- ioBroker Community Home
- Deutsch
- Tester
- Test Adapter TrashSchedule
@JB_Sullivan sagte in Test Adapter TrashSchedule v0.0.x:
@darkiop sagte in Test Adapter TrashSchedule v0.0.x:
Falls es hier jemand braucht, habe auf die schnelle mal ein Blockly für eine json-Tabelle mit den DPs erstellt:
<block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13"> <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field> <statement name="STATEMENT"> <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd"> <field name="oid">Object ID</field> </shadow> <block type="text" id="2Jn.QUiZj?ycCTjRK_W("> <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC"> <field name="BOOL">TRUE</field> </shadow> <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I"> <field name="PRETTIFY">FALSE</field> <value name="VALUE"> <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6"> <mutation items="4"></mutation> <value name="ADD0"> <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="69`+m2b?ah727]cb4b5m"> <field name="TEXT">Bio</field> </block> </value> <value name="ADD1"> <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="P#+:y_a5je5/#)4SO^L~"> <field name="TEXT">trashschedule.0.type.Bio.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="puB=e5tWv:s95)2|m63d"> <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="w`QASfUph?E*g6}`1K?B"> <field name="TEXT">Papier</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QI#7R02;o6yhi)k*GUWH"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$"> <field name="TEXT">trashschedule.0.type.Papier.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="]qySTY/w/@JC$^$1T;{G"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u"> <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="x%CaEm(Er0k@RdJmwY6|"> <field name="TEXT">Glas</field> </block> </value> <value name="ADD1"> <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+2IANn@_+1Bu_a97kr/P"> <field name="TEXT">trashschedule.0.type.Glas.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="27btsxWYG5;!kT^ypS(w"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="5RS-i8]2v|k98c(IL4jg"> <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD3"> <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="JW[g,${io?zI03+bo_dO"> <field name="TEXT">GelberSack</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{"> <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz"> <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i"> <field name="NUM">0</field> </shadow> </value> </block> </statement> </block>Gibt es bei Euch keine Restmüll Leerung?
Schaut cool aus, kannst du das hier posten welches Widget und wie hast Du das Icon oben hinbekommen?
Danke Dir.Gruß Saboti
@Saboti bin erst Donnerstag wieder Zuhause. Ich versuche es nicht zu vergessen ;)
Das ist nichts spezielles, Tabellen widget von den material design widgets.
Hier ist es ja ziemlich ruhig geworden.
Kann ich verstehen, bei mir läuft es auch unauffällig.
Habe noch an den Widgets und dem Skript zum "Alarmstatus" gefeilt.Bei den Widgets habe ich bei der Anzahl Tage das String-Widget gegen ein number-Widget getauscht. Da kann man Singular und Pluralformen anhängen:
"in 1 Tagen" hat mein Feng Shui gestört ;-)
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
<block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13"> <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field> <statement name="STATEMENT"> <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd"> <field name="oid">Object ID</field> </shadow> <block type="text" id="2Jn.QUiZj?ycCTjRK_W("> <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC"> <field name="BOOL">TRUE</field> </shadow> <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I"> <field name="PRETTIFY">FALSE</field> <value name="VALUE"> <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6"> <mutation items="4"></mutation> <value name="ADD0"> <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="69`+m2b?ah727]cb4b5m"> <field name="TEXT">Bio</field> </block> </value> <value name="ADD1"> <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="P#+:y_a5je5/#)4SO^L~"> <field name="TEXT">trashschedule.0.type.Bio.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="puB=e5tWv:s95)2|m63d"> <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="w`QASfUph?E*g6}`1K?B"> <field name="TEXT">Papier</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QI#7R02;o6yhi)k*GUWH"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$"> <field name="TEXT">trashschedule.0.type.Papier.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="]qySTY/w/@JC$^$1T;{G"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u"> <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="x%CaEm(Er0k@RdJmwY6|"> <field name="TEXT">Glas</field> </block> </value> <value name="ADD1"> <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+2IANn@_+1Bu_a97kr/P"> <field name="TEXT">trashschedule.0.type.Glas.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="27btsxWYG5;!kT^ypS(w"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="5RS-i8]2v|k98c(IL4jg"> <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD3"> <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="JW[g,${io?zI03+bo_dO"> <field name="TEXT">GelberSack</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{"> <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz"> <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i"> <field name="NUM">0</field> </shadow> </value> </block> </statement> </block> -
@darkiop
Sry für off-topic
Hast Du diese Tabelle selber aufgebaut oder ist das ein Widget?@Termina sagte in Test Adapter TrashSchedule v0.0.x:
Das sind mehrere Widgets:
[{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/braune_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"247px","width":"50px","height":"66px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Biotonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"271px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Biotonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/schwarze_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"176px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Restmüll.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"201px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/gelbe_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"105px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Gelbe Tonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"131px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Gebe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"","title_color":"#d7cec1","title_top":"-30","title_left":"10","header_height":"0","header_color":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"","signals-icon-size-0":"20","signals-blink-0":false,"signals-horz-0":"","signals-vert-0":"80","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"","signals-icon-size-1":"30","signals-blink-1":false,"signals-horz-1":"90","signals-vert-1":"76","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"","signals-oid-1":"","name":"Border Altpapier","filterkey":"Border"},"style":{"left":"1643px","top":"6px","width":"247px","height":"310px","font-family":"RobotoCondensed-Light","font-style":"normal","font-variant":"normal","font-weight":"","font-size":"large","z-index":"2","background":"rgba(100, 100, 100, 30)","border-width":"1px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","color":"white","border-radius":"10px"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/blaue_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"33px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Nächste Leerung","name":"Text1","filterkey":"text","title":"Altpapier & Gelber Sack"},"style":{"left":"1717px","top":"9px","width":"150px","height":"22px","z-index":"5","font-size":"large","font-family":"RobotoCondensed-Regular","color":"white","text-align":"center","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Altpapier.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"60px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Altpapier.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"60px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Biotonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"270px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Biotonnn.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Restmüll.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"200px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Gelbe Tonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"130px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Gelbe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"}]kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
<block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13"> <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field> <statement name="STATEMENT"> <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd"> <field name="oid">Object ID</field> </shadow> <block type="text" id="2Jn.QUiZj?ycCTjRK_W("> <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC"> <field name="BOOL">TRUE</field> </shadow> <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I"> <field name="PRETTIFY">FALSE</field> <value name="VALUE"> <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6"> <mutation items="4"></mutation> <value name="ADD0"> <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="69`+m2b?ah727]cb4b5m"> <field name="TEXT">Bio</field> </block> </value> <value name="ADD1"> <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="P#+:y_a5je5/#)4SO^L~"> <field name="TEXT">trashschedule.0.type.Bio.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="puB=e5tWv:s95)2|m63d"> <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="w`QASfUph?E*g6}`1K?B"> <field name="TEXT">Papier</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QI#7R02;o6yhi)k*GUWH"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$"> <field name="TEXT">trashschedule.0.type.Papier.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="]qySTY/w/@JC$^$1T;{G"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u"> <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="x%CaEm(Er0k@RdJmwY6|"> <field name="TEXT">Glas</field> </block> </value> <value name="ADD1"> <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+2IANn@_+1Bu_a97kr/P"> <field name="TEXT">trashschedule.0.type.Glas.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="27btsxWYG5;!kT^ypS(w"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="5RS-i8]2v|k98c(IL4jg"> <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD3"> <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="JW[g,${io?zI03+bo_dO"> <field name="TEXT">GelberSack</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{"> <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz"> <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i"> <field name="NUM">0</field> </shadow> </value> </block> </statement> </block>@darkiop sagte in Test Adapter TrashSchedule v0.0.x:
<block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13"> <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field> <statement name="STATEMENT"> <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd"> <field name="oid">Object ID</field> </shadow> <block type="text" id="2Jn.QUiZj?ycCTjRK_W("> <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC"> <field name="BOOL">TRUE</field> </shadow> <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I"> <field name="PRETTIFY">FALSE</field> <value name="VALUE"> <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6"> <mutation items="4"></mutation> <value name="ADD0"> <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="69`+m2b?ah727]cb4b5m"> <field name="TEXT">Bio</field> </block> </value> <value name="ADD1"> <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="P#+:y_a5je5/#)4SO^L~"> <field name="TEXT">trashschedule.0.type.Bio.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="puB=e5tWv:s95)2|m63d"> <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="w`QASfUph?E*g6}`1K?B"> <field name="TEXT">Papier</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QI#7R02;o6yhi)k*GUWH"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$"> <field name="TEXT">trashschedule.0.type.Papier.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="]qySTY/w/@JC$^$1T;{G"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u"> <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="x%CaEm(Er0k@RdJmwY6|"> <field name="TEXT">Glas</field> </block> </value> <value name="ADD1"> <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+2IANn@_+1Bu_a97kr/P"> <field name="TEXT">trashschedule.0.type.Glas.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="27btsxWYG5;!kT^ypS(w"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="5RS-i8]2v|k98c(IL4jg"> <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> <value name="ADD3"> <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="JW[g,${io?zI03+bo_dO"> <field name="TEXT">GelberSack</field> </block> </value> <value name="ADD1"> <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{"> <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field> </shadow> </value> </block> </value> </block> </value> <value name="ADD2"> <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g"> <mutation items="1"></mutation> <value name="ADD0"> <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz"> <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field> </shadow> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i"> <field name="NUM">0</field> </shadow> </value> </block> </statement> </block>Sry, ich meinte diese Tabelle
@Homoran sagte in Test Adapter TrashSchedule v0.0.x:
IMHO noch besseres Feng Shui: HTML-Widget + Binding = mach aus in 1 Tag am 05.12.3019 einfach Morgen
LG SBorg ( SBorg auf GitHub)
Projekte: Lebensmittelwarnung.de | WLAN-Wetterstation | PimpMyStation -
@SBorg sagte in Test Adapter TrashSchedule v0.0.x:
und wie???
Auch wenn alle denken ich sei Profi - bin nur ein (etwas aktiver) User
und wie???
{tage:trashschedule.0.type.Biotonne.daysleft;datum:trashschedule.0.type.Biotonne.nextdateformat; tage != 1 ? "in "+tage+" Tagen am "+datum :: "<div style='color: yellow'>Morgen</div>"}Musst natürlich noch den Datenpunkt anpassen. Auch mal zur Demo "Morgen" in gelb gefärbt.
...und vertippt bei meinem Post. Im Jahr 3019 brauch ich bestimmt keinerlei Feng Shui mehr :)LG SBorg ( SBorg auf GitHub)
...und vertippt bei meinem Post. Im Jahr 3019 brauch ich bestimmt keinerlei Feng Shui mehr :)@SBorg sagte in Test Adapter TrashSchedule v0.0.x:
Hatte ich stillschweigend akzeptiert ;-)
und Danke für das Binding
...und vertippt bei meinem Post. Im Jahr 3019 brauch ich bestimmt keinerlei Feng Shui mehr :)@SBorg danke für das binding
hast du nicht mal lust, einen thread mit deinen binding beispielen zu machen - so in der art - oder gibt es das schon
https://forum.iobroker.net/topic/24179/vorlage-hilfreiche-javascript-funktionen
ps: iobroker läuft ewig - noch die ur-ur-ur-... enkel werden es nutzen :-) - also immer auf das feng shui achten !
@liv-in-sky sagte in Test Adapter TrashSchedule v0.0.x:
@SBorg
oder ein Tutorial für die Website.Büddä!
Die liebe Zeit...
Ich stecke gerade in so vielen (eigenen) Projekten fest, dazu noch kpl. Renovierung Badezimmer (natürlich smart).
Dann kam ich auf die Idee nur noch eine Tonne (als Übersicht zur nächsten Leerung) zu nehmen und die per Binding zu färben...
Klar, könnte man auch alle übereinander legen und per "Sichtbarkeit" regeln, wo bleibt aber dann der Spaß/die Herausforderung?
Die liebe Zeit...
Frust!!!
Natürlich habe ich sie übereinandergelegt.
Dafür bastel ich gerade an einem Icon als Button um es wieder verschwinden zu lassen wenn man draufklickt, nachdem die Tonne an die Straße gestellt wurde.
view (du brauchst aber uhlas material design)
{ "settings": { "style": { "background_class": "" }, "theme": "redmond", "sizex": "", "sizey": "", "gridSize": "10", "useAsDefault": false, "snapType": 2, "class": "", "useBackground": false }, "widgets": { "e00001": { "tpl": "tplHtml", "data": { "g_fixed": true, "g_visibility": false, "g_css_font_text": true, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": false, "g_gestures": false, "g_signals": false, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "refreshInterval": "0", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "/vis.0/material-temp/lowbattery.png", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis.0/material-temp/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis.0/material-temp/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "html": "", "class": "mdui-abar mdui-bluegrey-bg", "lc-type": "last-change", "lc-is-interval": true, "lc-is-moment": false, "lc-format": "", "lc-position-vert": "top", "lc-position-horz": "right", "lc-offset-vert": 0, "lc-offset-horz": 0, "lc-font-size": "12px", "lc-font-family": "", "lc-font-style": "", "lc-bkg-color": "", "lc-color": "", "lc-border-width": "0", "lc-border-style": "", "lc-border-color": "", "lc-border-radius": 10, "lc-zindex": 0, "comment": "", "name": "app-bar" }, "style": { "left": "0px", "top": "0px", "width": "100%", "height": "50px", "z-index": "0", "color": "#ffffff", "text-align": "center", "font-family": "RobotoCondensed-Light" }, "widgetSet": "basic" }, "e00002": { "tpl": "tplImage", "data": { "g_fixed": false, "g_visibility": false, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": false, "g_gestures": false, "g_signals": false, "g_last_change": false, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "refreshInterval": "0", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "/vis/signals/lowbattery.png", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "lc-type": "last-change", "lc-is-interval": true, "lc-is-moment": false, "lc-format": "", "lc-position-vert": "top", "lc-position-horz": "right", "lc-offset-vert": 0, "lc-offset-horz": 0, "lc-font-size": "12px", "lc-font-family": "", "lc-font-style": "", "lc-bkg-color": "", "lc-color": "", "lc-border-width": "0", "lc-border-style": "", "lc-border-color": "", "lc-border-radius": 10, "lc-zindex": 0, "src": "/icons-mfd-png/message_garbage_3.png" }, "style": { "left": "0", "top": "0", "width": "50px", "height": "50px", "font-family": "RobotoCondensed-Light" }, "widgetSet": "basic" }, "e00003": { "tpl": "tplHtml", "data": { "g_fixed": true, "g_visibility": false, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": false, "g_gestures": false, "g_signals": false, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "refreshInterval": "0", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "/vis/signals/lowbattery.png", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "html": "Müllkalender", "class": "mdui-title", "lc-type": "last-change", "lc-is-interval": true, "lc-is-moment": false, "lc-format": "", "lc-position-vert": "top", "lc-position-horz": "right", "lc-offset-vert": 0, "lc-offset-horz": 0, "lc-font-size": "12px", "lc-font-family": "", "lc-font-style": "", "lc-bkg-color": "", "lc-color": "", "lc-border-width": "0", "lc-border-style": "", "lc-border-color": "", "lc-border-radius": 10, "lc-zindex": 0 }, "style": { "left": "calc(0% + 50px)", "top": "14px", "width": "160px", "height": "23px", "z-index": 1, "font-family": "RobotoCondensed-Light" }, "widgetSet": "basic" }, "e00004": { "tpl": "tplJquiButtonLinkBlank", "data": { "g_fixed": true, "g_visibility": true, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": false, "g_gestures": false, "g_signals": false, "g_last_change": false, "visibility-cond": "==", "visibility-val": "true", "visibility-groups-action": "hide", "buttontext": "EDIT", "padding": "0", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "/vis/signals/lowbattery.png", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "lc-type": "last-change", "lc-is-interval": true, "lc-is-moment": false, "lc-format": "", "lc-position-vert": "top", "lc-position-horz": "right", "lc-offset-vert": 0, "lc-offset-horz": 0, "lc-font-size": "12px", "lc-font-family": "", "lc-font-style": "", "lc-bkg-color": "", "lc-color": "", "lc-border-width": "0", "lc-border-style": "", "lc-border-color": "", "lc-border-radius": 10, "lc-zindex": 0, "href": "http://iobroker-master.birkenweg.walk-steinweiler.de:8082/vis/edit.html?material-temp#{view}", "no_style": false, "class": "mdui-flatbutton", "visibility-oid": "javascript.0.VIS.Edit_Mode" }, "style": { "left": "calc(100% - 80px)", "top": "10px", "width": "auto", "height": "30px" }, "widgetSet": "jqui" }, "e00005": { "tpl": "tplVis-materialdesign-Table", "data": { "oid": "javascript.0.VIS.Kalender_Tabelle_Muell", "g_fixed": false, "g_visibility": false, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": false, "g_gestures": false, "g_signals": false, "g_last_change": false, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "countCols": "2", "tableLayout": "standard", "showHeader": "true", "headerTextSize": "16px", "showColumn0": "true", "colType0": "text", "textAlign0": "right", "showColumn1": "true", "colType1": "text", "textAlign1": "center", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "/vis/signals/lowbattery.png", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "lc-type": "last-change", "lc-is-interval": true, "lc-is-moment": false, "lc-format": "", "lc-position-vert": "top", "lc-position-horz": "right", "lc-offset-vert": 0, "lc-offset-horz": 0, "lc-font-size": "12px", "lc-font-family": "", "lc-font-style": "", "lc-bkg-color": "", "lc-color": "", "lc-border-width": "0", "lc-border-style": "", "lc-border-color": "", "lc-border-radius": 10, "lc-zindex": 0, "showColumn2": "true", "colType2": "text", "textAlign2": "center", "showColumn3": "true", "colType3": "text", "textAlign3": "center", "showColumn4": "true", "colType4": "text", "textAlign4": "center", "showColumn5": "true", "colType5": "text", "textAlign5": "center", "label0": " ", "label1": "Nächste Leerung<br><em style=\"font-size: 14px\">(in Tagen)</em>", "label2": "Nächste Leerung", "colorBackground": "transparent", "fontFamily0": "RobotoCondensed-Light", "fontFamily1": "RobotoCondensed-Light", "fontFamily2": "RobotoCondensed-Light", "colTextColor2": "#ffffff", "colTextColor1": "#ffffff", "colTextColor0": "#ffffff", "colorHeaderRowText": "#ffffff", "headerFontFamily": "RobotoCondensed-Bold", "colTextSize0": "16px", "colTextSize1": "16px", "colTextSize2": "16px", "colNoWrap0": false, "dividers": "transparent", "columnWidth0": "100" }, "style": { "left": "10px", "top": "60px", "width": "calc(100% - 20px)", "height": "calc(100% - 90px)" }, "widgetSet": "materialdesign" } }, "name": "3_card_Kalender_Muell_new", "filterList": [] }Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
Vielen Dank für den Adapter, ich habe diesen nun auch in Betrieb genommen, aber leider scheint bei mir noch nicht allles zu passen. Ich habe keine aktuellen Werte für Gelbe Tonne, obwohl diese als nächstes Event erkannt wird. Die nächste Leerung wäre diesen Freitag, aber wie gesagt unter den Typen-Objekten wird nichts angezeigt.
Zusätzlich fehlen mir noch die Werte für den Restmüll, hier habe ich absolut nichts an Daten. Wie weit schaut der Adapter denn in die Zukunft? Ich könnte mir vorstellen, das hier einfach der nächste Wert zu weit in der Zukunft ist, denn die nächste Leerung wäre am 14.1.2020
Edit: Ok hat sich erledigt, nun sind alle Daten da, warum auch immer das so ewig gedauert hat. Ein Teil der Daten war sofort da, der andere hat 10-15 Minuten gedauert.
@Sempre Das kannst du im ical - Adapter einstellen.
Dort hast du die Vorschau normalerweise auf 7 Tage stehen. Wenn du dort 60 oder 90 einträgst werden auch sehr späte Termine noch richtig erfasst.ioBroker auf NUC unter Proxmox; VIS: 12" Touchscreen und 17" Touch; Lichtsteuerung, Thermometer und Sensoren: Tasmota (39); Ambiente Beleuchtung: WLED (9); Heizung: DECT Thermostate (9) an Fritz 6690; EMS-ESP; 1 Echo V2; 3 Echo DOT; 1 Echo Connect; 2 Echo Show 5; Unifi Ap-Ac Lite.
Hallo
ich habe mir über google nun einen Kalendar angelegt und über
npm i iobroker.trashscheduleinstalliert. Aktuell taucht leider das Objekt bei mir noch nicht auf.
Was könnte ich übersehen haben?Danke
Dort hast du die Vorschau normalerweise auf 7 Tage stehen. Wenn du dort 60 oder 90 einträgst werden auch sehr späte Termine noch richtig erfasst.@Chaot
dort habe ich 30 Tage drin, daher soltle es passen. Es hat nach einer Weile ja nun auch alle Datenpuntke angelegt, war nur verwundert warum es so ewig gedauert hat. Eine Vermutung war dann das der Adapter selber eventuell noch eine Zeitbegrenzung hat, aber passt ja :)
