  4. [gelöst] Adapterinstallation - node gyp error
node-pre-gyp erradapter installationinstallation
47 Beiträge 6 Kommentatoren 8.3k Aufrufe 5 Beobachtet
  • sigi234S sigi234
    @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
    EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
    einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash -
    Sundance
    @sigi234 Danke, Das hat das "permission denied" Problem behoben - aber den Rest leider nicht..
    root@HOME:/opt/iobroker# iobroker install iobroker.roomba
    NPM version: 6.9.0
    npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
    ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data > imgdOffset, "image data overlaps with another structure");
    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
     #define E(cond, msg) if(cond) return setErr(msg)
    ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data + imgdSize > len, "not enough image data");
    ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_x = abs(transforms[1]);
    In file included from /usr/include/c++/6/cstdlib:75:0,
                     from /usr/include/c++/6/ext/string_conversions.h:41,
                     from /usr/include/c++/6/bits/basic_string.h:5417,
                     from /usr/include/c++/6/string:52,
                     from /usr/include/c++/6/stdexcept:39,
                     from /usr/include/c++/6/array:39,
                     from /usr/include/c++/6/tuple:39,
                     from /usr/include/c++/6/functional:55,
                     from /usr/include/c++/6/memory:79,
                     from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                     from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
                     from ../../nan/nan.h:54,
                     from ../src/backend/Backend.h:6,
                     from ../src/Canvas.h:5,
                     from ../src/CanvasRenderingContext2d.h:6,
                     from ../src/CanvasRenderingContext2d.cc:3:
    /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
     extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
    In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
    /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
       abs(long long __x) { return __builtin_llabs (__x); }
    /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
       abs(long __i) { return __builtin_labs(__i); }
    ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_y = abs(transforms[2]);
    make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.57-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v10.16.2
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.57-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v10.16.2
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.5.0 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_06_49_697Z-debug.log
    host.HOME Adapter directory "null" does not exists
    Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    Gibt es außer einer kompletten Neuinstallation noch irgendwas, was ich testen könnte?
    Danke und beste grüße
    Sundance
    • S Sundance
      NPM version: 6.9.0
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      Sundance
      sigi234S Online
      sigi234S Online
      sigi234
      @Sundance
      Was sagt :
      node -v
      npm -v
      iobroker list instances
      Immer Daten sichern!
      • sigi234S sigi234
        @Sundance
        Was sagt :
        node -v
        npm -v
        Sundance
        @sigi234
        Hier die drei Ausgaben:
        pi@HOME:~ $ node -v
        v10.16.2
        pi@HOME:~ $ npm -v
        6.9.0
        pi@HOME:~ $ iobroker list instances
        + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.cloud.0                 : cloud       - disabled
        + system.adapter.discovery.0             : discovery   -  enabled
          system.adapter.ham.0                   : ham         -  enabled
        + system.adapter.history.0               : history     -  enabled
        + system.adapter.hm-rega.0               : hm-rega     -  enabled
        + system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
        + system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
        + system.adapter.hue.0                   : hue         -  enabled, port: 80
          system.adapter.info.0                  : info        -  enabled
          system.adapter.iot.0                   : iot         - disabled
        + system.adapter.javascript.0            : javascript  -  enabled
          system.adapter.mobile.0                : mobile      - disabled
          system.adapter.node-red.0              : node-red    -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.sayit.0                 : sayit       -  enabled, port: 0
          system.adapter.sonos.0                 : sonos       -  enabled
          system.adapter.tr-064.0                : tr-064      -  enabled
        + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.web.1                   : web         -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.zigbee.0                : zigbee      -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019366630-if00
        + instance is alive
        • S Sundance
          @sigi234
          pi@HOME:~ $ node -v
          v10.16.2
          pi@HOME:~ $ npm -v
          6.9.0
          + instance is alive
          sigi234S Online
          sigi234S Online
          sigi234
          @Sundance
          Das passt Alles, ioBroker neu starten......
          • sigi234S sigi234
            @Sundance
            Sundance
            @sigi234 Habe ich gemacht - Installation nochmal versucht, gleiche Fehler wie vorher.. Gibt es noch etwas, was ich versuchen kann?
            Danke vorab für deine Hilfe!
            • S Sundance
              sigi234S Online
              sigi234S Online
              sigi234
              Was für welcher ? Was geht nicht, bzw. funktioniert nicht?
              In den Admin kommst du normal rein?
              • sigi234S sigi234
                Sundance
                schrieb am zuletzt editiert von Sundance
                @sigi234
                Hier der aktuelle Fehler-output aus dem Terminal:
                pi@HOME:~ $ iobroker install iobroker.roomba
                NPM version: 6.9.0
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_17_48_762Z-debug.log
                In Admin komme ich normal rein, dort funktioniert auch alles wunderbar - allerdings hatte die Installation über Admin nie geklappt, daher habe ich es nun immer über die Konsole probiert. Leider bisher ohne Erfolg..
                Habe es hier zwar als user "Pi" installiert - per root kommen aber die gleichen fehler.
                • S Sundance
                  @sigi234
                  NPM version: 6.9.0
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                  sudo npm install canvas --unsafe-perm=true
                  • sigi234S sigi234
                    Sundance
                    @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
                    Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
                    pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                    Reading package lists... Done
                    Building dependency tree
                    build-essential is already the newest version (12.3).
                    libgif-dev is already the newest version (5.1.4-0.4).
                    libjpeg-dev is already the newest version (1:1.5.1-2).
                    libpango1.0-dev is already the newest version (1.40.5-1).
                    librsvg2-dev is already the newest version (2.40.16-1).
                    libcairo2-dev is already the newest version (1.14.8-1+rpi1).
                    0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
                    Und bei canvas:
                    pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
                    > canvas@2.5.0 install /home/pi/node_modules/canvas
                    make: Entering directory '/home/pi/node_modules/canvas/build'
                      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                      COPY Release/canvas-postbuild.node
                      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                      CXX(target) Release/obj.target/canvas/src/Backends.o
                      CXX(target) Release/obj.target/canvas/src/Canvas.o
                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                     from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                                     from /root/.node-gyp/10.16.2/include/node/node.h:63,
                    canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
                    make: Leaving directory '/home/pi/node_modules/canvas/build'
                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                    gyp ERR! cwd /home/pi/node_modules/canvas
                    gyp ERR! not ok
                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                    node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                    node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                    npm WARN pi No description
                    npm WARN pi No repository field.
                    npm WARN pi No README data
                    npm WARN pi No license field.
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
                    • S Sundance
                      Und bei canvas:
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      Kommt das gleiche wenn du es über den Admin installierst?
                      Gerade bei mir mal installiert:
                      • sigi234S sigi234
                        Sundance
                        @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
                        $ ./iobroker add roomba  --host HOME
                        NPM version: 6.9.0
                        node-pre-gyp
                        node-pre-gyp
                         WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
                        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                        ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                        ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
                        ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                        In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                        ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                        make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
                        gyp
                         ERR! build error
                        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        gyp ERR! not ok
                        node-pre-gyp
                         ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                        node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
                        ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        node-pre-gyp
                         ERR! not ok
                        npm
                        npm
                        WARN
                         optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm ERR! code ELIFECYCLEnpm ERR! errno 1
                        npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
                        npm ERR!
                        npm
                         ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
                        host.HOME install adapter roomba
                        NPM version: 6.9.0
                        node-pre-gyp
                        node-pre-gyp
                         WARN
                        In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
                        /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
                        ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
                        gyp ERR!
                        build error
                        gyp
                        gyp ERR!
                        stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                        gyp ERR! System Linux 4.19.57-v7+gyp
                        gyp
                        ERR! node-gyp -v v3.8.0gyp ERR! not ok
                        node-pre-gyp
                         ERR! build error
                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                         ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                        node-pre-gyp
                         ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
                        npm
                        npm
                         WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
                        npm
                        npm
                        ERR!
                        errno
                         1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
                        npm ERR!
                        npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
                        NPM version: 6.9.0
                        node-pre-gyp
                        node-pre-gyp
                         WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                        gyp
                        ERR!
                        build error
                        gyp
                        gyp ERR!
                        stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
                         ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                        gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
                        gyp ERR!
                        node-pre-gyp
                         ERR! build error
                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                        node-pre-gyp
                        node-pre-gyp ERR!
                        node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                        npm
                        npm
                        WARN
                        npm
                        WARN
                        notsup
                        npm
                        npm
                        ERR! errno
                        npm
                        npm ERR!
                        npm ERR!
                        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
                        ERROR: host.HOME Cannot install roomba
                        ERROR: process exited with code 13
                        • Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          Error 404 wundert mich.
                          Finde nur die Version 2.6.0.
                          Falscher Link ?
                          • Ralla66R Ralla66
                            Falscher Link ?
                            Sundance
                            @Ralla66 Stimmt.. der Link hier müsste es wohl sein laut repo:
                            https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                            Da ist im link ein "ARM" zu viel.. aber passt die Version dann überhaupt noch? Was müsste ich anpassen, damit ich es installieren kann?
                            • Ralla66R Offline
                              Ralla66R Offline
                              Ralla66
                              Der Link geht ja, versuch über die URL zu installieren.
                              • Ralla66R Ralla66
                                Sundance
                                @Ralla66 das scheint nicht zu klappen:
                                $ ./iobroker url "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz" --debug
                                install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                                npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz --production --save --prefix "/opt/iobroker" (System call)
                                npm
                                 ERR! code ENOPACKAGEJSON
                                npm
                                ERR!
                                package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz.npm
                                 ERR! package.json
                                 npm can't find a package.json file in your current directory.
                                npm
                                npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T13_53_17_665Z-debug.log
                                process exited with code 0
                                • Ralla66R Offline
                                  Ralla66R Offline
                                  Ralla66
                                  Da kann ich nicht mehr weiter helfen.
                                  Dir scheint ein package.json file zu fehlen oder liegt im falschen directory.
                                    Sundance
                                    @Ralla66 - okay, dann gebe ich mich erstmal geschlagen! Danke trotzdem für deine Hilfe!
                                    • ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      Installier mal canvas 2.6
                                      Meine Adapter: https://zefau.github.io/iobroker/
                                      • ZefauZ Zefau
                                        Sundance
                                        @Zefau - danke für den hinweis. hast du einen Tipp wo und wie genau ich das installieren soll? Der Fehler mit "package.json" kommt leider auch bei dem entsprechendem Link von der 2.6 Version..
                                        Ich habe als root einfach folgendes gemacht:
                                        npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                                        Aber der Fehler mit dem package.json bleibt:
                                        root@HOME:/home/pi# npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                                        npm ERR! code ENOPACKAGEJSON
                                        npm ERR! package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz.
                                        npm ERR! package.json npm can't find a package.json file in your current directory.
                                        npm ERR!     /root/.npm/_logs/2019-08-08T16_25_34_957Z-debug.log
                                        Hast du einen Tipp?
                                        • ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          schrieb am zuletzt editiert von Zefau
                                          Sorry, war noch unterwegs, daher die knappe Antwort.
                                          Hast du die build-essentials installiert?
                                          Danach dann einfach canvas 2.6.0 von npm:
                                          sudo npm install canvas@2.6.0 --unsafe-perm=true
                                          EDIT: den zweiten Befehl im iobroker.roomba Ordner ausführen. Also unter /opt/iobroker/node_modules/iobroker.roomba.
                                          EDIT2: Hab jetzt den Verlauf nicht komplett gelesen, aber die fehlende package.json liegt daran, dass du in einem völlig falschen Ordner bist (/home/pi?). Die Befehle müssen im iobroker.roomba Ordner ausgeführt werden, wenn diese dafür greifen sollen.
