  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    2.8k
    4.9k
    4.1k
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.7k Beiträge 461 Kommentatoren 2.1m Aufrufe 412 Beobachtet
  • M mguenther
    @tombox
    taucht bei mir aktuell auf:
    vw-connect.0	2021-07-16 19:01:45.166	error	(17911) "502 Bad Gateway: Registered endpoint failed to handle the request.\n"
    vw-connect.0	2021-07-16 19:01:45.166	error	(17911) 502
    vw-connect.0	2021-07-16 19:01:45.159	error	(17911) Failed to get token
    und dann
    vw-connect.0	2021-07-16 19:06:46.787	error	(17911) Failed to get records
    vw-connect.0	2021-07-16 19:06:46.786	error	(17911) {"tracing_id":"703540aaf50d09729156148cf72c1ab1","errors":[{"message":"Signin failed","code":"AUTHZ_SIGNIN_WITH_TOKEN"}]}
    vw-connect.0	2021-07-16 19:06:46.785	error	(17911) 401
    vw-connect.0	2021-07-16 19:06:46.754	error	(17911) Failed to get stations
    vw-connect.0	2021-07-16 19:06:46.754	error	(17911) {"tracing_id":"8109df1aa5f10e27494c8de9b32f72ed","errors":[{"message":"Signin failed","code":"AUTHZ_SIGNIN_WITH_TOKEN"}]}
    vw-connect.0	2021-07-16 19:06:46.752	error	(17911) 401
    vw-connect.0	2021-07-16 19:06:46.376	error	(17911) Failed to get chargeandpay records
    vw-connect.0	2021-07-16 19:06:46.375	error	(17911) {"tracing_id":"804a8efc6cb6f4efe1f33c0e06727984","errors":[{"message":"The request could not be authenticated","code":"UNAUTHORIZED"}]}
    vw-connect.0	2021-07-16 19:06:46.375	error	(17911) 401
    vw-connect.0	2021-07-16 19:06:46.372	error	(17911) Failed to get subscription
    vw-connect.0	2021-07-16 19:06:46.371	error	(17911) {"tracing_id":"18e581eb9382e50967aa44e9dac6fd3e","errors":[{"message":"The request could not be authenticated","code":"UNAUTHORIZED"}]}
    vw-connect.0	2021-07-16 19:06:46.370	error	(17911) 401
    usw...
    Der Adapter selber bleibt aber grün...
    tombox
    schrieb am zuletzt editiert von tombox
    #941
    @mguenther geht denn wecharge über die app?
    • T tombox
      mguenther
      #942
      @tombox
      generell geht es, ja. Ob es vorhin ging, weiß ich nicht.
        Backes
        #943
        Option "skodae" scheint noch Fehler zu erzeugen.
        siehe Log:
        Müsste diese Stelle hier sein Zeile 2518:
        • B Backes
          siehe Log:
          tombox
          #944
          @backes Habe ich übersehen gibt es denn sowas wie ein force reload bei skoda e autos.
          Habs in der github version rausgenommen bitte mal testen
          • M mguenther
            @tombox
            und dann
            usw...
            jhg
            #945
            @mguenther Diesen Fehler habe ich aktuell auch seit einigen Tagen.
            Konnte zwar nicht sehen ob das eine Auswirkung hat, aber die Fehlermeldung ist da.
              SiKo
              schrieb am zuletzt editiert von SiKo
              #946
              grundsätzlich läuft bei mir der Adapter. ich kann z.B. auch "Hupen & Blicken" Allerdings ist immer alles sehr zeitversetzt. Hab das Auto in der Garage entriegelt und Fenster teilweise geöffnet. bis ich das in ioBroker sehe vergehen oft Stunden. Mach ich hier etwas falsch?
                MrLee
                #947
                Moin!
                Auch von mir einen herzlichen Dank für den Adapter. Spiele mich gerade etwas rein, gerade bez. Akku und Ladestand.
                Da mein Fahrzeug (Audi) über die Standklimatisierung verfügt würde ich diese auch gerne steuern können (so wie aus der unsagbar schlechten Audi App...)
                Welchen Datenpunkt muß ich denn dafür nehmen? Remote/climatisation** erzeugen keine Reaktion bei mir.
                Des weiteren: Hat jemand erfahrung mit den möglichen polling zyklen bei Audi? Die Servererreichbarkeit ist ja eh nicht "optimal"
                Wer schön wenn jemand schon etwas Erfahrungen mit Audi gemacht hat...
                Liebe Grüße
                Mr.Lee
                • M MrLee
                  Moin!
                  Liebe Grüße
                  Mr.Lee
                  tombox
                  #948
                  @mrlee Standheizung geht auch nicht?
                  • T tombox
                    MrLee
                    #949
                    @tombox gerade probiert..nein, zumindest nix in der Audi App sichtbar
                      MrLee
                      #950
                      Generelle Frage...
                      Gibt es einen Datenpunkt der ein Datenupdate erzwingt?
                      bis denne
                      Mr.Lee
                      • M MrLee
                        tombox
                        #951
                        @mrlee in der app geht klima?
                        nicht man kann nur den interval in den optionen angeben
                        aktualisiert sich denn alles wenn du in der audi app nach unten ziehst
                        • T tombox
                          MrLee
                          #952
                          @tombox Jo, in der App geht klima, sofortstart, etc.
                          Im Adapter geht auch Abschließen und aufschließen, kontakt habe ich also :-)
                          Da ich die App gerne ganz und gar und in alle Ewigkeit ablösen würde...könnte man ein force-update noch in den Adapter einbauen oder geht das Systembedingt nicht?
                          • L Offline
                            Lattenleger 0
                            #953
                            Hallo, ich habe hier so gut wie alles durch gelesen, leider hilft es nicht bei meinem Problem. Ich habe 2 DATA Plugs in verschiedenen Autos. Beide liefern Daten an die Cloud in der GO App. Einer der Autos ist auch in der We Connect App mit Car-Net verknüpft. Dieses Auto ist auch im Adapter im io Brocker zu sehen. Leider sind beide über die DATA Plugs nicht zusehen. Was mache ich falsch?
                            • L Lattenleger 0
                              tombox
                              #954
                              @lattenleger-0 Dann musst du zwei instancen verwenden eine für we-connect und eine für go
                              L 1 Antwort Letzte Antwort
                                Magnus 1
                                #955
                                versuche mich gerade mit der v0.0.39 und bekomme in paar Daten geliefert, aber noch nicht die Dinge die mich wirklich interessieren (SOC, Trip history etc).
                                Im Protokoll findet sich folgender Fehler:
                                The service: statusreport_v1 for VIN:
                                vw-connect.0
                                2021-08-16 15:12:19.939	error	status update Failed WVW….
                                vw-connect.0
                                2021-08-16 15:12:19.927	error	{"error":{"errorCode":"VSR.security.9007","description":"The service: statusreport_v1 for VIN: WVW…. could not be found."}}
                                vw-connect.0
                                2021-08-16 15:12:19.926	error	502
                                vw-connect.0
                                2021-08-16 15:12:19.925	error	WVW….
                                Die VIN habe ich hier im Beitrag gekürzt.
                                Kann mir jemand helfen was hier schief läuft?
                                Es ist ein ID3 und da ja einige Daten geliefert werden zu meinem Fahrzeug gehe ich davon aus, dass die con mir eingegeben Zugangsdaten wohl stimmen.
                                Viele Grüße,
                                Magnus
                                • M Magnus 1
                                  vw-connect.0
                                  vw-connect.0
                                  vw-connect.0
                                  vw-connect.0
                                  Viele Grüße,
                                  Magnus
                                  tombox
                                  #956
                                  @magnus-1 Bitte bei typ ID auswählen
                                  • T tombox
                                    Magnus 1
                                    #957
                                    @tombox Super, dass war schnell und leicht zu fixen. jetzt kommt deutlich mehr.
                                    Noch nicht entdecken konnte ich die Trip infos. Gucke ich nur dran vorbei, oder gibt es die bei den ID nicht?
                                    Viele Grüße
                                    Magnus
                                    • M Magnus 1
                                      Viele Grüße
                                      Magnus
                                      tombox
                                      #958
                                      @magnus-1 nur das was es in der App gibt
                                      RaspiUserR 1 Antwort Letzte Antwort
                                      • T tombox
                                        Lattenleger 0
                                        schrieb am zuletzt editiert von Lattenleger 0
                                        #959
                                        @tombox Danke dir. Ich war auch zu blöd und habe nicht gesehen das man den „Type“ auf Go stellen muss. 🙄 👍
                                          SweetLakecity
                                          #960
                                          @tombox Vielen dank für den adapter. Für meinen Audi E tron kann ich problemlos status und dergleichen abrufen. Auch das Öffnen und schließen der türen per fernbedienung funktioniert gut. Beim starten der klimatisierung mit V1 erhalte ich folgende fehlermeldung ( {"error":{"errorCode": "climatisation.bs.invalid-parameter", "description": "invalid parameter : 'settings are missing'"}}) und mit V2 wird die aktion gestartet aber es passiert nichts. Wenn ich die klimatisierung über die MyAudiApp starte, kann ich sie mit dem adapater wieder stoppen. Ich hoffe, dass sie mir helfen können.
