  3. Entwicklung
  4. ZigBee neue/unbekannte Geräte - ab 1.0.0
    5.4k
zigbeezigbee 3.xneuer converter
402 Beiträge 87 Kommentatoren 107.7k Aufrufe 76 Beobachtet
  • Z Zentapher
    Meine neue Steckdose mag nicht so richtig...
    Adapter ist aktuell aus GitHub::
    starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
    Ich verwende einen CC1352P-2 mit aktueller Z-Stack_3.x.0 Firmware:
    Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
    Device Details:
    Device details
    model:ZNCZ04LM
    vendor:Xiaomi
    description:Mi power plug ZigBee EU
    supports:on/off, power measurement
    model:lumi.plug.mmeu01
    type:Router
    nwk:54748
    manuf id:4447
    manufacturer:LUMI
    power:Mains (single phase)
    app version:22
    hard version:1
    zcl version:3
    stack version:2
    date code:09-06-2019
    interviewed:true
    configured:false
    endpoint:1
    profile:260
    input clusters:genBasic (0)
    genDeviceTempCfg (2)
    genIdentify (3)
    genGroups (4)
    genScenes (5)
    genOnOff (6)
    aqaraOpple (64704)
    output clusters:genTime (10)
    genOta (25)
    endpoint:21
    profile:260
    input clusters:genAnalogInput (12)
    endpoint:22
    profile:260
    endpoint:242
    profile:41440
    output clusters:33
    Pairing Logs:
    New device joined '0x04cf8cdf3c75a3d1' model lumi.plug.mmeu01
    Interview successful: {"friendly_name":"0x04cf8cdf3c75a3d1","model":"ZNCZ04LM","vendor":"Xiaomi","description":"Mi power plug ZigBee EU","supported":true}
    Error: Device 04cf8cdf3c75a3d1 "lumi.plug.mmeu01" not described in statesMapping.. undefined
    Device '0x04cf8cdf3c75a3d1' announced itself
    Interview started: 0x04cf8cdf3c75a3d1
    arteckA Offline
    arteckA Offline
    arteck
    #141
    @Zentapher sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
    lumi.plug.mmeu01
    probiermal
    @FredF
    supports: on/off, brightness, color temperature, color xy
    das wird supported.. da steht nix von W
    FredFF Z Robi1010MDR 3 Antworten Letzte Antwort
    • arteckA arteck
      lumi.plug.mmeu01
      probiermal
      @FredF
      FredFF Offline
      FredFF Offline
      FredF
      Most Active Forum Testing
      #142
      @arteck sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
      • arteckA arteck
        lumi.plug.mmeu01
        probiermal
        @FredF
        Z Offline
        Z Offline
        Zentapher
        #143
        @arteck
        Super, funktioniert! Vielen Dank.
        • A aSilentSniper
          so ich habe es für heute aufgeben nachdem ich nochmal die neuste version von github installiert habe hat er zwar die remote erkannt aber ich konnte das Rollo nicht mehr steuern also habe ich es erstmal aufgeben und nutze das rollo nun nur mit der remote ohn iobroker leider
          chiroptera
          schrieb am zuletzt editiert von chiroptera
          #144
          @Asgothian Ich habe das selbe Problem mit der open/close Remote. Das Rollo kann mit dem CC2531 Stick gepairt werden und ist auch über ioBroker steuerbar. Wenn man versucht die Fernbedienung direkt mit dem Rollo zu pairen, dann ist das Pairing des Rollos wieder entfernt. Rollo und Fernbedienung lassen sich mit dem CC2531 Stick pairen, dann kommt aber die Fehlermeldung wie oben im Screenshot "not described in statesMapping" bei jedem Tastendruck. Das Profil der Fernbedienung ist auch nicht ordentlich vorhanden - keine Zustände. Das Rollo lässt sich in diesem Zustand über ioBroker aber noch steuern.
          Es scheint also nicht möglich das Rollo mit der Fernbedienung zu pairen und gleichzeitig über zigbee2mqqt. Beide Geräte Rollo und Fernbedienung lassen sich über zigbee2mqqt pairen.
          Nachtrag: Wenn man nur die Fernbedienung allein pairt, dann kommt die selbe Fehlermeldung bei jedem Tastendruck.
          Edit:
          Gerade erst gesehen - ich schau mal welche Version ich einsetze und gebe Rückmeldung ob es mit 1.0.3 funktioniert.
          Edit:
          Funktioniert einwandfrei mit V1.0.3 :-)
          • G Offline
            gd84
            #145
            @arteck
            Bist du bitte so nett und pflegst diesen Schalter noch ein:
            model:Switch 4x EU-LIGHTIFY
            type:EndDevice
            nwk:4292
            manuf id:4364
            manufacturer:OSRAM
            power:Battery
            app version:1
            hard version:1
            zcl version:1
            stack version:0
            date code:201703021135570
            build:e.1.0.0M
            interviewed:true
            configured:false
            endpoint:1
            profile:260
            genPowerCfg (1)
            genPollCtrl (32)
            touchlink (4096)
            64768
            output clusters:genIdentify (3)
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            genOta (25)
            lightingColorCtrl (768)
            touchlink (4096)
            endpoint:2
            profile:260
            touchlink (4096)
            64768
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            endpoint:3
            profile:260
            touchlink (4096)
            64768
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            endpoint:4
            profile:260
            touchlink (4096)
            64768
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            endpoint:5
            profile:260
            touchlink (4096)
            64768
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            endpoint:6
            profile:260
            touchlink (4096)
            64768
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            Wieso hat das Ding eigentlich 6 Endpoints bei 4 Tasten?
            Desweiteren habe ich eine Aqara Cube der mir nur das anzeigt:
            Ich verwende diese Firmware für den Stick:
            (4489) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190425}}
            Mit der 1.2 gehr er.
            • G gd84
              @arteck
              type:EndDevice
              nwk:4292
              manuf id:4364
              manufacturer:OSRAM
              power:Battery
              app version:1
              hard version:1
              zcl version:1
              stack version:0
              build:e.1.0.0M
              interviewed:true
              configured:false
              endpoint:1
              profile:260
              genPowerCfg (1)
              genPollCtrl (32)
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              genOta (25)
              touchlink (4096)
              endpoint:2
              profile:260
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              touchlink (4096)
              endpoint:3
              profile:260
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              touchlink (4096)
              endpoint:4
              profile:260
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              touchlink (4096)
              endpoint:5
              profile:260
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              touchlink (4096)
              endpoint:6
              profile:260
              touchlink (4096)
              64768
              genGroups (4)
              genScenes (5)
              genOnOff (6)
              genLevelCtrl (8)
              touchlink (4096)
              arteckA Offline
              arteckA Offline
              arteck
              #146
              @gd84 den Schalter bekommen wir nicht rein.. der läuft nicht sauber .. wegen dem anderen .. lese nochmal das eingangpost
              G 1 Antwort Letzte Antwort
              • L Offline
                locito09
                #147
                Hallo
                Ist es möglich auch diesen LED Strip hinzu zu fügen?
                • L locito09
                  Hallo
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #148
                  @locito09 jetzt
                  • arteckA arteck
                    lumi.plug.mmeu01
                    probiermal
                    @FredF
                    Robi1010MDR Offline
                    Robi1010MDR Offline
                    Robi1010MD
                    schrieb am zuletzt editiert von Robi1010MD
                    #149
                    @arteck Hallo, ich habe auch diese Steckdose (lumi.plug.mmeu01) und sie wird nicht richtig angezeigt. Was soll da nun getan werden?
                    • ? Offline
                      #150
                      @Sven-N said in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                      Habe ein Problem mit dem Rauchmelder Heiman SmokeSensor-N-3.0, zigbee erkennt ihn aber bekomme folgende Fehlermeldung:
                      Device 00158d0004c34730 "SmokeSensor-N-3.0" not described in statesMapping.
                      @arteck hattest du das gelesen?
                      • ? Offline
                        #151
                        Re: ZigBee neue/unbekannte Geräte - ab 1.0.0
                        zu aller erst, echt klasse Arbeit die Ihr alle hier leistet.
                        Mir ist bewusst, dass das hier kein unbekanntes Gerät ist, sollte es hier stören, dann bitte verschieben.
                        Ich bin seit ein paar Wochen dabei alles von der Hue Bridge auf den Zigbee Stick umzuziehen, das klappt auch soweit super aber bei zwei Leuchtmitteln bekomme ich falsche Bilder in der Kachel angezeigt.
                        b760814f-9b55-4cde-a176-5cc6c4caa325-image.png das sollte eher wie 5b85ae6b-96d5-49c1-b23e-987d1322b18a-image.png aussehen.
                        Wie, wo kann ich das ändern?
                        Viele Grüße
                        Bernd
                          Viele Grüße
                          Bernd
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #152
                          @dp20eic habs korrigiert..installier nochmal
                          @Robi1010MD installier vom GIT
                          @Sven-N installier vom GIT neu
                          ? 1 Antwort Letzte Antwort
                          • ? Offline
                            #153
                            @arteck said in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                            Hi, Danke hat funktioniert :)
                            Wünsche allen ein schönes Wochenende.
                            LG
                            Bernd
                            • arteckA arteck
                              #154
                              vielen Dank für deine Mühe, es geht.
                              • ? Offline
                                #155
                                Guten Morgen @arteck,
                                ich habe da noch ein Leuchtmittel, welches ein falsches Bild lädt, e4cafdd6-9cc9-49a6-a94a-618331a7a19d-image.png, das sollte eigentlich auch eine E14 LED Kerze sein wie zuvor 4705597f-76a6-41a4-8342-264a4473dc4f-image.png.
                                Man bin ich begeistert von iobroker und den Personen die das hier alles möglich machen.
                                Schönes Wochenende
                                Bernd
                                • arteckA arteck
                                  gd84
                                  #156
                                  @arteck
                                  Was genau am Schalter funktioniert den nicht?
                                  Ich habe den Eingangspost gelesen und bis auf den Unterschied das ich die zStack 3 nichts gefunden.
                                  Kann die Ota Funktion der Herdsmann-Converters irgendwie genutzt werden?
                                  • amrap030_1993A Offline
                                    amrap030_1993
                                    #157
                                    könnt ihr bitte die Ikea Tradfri E14 470lm Birnen hinzufügen?
                                    Vielen Dank im Voraus 🙂
                                      Saxnot
                                      #158
                                      könnt ihr bitte das folgende Gerät aufnehmen:
                                      Hersteller: Ledvance
                                      Model: PAR16 TW Z3 (LED-Spot PAR 16 50 Tunable White)
                                      Link: https://www.ledvance.de/consumer/smart/indoor-produkte/index.jsp
                                      Kachel:
                                      Müsste m.E. identisch mit dem Osram-Gerät sein: https://www.zigbee2mqtt.io/devices/AA68199.html
                                      Vielen Dank für Eure Mühe 😊
                                        Schönes Wochenende
                                        Bernd
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #159
                                        @dp20eic korrigiert
                                        @amrap030_1993 sollte jetzt gehen
                                        @Saxnot sollte jetzt gehen
                                        S amrap030_1993A 4 Antworten Letzte Antwort
                                        • ? Offline
                                          #160
                                          @dp20eic korrigiert
                                          Danke, sieht jetzt gut aus.
                                          Viele Grüße
                                          Bernd
