  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.8k Beiträge 463 Kommentatoren 2.3m Aufrufe 409 Beobachtet
  • opossumO Offline
    opossumO Offline
    opossum
    schrieb am zuletzt editiert von opossum
    #201
    leider wieder Fehler im Log, der Adapter ist aber grün.
    host.iobrokerprod 2020-05-23 03:20:50.454 error Caught by controller[1]: undefined
    host.iobrokerprod 2020-05-23 03:20:50.452 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    vw-connect.0 2020-05-23 03:20:50.088 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:50.088 error (24368) 401
    vw-connect.0 2020-05-23 03:20:50.012 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:50.012 error (24368) 401
    vw-connect.0 2020-05-23 03:20:50.009 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:50.007 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.973 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:49.973 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.966 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:49.966 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.965 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:49.965 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.930 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:49.930 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.925 info (24368) Terminated (NO_ERROR): Without reason
    vw-connect.0 2020-05-23 03:20:49.924 info (24368) terminating
    vw-connect.0 2020-05-23 03:20:49.923 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
    vw-connect.0 2020-05-23 03:20:49.923 error (24368) 401
    vw-connect.0 2020-05-23 03:20:49.882 info (24368) cleaned everything up...
    vw-connect.0 2020-05-23 03:20:49.882 error (24368) unhandled promise rejection: undefined
    Unhandled 2020-05-23 03:20:49.881 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vw-connect.0 2020-05-23 03:20:49.880 error (24368) 401
    Kann damit jemand etwas anfangen? Installiert die 0.0.16. Der Login über die Website funktioniert.
    https://www.schlepper-petersdorf.de
    • WszeneW Wszene
      Werde ich mal probieren
      Mal etwas anderes
      Kann man die Aktualisierung des Datenpunktes "vw-connect.0.TMBJB7NS7KN400337.status.data08.field01.value" irgendwie beeinflussen?
      Grund ist das sich das Fahrzeug schon lange wieder verschlossen hat bevor sich der Datenpunkt ändert
      EDIT:
      Ich habe jetzt mal die zeit genommen
      Die Aktualisierung hat jetzt über 5min gedauert
      Das ist auch etwas lang da ich mich via Telegram benachtigen lassen möchte wenn noch ein Fester offen ist
      tombox
      #202
      @Wszene update interval ist in den instanzoptionen
      • opossumO opossum
        tombox
        #203
        @opossum kannst du bitte checken ob du die aktuellste Js Controller hast 3.1.4.
        und nochmal be connect via GitHub installieren. Fehler ist nicht kritisch aber schaue ich mir an
        opossumO 1 Antwort Letzte Antwort
        • T tombox
          opossumO Offline
          opossumO Offline
          opossum
          #204
          Hallo, @tombox ,
          @tombox sagte in Test Adapter VW Connect v0.0.x:
          Ich habe den js-Controller 3.1.4 im Einsatz, habe den Adapter noch einmal über GitHub installiert. Mal schauen, ob das ok ist. Danke Dir.
          • V Offline
            V Offline
            vernichter04
            schrieb am zuletzt editiert von vernichter04
            #205
            He, seit 14.05. aktualisiert er meinen Benzinstand nimmer. Auch noch ein paar Andere aktualisiert es nicht.
            Kann ich eine Aktualisierung erzwingen? In der Skoda-App zeigt er den richtigen Stand an. Einige andere Daten werden auch aktuell angezeigt, so z.B. Position usw.
            Platzhalter
            • V vernichter04
              Platzhalter
              tombox
              #206
              @vernichter04 du solltest die Position wieder löschen
              Eigentlich zeigt er die Daten aus der App an. Bzw kannst du mal probieren ein aktualisieren der in der App durch runterziehen erzwingen. Vielleicht speichert die Information an eine andere Stelle.
              Werden Information wie Türen aktualisiert ?
              V 1 Antwort Letzte Antwort
              • T tombox
                V Offline
                V Offline
                vernichter04
                #207
                @tombox
                So, ich habe jetzt den Adapter auf die aktuelle Version geupdatet. Vorher war die 13 und 15 drauf, damit gings nicht. Jetzt mit der 16 hat er es aktualisiert.
                  brupas
                  #208
                  Hallo allerseits
                  Da ich nun in meinem Kodiaq das Connect eingerichtet habe, musste ich natürlich diesen adapter installieren 😊
                  Auf den ersten Blick scheint es zu funktionieren. Wollte zum testen die Standheizung einschalten. Kriege dann jedoch diese error.
                  jemand eine Idee?
                  • B brupas
                    Hallo allerseits
                    jemand eine Idee?
                    tombox
                    #209
                    @brupas hast du den sPIN eingegeben
                    B 1 Antwort Letzte Antwort
                    • T tombox
                      brupas
                      #210
                      @tombox ja habe ich gemacht. Soeben nochmals kontrolliert.
                      FredFF 1 Antwort Letzte Antwort
                      • B brupas
                        FredFF Online
                        FredFF Online
                        FredF
                        Most Active Forum Testing
                        #211
                        @tombox
                        Ich versuche nun seit längerem Daten vom Adapter zu bekommen. Leider auch mit 0.0.16 bisher erfolglos...
                        Fehler 403 und 409 was bedeuten die?
                        Login scheint zu klappen, Adapter ist auch grün und die Vehicle ID ist auch in den Objekten zu sehen.
                        Daten sind in der App vorhanden. Es ist ein Passat.
                        Kann man aus dem debug Log was erkennen?
                        2020-05-24 16:42:03.689 - info: host.ioBrokerLife instance system.adapter.vw-connect.0 started with pid 26130
                        2020-05-24 16:42:04.530 - debug: vw-connect.0 (26130) Redis Objects: Use Redis connection: 0.0.0.0:9001
                        2020-05-24 16:42:04.547 - debug: vw-connect.0 (26130) Objects client ready ... initialize now
                        2020-05-24 16:42:04.548 - debug: vw-connect.0 (26130) Objects create System PubSub Client
                        2020-05-24 16:42:04.549 - debug: vw-connect.0 (26130) Objects create User PubSub Client
                        2020-05-24 16:42:04.549 - debug: vw-connect.0 (26130) Objects client initialize lua scripts
                        2020-05-24 16:42:04.563 - debug: vw-connect.0 (26130) Objects connected to redis: 0.0.0.0:9001
                        2020-05-24 16:42:04.566 - debug: vw-connect.0 (26130) objectDB connected
                        2020-05-24 16:42:04.567 - debug: vw-connect.0 (26130) Redis States: Use Redis connection: 0.0.0.0:9000
                        2020-05-24 16:42:04.572 - debug: vw-connect.0 (26130) States create User PubSub Client
                        2020-05-24 16:42:04.573 - debug: vw-connect.0 (26130) States create System PubSub Client
                        2020-05-24 16:42:04.581 - debug: vw-connect.0 (26130) States connected to redis: 0.0.0.0:9000
                        2020-05-24 16:42:04.581 - debug: vw-connect.0 (26130) statesDB connected
                        2020-05-24 16:42:04.938 - info: vw-connect.0 (26130) starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.19.0
                        2020-05-24 16:42:05.577 - debug: vw-connect.0 (26130) parseEmailForm
                        2020-05-24 16:42:05.980 - debug: vw-connect.0 (26130) parsePasswordForm
                        2020-05-24 16:42:06.366 - debug: vw-connect.0 (26130) ""
                        2020-05-24 16:42:06.366 - debug: vw-connect.0 (26130) {"date":"Sun, 24 May 2020 14:42:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=9496332b-ea03-4091-a224-8c746b885068@apps_vw-dilab_com&relayState=e8fa0fd7522e62ed6fae044202f258b42aa67585&userId=c8be6aa5-a7d6-4f59-bf43-6537eab513b0&HMAC=b728d7970d34309086bdaae699558f749fee27760db9a0046d09055d30f4bb5d","pragma":"no-cache","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-content-type-options":"nosniff","x-frame-options":"DENY","x-vcap-request-id":"47357ee4-b08c-4fbc-404b-c0dc8c3da1ce","x-xss-protection":"1; mode=block"}
                        2020-05-24 16:42:07.030 - debug: vw-connect.0 (26130) Error: Invalid protocol: carnet:
                        2020-05-24 16:42:07.484 - debug: vw-connect.0 (26130) Login successful
                        2020-05-24 16:42:07.484 - debug: vw-connect.0 (26130) getData
                        2020-05-24 16:42:07.692 - debug: vw-connect.0 (26130) {"firstName":"xxx","lastName":"xxx ","salutation":"SALUTATION:MR","preferredContactChannel":"MARKETING_BLOCKADES:MOBILE","nickname":"xxx","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdentifierValue":"7jUNVnGNxIN7mqBgFOnIPzgLIsU","addresses":[{"country":"DE","usageType":"ADDRESS_USAGE_TYPE:HOME_ADDRESS","uuid":"4dd05dce-b874-417e-905d-ceb874b17e12","_updated":"2020-05-24T10:05:28.264Z","primary":true,"name":"xxx xxx","street":"xxx","housenumber":"11","zipCode":"xxx","city":"xxx","type":"ADDRESS_TYPE:v1.address.GermanAddress"},{"country":"DE","usageType":"ADDRESS_USAGE_TYPE:BILLING_ADDRESS","uuid":"0c5906f0-81fd-4e9f-80bf-cb147ed125e6","_updated":"2020-05-08T11:31:55.560Z","primary":false,"name":"xxx xxx","street":"xxx","housenumber":"11","zipCode":"xxx","city":"xxx","type":"ADDRESS_TYPE:v1.address.GermanAddress"}],"userIsPrivateIndicator":false,"preferredLanguage":"de"}
                        2020-05-24 16:42:07.917 - debug: vw-connect.0 (26130) {"userVehicles":{"vehicle":["xxxx"]}}
                        2020-05-24 16:42:08.242 - error: vw-connect.0 (26130) 403
                        2020-05-24 16:42:08.242 - error: vw-connect.0 (26130) status update Failed
                        2020-05-24 16:42:09.039 - debug: vw-connect.0 (26130) system.adapter.admin.0: logging true
                        2020-05-24 16:42:09.189 - error: vw-connect.0 (26130) 409
                        2020-05-24 16:42:09.189 - error: vw-connect.0 (26130) {"error":{"errorCode":"gw.error.unknown","description":"Invalid backend error"}}
                        2020-05-24 16:42:09.189 - error: vw-connect.0 (26130) get vehicle data Failed
                        Das vielleicht ein Problem:
                        T B 2 Antworten Letzte Antwort
                        • FredFF FredF
                          @tombox
                          tombox
                          #212
                          @FredF kannst du mir mal eine pn schreiben?
                          • FredFF FredF
                            @tombox
                            brupas
                            #213
                            @FredF die Error‘s habe ich bei mir auch
                            • J Offline
                              Jaschkopf
                              #214
                              Servus. Leider läuft der Adapter bei mir nicht mehr seitdem ich Node von 10 auf 12 geupdated habe. Hier ein Auszug aus dem Log:
                              2020-05-25 20:27:58.472 - info: host.raspberrypi iobroker add vw-connect --host raspberrypi
                              2020-05-25 20:28:00.985 - info: host.raspberrypi iobroker NPM version: 6.14.4
                              2020-05-25 20:28:00.988 - info: host.raspberrypi iobroker npm install iobroker.vw-connect@0.0.16 --loglevel error --prefix "/opt/iobroker" (System call)
                              2020-05-25 20:29:24.452 - info: host.raspberrypi iobroker host.raspberrypi install adapter vw-connect
                              2020-05-25 20:29:24.699 - info: host.raspberrypi iobroker upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                              2020-05-25 20:29:24.805 - info: host.raspberrypi iobroker upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                              2020-05-25 20:29:24.864 - info: host.raspberrypi iobroker upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                              2020-05-25 20:29:24.920 - info: host.raspberrypi iobroker upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                              2020-05-25 20:29:24.976 - info: host.raspberrypi iobroker upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                              2020-05-25 20:29:25.188 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect created/updated
                              2020-05-25 20:29:25.285 - info: host.raspberrypi iobroker host.raspberrypi create instance vw-connect
                              2020-05-25 20:29:25.295 - info: host.raspberrypi iobroker host.raspberrypi object vw-connect.0.info.connection created
                              2020-05-25 20:29:25.326 - info: host.raspberrypi iobroker host.raspberrypi object vw-connect.0.info created
                              2020-05-25 20:29:25.356 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.sigKill created
                              2020-05-25 20:29:25.389 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.eventLoopLag created
                              2020-05-25 20:29:25.423 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.outputCount created
                              2020-05-25 20:29:25.456 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.inputCount created
                              2020-05-25 20:29:25.490 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.uptime created
                              2020-05-25 20:29:25.565 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.memRss created
                              2020-05-25 20:29:25.595 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.memHeapTotal created
                              2020-05-25 20:29:25.627 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.memHeapUsed created
                              2020-05-25 20:29:25.658 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.cputime created
                              2020-05-25 20:29:25.689 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.cpu created
                              2020-05-25 20:29:25.721 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.compactMode created
                              2020-05-25 20:29:25.753 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.connected created
                              2020-05-25 20:29:25.784 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0.alive created
                              2020-05-25 20:29:25.817 - info: host.raspberrypi iobroker host.raspberrypi Set default value of vw-connect.0.info.connection: false
                              2020-05-25 20:29:25.855 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.vw-connect.0 created
                              2020-05-25 20:29:26.865 - info: host.raspberrypi iobroker exit 0
                              2020-05-25 20:29:28.900 - info: host.raspberrypi instance system.adapter.vw-connect.0 started with pid 24407
                              2020-05-25 20:29:30.257 - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:1183
                              2020-05-25 20:29:30.258 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                              2020-05-25 20:29:30.258 - error: host.raspberrypi Caught by controller[0]: ^
                              2020-05-25 20:29:30.259 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                              2020-05-25 20:29:30.259 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                              2020-05-25 20:29:30.259 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                              2020-05-25 20:29:30.259 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                              2020-05-25 20:29:30.259 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                              2020-05-25 20:29:30.260 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                              2020-05-25 20:29:30.260 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                              2020-05-25 20:29:30.260 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                              2020-05-25 20:29:30.261 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                              2020-05-25 20:29:30.261 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                              2020-05-25 20:29:30.261 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                              2020-05-25 20:29:30.261 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                              2020-05-25 20:29:30.262 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                              2020-05-25 20:29:30.262 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                              2020-05-25 20:29:30.262 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                              2020-05-25 20:29:30.263 - error: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2020-05-25 20:29:30.263 - info: host.raspberrypi Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                              2020-05-25 20:29:30.264 - info: host.raspberrypi system.adapter.vw-connect.0 will be rebuilt
                              2020-05-25 20:29:30.265 - warn: host.raspberrypi adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                              2020-05-25 20:29:30.265 - info: host.raspberrypi iobroker rebuild vw-connect
                              2020-05-25 20:29:30.867 - info: host.raspberrypi iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                              2020-05-25 20:29:31.878 - info: host.raspberrypi iobroker npm-rebuild:
                              2020-05-25 20:29:31.879 - info: host.raspberrypi iobroker npm-rebuild: Rebuild vw-connect done
                              2020-05-25 20:29:32.887 - info: host.raspberrypi iobroker npm-rebuild: exit 0
                              2020-05-25 20:29:32.924 - info: host.raspberrypi instance system.adapter.vw-connect.0 started with pid 24449
                              2020-05-25 20:29:34.001 - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:1183
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: ^
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                              2020-05-25 20:29:34.002 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                              2020-05-25 20:29:34.003 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                              2020-05-25 20:29:34.004 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                              2020-05-25 20:29:34.004 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                              2020-05-25 20:29:34.004 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                              2020-05-25 20:29:34.004 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                              2020-05-25 20:29:34.004 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                              2020-05-25 20:29:34.005 - error: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2020-05-25 20:29:34.005 - info: host.raspberrypi Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                              2020-05-25 20:29:34.005 - info: host.raspberrypi system.adapter.vw-connect.0 will be rebuilt
                              Liegt das an meinem System oder läuft der Adapter momentan nicht auf Node 12?
                              Gruß Jaschkopf
                              • J Jaschkopf
                                Gruß Jaschkopf
                                tombox
                                #215
                                @Jaschkopf
                                npm rebuild und npm install canvas im iobroker ordner ausführen
                                J 1 Antwort Letzte Antwort
                                • T tombox
                                  @Jaschkopf
                                  Jaschkopf
                                  #216
                                  @tombox hast du dafür zufällig die passenden Kommandos parat? 😅 und in welchem Pfad genau muss ich das ausführen? Danke für die Hilfe.
                                  Gruß Jaschkopf
                                  • J Jaschkopf
                                    Gruß Jaschkopf
                                    tombox
                                    schrieb am zuletzt editiert von tombox
                                    #217
                                    @Jaschkopf
                                    cd /opt/iobroker
                                    npm rebuild
                                    npm install canvas
                                    • T tombox
                                      @Jaschkopf
                                      cd /opt/iobroker
                                      npm rebuild
                                      npm install canvas
                                      Jaschkopf
                                      #218
                                      @tombox Super ein Traum. Hatte endlich mal Zeit und jetzt läuft alles wieder einwandfrei. Vielen Dank! 💪 💪
                                        Spark
                                        #219
                                        Hi ,
                                        @tombox , erstmal Danke für den Adapter!
                                        Bin Seit dieser Woche Besitzer eines neuen Passat GTE und wollte mir natürlich den Adapter installieren und schöne Dinge damit machen. Leider bekomme ich nicht wirklich einen Zugang. Sehe meine FIN und auch meine Persönlichen Daten, aber Kilometerstände, Vorklimatisieren usw werden nicht angezeigt. PW und S_Pin sind definitiv korrekt. Was mache ich falsch? Adapter ist 0.16
                                        Bekomme folgende Meldung:
                                        vw-connect.0 2020-06-05 12:00:12.989 error (6527) status update Failed
                                        vw-connect.0 2020-06-05 12:00:12.987 error (6527) 403
                                        vw-connect.0 2020-06-05 12:00:12.642 error (6527) get vehicle data Failed
                                        vw-connect.0 2020-06-05 12:00:12.639 error (6527) {"error":{"errorCode":"gw.error.unknown","description":"Invalid backend error"}}
                                        vw-connect.0 2020-06-05 12:00:12.636 error (6527) 40
                                        Danke schonmal für eure Hilfe!
                                        FredFF T 2 Antworten Letzte Antwort
                                        • S Spark
                                          Hi ,
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          schrieb am zuletzt editiert von FredF
                                          #220
                                          @Spark
                                          Du machst keinen Fehler. Mit meinem neuen geht es auch noch nicht. @tombox ist da dran.
