  4. Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern
@1.5.3 @2.1.1
37 Beiträge 4 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • S samsungfreak
    @Thomas-Braun sagte in Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern:
    nodejs -v && node -v && npm -v
    iobrokermaint@Broker:~$ nodejs -v && node -v && npm -v
    v12.16.3
    v12.16.3
    6.14.4
    @samsungfreak
    Im Ordner /opt/iobroker
    npm rebuild diskusage
      @samsungfreak
      samsungfreak
      Gibt leider nichts aus:
      iobrokermaint@Broker:~$ npm rebuild diskusage
      • S samsungfreak
        @samsungfreak Du stehst nicht im angegebenen Ordner.
          samsungfreak
          Oh stimmt -.-
          iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage
          > diskusage@0.2.4 install /opt/iobroker/node_modules/diskusage
          > node-gyp rebuild
          make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
            CXX(target) Release/obj.target/diskusage/src/main.o
          In file included from ../../nan/nan_converters.h:67:0,
                           from ../../nan/nan.h:221,
                           from ../src/main.cpp:3:
          ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
          ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
                 val->To ## TYPE(isolate->GetCurrentContext())                            \
          ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
           X(Boolean)
          In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,
                           from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:27,
                           from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67,
                           from ../../nan/nan.h:52,
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2664:59: note: declared here
                           V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
             declarator __attribute__((deprecated(message)))
          ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
          ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
             return val->NAME ## Value(isolate->GetCurrentContext());                     \
          ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
           X(bool, Boolean)
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2702:51: note: declared here
                           V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
          In file included from ../../nan/nan_new.h:189:0,
                           from ../../nan/nan.h:222,
          ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
          ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                     , obj));
          In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67:0,
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
             static MaybeLocal<Function> New(
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
          ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
          ../../nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
             return v8::StringObject::New(value).As<v8::StringObject>();
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note: candidate: static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)
             static Local<Value> New(Isolate* isolate, Local<String> value);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note:   candidate expects 2 arguments, 1 provided
          ../../nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
          ../../nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
          In file included from ../src/main.cpp:3:0:
          ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
          ../../nan/nan.h:1063:53: error: no matching function for call to ‘v8::Value::ToString()’
                 v8::Local<v8::String> string = from->ToString();
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
             V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                           Local<String> ToString(Isolate* isolate) const);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
          ../../nan/nan.h:1073:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’
                   length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
             int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
          ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
          ../../nan/nan.h:1847:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
                           bool Set(Local<Value> key, Local<Value> value));
          ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
          ../../nan/nan.h:1853:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               New(persistentHandle)->Set(key, value);
          ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
          ../../nan/nan.h:1859:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               New(persistentHandle)->Set(index, value);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3508:22: note: declared here
                           bool Set(uint32_t index, Local<Value> value));
          ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
          ../../nan/nan.h:1865:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   New(persistentHandle)->Get(New(key).ToLocalChecked()));
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3553:51: note: declared here
             V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
          ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
          ../../nan/nan.h:1871:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               return scope.Escape(New(persistentHandle)->Get(key));
          ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
          ../../nan/nan.h:1876:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               return scope.Escape(New(persistentHandle)->Get(index));
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3557:51: note: declared here
             V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
          In file included from /usr/include/c++/6/cassert:44:0,
                           from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node_object_wrap.h:26,
                           from ../../nan/nan.h:54,
          ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
          ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
               assert(persistent().IsNearDeath());
          In file included from ../../nan/nan.h:2690:0,
          ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
          ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
               persistent().MarkIndependent();
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:570:22: note: declared here
                 V8_INLINE void MarkIndependent());
          ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
          ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
               assert(wrap->handle_.IsNearDeath());
          ../src/main.cpp: In function ‘v8::Local<v8::Object> ConvertDiskUsage(const DiskUsage&)’:
          ../src/main.cpp:9:103: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               obj->Set(Nan::New<v8::String>("available").ToLocalChecked(), Nan::New<v8::Number>(usage.available));
          ../src/main.cpp:10:93: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               obj->Set(Nan::New<v8::String>("free").ToLocalChecked(), Nan::New<v8::Number>(usage.free));
          ../src/main.cpp:11:95: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               obj->Set(Nan::New<v8::String>("total").ToLocalChecked(), Nan::New<v8::Number>(usage.total));
          ../src/main.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/main.cpp:26:71: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’
                   DiskUsage result = GetDiskUsage(*v8::String::Utf8Value(info[0]));
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note: candidate: v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
               Utf8Value(Isolate* isolate, Local<v8::Value> obj);
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note:   candidate expects 2 arguments, 1 provided
          ../src/main.cpp: At global scope:
          ../src/main.cpp:37:15: error: variable or field ‘Init’ declared void
           void Init(v8::Handle<v8::Object> exports)
          ../src/main.cpp:37:11: error: ‘Handle’ is not a member of ‘v8’
          ../src/main.cpp:37:32: error: expected primary-expression before ‘>’ token
          ../src/main.cpp:37:34: error: ‘exports’ was not declared in this scope
          In file included from ../../nan/nan.h:52:0,
          ../src/main.cpp:42:24: error: ‘Init’ was not declared in this scope
           NODE_MODULE(diskusage, Init)
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                 (node::addon_register_func) (regfunc),                          \
          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
          ../src/main.cpp:42:24: note: suggested alternative:
          /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:225:18: note:   ‘node::Init’
           NODE_EXTERN void Init(int* argc,
          ../src/main.cpp:21:19: warning: ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’ defined but not used [-Wunused-function]
           static NAN_METHOD(GetDiskUsage)
          ../../nan/nan.h:1473:33: note: in definition of macro ‘NAN_METHOD’
               Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
          diskusage.target.mk:114: die Regel für Ziel „Release/obj.target/diskusage/src/main.o“ scheiterte
          make: *** [Release/obj.target/diskusage/src/main.o] Fehler 1
          make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
          gyp ERR! System Linux 4.9.0-12-amd64
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/diskusage
          gyp ERR! node -v v12.16.3
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! diskusage@0.2.4 install: `node-gyp rebuild`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the diskusage@0.2.4 install script.
          npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_29_18_103Z-debug.log
          • S samsungfreak
            Oh stimmt -.-
            > node-gyp rebuild
             X(Boolean)
             X(bool, Boolean)
                                       , obj));
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            @samsungfreak
            npm rebuild diskusage --from-source
              @samsungfreak
              samsungfreak
              @samsungfreak
              Der Befehl hat funktioniert allerdings ebenfalls mit den Fehlern:
              iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage --from-source
              > node-gyp rebuild
               X(Boolean)
               X(bool, Boolean)
                                         , obj));
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_54_39_055Z-debug.log
              • S samsungfreak
                @samsungfreak
                > node-gyp rebuild
                 X(Boolean)
                 X(bool, Boolean)
                                           , obj));
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                @samsungfreak
                iobroker rebuild self
                • Thomas BraunT Online
                  npm cache clear
                    npm cache clear
                    samsungfreak
                    npm cache clear
                    /opt/iobroker$ npm cache clear
                    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                    npm ERR!
                    npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                    npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T16_44_18_291Z-debug.log
                    iobrokermaint@PA-Broker:/opt/iobroker$
                      @samsungfreak
                      samsungfreak
                      @samsungfreak
                      Den Befehl gibt es leider nicht
                      /opt/iobroker$ iobroker rebuild self
                      Commands:
                      iobroker setup [--objects <host>] [--states <host>] [custom]
                      iobroker start
                      iobroker stop
                      iobroker start <adapter>
                      iobroker stop <adapter>
                      iobroker start all
                      iobroker restart
                      iobroker restart <adapter>
                      iobroker info
                      iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                      iobroker install <adapter>
                      iobroker url <url> [<name>]
                      iobroker del <adapter>
                      iobroker del <adapter>.<instance>
                      iobroker update [repository url] [--updatable/--u] [--installed/--i]
                      iobroker upgrade [repository url]
                      iobroker upgrade self [repository url]
                      iobroker upgrade <adapter> [repository url]
                      iobroker upload <pathToLocalFile> <pathIniobroker>
                      iobroker upload all
                      iobroker upload <adapter>
                      iobroker object get <id>
                      iobroker object del <id>
                      iobroker object chmod <object-mode> [state-mode] <id>
                      iobroker object chown <user> <group> <id>
                      iobroker object list <id>
                      iobroker state get <id> [
                      iobroker state getplain <id> [--pretty]
                      iobroker state getvalue <id>
                      iobroker state set <id> <value> [ack]
                      iobroker state del <id>
                      iobroker message <adapter>[.instanceid] <command> [<message>]
                      iobroker list <type> [filter]
                      iobroker chmod <mode> <file>
                      iobroker chown <user> <group> <file>
                      iobroker touch <file>
                      iobroker rm <file>
                      iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                      iobroker file write <filesystem-path-to-read> <iobroker-path-to-read>
                      iobroker user add <user> [--ingroup group] [--password pass]
                      iobroker user del <user>
                      iobroker user passwd <user> [--password pass]
                      iobroker user enable <user>
                      iobroker user disable <user>
                      iobroker user get <user>
                      iobroker user check <user> [--password pass]
                      iobroker group add <group>
                      iobroker group del <group>
                      iobroker group list <group>
                      iobroker group enable <group>
                      iobroker group disable <group>
                      iobroker group get <group>
                      iobroker group adduser <group> <user>
                      iobroker group deluser <group> <user>
                      iobroker host this
                      iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                      iobroker license <license.file or license.text>
                      iobroker clean
                      iobroker backup
                      iobroker restore <backup name or path>
                      iobroker <command> --timeout 5000
                      iobroker status
                      iobroker repo [name]
                      iobroker repo add <name> <path or url>
                      iobroker repo set <name>
                      iobroker repo del <name>
                      iobroker uuid
                      iobroker unsetup
                      iobroker multihost <enable|disable> [--secure true|false]
                      iobroker multihost browse
                      iobroker multihost connect
                      iobroker version [adapter]
                      iobroker [adapter] -v
                      Optionen:
                        --help     Hilfe anzeigen  [boolean]
                        --version  Version anzeigen  [boolean]
                      • S samsungfreak
                        @samsungfreak
                        Commands:
                        iobroker start
                        iobroker stop
                        iobroker start all
                        iobroker restart
                        iobroker info
                        iobroker upload all
                        iobroker rm <file>
                        iobroker host this
                        iobroker clean
                        iobroker backup
                        iobroker status
                        iobroker uuid
                        iobroker unsetup
                        Optionen:
                        @samsungfreak Bei js-controller 2 gibt es den noch nicht.
                        Keine Ahnung was da bei dir klemmt. Ich glaube da hängt noch irgendwas uraltes im npm cache drin.
                          samsungfreak
                          @Thomas-Braun Gut wenn es nicht geht dann bleibt mir nichts über als das Update mit "Fehlern" durchzuführen. Da der IOBroker nach dem Update weiter ohne Problme läuft hoffe ich mal, dass das Problem beim nächsten Update nicht auftritt:)
