  4. Updates 10.07.2016
    6.7k
Updates 10.07.2016
42 Beiträge 13 Kommentatoren 9.3k Aufrufe
    @dwm:
    Habt Ihr evt. eine Idee, wieso der controller nicht installiert? `
    @dwm:
    EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh' `
    hast du vorher
    iobroker stop
    gemacht?
    Sonst weiss ich ausser dem dummen reboot auch nichts
    Rainer
    • BluefoxB Offline
      BluefoxB Offline
      @dwm:
      Ich scheine da auch Probleme mit dem Update zu haben …
      root@penguin:/opt/iobroker# npm cache clean
      root@penguin:/opt/iobroker# npm install iobroker.js-controller
      > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      fs.js:549
        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
          at Error (native)
          at Object.fs.openSync (fs.js:549:18)
          at Object.fs.writeFileSync (fs.js:1156:15)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:513:23
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:534:11)
          at Module._compile (module.js:410:26)
          at Object.Module._extensions..js (module.js:417:10)
          at Module.load (module.js:344:32)
          at Function.Module._load (module.js:301:12)
      npm ERR! Linux 4.4.0-28-generic
      npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller"
      npm ERR! node v4.2.6
      npm ERR! npm  v2.15.8
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@0.10.1 install: `node lib/setup.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.10.1 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
      root@penguin:/opt/iobroker#</anonymous>
      Läuft auf Ubuntu 16.04 LTS …
      "Er ist tot, Jim" :)
      1000x
      Werner `
      Kannst du
      cd /opt/iobroker
      sudo iobroker stop
      sudo chmod 777 * -R
      sudo npm install iobroker.js-controller --production
      sudo iobroker start
      ausführen?
        dwm
        das hats getan …
        Jetzt klappts auch mit dem 1.2.6er admin! :D
        Erst mal herzlichen Dank!
        Jetzt nur mal um das auch zu verstehen ...
        • Zugriffsrechte vermurkst? Wie kann das sein? Sollte "root" nicht alles überbügeln können? Ich hab beobachtet dass manche module auf 755 standen, aber nicht als Problem gesehen.
        • was macht --production?
        Ich hatte das auch probiert mit
        iobroker stop
        iobroker update
        iobroker upgrade
        iobroker start
        … was aber auch nicht geklappt hatte. Na ja, läuft ja wieder!
        Nochmals merci
        Werner
        • BluefoxB Offline
          BluefoxB Offline
          ioBroker lief aber nicht als root und konnte auf die Dateien nicht zugreifen.
          "–production" installiert keine "Test"-Pakete und nur das was fürs Laufen gebraucht wird.
          • K Offline
            ktsalti
            @Bluefox:
            Kannst du
            cd /opt/iobroker
            sudo iobroker stop
            sudo chmod 777 * -R
            sudo iobroker start
            ausführen? `
            habe ich jetzt auch probiert, bekomme jetzt aber folgende Fehlermeldung
            root@raspberrypi:/opt/iobroker# sudo iobroker start
            Starting iobroker controller daemon...
            /home/pi/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
                        throw new Error(msg.error);
            Error: /home/pi/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/json3/lib/json3.js:379
            SyntaxError: Unexpected token )
                at exports.runInThisContext (vm.js:73:16)
                at Module._compile (module.js:443:25)
                at Object.Module._extensions..js (module.js:478:10)
                at Module.load (module.js:355:32)
                at Function.Module._load (module.js:310:12)
                at Module.require (module.js:365:17)
                at require (module.js:384:17)
                at Object. <anonymous>(/home/pi/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/index.js:7:12)
                at Module._compile (module.js:460:26)
                at ChildProcess. <anonymous>(/home/pi/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
                at ChildProcess.emit (events.js:110:17)
                at handleMessage (child_process.js:324:10)
                at Pipe.channel.onread (child_process.js:352:11)</anonymous></anonymous>
            Was ist jetzt noch falsch? Vor dem Update lief alles ohne Probleme.. zumindest nicht das ich welche germerkt hätte :)
            • paul53P Offline
              @ktsalti:
              Error: /home/pi/node_modules/iobroker.js-controller/node_modules/… `
              Es existiert noch eine alte Installation im falschen Verzeichnis. Ich würde das gesamte Verzeichnis "node_modules" im Verzeichnis "/home/pi" löschen und es als user "root" im Verzeichnis "/opt/iobroker" nochmal versuchen.
              • V Offline
                V Offline
                vore
                Hallo!
                Ich brauche doch noch mal Hilfe. Nach dem Update bekomme ich keinen Zugriff mehr über den Browser (Site can't be reached).
                Ich habe schon die einzelnen Befehle ausgeführt (stop,start,cache clean etc) es hilft aber leider nicht.
                Auf dem Cubietruck sehe ich mit "ps ax" nur den iobroker.js-controller laufen. nichts weiter.
                Mit "iobroker list instances" kommt keine Ausgabe. Versuche ich "iobroker update" kommt "system.config not found".
                Eigentlich hat das Update erst funktioniert, alles war Ok. Nach Neustart war ging nichts mehr.
                Jemand eine Idee?
                • BluefoxB Offline
                  BluefoxB Offline
                  @vore:
                  Hallo!
                  Jemand eine Idee?
                  Gruß `
                  http://www.iobroker.net/docu/?page_id=3928&lang=de
                  Schon probiert?
                  • V Offline
                    V Offline
                    vore
                    Hallo!
                    Habe ich soweit mal durchprobiert.
                    js-controller
                     6109 ? 00:00:3 iobroker.js-con
                    netstat -n -a -p TCP
                    tcp6       0      0 :::9000                 :::*                    LISTEN      6109/iobroker.js-co
                    tcp6       0      0 :::9001                 :::*                    LISTEN      6109/iobroker.js-co
                    node -v
                    v4.4.7
                    npm -v
                    npm -v
                    Hab probiert:
                    npm install iobroker.admin
                    iobroker upload admin
                    iobroker start admin
                    dann kommt
                    Cannot find any instance of "admin"
                    Habe mir mal das IOBroker Log von heute angesehen. Dieser Eintrag sscheitn auf jeden Fall ein Problem zu sein:
                    2016-07-17 20:34:23.107  - error: admin.0 no connection to objects DB
                    2016-07-17 20:49:16.885  - error: host.cubietruck _design/system missing - call node iobroker.js setup
                    Kann ich noch etwas tun oder hilft nur eine Neuinstallation?
                    • BluefoxB Offline
                      BluefoxB Offline
                      @vore:
                      Hallo!
                      js-controller
                      node -v
                      v4.4.7
                      npm -v
                      npm -v
                      Hab probiert:
                      dann kommt
                      Gruß `
                      IM welchem Verzeichnis hast du alle Befehle ausgeführt?
                      Es sieht so aus als ob im "home".
                      • V Offline
                        V Offline
                        vore
                        Hallo!
                        Das war unter /opt/iobroker.. ganz sicher. Ich bin immer erst in den Ordner gewechselt direkt nach dem Login über SSH.
                        Aber lass mal gut sein.. ich mache das neu drauf, keine Ahnung was ich da anscheinend vorher zerschossen habe.
                        • K Offline
                          ktsalti
                          @paul53:
                          @ktsalti:
                          Error: /home/pi/node_modules/iobroker.js-controller/node_modules/… Es existiert noch eine alte Installation im falschen Verzeichnis. Ich würde das gesamte Verzeichnis "node_modules" im Verzeichnis "/home/pi" löschen und es als user "root" im Verzeichnis "/opt/iobroker" nochmal versuchen.
                          Hi Paul,
                          habe ich gemacht. Beim installieren bekomme ich unter anderem die Meldung. Hat die was zu sagen?
                          ` > > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
                          node lib/setup.js setup first `
                          Komplett:
                          ! root@raspberrypi:/opt/iobroker# sudo npm install iobroker.js-controller –production
                          ! > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
                          ! > node lib/setup.js setup first
                          ! iobroker.js-controller@0.10.1 node_modules/iobroker.js-controller
                          ! ├── winston-daily-rotate-file@1.1.5
                          ! ├── daemonize2@0.4.2
                          ! ├── mime@1.3.4
                          ! ├── ncp@2.0.0
                          ! ├── node.extend@1.1.5 (is@3.1.0)
                          ! ├── semver@4.3.6
                          ! ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
                          ! ├── redis@2.6.2 (double-ended-queue@2.1.0-0, redis-parser@2.0.3, redis-commands@1.2.0)
                          ! ├── yargs@3.32.0 (camelcase@2.1.1, decamelize@1.2.0, y18n@3.2.1, window-size@0.1.4, os-locale@1.4.0, string-width@1.0.1, cliui@3.2.0)
                          ! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.1, async@1.0.0, colors@1.0.3)
                          ! ├── socket.io-client@1.4.8 (to-array@0.1.4, indexof@0.0.1, component-emitter@1.2.0, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.2.0, parseuri@0.0.4, socket.io-parser@2.2.6, engine.io-client@1.6.11)
                          ! ├── request@2.73.0 (is-typedarray@1.0.0, aws-sign2@0.6.0, oauth-sign@0.8.2, forever-agent@0.6.1, tunnel-agent@0.4.3, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, aws4@1.4.1, node-uuid@1.4.7, qs@6.2.0, tough-cookie@2.2.2, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, bl@1.1.2, har-validator@2.0.6, http-signature@1.1.1, hawk@3.1.3)
                          ! ├── socket.io@1.4.8 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.11)
                          ! ├── jszip@3.0.0 (asap@2.0.4, es6-promise@3.0.2, readable-stream@2.0.6, pako@1.0.1)
                          ! ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.10.2, fstream@1.0.10, mout@0.11.1)
                          ! ├── prompt@1.0.0 (revalidator@0.1.8, colors@1.1.2, pkginfo@0.4.0, read@1.0.7, winston@2.1.1, utile@0.3.0)
                          ! ├── npm@2.15.9
                          ! └── iobroker.admin@1.2.6 (connect-flash@0.1.1, xtend@4.0.1, cookie-parser@1.4.3, passport-local@1.0.0, passport@0.3.2, express-session@1.14.0, body-parser@1.15.2, express@4.14.0)
                          beim starten von iobroker bekomme ich dann:
                          ` > root@raspberrypi:/opt/iobroker# sudo iobroker start
                          module.js:338
                          throw err;
                          Error: Cannot find module '/home/pi/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (module.js:336:15)
                          at Function.Module._load (module.js:278:25)
                          at Function.Module.runMain (module.js:501:10)
                          at startup (node.js:129:16)
                          at node.js:814:3
                          root@raspberrypi:/opt/iobroker# `
                          irgendwas habe ich wohl einmal im falschen Ordner ausgeführt :(.
                          wie kann ich das wieder bereinigen?
                          • BluefoxB Offline
                            BluefoxB Offline
                            @ktsalti:
                            @paul53:
                            @ktsalti:
                            Hi Paul,
                            Komplett:
                            ! ├── mime@1.3.4
                            ! ├── ncp@2.0.0
                            ! ├── semver@4.3.6
                            ! ├── npm@2.15.9
                            module.js:338
                            throw err;
                            at node.js:814:3
                            wie kann ich das wieder bereinigen? `
                            Vermutlich "iobroker" Skript liegt in "/home/pi". Was passiert wenn du:
                            cd /opt/iobroker
                            node node_modules/iobroker.js-controller/controller.js
                            Aufrufst?
                            • K Offline
                              ktsalti
                              @Bluefox:
                              cd /opt/iobroker
                              Aufrufst? `
                              habe ich versucht, aber er steht dann über eine Stunde in dem Bild und nichts passiert. Ist das normal? Ist ein Rasbberry3
                              root@raspberrypi:~# cd /opt/iobroker
                              root@raspberrypi:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js
                              • BluefoxB Offline
                                BluefoxB Offline
                                @ktsalti:
                                @Bluefox:
                                cd /opt/iobroker
                                Aufrufst? `
                                Dafür sollte aber dann admin und alles laufen. Ist das so?
                                Es wird übrigens ewig stehen :)
                                • K Offline
                                  ktsalti
                                  hehe, da hätte ich ja noch ewig warten können :D
                                  admin läuft, aber alle meine Instanzen sind weg und alles was ich eingerichtet hatte. Gib es da noch eine Chance?
                                  Läuft es dann jetzt auch nach einen reboot wieder automatisch?
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    @ktsalti:
                                    Läuft es dann jetzt auch nach einen reboot wieder automatisch? `
                                    Das heißt, dass entwider deine Konfig in "home" geblieben ist oder dein hostname hat sich geändert.
                                    • wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      @Homoran:
                                      Heute hat es wieder einige Updates gegeben.
                                      Achtung es ist auch eine neue Controller Version dabei.(0.10.1)
                                      Anscheinend läuft die neue Version Admin (1.2.6) nicht mehr mit dem alten Controller . Iobroker ist dann nicht mehr erreichbar.
                                      Dann bitte auf der Konsole ausführen
                                      cd /opt/iobroker
                                      iobroker stop
                                      iobroker start
                                      Evtl. Ist auch noch ein Reboot notwendigen.
                                      Wenn man sicherheitshalber alles über die Konsole machen will macht man am besten
                                      cd /opt/iobroker
                                      iobroker stop
                                      iobroker update
                                      iobroker upgrade
                                      reboot
                                      Dann läuft alles weitestgehend automatisch.
                                      Rainer `
                                      ich habe heute nach längerer Abwesenheit mal mein System updaten wollen.
                                      Zuerst das besagte Problem nach Update des Admin gehabt. Dann über Konsole den controler upgedated.
                                      Danach kann ich kein anderes installiertes Pluging updaten.
                                      Habe auch 2x die Version über die Konsole versucht, ohne Erfolg.
                                      Hier mal der Printout:
                                      999_iobroker_upgrade_nok.txt
                                      So sieht es nach dem restart aus:
                                      Wenn ich jetzt, egal bei welchem Adapter auf die Upgrade funktion klicke, passiert nur das:
                                      Jemand ne Idee was da noch falsch läuft?
                                      Danke und Gruß
                                      • N Offline
                                        N Offline
                                        nobody
                                        Hallo wendy,
                                        es gibt leider einen bug in der aktuellen Version des Controller, weswegen zurzeit die Updates nicht funktionieren.
                                        Der Fix hierfür wird aber wohl noch etwas dauern.
                                        Die einfachste Lösung ist, vorerst auf die letzte funktionierende Version des Controller zurück zu gehen. Dafür muss der Controller manuell mittels npm installiert werden.
                                        cd /opt/iobroker
                                        iobroker stop
                                        npm install iobroker.js-controller@0.11.0
                                        iobroker start
                                        Danach sollten auch die Updates wieder wie gewohnt laufen.
                                          wendy2702W Offline
                                          wendy2702
                                          @nobody:
                                          Hallo wendy,
                                          cd /opt/iobroker
                                          iobroker stop
                                          iobroker start
                                          Danach sollten auch die Updates wieder wie gewohnt laufen. `
                                          Danke für die schnelle Antwort. Hat funktioniert.
