  4. Test Adapter vw-connect für VW, ID, Audi, Seat, Skoda
3.8k Beiträge 472 Kommentatoren 3.1m Aufrufe 414 Beobachtet
  • WszeneW
    WszeneW
    Wszene
    #191
    Ich habe auch gerade das Update gemacht aber leider auch ohne Erfolg
    Dann Habe ich die Instanz gelöscht und wieder neu hinzugefügt gleiches Problem
    Hier mal das Log
    2020-05-12 06:07:40.772  - info: host.ioBroker-NUC iobroker upgrade vw-connect
    2020-05-12 06:07:42.328  - info: host.ioBroker-NUC iobroker Update vw-connect from @0.0.11 to @0.0.13
    2020-05-12 06:07:42.688  - info: host.ioBroker-NUC iobroker NPM version: 6.14.4
    2020-05-12 06:07:42.691  - info: host.ioBroker-NUC iobroker npm install iobroker.vw-connect@0.0.13 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-05-12 06:08:18.018  - info: host.ioBroker-NUC iobroker upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
    2020-05-12 06:08:18.081  - info: host.ioBroker-NUC iobroker Update "system.adapter.vw-connect.0"
    2020-05-12 06:08:18.152  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 20030
    2020-05-12 06:08:18.252  - info: host.ioBroker-NUC iobroker upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
    2020-05-12 06:08:18.312  - info: host.ioBroker-NUC iobroker upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    2020-05-12 06:08:18.373  - info: host.ioBroker-NUC iobroker upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
    2020-05-12 06:08:18.434  - info: host.ioBroker-NUC iobroker upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
    2020-05-12 06:08:18.493  - info: host.ioBroker-NUC iobroker Adapter "vw-connect" updated
    2020-05-12 06:08:18.859  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:08:18.860  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:08:18.864  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:08:18.864  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:08:18.864  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:08:19.500  - info: host.ioBroker-NUC iobroker exit 0
    2020-05-12 06:08:50.636  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-05-12 06:09:28.240  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
    2020-05-12 06:09:41.767  - info: web.0 (15961) <==Disconnect system.user.admin from ::ffff:192.168.10.196 vis.0
    2020-05-12 06:09:42.233  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
    2020-05-12 06:09:48.875  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
    2020-05-12 06:10:00.039  - info: host.ioBroker-NUC instance system.adapter.dwd.0 started with pid 20501
    2020-05-12 06:10:01.992  - info: dwd.0 (20501) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
    2020-05-12 06:10:05.273  - info: dwd.0 (20501) Terminated (NO_ERROR): Without reason
    2020-05-12 06:10:05.789  - info: host.ioBroker-NUC instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-05-12 06:11:54.671  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 21008
    2020-05-12 06:11:55.387  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:11:55.390  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:11:55.391  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:11:55.393  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:15:22.606  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 21952
    2020-05-12 06:16:16.383  - info: host.ioBroker-NUC "system.adapter.vw-connect.0" disabled
    2020-05-12 06:16:21.817  - info: host.ioBroker-NUC "system.adapter.vw-connect.0" enabled
    2020-05-12 06:16:21.873  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 22217
    2020-05-12 06:16:22.593  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:16:22.598  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:29:12.472  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 25660
    2020-05-12 06:29:13.192  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:29:13.197  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:29:49.681  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-05-12 06:30:01.961  - info: dwd.0 (25891) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
    2020-05-12 06:30:02.875  - info: host.ioBroker-NUC iobroker restart
    2020-05-12 06:30:03.247  - info: host.ioBroker-NUC iobroker iobroker controller daemon is not running
    2020-05-12 06:30:03.253  - info: host.ioBroker-NUC iobroker Starting iobroker controller daemon...
    2020-05-12 06:30:04.141  - info: host.ioBroker-NUC instance system.adapter.daswetter.0 started with pid 25948
    2020-05-12 06:30:03.749  - info: host.ioBroker-NUC iobroker.js-controller version 3.0.20 js-controller starting
    2020-05-12 06:30:04.225  - info: host.ioBroker-NUC iobroker iobroker controller daemon started. PID: 25933
    2020-05-12 06:30:04.242  - info: host.ioBroker-NUC iobroker exit 0
    2020-05-12 06:30:03.754  - info: host.ioBroker-NUC Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-05-12 06:30:03.755  - info: host.ioBroker-NUC hostname: ioBroker-NUC, node: v12.16.3
    2020-05-12 06:30:03.756  - info: host.ioBroker-NUC ip addresses: 192.168.10.211 fe80::3c7e:77ff:fe42:6fc4
    2020-05-12 06:30:04.103  - info: host.ioBroker-NUC  Error inMem-objects listening on port 9001
    2020-05-12 06:30:04.168  - info: host.ioBroker-NUC  Error inMem-states listening on port 9000
    2020-05-12 06:30:04.262  - info: host.ioBroker-NUC connected to Objects and States
    2020-05-12 06:30:05.076  - info: host.ioBroker-NUC 37 instances found
    2020-05-12 06:30:05.169  - info: host.ioBroker-NUC starting 33 instances
    2020-05-12 06:30:05.302  - info: host.ioBroker-NUC instance system.adapter.admin.0 started with pid 25987
    2020-05-12 06:31:38.160  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:31:38.163  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:31:38.164  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2020-05-12 06:31:38.164  - info: host.ioBroker-NUC iobroker rebuild vw-connect
    2020-05-12 06:31:38.565  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:31:39.501  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:31:39.502  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:31:40.515  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:31:40.536  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 28467
    2020-05-12 06:31:41.208  - info: host.ioBroker-NUC instance system.adapter.deconz.0 started with pid 28496
    2020-05-12 06:31:41.320  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:31:41.325  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:31:41.325  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:31:41.327  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:31:41.327  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:31:41.327  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2020-05-12 06:31:41.328  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:31:41.752  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:32:02.200  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:32:02.201  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:32:03.208  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:32:03.223  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 28657
    2020-05-12 06:32:03.982  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:32:03.983  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:32:03.983  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:32:03.987  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:32:03.988  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:32:03.988  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2020-05-12 06:32:03.988  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:32:04.456  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:34:16.368  - info: iot.0 (914) starting. Version 1.4.18 in /opt/iobroker/node_modules/iobroker.iot, node: v12.16.3, js-controller: 3.1.4
    2020-05-12 06:34:17.440  - warn: iot.0 (914) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:35:17.865  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1424
    2020-05-12 06:35:18.644  - info: ical.0 (1347) Terminated (NO_ERROR): Without reason
    2020-05-12 06:35:18.695  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:18.699  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:35:18.699  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:35:18.702  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:35:18.703  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2020-05-12 06:35:18.703  - info: host.ioBroker-NUC iobroker rebuild vw-connect
    2020-05-12 06:35:19.161  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:35:19.170  - info: host.ioBroker-NUC instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2020-05-12 06:35:20.078  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:35:21.070  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:35:21.109  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1461
    2020-05-12 06:35:21.938  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:35:21.938  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:35:21.939  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:35:21.939  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2020-05-12 06:35:21.939  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:35:22.729  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:35:24.340  - info: deconz.0 (1476) starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.16.3, js-controller: 3.1.4
    2020-05-12 06:35:24.450  - info: deconz.0 (1476) deConz Version: 2.5.75; API version: 1.16.0
    2020-05-12 06:35:24.523  - info: deconz.0 (1476) Code 404: Ressource not found get devices: []
    2020-05-12 06:35:34.448  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:35:34.449  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:35:35.458  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:35:35.497  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1573
    2020-05-12 06:35:36.261  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:35:36.261  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:35:36.264  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:35:36.265  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:35:36.265  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2020-05-12 06:35:36.265  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:35:36.666  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:35:45.648  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:35:46.618  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:35:46.653  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1666
    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:35:47.446  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:38:36.253  - info: host.ioBroker-NUC iobroker del vw-connect.0
    2020-05-12 06:38:37.594  - info: host.ioBroker-NUC iobroker Delete adapter "vw-connect.0"
    2020-05-12 06:38:37.626  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 instances of vw-connect.0
    2020-05-12 06:38:37.638  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 devices of vw-connect.0
    2020-05-12 06:38:37.647  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 channels of vw-connect.0
    2020-05-12 06:38:37.768  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 2198 states of vw-connect.0
    2020-05-12 06:38:37.777  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 14 states of system.adapter.vw-connect.0
    2020-05-12 06:38:38.886  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Deleting 2215 object(s). Be patient...
    2020-05-12 06:38:39.782  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 2200 objects left to be deleted.
    2020-05-12 06:38:51.538  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 2000 objects left to be deleted.
    2020-05-12 06:39:03.506  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1800 objects left to be deleted.
    2020-05-12 06:39:14.493  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1600 objects left to be deleted.
    2020-05-12 06:39:24.513  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1400 objects left to be deleted.
    2020-05-12 06:39:34.609  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1200 objects left to be deleted.
    2020-05-12 06:39:45.465  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1000 objects left to be deleted.
    2020-05-12 06:39:56.760  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 800 objects left to be deleted.
    2020-05-12 06:40:00.028  - info: host.ioBroker-NUC instance system.adapter.dwd.0 started with pid 2752
    2020-05-12 06:40:01.966  - info: dwd.0 (2752) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.1.4
    2020-05-12 06:40:05.388  - info: dwd.0 (2752) Terminated (NO_ERROR): Without reason
    2020-05-12 06:40:05.903  - info: host.ioBroker-NUC instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-05-12 06:40:07.367  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 600 objects left to be deleted.
    2020-05-12 06:40:17.911  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 400 objects left to be deleted.
    2020-05-12 06:40:28.820  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 200 objects left to be deleted.
    2020-05-12 06:40:40.001  - info: host.ioBroker-NUC object deleted system.adapter.vw-connect.0
    2020-05-12 06:40:41.072  - info: host.ioBroker-NUC iobroker exit 0
    2020-05-12 06:41:15.758  - info: host.ioBroker-NUC iobroker url "https://github.com/TA2k/ioBroker.vw-connect/tarball/master" vw-connect
    2020-05-12 06:41:17.014  - info: host.ioBroker-NUC iobroker install https://github.com/TA2k/ioBroker.vw-connect/tarball/master
    2020-05-12 06:41:17.393  - info: host.ioBroker-NUC iobroker NPM version: 6.14.4
    2020-05-12 06:41:17.393  - info: host.ioBroker-NUC iobroker npm install https://github.com/TA2k/ioBroker.vw-connect/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
    2020-05-12 06:41:48.841  - info: host.ioBroker-NUC iobroker upload [5] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
    2020-05-12 06:41:48.941  - info: host.ioBroker-NUC iobroker upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
    2020-05-12 06:41:48.998  - info: host.ioBroker-NUC iobroker upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/tsconfig.json tsconfig.json application/json
    2020-05-12 06:41:49.056  - info: host.ioBroker-NUC iobroker upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    2020-05-12 06:41:49.112  - info: host.ioBroker-NUC iobroker upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
    2020-05-12 06:41:49.169  - info: host.ioBroker-NUC iobroker upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
    2020-05-12 06:41:50.306  - info: host.ioBroker-NUC iobroker exit 0
    2020-05-12 06:41:50.410  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-05-12 06:42:57.910  - info: host.ioBroker-NUC iobroker add vw-connect  --host ioBroker-NUC
    2020-05-12 06:42:59.233  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC create instance vw-connect
    2020-05-12 06:42:59.247  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object vw-connect.0.info.connection created
    2020-05-12 06:42:59.285  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object vw-connect.0.info created
    2020-05-12 06:42:59.321  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.sigKill created
    2020-05-12 06:42:59.353  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.eventLoopLag created
    2020-05-12 06:42:59.386  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.outputCount created
    2020-05-12 06:42:59.422  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.inputCount created
    2020-05-12 06:42:59.457  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.uptime created
    2020-05-12 06:42:59.493  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memRss created
    2020-05-12 06:42:59.530  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memHeapTotal created
    2020-05-12 06:42:59.563  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memHeapUsed created
    2020-05-12 06:42:59.597  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.cputime created
    2020-05-12 06:42:59.635  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.cpu created
    2020-05-12 06:42:59.669  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.compactMode created
    2020-05-12 06:42:59.702  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.connected created
    2020-05-12 06:42:59.736  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.alive created
    2020-05-12 06:42:59.766  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Set default value of vw-connect.0.info.connection: false
    2020-05-12 06:42:59.809  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0 created
    2020-05-12 06:43:00.816  - info: host.ioBroker-NUC iobroker exit 0
    2020-05-12 06:43:02.858  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3623
    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:03.602  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:43:03.602  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:43:03.602  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:43:03.603  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2020-05-12 06:43:03.604  - info: host.ioBroker-NUC iobroker rebuild vw-connect
    2020-05-12 06:43:03.961  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:43:04.735  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:43:04.735  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:43:05.744  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:43:05.827  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3660
    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:43:06.604  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:43:06.965  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:43:27.882  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:43:27.884  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:43:28.893  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:43:28.934  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3788
    2020-05-12 06:43:29.684  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:43:29.689  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
    2020-05-12 06:43:29.689  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
    2020-05-12 06:43:29.690  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2020-05-12 06:43:29.690  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
    2020-05-12 06:43:30.034  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
    2020-05-12 06:43:39.092  - info: host.ioBroker-NUC iobroker npm-rebuild:
    2020-05-12 06:43:39.094  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
    2020-05-12 06:43:40.102  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
    2020-05-12 06:43:40.137  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3874
    2020-05-12 06:43:40.843  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:43:40.847  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2020-05-12 06:43:55.455  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3949
    2020-05-12 06:43:56.201  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
    2020-05-12 06:43:56.202  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
    2020-05-12 06:43:56.205  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    2020-05-12 06:43:56.209  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-05-12 06:43:56.209  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    Meine Hard- & Software:
    • CC2652P Zigbee Stick
    • Lichtschalter mit Tasmota
    • IKEA TRÅDFRI Glühbirnen
    • Aqara Sensoren
    • WszeneW Wszene
      Hier mal das Log
      T
      T
      tombox
      #192
      @Wszene sieht nach einem canvas problem aus
      cd /opt/iobroker
      npm install canvas --unsafe-perm --production --save --prefix
      schon probiert?
      bzw sieht nach einem node update ohne npm rebuild aus
      cd /opt/iobroker
      npm rebuild
      • WszeneW
        WszeneW
        Wszene
        #193
        @tombox
        Danke das war genau das Problem
        Jetzt geht es wieder
        • Aqara Sensoren
        • T tombox
          @vernichter04 Es kann der login nicht aktuell gehalten werden. einfach adapter deaktivieren und morgen erneut probieren
          V
          V
          vernichter04
          #194
          @tombox
          Hallo, also ich bin deinem Rat gefolgt. Die Aktualisierung klappt gelegentlich. Die Fehler sind trotzdem da.
          • U
            U
            Ultor
            schrieb am zuletzt editiert von Ultor
            #195
            Hi @tombox ,
            Bei mir spuckt der Adapter (Version 0.0.15) leider gelegentlich immer noch Fehler aus und wird dann vom Host neu gestartet. Ich habe leider kein vollständiges Log zur Hand, das kann ich aber gerne nachreichen. Die JS-Controller-Version ist 3.1.2. Die Datenpunkte aktualisiert der Adapter scheinbar trotzdem korrekt (mit Skoda-App abgeglichen).
            Die Fehlermeldung Error 400 / Failing to refresh token habe ich übrigens ebenfalls, und zwar bei jeder Aktualisierung (über mehrere Tage getestet). Auch das scheint bei mir keine großartigen Auswirkungen zu haben, auch nach dieser Fehlermeldung sind alle Datenpunkte aktuell.
            host.ioBroker-RasPi4	2020-05-18 14:37:05.703	info	instance system.adapter.vw-connect.0 started with pid 14810
            host.ioBroker-RasPi4	2020-05-18 14:36:35.626	info	Restart adapter system.adapter.vw-connect.0 because enabled
            host.ioBroker-RasPi4	2020-05-18 14:36:35.626	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
            host.ioBroker-RasPi4	2020-05-18 14:36:35.625	error	Caught by controller[1]: undefined
            host.ioBroker-RasPi4	2020-05-18 14:36:35.620	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
            vw-connect.0	2020-05-18 14:36:34.917	error	(32413) unhandled promise rejection: undefined
            Unhandled	2020-05-18 14:36:34.917	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            • U Ultor
              Hi @tombox ,
              T
              T
              tombox
              #196
              @Ultor ich habe noch eine 0.0.16 veröffentlicht. ich bräuchte wirklich mal den refreshtoken fehler
              • S
                S
                Sneak-L8
                #197
                @tombox: ich habe heute von 0.0.8 auf 0.0.15 aktualisiert.
                Jetzt erhalte ich regelmäßig die beiden Fehler
                vw-connect.0	2020-05-18 20:44:52.526	error	(12761) status update Failed
                vw-connect.0	2020-05-18 20:44:52.524	error	(12761) 403
                vw-connect.0	2020-05-18 20:44:52.475	error	(12761) status update Failed
                vw-connect.0	2020-05-18 20:44:52.472	error	(12761) 403
                Ich vermute, weil meine beiden Services noch nicht verlängert wurden. Kann das sein? Zuvor waren sie zwar auch nocht verfügbar, aber der Fehler kam nicht.
                • WszeneW
                  WszeneW
                  Wszene
                  #198
                  Ich sitze gerade daran das ich den Zustand der Türen und Fenster in die VIS einbaue
                  Leider bin ich da irgendwie erfolglos
                  Wie habt ihr das bei euch umgesetzt
                  Ich habe folgenden Plan:
                  Ich habe mir Datenpunkte erstellt
                  Dann habe ich ein Blockly erstellt welches diese Datenpunkte befühlen soll.
                  Das Falls Objekt ist in dem Fall
                  "vw-connect.0.TMBJB7NS7KN400337.status.data08.field01.value"
                  Leider werden die Datenpunkte nicht befühlt.
                  Sieht jemand von euch den Fehler?
                  Marcel
                  • Aqara Sensoren
                  • U
                    U
                    Ultor
                    #199
                    Hallo @Wszene,
                    nimm mal statt das Aktualisiere-Element das Steuere-Element, dann sollte es funktionieren.
                    Gruß,
                    Daniel
                    • WszeneW
                      WszeneW
                      Wszene
                      schrieb am zuletzt editiert von Wszene
                      #200
                      Werde ich mal probieren
                      Mal etwas anderes
                      Kann man die Aktualisierung des Datenpunktes "vw-connect.0.TMBJB7NS7KN400337.status.data08.field01.value" irgendwie beeinflussen?
                      Grund ist das sich das Fahrzeug schon lange wieder verschlossen hat bevor sich der Datenpunkt ändert
                      EDIT:
                      Ich habe jetzt mal die zeit genommen
                      Die Aktualisierung hat jetzt über 5min gedauert
                      Das ist auch etwas lang da ich mich via Telegram benachtigen lassen möchte wenn noch ein Fester offen ist
                      • Aqara Sensoren
                      • opossumO
                        opossumO
                        opossum
                        schrieb am zuletzt editiert von opossum
                        #201
                        leider wieder Fehler im Log, der Adapter ist aber grün.
                        host.iobrokerprod 2020-05-23 03:20:50.454 error Caught by controller[1]: undefined
                        host.iobrokerprod 2020-05-23 03:20:50.452 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
                        vw-connect.0 2020-05-23 03:20:50.088 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:50.088 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:50.012 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:50.012 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:50.009 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:50.007 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.973 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:49.973 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.966 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:49.966 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.965 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:49.965 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.930 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:49.930 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.925 info (24368) Terminated (NO_ERROR): Without reason
                        vw-connect.0 2020-05-23 03:20:49.924 info (24368) terminating
                        vw-connect.0 2020-05-23 03:20:49.923 error (24368) {"error":{"errorCode":"gw.error.authentication","description":"Token expired"}}
                        vw-connect.0 2020-05-23 03:20:49.923 error (24368) 401
                        vw-connect.0 2020-05-23 03:20:49.882 info (24368) cleaned everything up...
                        vw-connect.0 2020-05-23 03:20:49.882 error (24368) unhandled promise rejection: undefined
                        Unhandled 2020-05-23 03:20:49.881 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        vw-connect.0 2020-05-23 03:20:49.880 error (24368) 401
                        Kann damit jemand etwas anfangen? Installiert die 0.0.16. Der Login über die Website funktioniert.
                        https://www.schlepper-petersdorf.de
                        • WszeneW Wszene
                          Mal etwas anderes
                          EDIT:
                          T
                          T
                          tombox
                          #202
                          @Wszene update interval ist in den instanzoptionen
                          • opossumO opossum
                            T
                            T
                            tombox
                            #203
                            @opossum kannst du bitte checken ob du die aktuellste Js Controller hast 3.1.4.
                            und nochmal be connect via GitHub installieren. Fehler ist nicht kritisch aber schaue ich mir an
                            opossumO 1 Antwort Letzte Antwort
                            • T tombox
                              opossumO
                              opossumO
                              opossum
                              #204
                              Hallo, @tombox ,
                              @tombox sagte in Test Adapter VW Connect v0.0.x:
                              Ich habe den js-Controller 3.1.4 im Einsatz, habe den Adapter noch einmal über GitHub installiert. Mal schauen, ob das ok ist. Danke Dir.
                              • V
                                V
                                vernichter04
                                schrieb am zuletzt editiert von vernichter04
                                #205
                                He, seit 14.05. aktualisiert er meinen Benzinstand nimmer. Auch noch ein paar Andere aktualisiert es nicht.
                                Kann ich eine Aktualisierung erzwingen? In der Skoda-App zeigt er den richtigen Stand an. Einige andere Daten werden auch aktuell angezeigt, so z.B. Position usw.
                                Platzhalter
                                • V vernichter04
                                  Platzhalter
                                  T
                                  T
                                  tombox
                                  #206
                                  @vernichter04 du solltest die Position wieder löschen
                                  Eigentlich zeigt er die Daten aus der App an. Bzw kannst du mal probieren ein aktualisieren der in der App durch runterziehen erzwingen. Vielleicht speichert die Information an eine andere Stelle.
                                  Werden Information wie Türen aktualisiert ?
                                  V 1 Antwort Letzte Antwort
                                  • T tombox
                                    V
                                    V
                                    vernichter04
                                    #207
                                    @tombox
                                    So, ich habe jetzt den Adapter auf die aktuelle Version geupdatet. Vorher war die 13 und 15 drauf, damit gings nicht. Jetzt mit der 16 hat er es aktualisiert.
                                    • B
                                      B
                                      brupas
                                      #208
                                      Hallo allerseits
                                      Da ich nun in meinem Kodiaq das Connect eingerichtet habe, musste ich natürlich diesen adapter installieren 😊
                                      Auf den ersten Blick scheint es zu funktionieren. Wollte zum testen die Standheizung einschalten. Kriege dann jedoch diese error.
                                      jemand eine Idee?
                                      • B brupas
                                        Hallo allerseits
                                        jemand eine Idee?
                                        T
                                        T
                                        tombox
                                        #209
                                        @brupas hast du den sPIN eingegeben
                                        • T tombox
                                          B
                                          B
                                          brupas
                                          #210
                                          @tombox ja habe ich gemacht. Soeben nochmals kontrolliert.
                                          33.2k
                                          84.3k
