  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    5.2k
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.7k Beiträge 461 Kommentatoren 2.1m Aufrufe 413 Beobachtet
  • J Offline
    joerg1979
    #1741
    ich bekomme ebenfalls die Fehlermeldung. Ich habe den Adapter vor paar Tagen das erste mal installiert und da ging es anfangs.
    Ich bekomme folgende Fehlermeldung:
    vw-connect.0
    2023-03-25 15:03:29.818	error	Failed second skoda login
    vw-connect.0
    2023-03-25 15:03:29.818	error	500
    vw-connect.0
    2023-03-25 15:03:29.817	error	Failed to get token
    vw-connect.0
    2023-03-25 15:03:29.635	debug	Found Token
    vw-connect.0
    2023-03-25 15:03:28.901	info	Login in with skodae
    vw-connect.0
    2023-03-25 15:03:28.900	info	Found 1 vehicles
    vw-connect.0
    2023-03-25 15:03:28.899	debug	{"vehicles":[{"vin":"XXX","licensePlate":"XXX",.... }]}
    vw-connect.0
    2023-03-25 15:03:27.881	debug	"{\"firstName\":\"XXX\",\"lastName\":\"XXX\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdentifierValue\":\"XXX\",\"preferredLanguage\":\"de\"}"
    vw-connect.0
    2023-03-25 15:03:27.759	debug	getData
    vw-connect.0
    2023-03-25 15:03:27.757	info	Login successful
    vw-connect.0
    2023-03-25 15:03:27.507	debug	Error: Invalid protocol: skodaconnect:
    vw-connect.0
    2023-03-25 15:03:26.884	debug	{"date":"Sat, 25 Mar 2023 14:03:26 GMT","content-length":"0","connection":"close","apigw-requestid":"XXX=","x-content-type-options":"nosniff","x-xss-protection":"1; mode=block","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=XXX-XXX-XXX-XXX-XXX@apps_vw-dilab_com&relayState=XXX&userId=XXX-XXX-XXX-XXX-XXX&HMAC=XXXX","content-language":"en-US"}
    vw-connect.0
    2023-03-25 15:03:26.884	debug	""
    vw-connect.0
    2023-03-25 15:03:25.939	debug	emailPasswordForm2
    vw-connect.0
    2023-03-25 15:03:25.615	debug	parseEmailForm
    vw-connect.0
    2023-03-25 15:03:25.143	info	Login in with skodae
    vw-connect.0
    2023-03-25 15:03:25.126	info	starting. Version 0.0.62 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v16.19.1, js-controller: 4.0.24
    vw-connect.0
    2023-03-25 15:03:24.905	debug	Plugin sentry Initialize Plugin (enabled=true)
    vw-connect.0
    2023-03-25 15:03:20.565	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    Vielleicht hilft das Logfile ein wenig bei der Suche
    Danke fürs kümmern
      pmther
      #1742
      Moin Leute, ich habe nochmal fragen zu dem WeConnect Adapter.
      Ich fahre einen 2020er Tiguan. Bei dem kann ich leider keinen Ordner finden, indem die Restreichweite, Fenster und Türen zu finden sind. Desweiteren steht bei der Batterie nur „null“..
      Bei meinem Verbrauch steht „74“.. gibt es eine Möglichkeit dies als richtigen Wert, also „7,4“ anzeigen zu lassen?
      Wie kann ich allgemein alle Werte auf Deutsch stellen?
      Lg
      Paul
      P GlasfaserG 2 Antworten Letzte Antwort
      • P pmther
        Lg
        Paul
        pmther
        #1743
        @pmther und wie kriege ich den wert geändert, sodass dort anstatt 'true' z.B. 'verriegelt steht?
        • P pmther
          Lg
          Paul
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #1744
          @pmther sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
          https://forum.iobroker.net/post/774552
          In der Vorlage ist dazu (fast ) alles drin
          Im Threadstart
          P 1 Antwort Letzte Antwort
          • GlasfaserG Glasfaser
            Im Threadstart
            pmther
            #1745
            @glasfaser Danke, dann schaue ich da mal
            stefu87_CHS 1 Antwort Letzte Antwort
            • P pmther
              stefu87_CHS Offline
              stefu87_CHS Offline
              stefu87_CH
              schrieb am zuletzt editiert von stefu87_CH
              #1746
              Habt ihr auch seit einigen Minuten solche Fehler im Log:?
              2023-03-27 19:39:16.790 - error: vw-connect.0 (315347) 504
              2023-03-27 19:39:16.791 - error: vw-connect.0 (315347) {"error":{"errorCode":"gw.error.timeout","description":"Backend Connection Timeout"}}
              2023-03-27 19:39:46.863 - error: vw-connect.0 (315347) 504
              2023-03-27 19:39:46.864 - error: vw-connect.0 (315347) {"error":{"errorCode":"gw.error.timeout","description":"Backend Connection Timeout"}}
              // (Skoda) Githubvers: v0.0.63
              Model : AMD Ryzen 7 8745HS w/ Radeon 780M Graphics
              Cores: 1 × 8 = 8 cores
              Threads: 16
              mit Proxmox
              LXC Container mit Iobroker
              GlasfaserG WszeneW 2 Antworten Letzte Antwort
              • stefu87_CHS stefu87_CH
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #1747
                @stefu87_ch sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                Ja ... dito ( Audi )
                // Github Vers. v0.0.63
                joergeliJ 2 Antworten Letzte Antwort
                  WszeneW Offline
                  WszeneW Offline
                  Wszene
                  #1748
                  Ja aber soetwas habe ich in unregelmässigen Abständen immer wiedr mal
                  meist wenn das Fahrzeug mal ein paar Tage steht und nicht Bewegt wird
                  Meine Hard- & Software:
                  • MSI Cubi 5 10M-049DE mit Proxmox
                  • CC2652P Zigbee Stick
                  • Steckdosen mit Tasmota und Zigbee
                  • Lichtschalter mit Tasmota
                  • IKEA TRÅDFRI Glühbirnen
                  • Aqara Sensoren
                  • WszeneW Wszene
                    stefu87_CHS Offline
                    stefu87_CHS Offline
                    stefu87_CH
                    #1749
                    @wszene ok.
                    Ich bewege mein Auto täglich. Also kann es bei mir nicht davon kommen.
                    Threads: 16
                    mit Proxmox
                    WszeneW 1 Antwort Letzte Antwort
                      @wszene ok.
                      WszeneW Offline
                      WszeneW Offline
                      Wszene
                      #1750
                      @stefu87_ch
                      nach einem Adapterneustart ist das Problem dann wieder weg
                      Wir haben nicht nur ein Auto und z.B. am WE steht meist eins davon rum
                      • Aqara Sensoren
                        joergeliJ Online
                        joergeliJ Online
                        joergeli
                        schrieb am zuletzt editiert von joergeli
                        #1751
                        @glasfaser
                        Bei mir ebenfalls seit gestern Error 504 (Audi A3 - kein e-Auto).
                        Adapter-Neustart hilft nicht.
                        Auto steht seit ein paar Tagen - Nach probeweisem Einschalten der Zündung gestern, dann Meldungen im "Mäusekino", daß Navi neu initialisiert wird, etc..
                        Außerdem real nicht existierende Anzeigen, daß z.B. alle Fenster geöffnet sind.
                        Die Fehler werden ebenfalls in der myAudi-App angezeigt.
                        Vermutung:
                        Durch längere Standzeit sinkt die Bordspannung ab, so daß das System "durcheinander" kommt.
                        ... muß heute mal 'ne Runde mit dem Auto drehen, um zu sehen, ob sich's dann wieder normalisiert.
                        Edit:
                        So, mal 'ne Runde gedreht -> funktioniert wieder, wobei ich nicht sagen kann, ob's wirklich daran lag, daß ich das Auto bewegt habe, oder zwischenzeitlich was an den Servern gemacht wurde.
                          joergeliJ Online
                          joergeliJ Online
                          joergeli
                          #1752
                          @ all
                          Fahrzeug: Audi A3, Bj 2022, - kein e-Auto.
                          Frage: Ich bekomme vom Adapter ( v0.0.63) keine Tripdata-Objekte angelegt.
                          Funktioniert das nur mit dem "DataPlug", oder kann der Adapter das bei Audi nicht?
                          • joergeliJ joergeli
                            @glasfaser
                            Vermutung:
                            Edit:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #1753
                            @joergeli sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                            Edit:
                            Eher am Server ...
                            Mein Auto stand auch nicht !
                            • D DirkWe
                              Hallo zusammen, bin seit gestern auch stolzer Enyaq-Besitzer und stehe vor genau dem gleichen Problem wie Anaximelis: Immer die gleichen Fehler:
                              Gestern Abend sind zumindest noch alle Datenpunkte sauber erzeugt und auch befüllt worden. Jetzt laufe ich immer in den Fehler. Ich hatte schon FaceID auf der APP in Verdacht, aber deaktivieren hat auch nicht geholfen. Wenn ich zur Lösung beitragen kann....? (Update&Upgrade sind durchgeführt)
                              tombox
                              #1754
                              @dirkwe Für den enyaq 500 Fehler bräuchte ich Zugang zu einem enyag um das zu beheben
                              • L Offline
                                leachim200
                                #1755
                                ich bekomme folgende Fehlermeldungen und erreiche den ID3 nicht mehr über den iobroker
                                vw-connect.0
                                	2023-03-29 16:57:10.648	error	Restart Adapter in 30min
                                vw-connect.0
                                	2023-03-29 16:57:10.646	error	Login Failed
                                vw-connect.0
                                	2023-03-29 16:57:10.645	error	getaddrinfo ENOTFOUND login.apps.emea.vwapps.io
                                vw-connect.0
                                	2023-03-29 16:57:10.644	error	Error: getaddrinfo ENOTFOUND login.apps.emea.vwapps.io
                                vw-connect.0
                                	2023-03-29 16:57:10.643	error	Failed in first login step
                                vw-connect.0
                                	2023-03-29 16:57:05.592	warn	Failed to get login url
                                vw-connect.0
                                	2023-03-29 16:57:05.589	error	Error: getaddrinfo ENOTFOUND login.apps.emea.vwapps.io
                                vw-connect.0
                                	2023-03-29 16:57:05.587	error	Failed in receive login url
                                L D 2 Antworten Letzte Antwort
                                • O Offline
                                  O Offline
                                  odooo
                                  #1756
                                  Hallo, bei manchen switches gibt es mehrere Versionen, z.B. lock und lockv2 oder climatisation/v2/v3 usw.
                                  Was ist da der Unterschied? Bzw. warum gibt es mehrere Versionen?
                                  • O odooo
                                    tombox
                                    #1757
                                    @odooo vw hat verschiedene Versionen je nach auto Variante eingebaut deswegen
                                    O 1 Antwort Letzte Antwort
                                    • T tombox
                                      O Offline
                                      O Offline
                                      odooo
                                      #1758
                                      @tombox danke für die schnelle Antwort! Das heißt manche Versionen funktionieren dann evtl. nicht oder beide/mehere switches funktionieren?
                                      • L leachim200
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        leachim200
                                        #1759
                                        Hat keiner eine Idee woran das Liegen kann das die Verbindung nicht mehr hergestellt wird?
                                        • L leachim200
                                          Sneak-L8
                                          #1760
                                          @leachim200 Neuste Version installiert?
                                          L 1 Antwort Letzte Antwort
