  4. Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern
@1.5.3 @2.1.1
37 Beiträge 4 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • S samsungfreak
    @Thomas-Braun Ich habe mal das ganze Updatelog hochgeladen. Kannst du daraus irgendetwas erkennen?
    UpdateLog.txt
    @samsungfreak In /opt/iobroker
    npm rebuild
      npm rebuild
      samsungfreak
      @Thomas-Braun sagte in Update JS-Controller @1.5.3 auf @2.1.1 mit Fehlern:
      npm rebuild
      Leider läuft der Prozess ebenfalls in Fehler -.-
      iobrokermaint@PA-Broker:/opt/iobroker$ npm rebuild
      > nodemailer@6.4.6 postinstall /opt/iobroker/node_modules/iobroker.email/node_modules/nodemailer
      > node -e "try{require('./postinstall')}catch(e){}"
      === Nodemailer 6.4.6 ===
      Thank you for using Nodemailer for your email sending needs! While Nodemailer
      itself is mostly meant to be a SMTP client there are other related projects in
      the Nodemailer project as well.
      For example:
      > IMAP API (  https://imapapi.com  ) is a server application to easily access
      IMAP accounts via REST API
      > NodemailerApp (  https://nodemailer.com/app/  ) is a cross platform GUI app to
      debug emails
      > iobroker.javascript@4.3.4 postinstall /opt/iobroker/node_modules/iobroker.javascript
      > node ./install/installTypings.js
      Installing NodeJS typings...
      latest @types: 14, installed node: 12
      > iobroker.vis@1.2.4 install /opt/iobroker/node_modules/iobroker.vis
      > node main.js --install
      > ursa-optional@0.9.8 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      > diskusage@0.2.4 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
        CXX(target) Release/obj.target/diskusage/src/main.o
      In file included from ../../nan/nan_converters.h:67:0,
                       from ../../nan/nan.h:221,
                       from ../src/main.cpp:3:
      ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
      ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
             val->To ## TYPE(isolate->GetCurrentContext())                            \
      ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
       X(Boolean)
      In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,
                       from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:27,
                       from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67,
                       from ../../nan/nan.h:52,
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2664:59: note: declared here
                       V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
      ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
         return val->NAME ## Value(isolate->GetCurrentContext());                     \
      ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
       X(bool, Boolean)
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2702:51: note: declared here
                       V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
      In file included from ../../nan/nan_new.h:189:0,
                       from ../../nan/nan.h:222,
      ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
      ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                 , obj));
      In file included from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:67:0,
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
         static MaybeLocal<Function> New(
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
      ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
      ../../nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
         return v8::StringObject::New(value).As<v8::StringObject>();
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note: candidate: static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)
         static Local<Value> New(Isolate* isolate, Local<String> value);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:5531:23: note:   candidate expects 2 arguments, 1 provided
      ../../nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
      ../../nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
      In file included from ../src/main.cpp:3:0:
      ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
      ../../nan/nan.h:1063:53: error: no matching function for call to ‘v8::Value::ToString()’
             v8::Local<v8::String> string = from->ToString();
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
         V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                       Local<String> ToString(Isolate* isolate) const);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
      ../../nan/nan.h:1073:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’
               length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
         int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1847:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
                       bool Set(Local<Value> key, Local<Value> value));
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1853:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(key, value);
      ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
      ../../nan/nan.h:1859:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           New(persistentHandle)->Set(index, value);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3508:22: note: declared here
                       bool Set(uint32_t index, Local<Value> value));
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
      ../../nan/nan.h:1865:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               New(persistentHandle)->Get(New(key).ToLocalChecked()));
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3553:51: note: declared here
         V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
      ../../nan/nan.h:1871:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           return scope.Escape(New(persistentHandle)->Get(key));
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
      ../../nan/nan.h:1876:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           return scope.Escape(New(persistentHandle)->Get(index));
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3557:51: note: declared here
         V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
      In file included from /usr/include/c++/6/cassert:44:0,
                       from /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node_object_wrap.h:26,
                       from ../../nan/nan.h:54,
      ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
      ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
           assert(persistent().IsNearDeath());
      In file included from ../../nan/nan.h:2690:0,
      ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
      ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
           persistent().MarkIndependent();
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:570:22: note: declared here
             V8_INLINE void MarkIndependent());
      ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
      ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
           assert(wrap->handle_.IsNearDeath());
      ../src/main.cpp: In function ‘v8::Local<v8::Object> ConvertDiskUsage(const DiskUsage&)’:
      ../src/main.cpp:9:103: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           obj->Set(Nan::New<v8::String>("available").ToLocalChecked(), Nan::New<v8::Number>(usage.available));
      ../src/main.cpp:10:93: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           obj->Set(Nan::New<v8::String>("free").ToLocalChecked(), Nan::New<v8::Number>(usage.free));
      ../src/main.cpp:11:95: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           obj->Set(Nan::New<v8::String>("total").ToLocalChecked(), Nan::New<v8::Number>(usage.total));
      ../src/main.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/main.cpp:26:71: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’
               DiskUsage result = GetDiskUsage(*v8::String::Utf8Value(info[0]));
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note: candidate: v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
           Utf8Value(Isolate* isolate, Local<v8::Value> obj);
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/v8.h:3135:5: note:   candidate expects 2 arguments, 1 provided
      ../src/main.cpp: At global scope:
      ../src/main.cpp:37:15: error: variable or field ‘Init’ declared void
       void Init(v8::Handle<v8::Object> exports)
      ../src/main.cpp:37:11: error: ‘Handle’ is not a member of ‘v8’
      ../src/main.cpp:37:32: error: expected primary-expression before ‘>’ token
      ../src/main.cpp:37:34: error: ‘exports’ was not declared in this scope
      In file included from ../../nan/nan.h:52:0,
      ../src/main.cpp:42:24: error: ‘Init’ was not declared in this scope
       NODE_MODULE(diskusage, Init)
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
             (node::addon_register_func) (regfunc),                          \
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
      ../src/main.cpp:42:24: note: suggested alternative:
      /home/iobrokermaint/.cache/node-gyp/12.16.3/include/node/node.h:225:18: note:   ‘node::Init’
       NODE_EXTERN void Init(int* argc,
      ../src/main.cpp:21:19: warning: ‘Nan::NAN_METHOD_RETURN_TYPE GetDiskUsage(Nan::NAN_METHOD_ARGS_TYPE)’ defined but not used [-Wunused-function]
       static NAN_METHOD(GetDiskUsage)
      ../../nan/nan.h:1473:33: note: in definition of macro ‘NAN_METHOD’
           Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
      diskusage.target.mk:114: die Regel für Ziel „Release/obj.target/diskusage/src/main.o“ scheiterte
      make: *** [Release/obj.target/diskusage/src/main.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.9.0-12-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
      gyp ERR! node -v v12.16.3
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! diskusage@0.2.4 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the diskusage@0.2.4 install script.
      npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_02_47_833Z-debug.log
      • S samsungfreak
        npm rebuild
        For example:
        debug emails
        > node rebuild.js
        > node-gyp rebuild
         X(Boolean)
         X(bool, Boolean)
                                   , obj));
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        @samsungfreak
        nodejs -v && node -v && npm -v
          @samsungfreak
          samsungfreak
          iobrokermaint@Broker:~$ nodejs -v && node -v && npm -v
          v12.16.3
          v12.16.3
          6.14.4
          • S samsungfreak
            v12.16.3
            v12.16.3
            6.14.4
            @samsungfreak
            Im Ordner /opt/iobroker
            npm rebuild diskusage
              @samsungfreak
              samsungfreak
              Gibt leider nichts aus:
              iobrokermaint@Broker:~$ npm rebuild diskusage
              • S samsungfreak
                @samsungfreak Du stehst nicht im angegebenen Ordner.
                  samsungfreak
                  Oh stimmt -.-
                  iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage
                  > node-gyp rebuild
                   X(Boolean)
                   X(bool, Boolean)
                                             , obj));
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_29_18_103Z-debug.log
                  • S samsungfreak
                    Oh stimmt -.-
                    > node-gyp rebuild
                     X(Boolean)
                     X(bool, Boolean)
                                               , obj));
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    @samsungfreak
                    npm rebuild diskusage --from-source
                      @samsungfreak
                      samsungfreak
                      @samsungfreak
                      Der Befehl hat funktioniert allerdings ebenfalls mit den Fehlern:
                      iobrokermaint@BROKER:/opt/iobroker$ npm rebuild diskusage --from-source
                      > node-gyp rebuild
                       X(Boolean)
                       X(bool, Boolean)
                                                 , obj));
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T15_54_39_055Z-debug.log
                      • S samsungfreak
                        @samsungfreak
                        > node-gyp rebuild
                         X(Boolean)
                         X(bool, Boolean)
                                                   , obj));
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        @samsungfreak
                        iobroker rebuild self
                        • Thomas BraunT Online
                          npm cache clear
                            npm cache clear
                            samsungfreak
                            npm cache clear
                            /opt/iobroker$ npm cache clear
                            npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                            npm ERR!
                            npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                            npm ERR!     /home/iobrokermaint/.npm/_logs/2020-05-17T16_44_18_291Z-debug.log
                              @samsungfreak
                              samsungfreak
                              @samsungfreak
                              Den Befehl gibt es leider nicht
                              /opt/iobroker$ iobroker rebuild self
                              Commands:
                              iobroker setup [--objects <host>] [--states <host>] [custom]
                              iobroker start
                              iobroker stop
                              iobroker start <adapter>
                              iobroker stop <adapter>
                              iobroker start all
                              iobroker restart
                              iobroker restart <adapter>
                              iobroker info
                              iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                              iobroker install <adapter>
                              iobroker url <url> [<name>]
                              iobroker del <adapter>
                              iobroker del <adapter>.<instance>
                              iobroker update [repository url] [--updatable/--u] [--installed/--i]
                              iobroker upgrade [repository url]
                              iobroker upgrade self [repository url]
                              iobroker upgrade <adapter> [repository url]
                              iobroker upload <pathToLocalFile> <pathIniobroker>
                              iobroker upload all
                              iobroker upload <adapter>
                              iobroker object get <id>
                              iobroker object del <id>
                              iobroker object chmod <object-mode> [state-mode] <id>
                              iobroker object chown <user> <group> <id>
                              iobroker object list <id>
                              iobroker state get <id> [
                              iobroker state getplain <id> [--pretty]
                              iobroker state getvalue <id>
                              iobroker state set <id> <value> [ack]
                              iobroker state del <id>
                              iobroker message <adapter>[.instanceid] <command> [<message>]
                              iobroker list <type> [filter]
                              iobroker chmod <mode> <file>
                              iobroker chown <user> <group> <file>
                              iobroker touch <file>
                              iobroker rm <file>
                              iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                              iobroker file write <filesystem-path-to-read> <iobroker-path-to-read>
                              iobroker user add <user> [--ingroup group] [--password pass]
                              iobroker user del <user>
                              iobroker user passwd <user> [--password pass]
                              iobroker user enable <user>
                              iobroker user disable <user>
                              iobroker user get <user>
                              iobroker user check <user> [--password pass]
                              iobroker group add <group>
                              iobroker group del <group>
                              iobroker group list <group>
                              iobroker group enable <group>
                              iobroker group disable <group>
                              iobroker group get <group>
                              iobroker group adduser <group> <user>
                              iobroker group deluser <group> <user>
                              iobroker host this
                              iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                              iobroker license <license.file or license.text>
                              iobroker clean
                              iobroker backup
                              iobroker restore <backup name or path>
                              iobroker <command> --timeout 5000
                              iobroker status
                              iobroker repo [name]
                              iobroker repo add <name> <path or url>
                              iobroker repo set <name>
                              iobroker repo del <name>
                              iobroker uuid
                              iobroker unsetup
                              iobroker multihost <enable|disable> [--secure true|false]
                              iobroker multihost browse
                              iobroker multihost connect
                              iobroker version [adapter]
                              iobroker [adapter] -v
                              Optionen:
                                --help     Hilfe anzeigen  [boolean]
                                --version  Version anzeigen  [boolean]
                              • S samsungfreak
                                @samsungfreak
                                Commands:
                                iobroker start
                                iobroker stop
                                iobroker start all
                                iobroker restart
                                iobroker info
                                iobroker upload all
                                iobroker rm <file>
                                iobroker host this
                                iobroker clean
                                iobroker backup
                                iobroker status
                                iobroker uuid
                                iobroker unsetup
                                Optionen:
                                @samsungfreak Bei js-controller 2 gibt es den noch nicht.
                                Keine Ahnung was da bei dir klemmt. Ich glaube da hängt noch irgendwas uraltes im npm cache drin.
                                  samsungfreak
                                  @Thomas-Braun Gut wenn es nicht geht dann bleibt mir nichts über als das Update mit "Fehlern" durchzuführen. Da der IOBroker nach dem Update weiter ohne Problme läuft hoffe ich mal, dass das Problem beim nächsten Update nicht auftritt:)
