  4. [Linux Shell-Skript] WLAN-Wetterstation
    1.0k
    6.1k
linuxshell-scriptwetterstationwlan-wetterstation
5.8k Beiträge 156 Kommentatoren 4.6m Aufrufe 137 Beobachtet
  • SBorgS SBorg
    @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    Ich persönlich werde es dann per Binding lt. der Tabelle einfärben
    In Grafana?
    Zeigst du uns/mir das wie das geht? ;)
    Binding = VIS :)
    Aber auch in Grafana:
    Ich weiß nur noch nicht so recht ob ich den Wert oder den Hintergrund färbe und die "---" bei keinem Index so lasse...
    "type": "stat",
    "title": "Hitzeindex",
    "gridPos": {
    "x": 7,
    "y": 37,
    "w": 2,
    "h": 3
    "id": 63,
    "targets": [
    "refId": "A",
    "policy": "default",
    "resultFormat": "time_series",
    "orderByTime": "ASC",
    "tags": [],
    "groupBy": [
    "type": "time",
    "params": [
    "$__interval"
    "type": "fill",
    "params": [
    "none"
    "select": [
    "type": "field",
    "params": [
    "value"
    "type": "last",
    "params": []
    "measurement": "javascript.0.Wetterstation.Info.Hitzeindex",
    "alias": "Hitzeindex"
    "transparent": true,
    "options": {
    "reduceOptions": {
    "values": false,
    "calcs": [
    "lastNotNull"
    "fields": ""
    "orientation": "auto",
    "textMode": "value",
    "colorMode": "value",
    "graphMode": "none",
    "justifyMode": "center"
    "fieldConfig": {
    "defaults": {
    "custom": {},
    "unit": "celsius",
    "decimals": 2,
    "noValue": "NA",
    "thresholds": {
    "mode": "absolute",
    "steps": [
    "color": "rgb(47, 48, 47)",
    "value": null
    "color": "light-yellow",
    "value": 32
    "color": "dark-yellow",
    "value": 40
    "color": "dark-orange",
    "value": 54
    "color": "dark-red",
    "value": 100
    "mappings": [
    "id": 1,
    "type": 1,
    "from": "",
    "to": "",
    "text": "---",
    "value": "0"
    "overrides": []
    "pluginVersion": "7.3.7",
    "links": [],
    "maxDataPoints": 100,
    "timeFrom": null,
    "timeShift": null,
    "interval": null,
    "cacheTimeout": null,
    "datasource": null
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #2281
    Servus
    Wurden die Einstellungen im Dashboard so richtig übernommen?
    Im Export von dir steht was von:
    "value": null
    "value": 32
    "value": 40
    "value": 54
    "value": 100
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      Servus
      "value": null
      "value": 32
      "value": 40
      "value": 54
      "value": 100
      SBorgS Offline
      SBorgS Offline
      SBorg
      #2282
      @negalein Wie alt ist denn deine Grafana-Version?
      Sollte eigentlich so aussehen (kannst du dann aber auch so in deine Version übernehmen):
      LG SBorg ( SBorg auf GitHub)
      • SBorgS SBorg
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #2283
        Danke, das hilft!
        Bin noch auf einer 6er unterwegs.
        • SBorgS SBorg
          @nashra 😁
          @Rand Ne, ist nicht seltsam ;)
          Ohne jetzt die genaue Anzahl nachzurechnen, ist es nicht unbedingt der Performance förderlich mehr als unbedingt nötig auszuführen. Jeder Sensor mit seinen x-Werten ist eine "Abfrage". 25 mögliche Sensoren mit 4 Werten = 100 Abfragen ggf. alle 30 Sekunden.
          Nur hat wohl keiner alle möglichen Sensoren, und die meisten, wie ich auch, kein Gateway bzw. Zusatzsensoren. Deswegen wird über die "Anzahl" der Sensoren in der *.conf die erforderliche Abfragemenge berechnet. Ein DP200 hat 3 Werte, bei dir 2 Sensoren = 6 nötige Abfragen
          Wären es mit den "Standardabfragen" (Temp, Feuchte, Wind...) nun bspw. in Summe 40 Abfragen, hast du aber durch "DP200=0" nun 6 zu wenig definiert = 34 Abfragen
          Somit ist nach der 34. Abfrage einfach Schluss...
          Jetzt vergleiche mal bei deinen beiden Versuchen die Ausgabe/Anzahl/Bezeichnung der Zusatzsensoren. Fällt dir da was (auch bzgl. der Anzahl wie viele fehlen) auf und gerade was da auch fehlt?
          Die Batterie-Werte sind ganz hinten im String, deswegen hat es für die Sensorwerte der DP200s noch gelangt, aber nicht mehr für alle Batteriewerte. Da ist dir nur nicht aufgefallen, dass die nicht mehr aktualisiert wurden... ;)
          ...und die Leck-Sensoren zählen (noch) nicht, da sie derzeit nicht berücksichtigt werden und quasi "unsichtbar" sind.
          Also alles gut und eigentlich wie erwartet 😁
          Rand
          #2284
          @sborg said in [Linux Shell-Skript] WLAN-Wetterstation:
          @nashra 😁
          Ahh, es wird nur die maximale Sensor Zahl damit erhöht und nicht explizit auf 2 dp200 geschaut; na das erklärt dann vieles :)
          Danke für die Erkläruimng
          • SBorgS SBorg
            Next round Updatetime:
            Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.3.0
            • ~ Fix Rundungsfehler Windchill/Taupunkt
            • + Min/max Aussentemperatur der letzten 24h
            • + Unterstützung für DP60 Sensor
            • ~ Fix für Protokoll #9 wg. fehlender Regenrate
            Wie immer zu finden im GitHub
            Wegen neuer Datenpunkte muss auch wetterstation.js ersetzt und einmalig ausgeführt werden.
            Neue Beta-Version des Wetterstation WLAN-Skriptes auf GitHub V2.4.0
            • + Hitzeindex (>20°C)
            • + Unterstützung von max. 4 DP200 Sensoren
            Wegen der neuen Datenpunkte muss auch wetterstation.js ersetzt und einmalig ausgeführt werden.
            Wäre toll wenn gerade die DP200-Nutzer testen könnten ob es funktioniert ;)
            Zum Hitzeindex sei auf die WiKi verwiesen. Ich persönlich werde es dann per Binding lt. der Tabelle einfärben :)
            SBorgS Offline
            SBorgS Offline
            SBorg
            #2285
            Agenda nun ziemlich abgearbeitet :) :
            Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.4.0
            Neue Beta-Version des Wetterstation WLAN-Skriptes auf GitHub V2.5.0
            • + Min/Max/Avg Aussentemperatur vor einem Jahr
            • + Unterstützung von max. 4 DP70 Sensoren
            • ~ Codeoptimierungen
            Wäre toll wenn gerade die DP70-Nutzer testen könnten ob es funktioniert ;)
            Neu ist nun die Bezeichnung bei den Sensoren. Dies dient rein der Übersichtlichkeit und kann so leider nur durch Neuanlage der Datenpunkte erfolgen.
            Die neuen Werte "vor einem Jahr" werden nur täglich einmalig mit den Mitternachtjobs erzeugt. Zur Kennzeichnung falls noch keine Werte vorhanden sind, wie immer mit utopischen 99er-Werten befüllt. Wäre interessant zu wissen ob es funktioniert, falls wer schon zum 10.02.2020 die Aussentemperatur geloggt hat :)
            NegaleinN ? R 3 Antworten Letzte Antwort
            • SBorgS SBorg
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #2286
              läuft :)
                läuft :)
                SBorgS Offline
                SBorgS Offline
                SBorg
                #2287
                @negalein :)
                Hatte ich noch vergessen zu erwähnen, die Anlage der DPs geschieht mit "0°C". Ab Mitternacht dann mit Werten falls vorhanden, sonst eben +/- 99.99°C (mehr Stellen können es nicht werden; so hat man gleich einen idealen Platzhalter für den VIS-Editor ;) )
                • SBorgS SBorg
                  #2288
                  @sborg update auf 2.5.0 - läuft.
                  Externe Sensoren sind für Q3 geplant... :-)
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #2289
                    @ilovegym sagte in 4[Linux Shell-Skript] WLAN-Wetterstation:
                    Habe selbst keine und sind auch bei mir nicht in Planung. Jetzt wo alles läuft brauche/kriege ich auch keine Muster mehr von Ecowitt ^^
                    Jetzt muss ich erst mal aufgeschobenen Privatkram erledigen, dann kann ich mich auch vielleicht endlich mal der PimpMyStation wieder zuwenden ;)
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #2290
                      @SBorg
                      OT: ist dir im Titel die 4 unabsichtlich reingerutscht?
                        @SBorg
                        SBorgS Offline
                        SBorgS Offline
                        SBorg
                        #2291
                        @SBorg
                        Welche "4" 😇
                        Jepp, ich habe vorhin V2.3.0 --> V2.4.0 geändert und wegen meiner blöden NB-Tastatur (da stimmen die Abstände nicht) zwei Tasten erwischt, habe aber nicht entdeckt was genau passiert ist. Nu weiß ich wenigstens wo sie gelandet ist 😁
                        • SBorgS SBorg
                          Rand
                          #2292
                          lemonbiterL 1 Antwort Letzte Antwort
                          • R Rand
                            lemonbiterL Offline
                            lemonbiterL Offline
                            lemonbiter
                            schrieb am zuletzt editiert von lemonbiter
                            #2293
                            @Negalein hatte mich hierhin empfohlen... Wow, was ein langer Thread... Ich fange gerade an zu lesen...
                            ich nutzte bislang die große Homematic Wetterstation. "Nu isse hin" (eine Schaufel am Windrad ist abgebrochen).
                            Gerne würde ich eine professioneller Lösung haben. Bspw. ist mit der Homematic keine Windböe zu messen. Und die Regenmessung... naja... Sehr unpräzise - in meinem Fall jedenfalls.
                            Im Forum haben einige über die "Weatherman" Lösung gesprochen, ich möchte aber nicht basteln, weil ich darin wirklich nicht gut bin.
                            Die Lösungen von Netatmo sehen gut aus, aber es gibt viele User, die sagen, das Gehäuse läuft mit Wasser voll, dadurch korrodieren die Batterien etc. Außerdem würde ich gerne die Daten direkt in ioB einlesen und nicht im Cloudzwang sein, mir diese da abholen zu müssen.
                            Ich wäre gerne bereit ein paar Euro mehr als für die HM Lösung oder vergleichbares zu bezahlen, wenn es einen Gegenwert (Qualität, Präzision, Zuverlässigkeit, schick 🙂 ) im Gegenzug gäbe.
                            Negalein hatte mir schon mal Froggit vorgeschlagen, mir aber empfohlen hier mal nachzufragen ... Ist die 4000er SINNVOLL steigerungsfähig? Was ist wirklich richtig gut? Windboen etc.
                            Ich lege keinen Wert auf riesige Displays mit Netzteilen, da ich eh schon festinstallierte Display für die VIS habe.
                            Am liebsten hätte ich als Ergänzung zur VIS nur 2 oder 3 kleine batteriebetriebene Display, die idealerweise die Temp. & Luftfeuchte von 2 oder 3 Standorten gleichzeitig anzeigen können, den Rest mache ich dann lieber auf die Displays mit VIS, die ich eh im Einsatz habe.
                            Wer weiß was? Kennt was? Kann was empfehlen...
                            LG und Danke im Voraus
                            LEM
                            • lemonbiterL lemonbiter
                              LEM
                              da_WoodyD Offline
                              da_WoodyD Offline
                              da_Woody
                              #2294
                              @lemonbiter warum postest du den selben text wie im anderen topic? lies dir hier mal alles durch, da werden deine fragen alle beantwortet. 2 gleisig das selbe thema bringt überhaupt nichts.
                              gruß vom Woody
                              • SBorgS Offline
                                SBorgS Offline
                                SBorg
                                schrieb am zuletzt editiert von SBorg
                                #2295
                                ...aber mal ehrlich, wer ließt sich hier bald 2.300 Posts durch ;)
                                Allerdings eine Diskussion gleichzeitig in zwei Threads zu führen ist wirklich nicht sehr angenehm.
                                Die 4000er hat als einzigen "Mehrwert" noch die "Jahresregenmenge". Da das Skript eh 24/7 laufen muss, berechne ich aber die Regenmenge eh noch selbst. Ist ja kein Hexenwerk vom 01.01. bis 31.12. die Tagesmenge einfach aufaddieren ;)
                                Meine eigene läuft seit knapp einem Jahr problemlos, die gemessenen Werte lassen sich auch durchaus mit anderen vergleichen. Aber es sind, und bleiben auch, Hobbystationen. 99% werden auch nicht den optimalen Standpunkt wählen können/wollen. Ich verzichte lieber auf etwas Genauigkeit, komme aber zum gelegentlichen reinigen des Trichters oder zum Batteriewechsel (bisher noch nicht nötig) lieber einigermaßen an die Station dran, als dann auf dem Dach rumzuturnen oder mit einer ellenlangen Leiter rumzuwerkeln...
                                Es bleibt also mehr oder minder reine Geschmackssache welche es werden soll, sie unterscheiden sich hauptsächlich durch das Display (man kann auch den Wettermast und nur das Gateway nutzen). Nur sollte man darauf achten wenn man dieses Projekt nutzen möchte, nach Möglichkeit eine Station nutzen die per eigenem Wetterserver funktioniert (falls sie WS View unterstützt ist dies der Fall).
                                Zusatzanzeigen ließen sich dann über den ioB realisieren. Da dort alle Messwerte landen, könnte man sich für paar € auch selbst eine Anzeige basteln (MagicMirror, LaMetric, Wemos Mini mit OLED/E-Ink...).
                                ...oder man kauft halt noch ein weiteres Display...
                                da_WoodyD lemonbiterL 2 Antworten Letzte Antwort
                                • da_WoodyD da_Woody
                                  lemonbiterL Offline
                                  lemonbiterL Offline
                                  lemonbiter
                                  #2296
                                  @da_woody sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                  Ich hatte den Thread leider nicht gefunden und negalein hatte mich darauf verwiesen wie ich schrieb... Ihr habt recht. 2 Threads sind doof...
                                  • SBorgS SBorg
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    da_Woody
                                    #2297
                                    grundsätzlich reichen mal die ersten 2 seiten... schon klar das das keiner liest, auch nicht notwendig. ;)
                                    @lemonbiter war nicht böse gemeint, aber nach dem hinweis da nochmal den selben text... auf der ersten seite stehn einige stationen die funktionieren. der rest kommt dann schon. fragen kann man dann immer noch wenn was unklar ist und man es nicht findet...
                                    gruß vom Woody
                                    • SBorgS SBorg
                                      lemonbiterL Offline
                                      lemonbiterL Offline
                                      lemonbiter
                                      #2298
                                      Die 4000er hat als einzigen "Mehrwert" noch die "Jahresregenmenge". Da das Skript eh 24/7 laufen muss, berechne ich aber die Regenmenge eh noch selbst. Ist ja kein Hexenwerk vom 01.01. bis 31.12. die Tagesmenge einfach aufaddieren 😉
                                      Sorry, das habe ich nicht gut formuliert. Was ich meinte war: Macht es Sinn die nächst größere Froggit zu nehmen. Bspw. die WH-6000 PRO
                                      LG
                                      LEM
                                      da_WoodyD SBorgS 2 Antworten Letzte Antwort
                                        LG
                                        LEM
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        da_Woody
                                        #2299
                                        @lemonbiter über sinn oder unsinn lässt sich trefflich streiten. ;)
                                        im endeffekt deine entscheidung was die mehr kann(?) als die 4000er. brauchst du das, bietet das script das an, ...
                                        gruß vom Woody
                                          LG
                                          LEM
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #2300
                                          @lemonbiter Kommt letztendlich auch darauf an was du genau möchtest. Ob der Wettermast besser ist als die anderen kann ich dir nicht beantworten, zumindest hat er einen Ventilator gegen Hitzestau drin.
                                          Das Display ist nach wie vor Geschmackssache und wenn es dir um den Zusatzsensor (für Innen) geht, bist du IMHO mit dem Gateway flexibler und deutlich günstiger. Außerdem werden per Gateway dann alle im 1. Post genannten (und deren Anzahl!) Sensoren unterstützt. Mit dem "größeren" Display kannst du halt zusätzlich den ein oder anderen Innensensor noch anzeigen lassen.
                                          Aber aus mittlerweile einjähriger Erfahrung: das Display steht schick in der Ecke, ab und zu schaut auch mal jemand drauf, irgendwelche Werte per Tastendruck fragt keiner ab und jeder schaut eigentlich nur in der VIS nach. Ein paar Werte werden auch für das SmartHome benutzt.
                                          An der Stelle noch der übliche Hinweis: alle Stationen haben nur einen Rengenmengenmesser, keinen -sensor. Für eine echte Regenerkennung (bspw. Markise einfahren) ist es viel zu träge. Ein leichter Nieselregen löst, je nach dem wie voll die Wippe ist, erst bis zu 15-20 Minuten nach Start des Regenereignisses aus. Da wäre die Markise schon triefend nass...
