104	debug	(15538) sendMsg[1] >>> {"id":22,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:46.607	debug	(15538) CLEAN_LOGGING[{"Datum":"3.3","Start":"19:02","Saugzeit":"4 min","Fläche":"7.17 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"16:15","Saugzeit":"10 min","Fläche":"8.27 m²","Error":0,"Ende
                    mihome-vacuum.0	2020-03-03 19:47:46.600	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":21}
                    mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) 2. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:46.434	debug	(15538) Receive <<< {"result":[[1577275556,1577275612,14,0,0,0]],"id":20}
                    mihome-vacuum.0	2020-03-03 19:47:46.405	debug	(15538) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1577275556]}
                    mihome-vacuum.0	2020-03-03 19:47:46.210	debug	(15538) Receive <<< {"result":[[1577705584,1577707390,1705,27040000,0,1]],"id":19}
                    mihome-vacuum.0	2020-03-03 19:47:46.204	debug	(15538) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1577705584]}
                    mihome-vacuum.0	2020-03-03 19:47:46.086	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":18}
                    mihome-vacuum.0	2020-03-03 19:47:46.024	debug	(15538) Receive <<< {"result":[[1577707998,1577708227,229,4305000,0,1]],"id":17}
                    mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) 1. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) sendMsg[1] >>> {"id":18,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:46.004	debug	(15538) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1577707998]}
                    mihome-vacuum.0	2020-03-03 19:47:45.830	debug	(15538) Receive <<< {"result":[[1577708513,1577708756,243,3115000,0,1]],"id":16}
                    mihome-vacuum.0	2020-03-03 19:47:45.803	debug	(15538) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1577708513]}
                    mihome-vacuum.0	2020-03-03 19:47:45.617	debug	(15538) Receive <<< {"result":[[1581150811,1581153929,3118,44420000,0,1]],"id":15}
                    mihome-vacuum.0	2020-03-03 19:47:45.602	debug	(15538) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1581150811]}
                    mihome-vacuum.0	2020-03-03 19:47:45.508	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":14}
                    mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) 0. Mappointer_nomap___map_upload_handler
                    mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:45.416	debug	(15538) Receive <<< {"result":[[1582118288,1582120675,2387,39517500,0,1]],"id":13}
                    mihome-vacuum.0	2020-03-03 19:47:45.401	debug	(15538) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1582118288]}
                    mihome-vacuum.0	2020-03-03 19:47:45.223	debug	(15538) Receive <<< {"result":[[1583060389,1583063854,3465,54702500,0,1]],"id":12}
                    mihome-vacuum.0	2020-03-03 19:47:45.201	debug	(15538) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583060389]}
                    mihome-vacuum.0	2020-03-03 19:47:45.012	debug	(15538) Receive <<< {"result":[[1583244883,1583245887,1004,17005000,0,1]],"id":11}
                    mihome-vacuum.0	2020-03-03 19:47:44.999	debug	(15538) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1583244883]}
                    mihome-vacuum.0	2020-03-03 19:47:44.990	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":10}
                    mihome-vacuum.0	2020-03-03 19:47:44.984	debug	(15538) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                    mihome-vacuum.0	2020-03-03 19:47:44.804	debug	(15538) Receive <<< {"result":[[1583248554,1583249170,616,8267500,0,1]],"id":9}
                    mihome-vacuum.0	2020-03-03 19:47:44.799	debug	(15538) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1583248554]}
                    mihome-vacuum.0	2020-03-03 19:47:44.794	debug	(15538) Receive <<< {"result":"unknown_method","id":8}
                    mihome-vacuum.0	2020-03-03 19:47:44.791	info	(15538) create state for carpet_mode
                    mihome-vacuum.0	2020-03-03 19:47:44.791	debug	(15538) Receive <<< {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":7}
                    mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                    mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                    mihome-vacuum.0	2020-03-03 19:47:44.615	debug	(15538) Receive <<< {"result":[[1583258556,1583258934,224,7165000,0,0]],"id":6}
                    mihome-vacuum.0	2020-03-03 19:47:44.598	debug	(15538) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1583258556]}
                    mihome-vacuum.0	2020-03-03 19:47:44.597	debug	(15538) Receive <<< {"result":[397771,6147175000,265,[1583258556,1583248554,1583244883,1583060389,1582118288,1581150811,1577708513,1577707998,1577705584,1577275556]],"id":5}
                    mihome-vacuum.0	2020-03-03 19:47:44.585	debug	(15538) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                    mihome-vacuum.0	2020-03-03 19:47:44.416	debug	(15538) Receive <<< {"result":[{"main_brush_work_time":398002,"side_brush_work_time":398002,"filter_work_time":182552,"sensor_dirty_time":12991}],"id":4}
                    mihome-vacuum.0	2020-03-03 19:47:44.384	debug	(15538) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                    mihome-vacuum.0	2020-03-03 19:47:44.238	info	(15538) set nächster Timer: Nicht verfügbar
                    mihome-vacuum.0	2020-03-03 19:47:44.192	debug	(15538) Receive <<< {"result":[90],"id":3}
                    mihome-vacuum.0	2020-03-03 19:47:44.185	debug	(15538) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                    mihome-vacuum.0	2020-03-03 19:47:44.157	error	(15538) TypeError: Cannot read property 'id' of undefined
                    mihome-vacuum.0	2020-03-03 19:47:44.128	debug	(15538) 25444
                    mihome-vacuum.0	2020-03-03 19:47:44.011	debug	(15538) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Wlan","bssid":"21:9B:C2:F5:08:F7","rssi":-50},"netif":{"l
                    mihome-vacuum.0	2020-03-03 19:47:43.986	debug	(15538) Next WiFi check: 03.03 19:48
                    mihome-vacuum.0	2020-03-03 19:47:43.985	debug	(15538) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                    mihome-vacuum.0	2020-03-03 19:47:43.783	info	(15538) Connected
                    mihome-vacuum.0	2020-03-03 19:47:43.755	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-03 19:47:43.754	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3337,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
                    mihome-vacuum.0	2020-03-03 19:47:43.740	debug	(15538) sendMsg[1] >>> {"id":1,"method":"get_status"}
                    mihome-vacuum.0	2020-03-03 19:47:43.732	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-03 19:47:43.731	info	(15538) connecting, This can take up to 5 minutes ...
                    mihome-vacuum.0	2020-03-03 19:47:43.731	warn	(15538) Time difference between Mihome Vacuum and ioBroker: -90 sec
                    mihome-vacuum.0	2020-03-03 19:47:43.730	debug	(15538) Receive <<< Helo <<< 21310020000
                    mihome-vacuum.0	2020-03-03 19:47:43.720	info	(15538) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                    mihome-vacuum.0	2020-03-03 19:47:43.711	debug	(15538) server started on 0.0.0.0:53421
                    mihome-vacuum.0	2020-03-03 19:47:43.707	info	(15538) Disconnect
                    mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Create state clean_home for controlling by cloud adapter
                    mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Expert mode enabled, states created
                    mihome-vacuum.0	2020-03-03 19:47:43.696	debug	(15538) load Map creator... true
                    mihome-vacuum.0	2020-03-03 19:47:43.669	info	(15538) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                    mihome-vacuum.0	2020-03-03 19:47:39.709	info	(10066) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) terminating
                    mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) Got terminate signal TERMINATE_YOURSELF
                    Nach Neustart des Adapters.
                    • J jensus11
                      dirkhe
                      #491
                      @jensus11 Hmmm, ich glaube, da muss @Meistertr meistertmal einen Blick drauf werfen. Aber das ist aktuell der Adapter von mir, nehme zur Sicherheit hat 2.0.7 vom offiziellen Community github.
                      • J Offline
                        jensus11
                        #492
                        Hatte 2.0.6 dann 2.0.7 und jetzt die von dir. Bei den anderen ging das auch nicht.
                        MeistertrM 1 Antwort Letzte Antwort
                        • J jensus11
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          #493
                          @jensus11 hast du valetudo in der config angeklickt? auf jedenfall hast du Xiaomi map mit angeklickt, was nicht sollte wenn du valetudo installiert hast
                          • J Offline
                            jensus11
                            #494
                            So habe ich das eingestellt.
                              dirkhe
                              #495
                              @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                              Sollten wir dann da Radio Buttons von machen?
                              • D dirkhe
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                #496
                                @dirkhe jep wollte da noch ein deselect mit einbauen das nur eins geht
                                  dehein2
                                  #497
                                  Hallo nochmal,
                                  ich habe nun Valetudo installiert und das webinterface funktioniert. Leider klappt die Bedienung über iobroker nicht. Es hat kurz funktioniert nun aber wieder nicht. Weder reagiert der Roboter zuverflässig auf Tastendrücke noch bekomme ich eine Karte angezeigt. Hier einmal ein Log:
                                  mihome-vacuum.0	2020-03-03 21:32:51.728	debug	(9962) requesting params every: 60 Sec
                                  mihome-vacuum.0	2020-03-03 21:32:43.764	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                                  mihome-vacuum.0	2020-03-03 21:32:43.759	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                  mihome-vacuum.0	2020-03-03 21:32:43.758	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267563751,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                                  mihome-vacuum.0	2020-03-03 21:32:42.738	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267562734,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                                  mihome-vacuum.0	2020-03-03 21:32:39.365	debug	(9962) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583267559362,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066074377}
                                  mihome-vacuum.0	2020-03-03 21:32:33.774	debug	(9962) no answer for get_consumable(id:19) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:33.575	warn	(9962) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                  mihome-vacuum.0	2020-03-03 21:32:33.574	debug	(9962) no answer for miIO.info(id:18) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:33.572	debug	(9962) no answer for get_status(id:17) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:30.061	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267550058,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                  mihome-vacuum.0	2020-03-03 21:32:29.391	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267549384,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                  mihome-vacuum.0	2020-03-03 21:32:28.387	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267548380,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                  mihome-vacuum.0	2020-03-03 21:32:24.506	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267544500,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                                  mihome-vacuum.0	2020-03-03 21:32:23.564	debug	(9962) no answer for get_status(id:16) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:22.574	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267542571,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                                  mihome-vacuum.0	2020-03-03 21:32:18.567	debug	(9962) requesting params every: 60 Sec
                                  mihome-vacuum.0	2020-03-03 21:32:18.565	info	(9962) Connected
                                  mihome-vacuum.0	2020-03-03 21:32:18.561	info	(9962) Disconnect
                                  mihome-vacuum.0	2020-03-03 21:32:16.356	debug	(9962) no answer for get_status(id:15) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:14.354	debug	(9962) no answer for undefined(id:14) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:09.741	debug	(9962) no answer for get_room_mapping(id:13) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:09.730	debug	(9962) no answer for get_carpet_mode(id:12) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:09.679	debug	(9962) system.adapter.admin.0: logging true
                                  mihome-vacuum.0	2020-03-03 21:32:08.412	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                                  mihome-vacuum.0	2020-03-03 21:32:08.210	debug	(9962) no answer for get_clean_record(id:11) received, giving up
                                  mihome-vacuum.0	2020-03-03 21:32:06.558	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                                  mihome-vacuum.0	2020-03-03 21:32:06.555	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                  mihome-vacuum.0	2020-03-03 21:32:06.554	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267526551,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                                  mihome-vacuum.0	2020-03-03 21:32:03.410	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                                  mihome-vacuum.0	2020-03-03 21:31:59.347	info	(9962) trigger cleaning all null
                                  • R Offline
                                    root_
                                    schrieb am zuletzt editiert von root_
                                    #498
                                    Hab seit dem update auf die neusste Version auch so 1-2 Probleme.
                                    Bei mir startet der Sauger über ein js. das hat heut nicht mehr funktioniert.
                                    9Uhr sollte er loslegen:
                                    mihome-vacuum.0	2020-03-04 09:00:00.029	info	(13716) trigger cleaning all null
                                    Das js löst den mihome-vacuum.0.control.start button aus.
                                    Jetzt hab ich den Button per hand ausgelöst und da ging es dann.
                                    Zum anderen bekomme ich diese Meldungen:
                                    mihome-vacuum.0	2020-03-04 09:37:13.736	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:35:53.774	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:27.812	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:24.708	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:20.458	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:17.147	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:13.814	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:10.498	error	(13716) Error: IndexSizeError: The source width is 0.
                                    mihome-vacuum.0	2020-03-04 09:34:07.335	error	(13716) Error: IndexSizeError: The source width is 0.
                                    Es handelt sich um einen Gen1 mit Xiaomi FW und Cloudanbindung im Adapter.
                                    • R root_
                                      dirkhe
                                      #499
                                      @root_ bitte Mal loglevel auf debug setzen.
                                      Wie triggerst du denn per ja?
                                      R 1 Antwort Letzte Antwort
                                      • D dehein2
                                        Hallo nochmal,
                                        dirkhe
                                        #500
                                        @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
                                        • D dirkhe
                                          root_
                                          #501
                                          @dirkhe
                                          Genau, per true. Ging bis jetzt 1a.
                                          Ob es notwendig ist bei einem Button weiss ich nicht aber ich setze ihn nach 1000ms wieder auf false.
