  4. PI4 Lässt JS Kontrolle nicht updaten
js-controller 2.0.25
106 Beiträge 8 Kommentatoren 13.9k Aufrufe 9 Beobachtet
  • AlCalzoneA AlCalzone
    @freaktech Und hast du das
    inzwischen gemacht? Was war die Ausgabe davon? Danach kannst du das Upgrade probieren.
    freaktech
    #61
    @AlCalzone
    pi@iobrocker:/opt/iobroker $
    pi@iobrocker:/opt/iobroker $ npm WARN using --force I sure hope you know what you are doing.
    Usage: npm <command>
    where <command> is one of:
        access, adduser, audit, bin, bugs, c, cache, ci, cit,
        clean-install, clean-install-test, completion, config,
        create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
        edit, explore, get, help, help-search, hook, i, init,
        install, install-ci-test, install-test, it, link, list, ln,
        login, logout, ls, org, outdated, owner, pack, ping, prefix,
        profile, prune, publish, rb, rebuild, repo, restart, root,
        run, run-script, s, se, search, set, shrinkwrap, star,
        stars, start, stop, t, team, test, token, tst, un,
        uninstall, unpublish, unstar, up, update, v, version, view,
        whoami
    npm <command> -h  quick help on <command>
    npm -l            display full usage info
    npm help <term>   search for help on <term>
    npm help npm      involved overview
    Specify configs in the ini-formatted file:
        /home/pi/.npmrc
    or on the command line via: npm <command> --key value
    Config info can be viewed via: npm help config
    npm@6.12.0 /usr/local/lib/node_modules/npm
    pi@iobrocker:/opt/iobroker $ pi@iobrocker:/opt/iobroker/node_modules/iobroker.hue $
    -bash: pi@iobrocker:/opt/iobroker/node_modules/iobroker.hue: Datei oder Verzeichnis nicht gefunden
    • F freaktech
      @AlCalzone said in PI4 Lässt JS Kontrolle nicht updaten:
      wget -qO- https://registry.npmjs.org/
      pi@iobrocker:/opt/iobroker $ wget -qO- https://registry.npmjs.org/
      {"db_name":"registry","doc_count":1417354,"doc_del_count":340,"update_seq":5737861,"purge_seq":0,"compact_running":false,"disk_size":24759636103,"data_size":19681074249,"instance_start_time":"1570691704792381","disk_format_version":6,"committed_update_seq":5737861}pi@iobrocker:/opt/iobroker $
      hier passiert aber nichts
      pi@iobrocker:/opt/iobroker/node_modules/iobroker.hue $ node main.js --force --logs
      apollon77A Online
      apollon77A Online
      #62
      @freaktech Ok, die Ausgabe sieht an sich ok aus von dem npm Ding.
      Manueller Adapterstart: ist ioBroker auch gestartet auf dem Host? Der muss laufen sonst geht das nicht.
      bzw mach mal:
      ´node main.js silly --force --logs`
      F 1 Antwort Letzte Antwort
      • F freaktech
        @AlCalzone
            whoami
            /home/pi/.npmrc
        apollon77A Online
        apollon77A Online
        #63
        @freaktech Kommando sieht falsch aus
        • F Offline
          freaktech
          #64
          pi@iobrocker:/opt/iobroker $ node main.js silly --force --logs
          internal/modules/cjs/loader.js:583
              throw err;
          Error: Cannot find module '/opt/iobroker/main.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
              at Function.Module._load (internal/modules/cjs/loader.js:507:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
          • F freaktech
                throw err;
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            schrieb am zuletzt editiert von AlCalzone
            #65
            @freaktech sagte in PI4 Lässt JS Kontrolle nicht updaten:
            falscher Ordner
            Was ist mit den anderen Befehlen, nach denen ich inzwischen 2x gefragt habe? Achte bitte darauf, dass du die Befehle richtig eintippst oder kopierst.
            Die letzten Logs sehen mir so aus als kopierst du wild irgendwelche Warnmeldungen und/oder Logausgaben als Befehle.
            Warum sudo böse ist: https://forum.iobroker.net/post/17109
            • apollon77A apollon77
              bzw mach mal:
              freaktech
              #66
              @apollon77 said in PI4 Lässt JS Kontrolle nicht updaten:
              mach ich ja
                  throw err;
              was mach ich falsch?
              • F freaktech
                mach ich ja
                    throw err;
                apollon77A Online
                apollon77A Online
                #67
                @freaktech Jetzt vergleich das mal mit dem was Du selbst weiter oben gepotet hast
                https://forum.iobroker.net/post/310830
                cd node_modules/iobroker.hue
                vergessen?
                • F Offline
                  freaktech
                  #68
                  ja sorry ich bin wohl zu doof um es zu kapieren
                  diese vorgehensweise ist ja wohl auch falsch
                  pi@iobrocker:~ $ cd /opt/iobroker
                  pi@iobrocker:/opt/iobroker $ cd node_modules/iobroker.hue
                  pi@iobrocker:/opt/iobroker/node_modules/iobroker.hue $ node main.js silly --force --logs
                  AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                  • F freaktech
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #69
                    @freaktech Jetzt ist der Pfad schon mal richtig. Läuft trotzdem nicht... Vielleicht muss der nochmal installiert werden. Dazu müssen wir dein npm-Problem aber lösen.
                    Also... was ist jetzt hiermit?
                    • F freaktech
                      apollon77A Online
                      apollon77A Online
                      #70
                      @freaktech Ok, Frage: kommt es direkt zurück der Befehl oder "Hängt er"?
                      • F Offline
                        freaktech
                        #71
                        das bringt leider nichts
                        pi@iobrocker:/opt/iobroker $ npm cache verify
                        Cache verified and compressed (~/.npm/_cacache):
                        Content verified: 0 (0 bytes)
                        Index entries: 0
                        Finished in 0.067s
                        pi@iobrocker:/opt/iobroker $ npm cache clean --force
                        pi@iobrocker:/opt/iobroker $ npm cche verify
                            whoami
                            /home/pi/.npmrc
                        Did you mean this?
                            cache
                        Index entries: 0
                        Finished in 0.067s
                        pi@iobrocker:/opt/iobroker $ ^C
                        pi@iobrocker:/opt/iobroker $ sudo iobroker stop
                        pi@iobrocker:/opt/iobroker $ sudo iobroker update
                        Used repository: latest
                        hash not changed, use actual sources
                        update done
                        Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.hue/io-package.json: SyntaxError: Unexpected end of JSON input
                        Adapter    "admin"         : 3.6.9    , installed 3.6.9
                        Adapter    "admin-2"       : 2.0.10
                        Adapter    "alexa2"        : 2.6.4    , installed 2.6.4
                        Adapter    "alpha2"        : 1.0.0
                        Adapter    "amazon-dash"   : 0.3.1
                        Adapter    "artnet"        : 1.0.0
                        Adapter    "asterisk"      : 1.0.6
                        Adapter    "asuswrt"       : 1.0.1
                        Adapter    "b-control-em"  : 0.2.1
                        Adapter    "backitup"      : 1.2.0    , installed 1.2.0
                        Adapter    "beckhoff"      : 1.0.6
                        Adapter    "benq"          : 0.2.0
                        Adapter    "ble"           : 0.10.1
                        Adapter    "bmw"           : 1.4.0
                        Adapter    "boblight"      : 0.0.1
                        Adapter    "bosesoundtouch": 0.2.4
                        Adapter    "botvac"        : 1.0.0
                        Adapter    "bring"         : 1.6.5
                        Adapter    "broadlink2"    : 2.0.0
                        Adapter    "chromecast"    : 2.2.3
                        Adapter    "cloud"         : 2.6.2    , installed 2.6.2
                        Adapter    "comfoair"      : 0.3.2
                        Adapter    "contactid"     : 1.0.0
                        Adapter    "corrently"     : 0.0.2
                        Adapter    "countdown"     : 1.0.4
                        Adapter    "cul"           : 1.0.0
                        Adapter    "daikin"        : 1.0.5
                        Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                        Adapter    "deconz"        : 1.1.2
                        Adapter    "denon"         : 1.6.1
                        Adapter    "devices"       : 0.1.7
                        Adapter    "discovergy"    : 0.4.7
                        Adapter    "discovery"     : 2.0.0    , installed 2.0.0
                        Adapter    "doorbird"      : 0.1.5
                        Adapter    "ds18b20"       : 1.0.2
                        Adapter    "dwd"           : 2.4.3
                        Adapter    "ebus"          : 0.8.0
                        Adapter    "egigeozone"    : 0.1.2
                        Adapter    "ekey"          : 1.1.0
                        Adapter    "email"         : 1.0.5
                        Adapter    "emby"          : 1.0.0
                        Adapter    "energymanager" : 1.2.1
                        Adapter    "enet"          : 1.0.1
                        Adapter    "epson_stylus_px830": 0.2.1
                        Adapter    "fakeroku"      : 0.2.1
                        Adapter    "feiertage"     : 1.0.11
                        Adapter    "fhem"          : 1.3.0
                        Adapter    "find-my-iphone": 0.2.17
                        Adapter    "firetv"        : 0.0.33
                        Adapter    "flot"          : 1.9.2
                        Adapter    "foobar2000"    : 1.0.0
                        Adapter    "fritzbox"      : 0.2.1
                        Adapter    "fritzdect"     : 0.2.4
                        Adapter    "fronius"       : 1.0.5
                        Adapter    "fullcalendar"  : 0.2.4
                        Adapter    "fullybrowser"  : 1.0.1
                        Adapter    "g-homa"        : 0.5.1
                        Adapter    "geofency"      : 0.3.2
                        Adapter    "gruenbeck"     : 0.0.14
                        Adapter    "habpanel"      : 0.3.4
                        Adapter    "haier"         : 1.0.2
                        Adapter    "ham"           : 1.1.2
                        Adapter    "ham-wemo"      : 1.0.1
                        Adapter    "harmony"       : 1.2.2
                        Adapter    "hass-mqtt"     : 0.0.7
                        Adapter    "heatingcontrol": 0.2.3
                        Adapter    "heytech"       : 0.1.4
                        Adapter    "hid"           : 0.1.17
                        Adapter    "hilink"        : 0.2.7
                        Adapter    "history"       : 1.8.7
                        Adapter    "hm-rega"       : 2.4.12
                        Adapter    "hm-rpc"        : 1.10.0
                        Adapter    "hmip"          : 0.0.11
                        Adapter    "hombot"        : 0.1.3
                        Adapter    "homeconnect"   : 0.0.24
                        Adapter    "homee"         : modified
                        Adapter    "homepilot"     : 1.0.3
                        Adapter    "hp-ilo"        : 1.0.1
                        Adapter    "hs100"         : 1.0.10
                        Adapter    "hue"           : 2.0.0
                        Adapter    "hue-extended"  : 0.9.0
                        Adapter    "hyperion"      : 0.0.9
                        Adapter    "i2c"           : 0.0.6
                        Adapter    "ical"          : 1.7.0    , installed 1.7.0
                        Adapter    "icons-addictive-flavour-png": 0.1.0
                        Adapter    "icons-fatcow-hosting": 0.1.0
                        Adapter    "icons-icons8"  : 0.0.1
                        Adapter    "icons-material-png": 0.1.0
                        Adapter    "icons-material-svg": 0.1.0
                        Adapter    "icons-mfd-png" : 1.0.2
                        Adapter    "icons-mfd-svg" : 1.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.3
                        Adapter    "icons-ultimate-png": 1.0.1
                        Adapter    "influxdb"      : 1.6.3
                        Adapter    "info"          : 1.5.5    , installed 1.5.5
                        Adapter    "innogy-smarthome": 0.3.3
                        Adapter    "intesishome"   : 0.1.2
                        Adapter    "iogo"          : 0.4.13
                        Adapter    "iot"           : 1.1.8
                        Adapter    "iqontrol"      : 0.2.12
                        Adapter    "javascript"    : 4.3.0    , installed 4.3.0
                        Adapter    "jeelink"       : 0.1.3
                        Controller "js-controller" : 2.0.29   , installed 1.5.14 [Updateable]
                        Adapter    "js2fs"         : 0.1.5    , installed 0.1.5
                        Adapter    "kecontact"     : 0.1.0
                        Adapter    "klf200"        : 0.9.5
                        Adapter    "km200"         : 2.0.3
                        Adapter    "knmi-weather"  : 0.1.1
                        Adapter    "knx"           : 1.0.35
                        Adapter    "kodi"          : 1.0.0
                        Adapter    "kress"         : 2.5.5
                        Adapter    "landroid"      : 1.0.3
                        Adapter    "lcn"           : 0.4.2
                        Adapter    "letrika_comgw" : 0.0.4
                        Adapter    "lgtv"          : 1.0.8
                        Adapter    "lgtv-rs"       : 0.0.4
                        Adapter    "lgtv11"        : 1.0.5
                        Adapter    "lifx"          : 0.1.0
                        Adapter    "lightify"      : 0.2.16
                        Adapter    "link"          : 0.4.4
                        Adapter    "linkeddevices" : 1.0.1
                        Adapter    "lovelace"      : 0.1.5
                        Adapter    "loxone"        : 1.0.0
                        Adapter    "luftdaten"     : 0.0.7
                        Adapter    "lupusec"       : 1.2.0
                        Adapter    "luxtronik1"    : 0.0.7
                        Adapter    "material"      : 0.10.6
                        Adapter    "maxcube"       : 0.1.2    , installed 0.1.2
                        Adapter    "maxcul"        : 1.1.2
                        Adapter    "mbus"          : 1.1.1
                        Adapter    "mclighting"    : 0.0.12
                        Adapter    "megad"         : 1.2.1
                        Adapter    "megadd"        : 0.2.0
                        Adapter    "megaesp"       : 0.1.0
                        Adapter    "mercedesme"    : 0.0.16
                        Adapter    "meross"        : 1.0.0
                        Adapter    "meteoalarm"    : 1.0.5
                        Adapter    "miele"         : 0.1.5
                        Adapter    "mihome"        : 1.2.8
                        Adapter    "mihome-airpurifier": 0.0.6
                        Adapter    "mihome-lamp"   : 1.1.0
                        Adapter    "mihome-plug"   : 0.2.0
                        Adapter    "mihome-vacuum" : 1.1.5
                        Adapter    "miio"          : 0.0.13
                        Adapter    "mikrotik"      : 1.0.4
                        Adapter    "milight"       : 0.3.6
                        Adapter    "milight-smart-light": 0.2.7
                        Adapter    "mobile"        : 0.5.0
                        Adapter    "modbus"        : 3.0.0
                        Adapter    "moma"          : 1.2.2
                        Adapter    "mpd"           : 1.0.2
                        Adapter    "mqtt"          : 2.1.1    , installed 2.1.1
                        Adapter    "mqtt-client"   : 1.1.1
                        Adapter    "multicast"     : 0.1.1
                        Adapter    "musiccast"     : 0.1.2
                        Adapter    "mysensors"     : 2.0.0
                        Adapter    "nanoleaf-lightpanels": 0.8.2
                        Adapter    "nello"         : 2.0.8
                        Adapter    "netatmo"       : 1.3.1
                        Adapter    "nibeuplink"    : 0.2.2
                        Adapter    "nina"          : 0.0.13
                        Adapter    "node-red"      : 1.12.0
                        Adapter    "nuki"          : 1.0.7
                        Adapter    "nuki2"         : 1.0.4
                        Adapter    "nut"           : 1.1.3
                        Adapter    "oilfox"        : 0.0.7
                        Adapter    "onkyo"         : 2.0.3
                        Adapter    "onvif"         : modified
                        Adapter    "openhab"       : 1.1.0
                        Adapter    "opentherm"     : 0.1.9
                        Adapter    "openweathermap": modified
                        Adapter    "opi"           : 0.1.1    , installed 0.1.1
                        Adapter    "oppoplayer"    : 0.2.1
                        Adapter    "owfs"          : 0.6.1
                        Adapter    "owntracks"     : 0.6.2
                        Adapter    "panasonic-viera": 1.0.2
                        Adapter    "parser"        : 1.0.7
                        Adapter    "paw"           : 0.3.2
                        Adapter    "phantomjs"     : 1.0.1
                        Adapter    "pi-hole"       : 1.2.1
                        Adapter    "piface"        : 1.0.0
                        Adapter    "pimatic"       : 0.1.5
                        Adapter    "ping"          : 1.3.2
                        Adapter    "places"        : 0.7.0
                        Adapter    "plex"          : 0.6.0
                        Adapter    "plexconnect"   : 0.0.7
                        Adapter    "pollenflug"    : 1.0.3
                        Adapter    "primelab"      : 1.0.2
                        Adapter    "proxmox"       : 0.5.1
                        Adapter    "proxy"         : 1.1.1
                        Adapter    "pushbullet"    : 0.0.11
                        Adapter    "pushover"      : 1.1.1    , installed 1.1.1
                        Adapter    "pushsafer"     : 0.1.8
                        Adapter    "radar2"        : 1.0.9
                        Adapter    "radiohead"     : 1.0.2
                        Adapter    "rflink"        : 2.0.0
                        Adapter    "rickshaw"      : 1.0.0
                        Adapter    "ring"          : 1.0.5
                        Adapter    "roadtraffic"   : 0.0.2
                        Adapter    "roomba"        : 1.0.7
                        Adapter    "rpi2"          : 1.1.1
                        Adapter    "s7"            : 1.1.4
                        Adapter    "samsung"       : 0.2.9
                        Adapter    "sayit"         : 1.8.2
                        Adapter    "sbfspot"       : 2.3.2
                        Adapter    "scenes"        : 1.1.0
                        Adapter    "schoolfree"    : 0.2.2
                        Adapter    "shelly"        : 3.1.1    , installed 3.1.1
                        Adapter    "shuttercontrol": 0.3.2
                        Adapter    "sia"           : 1.0.3
                        Adapter    "siegenia"      : 1.0.0
                        Adapter    "simple-api"    : 2.3.1    , installed 2.3.1
                        Adapter    "sma-em"        : 0.5.3
                        Adapter    "smappee"       : 0.2.2
                        Adapter    "smartmeter"    : 1.2.2
                        Adapter    "snips"         : 1.5.0
                        Adapter    "snmp"          : 0.5.0
                        Adapter    "socketio"      : 2.1.2    , installed 2.1.2
                        Adapter    "solarlog"      : 0.1.5
                        Adapter    "solarwetter"   : 1.0.0
                        Adapter    "sonnen"        : 1.3.0
                        Adapter    "sonoff"        : 2.2.2
                        Adapter    "sonos"         : 2.0.0
                        Adapter    "sonus"         : 0.1.1
                        Adapter    "sony-bravia"   : 1.0.1
                        Adapter    "sourceanalytix": 0.2.5
                        Adapter    "spotify-premium": 1.0.0
                        Adapter    "sql"           : 1.9.5
                        Adapter    "squeezebox"    : 1.0.0
                        Adapter    "squeezeboxrpc" : 0.8.18
                        Adapter    "starline"      : 1.0.0
                        Adapter    "statistics"    : 0.2.2
                        Adapter    "stiebel-isg"   : 1.4.7
                        Adapter    "synology"      : 0.0.4
                        Adapter    "systeminfo"    : 0.2.2
                        Adapter    "tankerkoenig"  : 2.0.6
                        Adapter    "telegram"      : 1.4.3    , installed 1.4.3
                        Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                        Adapter    "text2command"  : 1.3.0
                        Adapter    "tileboard"     : modified
                        Adapter    "tinker"        : 0.1.4
                        Adapter    "tr-064"        : 0.4.18
                        Adapter    "tradfri"       : 2.4.4
                        Adapter    "tunnelbroker-endpoint-updater": modified
                        Adapter    "tuya"          : 3.0.0
                        Adapter    "tvspielfilm"   : 1.0.4
                        Adapter    "unifi"         : 0.3.1
                        Adapter    "upnp"          : 1.0.14
                        Adapter    "valloxmv"      : 1.0.0
                        Adapter    "vcard"         : 0.0.9
                        Adapter    "viessmann"     : 1.2.2
                        Adapter    "viessmannapi"  : 1.3.2
                        Adapter    "virtualpowermeter": 1.0.1
                        Adapter    "vis"           : 1.2.1    , installed 1.2.1
                        Adapter    "vis-bars"      : 0.1.4
                        Adapter    "vis-canvas-gauges": 0.1.5
                        Adapter    "vis-colorpicker": 1.1.1   , installed 1.1.1
                        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                        Adapter    "vis-google-fonts": 0.1.0
                        Adapter    "vis-history"   : 1.0.0
                        Adapter    "vis-hqwidgets" : 1.1.2    , installed 1.1.2
                        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                        Adapter    "vis-justgage"  : 1.0.1
                        Adapter    "vis-keyboard"  : 0.0.2
                        Adapter    "vis-lcars"     : 1.0.4
                        Adapter    "vis-map"       : 1.0.2
                        Adapter    "vis-material"  : 0.1.3
                        Adapter    "vis-metro"     : 1.1.2
                        Adapter    "vis-players"   : 0.1.5
                        Adapter    "vis-plumb"     : 1.0.2
                        Adapter    "vis-rgraph"    : 0.0.2
                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                        Adapter    "vis-weather"   : 2.3.0
                        Adapter    "vr200"         : 1.0.0
                        Adapter    "weatherunderground": 3.1.3
                        Adapter    "web"           : 2.4.5    , installed 2.4.5
                        Adapter    "wetty"         : 0.1.1
                        Adapter    "wiffi-wz"      : 2.1.4
                        Adapter    "wifilight"     : 0.2.0
                        Adapter    "wlanthermo-nano": 0.1.1
                        Adapter    "wm-bus"        : 0.3.1
                        Adapter    "wolf"          : 0.9.2
                        Adapter    "worx"          : 0.4.0
                        Adapter    "xbox"          : 0.5.8
                        Adapter    "xs1"           : 1.0.2
                        Adapter    "yahka"         : 0.9.2
                        Adapter    "yamaha"        : 0.3.19
                        Adapter    "yeelight-2"    : 1.0.1
                        Adapter    "yr"            : 2.0.3
                        Adapter    "zigbee"        : 0.11.3
                        Adapter    "zont"          : 0.5.3
                        Adapter    "zwave"         : 1.6.3
                        Adapter    "zwave2"        : 0.1.3
                        pi@iobrocker:/opt/iobroker $ sudo iobroker upgrade self
                        Update js-controller from @1.5.14 to @2.0.29
                        NPM version: 6.12.0
                        npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                        npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
                        npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                        npm ERR! code EINTEGRITY
                        npm ERR! errno EINTEGRITY
                        npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/y18n: Integrity verification failed for sha512-nT7014PDaWpa3jrXmq1tS07aiudLEjWmD1iEbLzOxO/4+6DMqVptZ1Scz5PnnN/haHCZTAmWOMNvHKfY32wv9A== (/home/iobroker/.npm/_cacache/content-v2/sha512/9d/3e/f4d783c3696a5ade3ad79aad6d4b4eda8ae74b1235a60f58846cbccec4eff8fba0cca95a6d67549ccf93e79cdfe16870994c099638c36f1ca7d8df6c2ff4)
                        npm ERR!     /home/iobroker/.npm/_logs/2019-10-14T12_19_41_959Z-debug.log
                        Host "iobrocker" (linux) updated
                        Execute: chmod -R 777 /opt/iobroker
                        Chmod finished. Restart controller
                        Starting node restart.js
                        apollon77A AlCalzoneA 2 Antworten Letzte Antwort
                          freaktech
                          #72
                          @apollon77
                          mehr als was ich gepostet habe passiert nicht
                          • F freaktech
                            Index entries: 0
                            Finished in 0.067s
                                whoami
                                /home/pi/.npmrc
                            Did you mean this?
                                cache
                            Index entries: 0
                            Finished in 0.067s
                            update done
                            NPM version: 6.12.0
                            apollon77A Online
                            apollon77A Online
                            #73
                            @freaktech
                            Now we come closer. Please reinstall iobroker.hue
                            cd /opt/iobroker
                            npm install iobroker.hue
                            iobroker upload hue
                            • F Offline
                              freaktech
                              schrieb am zuletzt editiert von freaktech
                              #74
                              gemacht
                              pi@iobrocker:/opt/iobroker $ npm install iobroker.hue
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              + iobroker.hue@2.0.0
                              updated 1 package and audited 6689 packages in 20.17s
                              found 70 vulnerabilities (50 low, 1 moderate, 19 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                              pi@iobrocker:/opt/iobroker $ iobroker upload hue
                              got /opt/iobroker/node_modules/iobroker.hue/admin
                              upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                              upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                              upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                              upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                              upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                              Update "system.adapter.hue.0"
                              aber die Probleme mit den Adaptern bleiben
                              ost.iobrocker	2019-10-14 14:30:11.940	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              host.iobrocker	2019-10-14 14:30:11.940	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              host.iobrocker	2019-10-14 14:30:11.939	error	Caught by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:30:07.300	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              host.iobrocker	2019-10-14 14:30:07.300	error	Caught by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              host.iobrocker	2019-10-14 14:30:07.299	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              host.iobrocker	2019-10-14 14:30:07.299	error	Caught by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:30:01.683	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:30:01.683	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:30:01.682	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:30:01.681	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:30:01.681	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:30:01.670	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:30:00.129	error	instance system.adapter.shelly.0 terminated with code 156 ()
                              host.iobrocker	2019-10-14 14:29:57.192	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:57.192	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:57.189	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:57.189	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:57.189	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:53.570	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:53.570	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:53.569	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:53.568	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:49.899	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:49.899	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:49.899	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:49.899	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:49.898	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:49.897	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:49.834	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              hue.0	2019-10-14 14:29:49.834	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              hue.0	2019-10-14 14:29:49.834	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              hue.0	2019-10-14 14:29:49.834	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              hue.0	2019-10-14 14:29:49.834	error	at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              hue.0	2019-10-14 14:29:49.834	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              hue.0	2019-10-14 14:29:49.834	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              hue.0	2019-10-14 14:29:49.834	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              hue.0	2019-10-14 14:29:49.834	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              hue.0	2019-10-14 14:29:49.834	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              hue.0	2019-10-14 14:29:49.834	error	TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:49.833	error	uncaught exception: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:47.958	error	instance system.adapter.js2fs.0 terminated with code 1 ()
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
                              Caught	2019-10-14 14:29:47.958	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:79:20)
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: TypeError: fns.adapter is not a function
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: ^
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: fns.adapter = fns.adapter(options);
                              Caught	2019-10-14 14:29:47.957	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                              host.iobrocker	2019-10-14 14:29:46.020	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:46.020	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:46.020	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:46.019	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:46.019	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:46.018	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:42.288	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:42.288	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:42.288	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:42.287	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:42.286	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:38.610	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:38.610	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:38.609	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:38.609	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:38.609	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:38.609	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:38.531	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              hue.0	2019-10-14 14:29:38.531	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              hue.0	2019-10-14 14:29:38.531	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              hue.0	2019-10-14 14:29:38.531	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              hue.0	2019-10-14 14:29:38.531	error	at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              hue.0	2019-10-14 14:29:38.531	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              hue.0	2019-10-14 14:29:38.531	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              hue.0	2019-10-14 14:29:38.531	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              hue.0	2019-10-14 14:29:38.531	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              hue.0	2019-10-14 14:29:38.531	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              hue.0	2019-10-14 14:29:38.531	error	TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:38.531	error	uncaught exception: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:34.854	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:34.854	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:34.853	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:34.852	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              opi.0	2019-10-14 14:29:33.825	error	No Value found for memory_available
                              opi.0	2019-10-14 14:29:33.820	error	No Value found for cpu_frequency
                              host.iobrocker	2019-10-14 14:29:31.068	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:31.068	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:31.067	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:31.067	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:27.315	error	instance system.adapter.hue.0 terminated with code 0 (OK)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              Caught	2019-10-14 14:29:27.315	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              Caught	2019-10-14 14:29:27.314	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              Caught	2019-10-14 14:29:27.314	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              Caught	2019-10-14 14:29:27.314	error	by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              Caught	2019-10-14 14:29:27.314	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              Caught	2019-10-14 14:29:27.314	error	by controller[0]: TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:27.251	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                              hue.0	2019-10-14 14:29:27.251	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              hue.0	2019-10-14 14:29:27.251	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                              hue.0	2019-10-14 14:29:27.251	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                              hue.0	2019-10-14 14:29:27.251	error	at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
                              hue.0	2019-10-14 14:29:27.251	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
                              hue.0	2019-10-14 14:29:27.251	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
                              hue.0	2019-10-14 14:29:27.251	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5289:62)
                              hue.0	2019-10-14 14:29:27.251	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                              hue.0	2019-10-14 14:29:27.251	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                              hue.0	2019-10-14 14:29:27.251	error	TypeError: Bottleneck is not a constructor
                              hue.0	2019-10-14 14:29:27.251	error	uncaught exception: Bottleneck is not a constructor
                              host.iobrocker	2019-10-14 14:29:26.446	error	Cannot download adapter "ring@1.0.5". To restart it disable/enable it or restart host.
                              host.iobrocker	2019-10-14 14:29:25.946	error	Cannot download adapter "ring@1.0.5". To restart it disable/enable it or restart host.
                              host.iobrocker	2019-10-14 14:29:25.446	error	Cannot download adapter "ring@1.0.5". To restart it disable/enable it or restart host.
                              host.iobrocker	2019-10-14 14:29:24.945	error	Cannot download adapter "ring@1.0.5". To restart it disable/enable it or restart host.
                              iobroker	2019-10-14 14:29:23.928	error	Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                              iobroker	2019-10-14 14:29:23.894	error	host.iobrocker Adapter directory "null" does not exists
                              NPM version: 6.12.0
                              npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/get-caller-file: Integrity verification failed for sha512-IfwTILdYjp+Ukq2yLXk0yAqHSiUGHzUpHmnejtSMhGVNEMp+9NYf8fvPGycAdHHx+r64IPSjnRM4gc/DFuCbNw== (/home/iobroker/.npm/_cacache/content-v2/sha512/21/fc/1320b7588e9f9492adb22d7934c80a874a25061f35291e69de8ed48c84654d10ca7ef4d61ff1fbcf1b27007471f1fabeb820f4a39d133881cfc316e09b37)
                              npm ERR!     /home/iobroker/.npm/_logs/2019-10-14T12_33_53_854Z-debug.log
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/lib': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/lib/hueHelper.js': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/package.json': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/instruction.png': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/index_m.html': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/index.html': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/words.js': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/main.js': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/LICENSE': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/modules.xml': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/ioBroker.hue.iml': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/vcs.xml': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/misc.xml': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/workspace.xml': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/io-package.json': Die Operation ist nicht erlaubt
                              chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/README.md': Die Operation ist nicht erlaubt
                              • F Offline
                                freaktech
                                #75
                                ich befürchte ich muss dann mit einer neuen SD card starten
                                aber diese löschen ist mir zu gefährlich
                                • F freaktech
                                  Index entries: 0
                                  Finished in 0.067s
                                      whoami
                                      /home/pi/.npmrc
                                  Did you mean this?
                                      cache
                                  Index entries: 0
                                  Finished in 0.067s
                                  update done
                                  NPM version: 6.12.0
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #76
                                  Ahh, ich glaub ich weiß was los ist!
                                  Das ist der Cache für den User pi. Es scheint aber dein Cache für den User iobroker defekt zu sein.
                                  Bitte führe folgendes aus:
                                  sudo -H -u iobroker npm cache verify
                                  Die Ausgabe davon dürfte interessant sein.
                                  • F Offline
                                    freaktech
                                    #77
                                    gerne
                                    pi@iobrocker:/opt/iobroker $ sudo -H -u iobroker npm cache verify
                                    Content verified: 2236 (238151167 bytes)
                                    Corrupted content removed: 6
                                    Content garbage-collected: 320 (25315666 bytes)
                                    Missing content: 6
                                    Index entries: 3784
                                    Finished in 38.938s
                                    • F freaktech
                                      gerne
                                      Missing content: 6
                                      Index entries: 3784
                                      Finished in 38.938s
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #78
                                      Bingo!
                                      Magst du noch ein weiteres mal iobroker upgrade self probieren? Bitte auch wieder die Ausgabe posten.
                                        Bingo!
                                        freaktech
                                        #79
                                        @AlCalzone
                                        anbei
                                        pi@iobrocker:/opt/iobroker $ iobroker upgrade self
                                        NPM version: 6.12.0
                                        In file included from ../src/unix_dgram.cc:5:
                                        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                        ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                        ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
                                        ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                                             argv);
                                        ../../nan/nan.h:1024:46: note: declared here
                                           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                                                             argv);
                                        ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
                                        ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                                             0, NULL);
                                                             0, NULL);
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           domain      = info[0]->Int32Value();
                                        In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,
                                                         from /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:63,
                                                         from ../../nan/nan.h:54,
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here
                                           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                           declarator __attribute__((deprecated(message)))
                                        ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           type        = info[1]->Int32Value();
                                        ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           protocol    = info[2]->Int32Value();
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           fd = info[0]->Int32Value();
                                        ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                           String::Utf8Value path(info[1]);
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2892:28: note: declared here
                                                           explicit Utf8Value(Local<v8::Value> obj));
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           buf = info[1]->ToObject();
                                        In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:63,
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:10046:15: note: declared here
                                         Local<Object> Value::ToObject() const {
                                        ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           offset = info[2]->Uint32Value();
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2477:47: note: declared here
                                           V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                                        ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           length = info[3]->Uint32Value();
                                        ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                           String::Utf8Value path(info[4]);
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        In file included from ../../nan/nan.h:54,
                                        ../src/unix_dgram.cc: At global scope:
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:570:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                               (node::addon_register_func) (regfunc),                          \
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:604:3: note: in expansion of macro ‘NODE_MODULE_X’
                                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                        ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
                                         NODE_MODULE(unix_dgram, Initialize)
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/node_object_wrap.h:85:78:   required from here
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                                        reinterpret_cast<Callback>(callback), type);
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                                        ../../nan/nan_object_wrap.h:65:61:   required from here
                                        /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/chokidar/node_modules/fsevents):
                                        • F freaktech
                                          @AlCalzone
                                          anbei
                                          NPM version: 6.12.0
                                                               argv);
                                                               argv);
                                                               0, NULL);
                                                               0, NULL);
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #80
                                          @freaktech Sieht an sich gut aus. Gibt iobroker -v jetzt endlich die neue Version aus?
