  4. Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern
@1.5.3 @2.1.1
37 Beiträge 4 Kommentatoren 2.3k Aufrufe 2 Beobachtet
    @samsungfreak Da fehlt der Anfang. Inkl. der Befehlszeile.
    samsungfreak
    schrieb am zuletzt editiert von samsungfreak
    @Thomas-Braun Ich habe mal das ganze Updatelog hochgeladen. Kannst du daraus irgendetwas erkennen?
    UpdateLog.txt
    • S samsungfreak
      UpdateLog.txt
      @samsungfreak In /opt/iobroker
      npm rebuild
        npm rebuild
        samsungfreak
        @Thomas-Braun sagte in Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern:
        npm rebuild
        Leider läuft der Prozess ebenfalls in Fehler -.-
        iobrokermaint@PA-Broker:/opt/iobroker$ npm rebuild
        > nodemailer@6.4.6 postinstall /opt/iobroker/node_modules/iobroker.email/node_modules/nodemailer
        > node -e "try{require('./postinstall')}catch(e){}"
        === Nodemailer 6.4.6 ===
        Thank you for using Nodemailer for your email sending needs! While Nodemailer
        itself is mostly meant to be a SMTP client there are other related projects in
        the Nodemailer project as well.
        For example:
        > IMAP API (  https://imapapi.com  ) is a server application to easily access
        IMAP accounts via REST API
        > NodemailerApp (  https://nodemailer.com/app/  ) is a cross platform GUI app to
        debug emails
        > iobroker.javascript@4.3.4 postinstall /opt/iobroker/node_modules/iobroker.javascript
        > node ./install/installTypings.js
        Installing NodeJS typings...
        latest @types: 14, installed node: 12
        > iobroker.vis@1.2.4 install /opt/iobroker/node_modules/iobroker.vis
        > node main.js --install
        > ursa-optional@0.9.8 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@0.2.4 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
          CXX(target) Release/obj.target/diskusage/src/main.o
        In file included from ../../nan/nan_converters.h:67:0,
                         from ../../nan/nan.h:221,
                         from ../src/main.cpp:3:
        ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
        ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
               val->To ## TYPE(isolate->GetCurrentContext())                            \
        ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
         X(Boolean)
        In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,
                         from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:27,
                         from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67,
                         from ../../nan/nan.h:52,
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2664:59: note: declared here
                         V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
        ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
           return val->NAME ## Value(isolate->GetCurrentContext());                     \
        ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
         X(bool, Boolean)
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2702:51: note: declared here
                         V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
        In file included from ../../nan/nan_new.h:189:0,
                         from ../../nan/nan.h:222,
        ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
        ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                   , obj));
        In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67:0,
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
           static MaybeLocal<Function> New(
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
        ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
        ../../nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
           return v8::StringObject::New(value).As<v8::StringObject>();
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note: candidate: static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)
           static Local<Value> New(Isolate* isolate, Local<String> value);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note:   candidate expects 2 arguments, 1 provided
        ../../nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
        ../../nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
        In file included from ../src/main.cpp:3:0:
        ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
        ../../nan/nan.h:1063:53: error: no matching function for call to ‘v8::Value::ToString()’
               v8::Local<v8::String> string = from->ToString();
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
           V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                         Local<String> ToString(Isolate* isolate) const);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
        ../../nan/nan.h:1073:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’
                 length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
           int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1847:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
                         bool Set(Local<Value> key, Local<Value> value));
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1853:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(key, value);
        ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
        ../../nan/nan.h:1859:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             New(persistentHandle)->Set(index, value);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3508:22: note: declared here
                         bool Set(uint32_t index, Local<Value> value));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
        ../../nan/nan.h:1865:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 New(persistentHandle)->Get(New(key).ToLocalChecked()));
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3553:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
        ../../nan/nan.h:1871:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return scope.Escape(New(persistentHandle)->Get(key));
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
        ../../nan/nan.h:1876:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return scope.Escape(New(persistentHandle)->Get(index));
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3557:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
        In file included from /usr/include/c++/6/cassert:44:0,
                         from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node_object_wrap.h:26,
                         from ../../nan/nan.h:54,
        ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
        ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
             assert(persistent().IsNearDeath());
        In file included from ../../nan/nan.h:2690:0,
        ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
        ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
             persistent().MarkIndependent();
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:570:22: note: declared here
               V8_INLINE void MarkIndependent());
        ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
        ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
             assert(wrap->handle_.IsNearDeath());
        ../src/main.cpp: In function ‘v8::Local<v8::Object> ConvertDiskUsage(const DiskUsage&)’:
        ../src/main.cpp:9:103: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             obj->Set(Nan::New<v8::String>("available").ToLocalChecked(), Nan::New<v8::Number>(usage.available));
        ../src/main.cpp:10:93: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             obj->Set(Nan::New<v8::String>("free").ToLocalChecked(), Nan::New<v8::Number>(usage.free));
        ../src/main.cpp:11:95: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             obj->Set(Nan::New<v8::String>("total").ToLocalChecked(), Nan::New<v8::Number>(usage.total));
        ../src/main.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/main.cpp:26:71: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’
                 DiskUsage result = GetDiskUsage(*v8::String::Utf8Value(info[0]));
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note: candidate: v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
             Utf8Value(Isolate* isolate, Local<v8::Value> obj);
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note:   candidate expects 2 arguments, 1 provided
        ../src/main.cpp: At global scope:
        ../src/main.cpp:37:15: error: variable or field ‘Init’ declared void
         void Init(v8::Handle<v8::Object> exports)
        ../src/main.cpp:37:11: error: ‘Handle’ is not a member of ‘v8’
        ../src/main.cpp:37:32: error: expected primary-expression before ‘>’ token
        ../src/main.cpp:37:34: error: ‘exports’ was not declared in this scope
        In file included from ../../nan/nan.h:52:0,
        ../src/main.cpp:42:24: error: ‘Init’ was not declared in this scope
         NODE_MODULE(diskusage, Init)
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
               (node::addon_register_func) (regfunc),                          \
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
        ../src/main.cpp:42:24: note: suggested alternative:
        /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:225:18: note:   ‘node::Init’
         NODE_EXTERN void Init(int* argc,
        ../src/main.cpp:21:19: warning: ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’ defined but not used [-Wunused-function]
         static NAN_METHOD(GetDiskUsage)
        ../../nan/nan.h:1473:33: note: in definition of macro ‘NAN_METHOD’
             Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
        diskusage.target.mk:114: die Regel für Ziel „Release/obj.target/diskusage/src/main.o“ scheiterte
        make: *** [Release/obj.target/diskusage/src/main.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.9.0-12-amd64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/diskusage
        gyp ERR! node -v v12.16.3
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! diskusage@0.2.4 install: `node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the diskusage@0.2.4 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_02_47_833Z-debug.log
        • S samsungfreak
          npm rebuild
          For example:
          debug emails
          > node rebuild.js
          > node-gyp rebuild
           X(Boolean)
           X(bool, Boolean)
                                     , obj));
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          @samsungfreak
          nodejs -v && node -v && npm -v
            @samsungfreak
            samsungfreak
            iobrokermaint@Broker:~$ nodejs -v && node -v && npm -v
            v12.16.3
            v12.16.3
            6.14.4
            • S samsungfreak
              v12.16.3
              v12.16.3
              6.14.4
              @samsungfreak
              Im Ordner /opt/iobroker
              npm rebuild diskusage
                @samsungfreak
                samsungfreak
                Gibt leider nichts aus:
                iobrokermaint@Broker:~$ npm rebuild diskusage
                • S samsungfreak
                  @samsungfreak Du stehst nicht im angegebenen Ordner.
                    samsungfreak
                    Oh stimmt -.-
                    iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage
                    > node-gyp rebuild
                     X(Boolean)
                     X(bool, Boolean)
                                               , obj));
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_29_18_103Z-debug.log
                    • S samsungfreak
                      Oh stimmt -.-
                      > node-gyp rebuild
                       X(Boolean)
                       X(bool, Boolean)
                                                 , obj));
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      @samsungfreak
                      npm rebuild diskusage --from-source
                        @samsungfreak
                        samsungfreak
                        @samsungfreak
                        Der Befehl hat funktioniert allerdings ebenfalls mit den Fehlern:
                        iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage --from-source
                        > node-gyp rebuild
                         X(Boolean)
                         X(bool, Boolean)
                                                   , obj));
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_54_39_055Z-debug.log
                        • S samsungfreak
                          @samsungfreak
                          > node-gyp rebuild
                           X(Boolean)
                           X(bool, Boolean)
                                                     , obj));
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          @samsungfreak
                          iobroker rebuild self
                          • Thomas BraunT Online
                            npm cache clear
                              npm cache clear
                              samsungfreak
                              npm cache clear
                              /opt/iobroker$ npm cache clear
                              npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                              npm ERR!
                              npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                              npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T16_44_18_291Z-debug.log
                                @samsungfreak
                                samsungfreak
                                @samsungfreak
                                Den Befehl gibt es leider nicht
                                /opt/iobroker$ iobroker rebuild self
                                Commands:
                                iobroker setup [--objects <host>] [--states <host>] [custom]
                                iobroker start
                                iobroker stop
                                iobroker start <adapter>
                                iobroker stop <adapter>
                                iobroker start all
                                iobroker restart
                                iobroker restart <adapter>
                                iobroker info
                                iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                                iobroker install <adapter>
                                iobroker url <url> [<name>]
                                iobroker del <adapter>
                                iobroker del <adapter>.<instance>
                                iobroker update [repository url] [--updatable/--u] [--installed/--i]
                                iobroker upgrade [repository url]
                                iobroker upgrade self [repository url]
                                iobroker upgrade <adapter> [repository url]
                                iobroker upload <pathToLocalFile> <pathIniobroker>
                                iobroker upload all
                                iobroker upload <adapter>
                                iobroker object get <id>
                                iobroker object del <id>
                                iobroker object chmod <object-mode> [state-mode] <id>
                                iobroker object chown <user> <group> <id>
                                iobroker object list <id>
                                iobroker state get <id> [
                                iobroker state getplain <id> [--pretty]
                                iobroker state getvalue <id>
                                iobroker state set <id> <value> [ack]
                                iobroker state del <id>
                                iobroker message <adapter>[.instanceid] <command> [<message>]
                                iobroker list <type> [filter]
                                iobroker chmod <mode> <file>
                                iobroker chown <user> <group> <file>
                                iobroker touch <file>
                                iobroker rm <file>
                                iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                                iobroker file write <filesystem-path-to-read> <iobroker-path-to-read>
                                iobroker user add <user> [--ingroup group] [--password pass]
                                iobroker user del <user>
                                iobroker user passwd <user> [--password pass]
                                iobroker user enable <user>
                                iobroker user disable <user>
                                iobroker user get <user>
                                iobroker user check <user> [--password pass]
                                iobroker group add <group>
                                iobroker group del <group>
                                iobroker group list <group>
                                iobroker group enable <group>
                                iobroker group disable <group>
                                iobroker group get <group>
                                iobroker group adduser <group> <user>
                                iobroker group deluser <group> <user>
                                iobroker host this
                                iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                                iobroker license <license.file or license.text>
                                iobroker clean
                                iobroker backup
                                iobroker restore <backup name or path>
                                iobroker <command> --timeout 5000
                                iobroker status
                                iobroker repo [name]
                                iobroker repo add <name> <path or url>
                                iobroker repo set <name>
                                iobroker repo del <name>
                                iobroker uuid
                                iobroker unsetup
                                iobroker multihost <enable|disable> [--secure true|false]
                                iobroker multihost browse
                                iobroker multihost connect
                                iobroker version [adapter]
                                iobroker [adapter] -v
                                Optionen:
                                  --help     Hilfe anzeigen  [boolean]
                                  --version  Version anzeigen  [boolean]
                                • S samsungfreak
                                  @samsungfreak
                                  Commands:
                                  iobroker start
                                  iobroker stop
                                  iobroker start all
                                  iobroker restart
                                  iobroker info
                                  iobroker upload all
                                  iobroker rm <file>
                                  iobroker host this
                                  iobroker clean
                                  iobroker backup
                                  iobroker status
                                  iobroker uuid
                                  iobroker unsetup
                                  Optionen:
                                  @samsungfreak Bei js-controller 2 gibt es den noch nicht.
                                  Keine Ahnung was da bei dir klemmt. Ich glaube da hängt noch irgendwas uraltes im npm cache drin.
                                    samsungfreak
                                    @Thomas-Braun Gut wenn es nicht geht dann bleibt mir nichts über als das Update mit "Fehlern" durchzuführen. Da der IOBroker nach dem Update weiter ohne Problme läuft hoffe ich mal, dass das Problem beim nächsten Update nicht auftritt:)
