  4. Test Adapter TrashSchedule
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 716.2k Aufrufe 171 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @darkiop sagte in Test Adapter TrashSchedule v0.0.x:
    Falls es hier jemand braucht, habe auf die schnelle mal ein Blockly für eine json-Tabelle mit den DPs erstellt:
     <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13">
      <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field>
      <statement name="STATEMENT">
        <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{">
          <field name="TYPE">false</field>
          <value name="OID">
            <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd">
              <field name="oid">Object ID</field>
            </shadow>
            <block type="text" id="2Jn.QUiZj?ycCTjRK_W(">
              <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field>
            </block>
          </value>
          <value name="VALUE">
            <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC">
            </shadow>
            <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I">
              <field name="PRETTIFY">FALSE</field>
                <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6">
                  <mutation items="4"></mutation>
                  <value name="ADD0">
                    <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}">
                      <value name="ADD0">
                        <block type="text" id="69`+m2b?ah727]cb4b5m">
                          <field name="TEXT">Bio</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ">
                          <mutation items="1"></mutation>
                          <value name="ADD0">
                            <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu">
                              <value name="OID">
                                <shadow type="text" id="P#+:y_a5je5/#)4SO^L~">
                                  <field name="TEXT">trashschedule.0.type.Bio.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch">
                          <value name="ADD0">
                            <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%">
                              <value name="OID">
                                <shadow type="text" id="puB=e5tWv:s95)2|m63d">
                                  <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD1">
                    <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ">
                      <value name="ADD0">
                        <block type="text" id="w`QASfUph?E*g6}`1K?B">
                          <field name="TEXT">Papier</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QI#7R02;o6yhi)k*GUWH">
                          <value name="ADD0">
                            <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6">
                              <value name="OID">
                                <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$">
                                  <field name="TEXT">trashschedule.0.type.Papier.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="]qySTY/w/@JC$^$1T;{G">
                          <value name="ADD0">
                            <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw">
                              <value name="OID">
                                <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u">
                                  <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD2">
                    <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS">
                      <value name="ADD0">
                        <block type="text" id="x%CaEm(Er0k@RdJmwY6|">
                          <field name="TEXT">Glas</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n">
                          <value name="ADD0">
                            <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG">
                              <value name="OID">
                                <shadow type="text" id="+2IANn@_+1Bu_a97kr/P">
                                  <field name="TEXT">trashschedule.0.type.Glas.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="27btsxWYG5;!kT^ypS(w">
                          <value name="ADD0">
                            <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/">
                              <value name="OID">
                                <shadow type="text" id="5RS-i8]2v|k98c(IL4jg">
                                  <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD3">
                    <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C">
                      <value name="ADD0">
                        <block type="text" id="JW[g,${io?zI03+bo_dO">
                          <field name="TEXT">GelberSack</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,">
                          <value name="ADD0">
                            <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|">
                              <value name="OID">
                                <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g">
                          <value name="ADD0">
                            <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy">
                              <value name="OID">
                                <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
          <value name="DELAY_MS">
            <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i">
              <field name="NUM">0</field>
            </shadow>
          </value>
        </block>
      </statement>
    </block>
    Gibt es bei Euch keine Restmüll Leerung?
    SabotiS Offline
    SabotiS Offline
    Saboti
    #140
    @JB_Sullivan sagte in Test Adapter TrashSchedule v0.0.x:
          <value name="OID">
            </shadow>
            </block>
          </value>
            </shadow>
                  <value name="ADD0">
                      <value name="ADD0">
                        </block>
                      </value>
                      <value name="ADD1">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD1">
                      <value name="ADD0">
                        </block>
                      </value>
                      <value name="ADD1">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD2">
                      <value name="ADD0">
                        </block>
                      </value>
                      <value name="ADD1">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD3">
                      <value name="ADD0">
                        </block>
                      </value>
                      <value name="ADD1">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                          <value name="ADD0">
                              <value name="OID">
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
            </shadow>
          </value>
        </block>
      </statement>
    </block>
    Schaut cool aus, kannst du das hier posten welches Widget und wie hast Du das Icon oben hinbekommen?
    Danke Dir.
    Gruß Saboti
    • SabotiS Saboti
            <value name="OID">
              </shadow>
              </block>
            </value>
              </shadow>
                    <value name="ADD0">
                        <value name="ADD0">
                          </block>
                        </value>
                        <value name="ADD1">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="ADD1">
                        <value name="ADD0">
                          </block>
                        </value>
                        <value name="ADD1">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="ADD2">
                        <value name="ADD0">
                          </block>
                        </value>
                        <value name="ADD1">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="ADD3">
                        <value name="ADD0">
                          </block>
                        </value>
                        <value name="ADD1">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                            <value name="ADD0">
                                <value name="OID">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
              </shadow>
            </value>
          </block>
        </statement>
      </block>
      Danke Dir.
      Gruß Saboti
      darkiop
      #141
      @Saboti bin erst Donnerstag wieder Zuhause. Ich versuche es nicht zu vergessen ;)
      Das ist nichts spezielles, Tabellen widget von den material design widgets.
      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
        #142
        Hier ist es ja ziemlich ruhig geworden.
        Kann ich verstehen, bei mir läuft es auch unauffällig.
        Habe noch an den Widgets und dem Skript zum "Alarmstatus" gefeilt.
        Bei den Widgets habe ich bei der Anzahl Tage das String-Widget gegen ein number-Widget getauscht. Da kann man Singular und Pluralformen anhängen:
        "in 1 Tagen" hat mein Feng Shui gestört ;-)
        • D darkiop
                <value name="OID">
                  </shadow>
                  </block>
                </value>
                  </shadow>
                        <value name="ADD0">
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD1">
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="ADD3">
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                    <value name="OID">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  </shadow>
                </value>
              </block>
            </statement>
          </block>
          Termina
          #143
          @darkiop
          Sry für off-topic
          Hast Du diese Tabelle selber aufgebaut oder ist das ein Widget?
          • T Termina
            @darkiop
            Sry für off-topic
            #144
            @Termina sagte in Test Adapter TrashSchedule v0.0.x:
            Das sind mehrere Widgets:
            [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/braune_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"247px","width":"50px","height":"66px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Biotonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"271px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Biotonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/schwarze_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"176px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Restmüll.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"201px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/gelbe_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"105px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Gelbe Tonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"131px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Gebe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"","title_color":"#d7cec1","title_top":"-30","title_left":"10","header_height":"0","header_color":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"","signals-icon-size-0":"20","signals-blink-0":false,"signals-horz-0":"","signals-vert-0":"80","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"","signals-icon-size-1":"30","signals-blink-1":false,"signals-horz-1":"90","signals-vert-1":"76","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"","signals-oid-1":"","name":"Border Altpapier","filterkey":"Border"},"style":{"left":"1643px","top":"6px","width":"247px","height":"310px","font-family":"RobotoCondensed-Light","font-style":"normal","font-variant":"normal","font-weight":"","font-size":"large","z-index":"2","background":"rgba(100, 100, 100, 30)","border-width":"1px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","color":"white","border-radius":"10px"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/blaue_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"33px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Nächste Leerung","name":"Text1","filterkey":"text","title":"Altpapier & Gelber Sack"},"style":{"left":"1717px","top":"9px","width":"150px","height":"22px","z-index":"5","font-size":"large","font-family":"RobotoCondensed-Regular","color":"white","text-align":"center","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Altpapier.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"60px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Altpapier.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"60px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Biotonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"270px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Biotonnn.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Restmüll.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"200px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Gelbe Tonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"130px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Gelbe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"}]
            • D darkiop
                    <value name="OID">
                      </shadow>
                      </block>
                    </value>
                      </shadow>
                            <value name="ADD0">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD3">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      </shadow>
                    </value>
                  </block>
                </statement>
              </block>
              Termina
              #145
                    <value name="OID">
                      </shadow>
                      </block>
                    </value>
                      </shadow>
                            <value name="ADD0">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD1">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD2">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD3">
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                    <value name="ADD0">
                                        <value name="OID">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      </shadow>
                    </value>
                  </block>
                </statement>
              </block>
              Sry, ich meinte diese Tabelle
              D ? 2 Antworten Letzte Antwort
                SBorgS Offline
                SBorgS Offline
                SBorg
                #146
                @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
                IMHO noch besseres Feng Shui: HTML-Widget + Binding = mach aus in 1 Tag am 05.12.3019 einfach Morgen
                LG SBorg ( SBorg auf GitHub)
                • SBorgS SBorg
                  #147
                  @SBorg sagte in Test Adapter TrashSchedule v0.0.x:
                  und wie???
                  Auch wenn alle denken ich sei Profi - bin nur ein (etwas aktiver) User
                    und wie???
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    schrieb am zuletzt editiert von SBorg
                    #148
                    {tage:trashschedule.0.type.Biotonne.daysleft;datum:trashschedule.0.type.Biotonne.nextdateformat; tage != 1 ? "in "+tage+" Tagen am "+datum :: "<div style='color: yellow'>Morgen</div>"}
                    Musst natürlich noch den Datenpunkt anpassen. Auch mal zur Demo "Morgen" in gelb gefärbt.
                    ...und vertippt bei meinem Post. Im Jahr 3019 brauch ich bestimmt keinerlei Feng Shui mehr :)
                    HomoranH liv-in-skyL 2 Antworten Letzte Antwort
                    • SBorgS SBorg
                      #149
                      Hatte ich stillschweigend akzeptiert ;-)
                      und Danke für das Binding
                      • SBorgS SBorg
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #150
                        @SBorg danke für das binding
                        hast du nicht mal lust, einen thread mit deinen binding beispielen zu machen - so in der art - oder gibt es das schon
                        https://forum.iobroker.net/topic/24179/vorlage-hilfreiche-javascript-funktionen
                        ps: iobroker läuft ewig - noch die ur-ur-ur-... enkel werden es nutzen :-) - also immer auf das feng shui achten !
                        • liv-in-skyL liv-in-sky
                          #151
                          @liv-in-sky sagte in Test Adapter TrashSchedule v0.0.x:
                          @SBorg
                          oder ein Tutorial für die Website.
                          Büddä!
                          • SBorgS Offline
                            SBorgS Offline
                            SBorg
                            #152
                            Die liebe Zeit...
                            Ich stecke gerade in so vielen (eigenen) Projekten fest, dazu noch kpl. Renovierung Badezimmer (natürlich smart).
                            Dann kam ich auf die Idee nur noch eine Tonne (als Übersicht zur nächsten Leerung) zu nehmen und die per Binding zu färben...
                            Klar, könnte man auch alle übereinander legen und per "Sichtbarkeit" regeln, wo bleibt aber dann der Spaß/die Herausforderung? 😀
                            • SBorgS SBorg
                              Die liebe Zeit...
                              #153
                              Frust!!!
                              Natürlich habe ich sie übereinandergelegt.
                              Dafür bastel ich gerade an einem Icon als Button um es wieder verschwinden zu lassen wenn man draufklickt, nachdem die Tonne an die Straße gestellt wurde.
                              • T Termina
                                      <value name="OID">
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                              <value name="ADD0">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD3">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        </shadow>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                                darkiop
                                #154
                                @Termina
                                view (du brauchst aber uhlas material design)
                                 "settings": {
                                   "style": {
                                     "background_class": ""
                                   "theme": "redmond",
                                   "sizex": "",
                                   "sizey": "",
                                   "gridSize": "10",
                                   "useAsDefault": false,
                                   "snapType": 2,
                                   "class": "",
                                   "useBackground": false
                                 "widgets": {
                                   "e00001": {
                                     "tpl": "tplHtml",
                                     "data": {
                                       "g_fixed": true,
                                       "g_visibility": false,
                                       "g_css_font_text": true,
                                       "g_css_background": false,
                                       "g_css_shadow_padding": false,
                                       "g_css_border": false,
                                       "g_gestures": false,
                                       "g_signals": false,
                                       "visibility-cond": "==",
                                       "visibility-val": 1,
                                       "visibility-groups-action": "hide",
                                       "refreshInterval": "0",
                                       "signals-cond-0": "==",
                                       "signals-val-0": true,
                                       "signals-icon-0": "/vis.0/material-temp/lowbattery.png",
                                       "signals-icon-size-0": 0,
                                       "signals-blink-0": false,
                                       "signals-horz-0": 0,
                                       "signals-vert-0": 0,
                                       "signals-hide-edit-0": false,
                                       "signals-cond-1": "==",
                                       "signals-val-1": true,
                                       "signals-icon-1": "/vis.0/material-temp/lowbattery.png",
                                       "signals-icon-size-1": 0,
                                       "signals-blink-1": false,
                                       "signals-horz-1": 0,
                                       "signals-vert-1": 0,
                                       "signals-hide-edit-1": false,
                                       "signals-cond-2": "==",
                                       "signals-val-2": true,
                                       "signals-icon-2": "/vis.0/material-temp/lowbattery.png",
                                       "signals-icon-size-2": 0,
                                       "signals-blink-2": false,
                                       "signals-horz-2": 0,
                                       "signals-vert-2": 0,
                                       "signals-hide-edit-2": false,
                                       "html": "",
                                       "class": "mdui-abar mdui-bluegrey-bg",
                                       "lc-type": "last-change",
                                       "lc-is-interval": true,
                                       "lc-is-moment": false,
                                       "lc-format": "",
                                       "lc-position-vert": "top",
                                       "lc-position-horz": "right",
                                       "lc-offset-vert": 0,
                                       "lc-offset-horz": 0,
                                       "lc-font-size": "12px",
                                       "lc-font-family": "",
                                       "lc-font-style": "",
                                       "lc-bkg-color": "",
                                       "lc-color": "",
                                       "lc-border-width": "0",
                                       "lc-border-style": "",
                                       "lc-border-color": "",
                                       "lc-border-radius": 10,
                                       "lc-zindex": 0,
                                       "comment": "",
                                       "name": "app-bar"
                                     "style": {
                                       "left": "0px",
                                       "top": "0px",
                                       "width": "100%",
                                       "height": "50px",
                                       "z-index": "0",
                                       "color": "#ffffff",
                                       "text-align": "center",
                                       "font-family": "RobotoCondensed-Light"
                                     "widgetSet": "basic"
                                   "e00002": {
                                     "tpl": "tplImage",
                                     "data": {
                                       "g_fixed": false,
                                       "g_css_font_text": false,
                                       "g_signals": false,
                                       "g_last_change": false,
                                       "signals-icon-0": "/vis/signals/lowbattery.png",
                                       "signals-icon-1": "/vis/signals/lowbattery.png",
                                       "signals-icon-2": "/vis/signals/lowbattery.png",
                                       "lc-format": "",
                                       "lc-bkg-color": "",
                                       "lc-color": "",
                                       "lc-zindex": 0,
                                       "src": "/icons-mfd-png/message_garbage_3.png"
                                     "style": {
                                       "left": "0",
                                       "top": "0",
                                       "width": "50px",
                                       "height": "50px",
                                   "e00003": {
                                     "tpl": "tplHtml",
                                     "data": {
                                       "g_fixed": true,
                                       "g_signals": false,
                                       "html": "Müllkalender",
                                       "class": "mdui-title",
                                       "lc-format": "",
                                       "lc-bkg-color": "",
                                       "lc-color": "",
                                       "lc-zindex": 0
                                     "style": {
                                       "left": "calc(0% + 50px)",
                                       "top": "14px",
                                       "width": "160px",
                                       "height": "23px",
                                       "z-index": 1,
                                   "e00004": {
                                     "tpl": "tplJquiButtonLinkBlank",
                                     "data": {
                                       "g_fixed": true,
                                       "g_visibility": true,
                                       "g_signals": false,
                                       "visibility-val": "true",
                                       "buttontext": "EDIT",
                                       "padding": "0",
                                       "lc-format": "",
                                       "lc-bkg-color": "",
                                       "lc-color": "",
                                       "lc-zindex": 0,
                                       "href": "http://iobroker-master.birkenweg.walk-steinweiler.de:8082/vis/edit.html?material-temp#{view}",
                                       "no_style": false,
                                       "class": "mdui-flatbutton",
                                       "visibility-oid": "javascript.0.VIS.Edit_Mode"
                                     "style": {
                                       "left": "calc(100% - 80px)",
                                       "top": "10px",
                                       "width": "auto",
                                       "height": "30px"
                                     "widgetSet": "jqui"
                                   "e00005": {
                                     "tpl": "tplVis-materialdesign-Table",
                                     "data": {
                                       "oid": "javascript.0.VIS.Kalender_Tabelle_Muell",
                                       "g_fixed": false,
                                       "g_signals": false,
                                       "countCols": "2",
                                       "tableLayout": "standard",
                                       "showHeader": "true",
                                       "headerTextSize": "16px",
                                       "showColumn0": "true",
                                       "colType0": "text",
                                       "textAlign0": "right",
                                       "showColumn1": "true",
                                       "colType1": "text",
                                       "textAlign1": "center",
                                       "lc-format": "",
                                       "lc-bkg-color": "",
                                       "lc-color": "",
                                       "lc-zindex": 0,
                                       "showColumn2": "true",
                                       "colType2": "text",
                                       "textAlign2": "center",
                                       "showColumn3": "true",
                                       "colType3": "text",
                                       "textAlign3": "center",
                                       "showColumn4": "true",
                                       "colType4": "text",
                                       "textAlign4": "center",
                                       "showColumn5": "true",
                                       "colType5": "text",
                                       "textAlign5": "center",
                                       "label0": " ",
                                       "label1": "Nächste Leerung<br><em style=\"font-size: 14px\">(in Tagen)</em>",
                                       "label2": "Nächste Leerung",
                                       "colorBackground": "transparent",
                                       "fontFamily0": "RobotoCondensed-Light",
                                       "fontFamily1": "RobotoCondensed-Light",
                                       "fontFamily2": "RobotoCondensed-Light",
                                       "colTextColor2": "#ffffff",
                                       "colTextColor1": "#ffffff",
                                       "colTextColor0": "#ffffff",
                                       "colorHeaderRowText": "#ffffff",
                                       "headerFontFamily": "RobotoCondensed-Bold",
                                       "colTextSize0": "16px",
                                       "colTextSize1": "16px",
                                       "colTextSize2": "16px",
                                       "colNoWrap0": false,
                                       "dividers": "transparent",
                                       "columnWidth0": "100"
                                     "style": {
                                       "left": "10px",
                                       "top": "60px",
                                       "width": "calc(100% - 20px)",
                                       "height": "calc(100% - 90px)"
                                     "widgetSet": "materialdesign"
                                 "name": "3_card_Kalender_Muell_new",
                                 "filterList": []
                                  ktsalti
                                  #155
                                  Guten Abend,
                                  ich möchte mich auch für den Adapter bedanken!! Habe damit jetzt auch mein altes Script deaktiviert und gleichzeitig eure Widgets mit eingebaut!! :)
                                  Vielen Dank!
                                  ktsalti
                                  • D darkiop
                                          <value name="OID">
                                            </shadow>
                                            </block>
                                          </value>
                                            </shadow>
                                                  <value name="ADD0">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            </shadow>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                    BostilB Offline
                                    BostilB Offline
                                    Bostil
                                    schrieb am zuletzt editiert von Bostil
                                    #156
                                    hier stand Stuss -> kann gelöscht werden
                                      Sempre
                                      schrieb am zuletzt editiert von Sempre
                                      #157
                                      @haus-automatisierung
                                      Vielen Dank für den Adapter, ich habe diesen nun auch in Betrieb genommen, aber leider scheint bei mir noch nicht allles zu passen. Ich habe keine aktuellen Werte für Gelbe Tonne, obwohl diese als nächstes Event erkannt wird. Die nächste Leerung wäre diesen Freitag, aber wie gesagt unter den Typen-Objekten wird nichts angezeigt.
                                      Zusätzlich fehlen mir noch die Werte für den Restmüll, hier habe ich absolut nichts an Daten. Wie weit schaut der Adapter denn in die Zukunft? Ich könnte mir vorstellen, das hier einfach der nächste Wert zu weit in der Zukunft ist, denn die nächste Leerung wäre am 14.1.2020
                                      Edit: Ok hat sich erledigt, nun sind alle Daten da, warum auch immer das so ewig gedauert hat. Ein Teil der Daten war sofort da, der andere hat 10-15 Minuten gedauert.
                                      • S Sempre
                                        ChaotC Offline
                                        ChaotC Offline
                                        Chaot
                                        #158
                                        @Sempre Das kannst du im ical - Adapter einstellen.
                                        Dort hast du die Vorschau normalerweise auf 7 Tage stehen. Wenn du dort 60 oder 90 einträgst werden auch sehr späte Termine noch richtig erfasst.
                                        • ? Offline
                                          #159
                                          @Chaot
                                          Hallo
                                          ich habe mir über google nun einen Kalendar angelegt und über
                                          npm i iobroker.trashschedule
                                          installiert. Aktuell taucht leider das Objekt bei mir noch nicht auf.
                                          Was könnte ich übersehen haben?
