  5. Fenster und andere Geräte zählen opt. Alexa Ansagen
    5.1k
blocklyjavascript
1.2k Beiträge 41 Kommentatoren 486.0k Aufrufe 71 Beobachtet
  • S sandro_gera
    @dslraser
    Hallo ich habe gerade nach dem folgenden Alias Skript meine Aliasse erstellen wollen.
    Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
       			Changelog
    Version 1.1.4
    - fix error by using bCreateAliasPath and bConvertExistingPath (has no target 9/Error creating alias-path)
       	Flags /
       	Variablen
    // typeAlias = 'boolean'; // oder 'number'
    // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
    // write = "val ? 'Ein' : 'Aus'";
    // nameAlias = 'Licht Haustür';
    // role = 'switch';
    // desc = 'per Script erstellt';
    // min = 0; // nur Zahlen
    // max = 100; // nur Zahlen
    // unit = '%'; // nur für Zahlen
    // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
    let bCreateAliasPath = true;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
    Requirements: bCreateAliasPath == true
    If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
    let bConvertExistingPath = false;
       	Don't change anything from here /
       	Ab hier nichts verändern
    let arEnum = [];
    let arId = [];
    let timeoutAssignEnum;
    var callbackAlias = undefined;
    function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
     if(!idDst.includes('alias.0.'))
         idDst = 'alias.0.' + idDst;
     if(!existsObject(idSrc))
         log('Source-Id ' + idSrc +' does not exists.','warn');
         return;
     // Create the object Path for alias id,
     // so you can assign rooms and function to the parents
     var createAliasPath = (id) => {
          if(bCreateAliasPath){
               let lisMergedIds = [];
               let mergedId = 'alias.0';
               id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
               let split = id.split('.');
               for(let i=0;i<split.length-1;i++){
                   mergedId += '.' + split[i];
                   lisMergedIds.push(mergedId);
               function path(){
                   if(lisMergedIds.length == 0) {
                       alias();
                       return;
                   let tmpId = lisMergedIds[0];
                   lisMergedIds.splice(0,1); // remove element
                   if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                       let obj;
                       if(existsObject(tmpId))
                           obj = getObject(tmpId);
                       else
                           obj = {};
                       let bApply = false;
                       if(obj != undefined){
                           if(obj.type == undefined || String(obj.type) != 'meta'){
                               obj.type = 'meta';
                               bApply = true;
                           if(obj.common == undefined){
                               obj.common = {};
                               obj.common.type = 'meta.folder';
                               bApply = true;
                           else if(obj.common.type == undefined || String(obj.common.type) != 'meta.folder'){
                               bApply = true;
                           if(obj.native == undefined){
                               obj.native = {};
                               bApply = true;
                       else{
                           path();
                           log('Object is undefined');
                           return;
                       if(bApply){
                           setObject(tmpId, obj, (err) =>{
                           if(!err){
                               log('Created Alias-Path ' + tmpId);
                               path();
                           else
                               log('Error creating alias-path','error');
                       else
                           path();
               path();
          else
            alias();
     function alias(){
         // Create alias object
           if(!existsObject(idDst)){
               let obj = {};
               obj.type = 'state';
               obj.common = getObject(idSrc).common;
               obj.common.alias = {};
               obj.common.alias.id = idSrc;
               if(typeAlias !== undefined)
                   obj.common.type = typeAlias;
               if(obj.common.read !== undefined)
                   obj.common.alias.read = read;
               if(obj.common.write !== undefined)
                   obj.common.alias.write = write;
               if(nameAlias !== undefined)
                   obj.common.name = nameAlias;
               if(role !== undefined)
                   obj.common.role = role;
               if(desc !== undefined)
                   obj.common.desc = desc;
               if(min !== undefined)
                   obj.common.min = min;
               if(max !== undefined)
                   obj.common.max = max;
               if(unit !== undefined)
                   obj.common.unit = unit;
               if(states !== undefined)
                   obj.common.states = states;
               obj.native = {};
               obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
               log('Created Alias-State ' + idDst);
               setObject(idDst, obj,(err) =>{
                   if(!err)
                       startAttach();
                   else
                       log('Error creating-alias','error');
           else
               startAttach();
     // Save ID and Enum (room or function)
     var attach = (id, enu,value) => {
         if(id.length == 0){
             log('ID has lenght 0, can not attach to enum','warn');
             return;
         if(value.length == 0){
             log('Value has lenght 0','warn');
             return;
         let sEnuId = 'enum.' + enu + '.' + value;
         if(enu.length > 0 && existsObject(sEnuId))
             let obj = getObject(sEnuId)
             let members = obj.common.members;
             if(!members.includes(id)){
                 arEnum.push(sEnuId);
                 arId.push(id);
         else
      	      log('Can not find enum ' + sEnuId,'warn');
    function startAttach(){
       let bRoom = raum !== undefined && raum.length > 0;
       let bGewerk = gewerk !== undefined && gewerk.length > 0;
       if(bRoom)
           attach(idDst,'rooms',raum);
       if(bGewerk)
           attach(idDst,'functions',gewerk);
       if(bRoom || bGewerk){
               if(timeoutAssignEnum){
                   clearTimeout(timeoutAssignEnum);
                   timeoutAssignEnum = null;
               timeoutAssignEnum = setTimeout(finishScript,100);
     createAliasPath(idDst);
    function finishScript(){
       assignEnums();
    // Add the saved IDs to the rooms/functions
    function assignEnums(){
    if(arEnum.length == 0 || arId.length == 0){
         return;
    if(arEnum.length != arId.length){
         log('Arrays have different size','error');
         return;
    let mapEnumId = new Map();
    for(let i=0;i < arEnum.length; i++){
        let enu = arEnum[i];
        let id = arId[i];
        if(existsObject(id)){
       	 let obj = getObject(enu)
       	 let members;
       	 if(!mapEnumId.has(enu)){
       		 mapEnumId.set(enu,members);
       	 else
       		 members = mapEnumId.get(enu);
       		  log("Adding " + id + " to " + enu);
       		  members.push(id);
        else
            log('Can not find Alias ' + id,'error');
     function setMembers(members,enu,map){
         let obj = getObject(enu);
         obj.common.members = members;
         setObject(enu,obj);
     mapEnumId.forEach(setMembers);
       	END /
       	ENDE
    //  Fenster
    //2 x Fenstersensoren HMIP
    //einfache HMIP Fenstersensoren über rpc-Adapter in function fenster_alias
    //{0: 'geschlossen', 1: 'geöffnet'}
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Wohnzimmer Fenster links STATE*/, 'Fenster.Wohnzimmer_Fenster_links', undefined, 'fenster_alias', 'number', undefined, undefined, 'Wohnzimmer links', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Küche Fenster links STATE*/, 'Fenster.Kueche_Fenster_links', undefined, 'fenster_alias', 'number',undefined, undefined, 'Küche links', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
    //einfache HM Fenstersensoren über rpc-Adapter in function fenster_alias
    //{false: 'geschlossen', true: 'geöffnet'}
    createAlias('deconz.0.Sensors.7.open'/*Fensterkontakt-Küche open*/, 'Fenster.Fensterkontakt_Kueche', undefined, 'fenster_alias', 'boolean', undefined, undefined, 'Fensterkontakt-Küche', 'window.value', 'per Script erstellt', undefined, undefined, undefined, {false: 'geschlossen', true: 'geöffnet'})
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Küche Fenster links STATE*/, 'Fenster.Kueche_Fenster_links', undefined, 'fenster_alias', 'boolean',undefined, undefined, 'Küche links', 'window.value', 'per Script erstellt', undefined, undefined, undefined, {false: 'geschlossen', true: 'geöffnet'})
    //2 x Fensterdrehgriffe HMIP
    //HMIP Fensterdrehgriffe über rpc-Adapter in function fenster_alias
    //{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'}
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Keller W-Baum Fenster STATE*/, 'Fenster.Keller_Weihnachtsbaum_Fenster', undefined, 'fenster_alias', 'number',undefined, undefined, 'Keller W Baum', 'window.value', 'per Script erstellt', 0, 2, '',{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'})
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Keller Wohnzimmer Fenster mitte STATE*/, 'Fenster.Keller_Wohnzimmer_Fenster_mitte', undefined, 'fenster_alias', 'number',undefined, undefined, 'Keller Wohnzimmer mitte', 'window.value', 'per Script erstellt', 0, 2, '',{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'})
    //2 x Fenster(Türen) Sensoren HMIP
    //einfache HMIP Fenstersensoren über rpc-Adapter in function tueren_alias
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Wohnzimmer Terrassentür STATE*/, 'Tueren.Terrassentuer', undefined, 'tueren_alias', 'number',undefined, undefined, 'Terrassentür', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
    //createAlias('hm-rpc.0.xxx.1.STATE'/*Haustür STATE*/, 'Tueren.Haustuer', undefined, 'tueren_alias', 'number',undefined, undefined, 'Haustür', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
    //  Steckdosen
    //2 x Steckdosen
    //HMIP Steckdosen über rpc-Adapter in function steckdosen_alias
    //{false: 'aus', true: 'an'}
    createAlias('deconz.0.Lights.14.on'/*Steckdosenleiste-Abstellkammer on*/, 'Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Steckdosenleiste-Abstellkammer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.15.on'/*Computer-1-Arbeitszimmer on*/, 'Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Computer-1-Arbeitszimmer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.33.on'/*Computer-2-Arbeitszimmer on*/, 'Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Computer_2_Arbeitszimmer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.31.on'/*Dunstabzugshaube-Küche on*/, 'Steckdosen.Kueche.Dunstabzugshaube_Kueche', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Dunstabzugshaube-Küche', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.13.on'/*Kaffeemaschine-Küche on*/, 'Steckdosen.Kueche.Kaffeemaschine_Kueche', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Kaffeemaschine-Küche', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.12.on'/*Fernseher-Küche on*/, 'Steckdosen.Kueche.Fernseher-Kueche', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Fernseher-Küche', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.7.on'/*Fernseher-Esszimmer on*/, 'Steckdosen.Esszimmer.Fernseher_Esszimmer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Fernseher-Esszimmer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.10.on'/*Media-Wohnzimmer on*/, 'Steckdosen.Wohnzimmer.Media_Wohnzimmer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Media-Wohnzimmer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.8.on'/*Netzteil-Laptop on*/, 'Steckdosen.Wohnzimmer.Netzteil_Laptop', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Netzteil-Laptop', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.11.on'/*Fernseher-Schlafzimmer on*/, 'Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Fernseher-Schlafzimmer', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.30.on'/*Pumpe-Schuppen on*/, 'Steckdosen.Schuppen.Pumpe_Schuppen', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Pumpe-Schuppen', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    //  Bewegungsmelder
    //2 x Bewegungsmelder und 2 x Präsenzmelder und 1 x Erschütterungssensor
    //HMIP Bewegungsmelder und Präsenzmelder über rpc-Adapter in function bewegungsmelder_alias
    //{false: 'inaktiv', true: 'aktiv'}
    //createAlias('hm-rpc.0.xxx.1.MOTION'/*Bewegungsmelder Weihnachtsbaumkeller MOTION*/, 'Bewegungsmelder.Bewegungsmelder_Weihnachtsbaumkeller', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'W Baum Keller', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
    //createAlias('hm-rpc.0.xxx.1.MOTION'/*Bewegungsmelder Heizungskeller MOTION*/, 'Bewegungsmelder.Bewegungsmelder_Heizungskeller', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Heizungskeller', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
    //ab hier 2 x Präsenzmelder
    //createAlias('hm-rpc.0.xxx.1.PRESENCE_DETECTION_STATE'/*Präsenzmelder Badezimmer PRESENCE DETECTION STATE*/, 'Bewegungsmelder.Praesenzmelder_Badezimmer', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Badezimmer', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
    //createAlias('hm-rpc.0.xxx.1.PRESENCE_DETECTION_STATE'/*Präsenzmelder Dusche PRESENCE DETECTION STATE*/, 'Bewegungsmelder.Praesenzmelder_Dusche', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Dusche', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
    //ab hier 1 x Erschütterungssensor
    //createAlias('hm-rpc.0.xxx.1.MOTION'/*Briefkasten MOTION*/, 'Bewegungsmelder.Praesenzmelder_Briefkasten', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Briefkasten', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
    //  Licht
    //2 x HUE und 5 x HMIP Licht über HUE und rpc-Adapter in function licht_alias
    createAlias('deconz.0.Lights.29.on'/*Deckenlampe-Arbeitszimmer on*/, 'Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-Arbeitszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.28.on'/*Wandlampe-Arbeitszimmer on*/, 'Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Wandlampe-Arbeitszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.27.on'/*Deckenlampe-Badezimmer on*/, 'Licht.Badezimmer.Deckenlampe_Badezimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-Badezimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.17.on'/*Deckenlampe-Flur on*/, 'Licht.Flur.Deckenlampe_Flur', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-Flur', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.6.on'/*Lampe-Verteilung on*/, 'Licht.Flur.Lampe_Verteilung', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Lampe-Verteilung', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Shelly-Serienschalter-Bad.POWER1'/*Shelly-Serienschalter-Bad POWER1*/, 'Licht.Bad.Spot_Bad', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Spot-Bad', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Shelly-Serienschalter-Bad.POWER2'/*Shelly-Serienschalter-Bad POWER2*/, 'Licht.Bad.Sternenhimmel_Bad', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Sternenhimmel-Bad', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.20.on'/*Schrank-1-Bad on*/, 'Licht.Bad.Schrank_1_Bad', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Schrank-1-Bad', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.19.on'/*Schrank-2-Bad on*/, 'Licht.Bad.Schrank_2_Bad', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Schrank-2-Bad', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Sonoff-Serienschalter-Küche.POWER1'/*Sonoff-Serienschalter-Küche POWER1*/, 'Licht.Kueche.Deckenlampe_Kueche', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-Küche', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Sonoff-Serienschalter-Küche.POWER2'/*Sonoff-Serienschalter-Küche POWER2*/, 'Licht.Kueche.Lampe_1_Kueche', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Lampe-1-Küche', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.21.on'/*Spüle-Küche on*/, 'Licht.Kueche.Spuele_Kueche', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Spüle-Küche', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.22.on'/*Sitzecke-Küche on*/, 'Licht.Kueche.Sitzecke_Küche', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Sitzecke-Küche', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Sonoff-Serienschalter-Esszimmer.POWER1'/*Sonoff-Serienschalter-Esszimmer POWER1*/, 'Licht.Esszimmer.Deckenlampe_1_Esszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-1-Esszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Sonoff-Serienschalter-Esszimmer.POWER2'/*Sonoff-Serienschalter-Esszimmer POWER2*/, 'Licht.Esszimmer.Deckenlampe_2_Esszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-2-Esszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.23.on'/*Schrank-1-Esszimmer on*/, 'Licht.Esszimmer.Schrank_1_Esszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Schrank-1-Esszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.2.on'/*Schrank-2-Esszimmer on*/, 'Licht.Esszimmer.Schrank_2_Esszimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Schrank-2-Esszimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.24.on'/*Deckenlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Deckenlampe_Wohnzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-Wohnzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.3.on'/*Wandlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Wandlampe_Wohnzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Wandlampe-Wohnzimmer, 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.9.on'/*Deckenfluter-Wohnzimmer on*/, 'Licht.Wohnzimmer.Deckenfluter_Wohnzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenfluter-Wohnzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.1.on'/*Tischlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Tischlampe_Wohnzimmer, undefined, 'licht_alias', 'boolean', undefined, undefined, 'Tischlampe-Wohnzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.5.on'/*Deckenlampe-1-Schlafzimmer on*/, 'Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-1-Schlafzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.26.on'/*Deckenlampe-2-Schlafzimmer on*/, 'Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-2-Schlafzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.25.on'/*Deckenlampe-3-Schlafzimmer on*/, 'Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Deckenlampe-3-Schlafzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('sonoff.0.Lampe-Kellertreppe.POWER'/*Lampe-Kellertreppe POWER*/, 'Licht.Keller.Lampe_Kellertreppe', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Lampe-Kellertreppe', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    createAlias('deconz.0.Lights.18.on'/*Lampen-Schuppen on*/, 'Licht.Schuppen.Lampen-Schuppen', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Lampen-Schuppen', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    //ab hier 2 x Licht HMIP Steckdosen über rpc Adapter
    //createAlias('hm-rpc.0.xxx.3.STATE'/*Kugellampe STATE*/, 'Licht.Wohnzimmer_Kugel_Licht', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Kugellicht', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    //createAlias('hm-rpc.0.xxx.3.STATE'/*Gäste WC Licht STATE*/, 'Licht.Gaeste_WC_Licht', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Gäste WC Licht', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
    //  Temperaturen
    //HMIP 2 x Temperaturen über rpc-Adapter in function temperaturen_alias
    createAlias('hmip.0.devices.3014F711A0000A1A49A53E9E.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Abstellkammer.Temperatur_Abstellkammer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Abstellkammer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A533E3.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Arbeitszimmer.Temperatur_Arbeitszimmer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Arbeitszimmer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A533DC.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Badezimmer.Temperatur_Badezimmer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Badezimmer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A53F7A.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Bad.Temperatur_Bad', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Bad', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A536FD.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Kueche.Temperatur_Kueche', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Küche', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A534C1.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Esszimmer.Temperatur_Esszimmer_1', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Esszimmer-1', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A545DA.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Esszimmer.Temperatur_Esszimmer_2', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Esszimmer-2', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A53500.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Wohnzimmer.Temperatur_Wohnzimmer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Wohnzimmer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A54635.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_1', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Schlafzimmer-1', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    createAlias('hmip.0.devices.3014F711A0000A1A49A533DB.channels.1.valveActualTemperature'/*valveActualTemperature*/, 'Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Schlafzimmer-2', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
    //  Batterien_voll_leer
    //2 x Batterien voll-leer über boolean Wert false/true in function batterien_voll_leer_alias
    createAlias('deconz.0.Sensors.7.battery'/*Fensterkontakt-Küche battery*/, 'Batterien_voll_leer.Fensterkontakt_Kueche', undefined, 'batterien_voll_leer_alias', 'boolean', undefined, undefined, 'Fensterkontakt-Küche', 'indicator.lowbat', 'per Script erstellt', undefined, undefined, undefined, {false: 'voll', true: 'leer'})
    createAlias('deconz.0.Sensors.3.battery'/*Bewegungsmelder battery*/, 'Batterien_voll_leer.Bewegungsmelder_Flur', undefined, 'batterien_voll_leer_alias', 'boolean', undefined, undefined, 'Bewegungsmelder-Flur', 'indicator.lowbat', 'per Script erstellt', undefined, undefined, undefined, {false: 'voll', true: 'leer'})
    //  Batterien_Volt
    //2 x Batterien Volt Anzeige in function batterien_volt_alias
    //createAlias('hm-rpc.0.xxx.0.OPERATING_VOLTAGE'/*Wohnzimmer Fenster links:0 OPERATING VOLTAGE*/, 'Batterien_Volt.Wohnzimmer_Fenster_links', undefined, 'batterien_volt_alias', 'number', undefined, undefined, 'Wohnzimmer Fenster links', 'value.voltage', 'per Script erstellt', undefined, undefined, 'Volt', undefined)
    //createAlias('hm-rpc.0.xxx.0.OPERATING_VOLTAGE'/*Küche Fenster links:0 OPERATING VOLTAGE*/, 'Batterien_Volt.Kueche_Fenster_links', undefined, 'batterien_volt_alias', 'number', undefined, undefined, 'Küche Fenster links', 'value.voltage', 'per Script erstellt', undefined, undefined, 'Volt', undefined)
    Dabei bekomme ich im Log folgende Fehlermeldung:
    javascript.0	2020-11-18 18:22:12.265	error	(2706) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2020-11-18 18:22:12.265	error	(2706) at runMicrotasks (<anonymous>)
    javascript.0	2020-11-18 18:22:12.264	error	(2706) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2020-11-18 18:22:12.264	error	(2706) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-11-18 18:22:12.263	error	(2706) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
    javascript.0	2020-11-18 18:22:12.263	error	(2706) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.0	2020-11-18 18:22:12.263	error	(2706) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.0	2020-11-18 18:22:12.262	error	(2706) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.0	2020-11-18 18:22:12.262	error	(2706) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.0	2020-11-18 18:22:12.261	error	(2706) at Object.createScript (vm.js:261:10)
    javascript.0	2020-11-18 18:22:12.261	error	(2706) at new Script (vm.js:88:7)
    javascript.0	2020-11-18 18:22:12.260	error	(2706) SyntaxError: missing ) after argument list
    javascript.0	2020-11-18 18:22:12.260	error	(2706) ^^^^^^^^^^^^^^^^^^^^^^^^
    javascript.0	2020-11-18 18:22:12.259	error	(2706) createAlias('deconz.0.Lights.3.on'/*Wandlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Wandlampe_Wohnzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Wandlampe-Wohnzimmer, 'switch
    javascript.0	2020-11-18 18:22:12.259	error	(2706) script.js.common.Test.Aliase compile failed: at script.js.common.Test.Aliase:350
    Ich hoffe mir kann jemand sagen wo meine Fehler liegen.
    Vielen dank im Voraus
    dslraserD Offline
    dslraserD Offline
    dslraser
    #961
    @sandro_gera sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
    Es gibt auch eine neuere Version vom Script.
    • dslraserD dslraser
      sandro_gera
      #962
      @dslraser
      Danke, Das Semikolon hatte ich echt übersehen.
      Die ne Version hatte ich gesehen bin damit nur nicht zurecht gekommen. ich wußte nicht wo ich da meine Geräte eingebe.
      Semikolon habe ich gesetzt allerdings ändert sich nicht an der Fehlermeldung.
      createAlias('deconz.0.Lights.3.on'/*Wandlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Wandlampe_Wohnzimmer', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Wandlampe-Wohnzimmer', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
      javascript.0	2020-11-18 19:04:57.921	error	(28754) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2020-11-18 19:04:57.921	error	(28754) at runMicrotasks (<anonymous>)
      javascript.0	2020-11-18 19:04:57.921	error	(28754) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2020-11-18 19:04:57.920	error	(28754) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-11-18 19:04:57.920	error	(28754) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
      javascript.0	2020-11-18 19:04:57.920	error	(28754) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
      javascript.0	2020-11-18 19:04:57.920	error	(28754) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
      javascript.0	2020-11-18 19:04:57.920	error	(28754) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
      javascript.0	2020-11-18 19:04:57.919	error	(28754) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
      javascript.0	2020-11-18 19:04:57.919	error	(28754) at Object.createScript (vm.js:261:10)
      javascript.0	2020-11-18 19:04:57.919	error	(28754) at new Script (vm.js:88:7)
      javascript.0	2020-11-18 19:04:57.919	error	(28754) SyntaxError: missing ) after argument list
      javascript.0	2020-11-18 19:04:57.919	error	(28754) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      javascript.0	2020-11-18 19:04:57.918	error	(28754) createAlias('deconz.0.Lights.1.on'/*Tischlampe-Wohnzimmer on*/, 'Licht.Wohnzimmer.Tischlampe_Wohnzimmer, undefined, 'licht_alias', 'boolean', undefined, undefined, 'Tischlampe-Wohnzimmer', 's
      javascript.0	2020-11-18 19:04:57.918	error	at script.js.common.Test.Aliase:352
      javascript.0	2020-11-18 19:04:57.918	error	(28754) script.js.common.Test.Aliase compile failed:
      Master RPI4 8GB, Slave RPI3 1GB
      Node.js v18.17.1, npm: 9.6.7,
      JS-Controller: 5.0.16
      • S sandro_gera
        @dslraser
        dslraserD Offline
        dslraserD Offline
        dslraser
        #963
        @sandro_gera
        jetzt wird Zeile 352 angemeckert (steht auch so in der Fehlermeldung)
        Da fehlt auch ein Semikolon, nur an anderer Stelle
        S 2 Antworten Letzte Antwort
          @sandro_gera
          sandro_gera
          #964
          @dslraser
          sorry ich hab es gerade gesehen.
            @sandro_gera
            sandro_gera
            #965
            @dslraser
            Schau mal einer an plötzlich gehts
            • S sandro_gera
              @dslraser
              dslraserD Offline
              dslraserD Offline
              dslraser
              #966
              @dslraser
                @dslraser
                sandro_gera
                #967
                @dslraser
                ok jetzt kann ich mir der Blocky Erstellung weiter machen. Mal sehen wie ich damit klar komme.
                Bezüglich der neuen Skript Version. Sollte ich daruf umstellen und wenn ja kannst du mir sagen wie ich das anstelle?
                • S sandro_gera
                  @dslraser
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #968
                  @sandro_gera
                  Da brauchst Du eigentlich nur alles vom neuen Script kopieren und im alten Script alles oberhalb Zeile 266 damit ersetzen.
                    @sandro_gera
                    sandro_gera
                    #969
                    @dslraser
                    achso na wenn das so einfach ist dann mach ich das nachher noch
                    • S sandro_gera
                      @dslraser
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      #970
                      @dslraser
                      Ich habe eben mal kurz Deine alias überflogen. In der ID sind Bindestriche oder Unterstriche okay.
                      Im Namen (schau Dir mal die Datenpunkte in den Objekten an--bei Name), da könnten Bindestriche Dir eventuell in die Suppe spucken, falls Du Alexa Ansagen verwenden möchtest. Ich habe beim Namen, wenn es mehrere Worte sind, Leerzeichen dazwischen, dann werden die auch genau so angesagt. Wie Worte mit Bindestrichen angesagt werden weiß ich gerade nicht ? Kannst ja mal von Hand beim Alexa2 Adapter so ein Wort bei speak eintragen...
                      S dslraserD 2 Antworten Letzte Antwort
                        @dslraser
                        sandro_gera
                        schrieb am zuletzt editiert von sandro_gera
                        #971
                        @dslraser
                        also ich hab die Geräte so übernommen wie sie bei mir in alexa schon unter den Geräten funtionieren. Dann sollte das doch gehen oder?
                        Ich hab bei jedem Namen einen Bindestrich.
                          @dslraser
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #972
                          @dslraser sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                          @sandro_gera ich habe es gerade mal selbst bei einer Ankündigung probiert mit
                          Wohnzimmer-Lampe an
                          das wurde trotzdem vernünftig ausgesprochen, also geht es wohl auch so.
                            Wohnzimmer-Lampe an
                            sandro_gera
                            #973
                            @dslraser
                            Also ich hab jetzt das Blocky mal gestartet da kommen haufenweise Warnmeldungen
                            2020-11-18 19:40:34.891 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.940 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.940 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.940 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:34.941 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.943 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.945 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.945 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.947 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.947 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.947 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                            2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.949 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.949 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.949 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                            2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.951 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.951 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.951 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                            2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.953 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.953 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.953 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                            2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.955 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.955 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.955 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                            2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.957 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.957 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                            2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.959 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.959 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                            2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.961 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                            2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.963 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                            2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.965 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.966 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                            2020-11-18 19:40:34.967 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.968 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                            2020-11-18 19:40:34.969 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.970 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                            2020-11-18 19:40:34.971 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.972 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                            2020-11-18 19:40:34.973 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.973 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.974 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                            2020-11-18 19:40:34.975 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.975 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.976 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                            2020-11-18 19:40:34.977 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.977 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.978 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.980 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.980 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.980 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.982 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.982 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.982 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.984 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.984 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.984 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.986 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.986 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.988 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                            2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.990 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.991 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.993 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                            2020-11-18 19:40:34.994 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.995 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                            2020-11-18 19:40:34.996 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:34.996 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.997 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:34.999 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:34.999 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:34.999 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.001 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.001 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.003 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.004 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.005 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                            2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.006 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.007 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                            2020-11-18 19:40:35.007 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.008 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.010 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.010 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.010 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.011 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.011 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.012 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                            2020-11-18 19:40:35.013 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.014 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                            2020-11-18 19:40:35.015 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.017 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                            2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.019 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.019 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.019 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                            2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.021 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.021 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.021 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                            2020-11-18 19:40:35.022 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.022 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.023 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                            2020-11-18 19:40:35.024 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.024 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.026 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                            2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.028 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                            2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.030 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.032 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.034 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.034 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.036 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.036 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                            2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.038 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.038 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.040 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.040 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.042 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.044 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.044 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                            2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                            2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.046 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.071 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                            2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.073 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.073 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.073 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                            2020-11-18 19:40:35.074 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.074 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.076 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.077 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.079 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.083 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.085 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.085 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.086 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.088 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.089 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.089 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.091 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                            2020-11-18 19:40:35.092 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.092 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.094 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                            2020-11-18 19:40:35.095 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.095 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.097 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                            2020-11-18 19:40:35.098 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.098 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.100 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                            2020-11-18 19:40:35.101 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.101 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.103 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                            2020-11-18 19:40:35.104 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.104 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.105 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                            2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.108 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.108 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.108 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.110 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.110 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.111 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.113 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.113 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.114 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                            2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.117 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.117 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.117 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                            2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.120 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.120 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.120 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.121 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.123 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.123 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.124 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.124 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.126 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                            2020-11-18 19:40:35.127 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                            2020-11-18 19:40:35.127 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.129 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                            2020-11-18 19:40:35.130 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                            2020-11-18 19:40:35.130 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.132 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                            2020-11-18 19:40:35.133 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.133 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.135 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.136 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.138 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                            2020-11-18 19:40:35.139 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.141 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.141 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                            2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.144 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.144 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.144 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                            2020-11-18 19:40:35.146 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.146 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.148 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                            2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.150 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.150 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.150 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                            2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.153 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.153 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.154 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                            2020-11-18 19:40:35.155 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.156 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.156 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.157 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.157 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.158 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                            2020-11-18 19:40:35.159 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.159 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.161 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                            2020-11-18 19:40:35.162 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                            2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                            2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.164 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.175 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                            2020-11-18 19:40:35.176 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1005:76)
                            2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.178 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                            2020-11-18 19:40:35.179 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1006:471)
                            2020-11-18 19:40:35.179 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.180 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                            2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1007:76)
                            2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.183 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.183 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.184 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                            2020-11-18 19:40:35.185 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1005:76)
                            2020-11-18 19:40:35.185 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.186 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                            2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1006:471)
                            2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.189 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.189 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            2020-11-18 19:40:35.189 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                            2020-11-18 19:40:35.190 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1007:76)
                            2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                            2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                            2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                            2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                            Master RPI4 8GB, Slave RPI3 1GB
                            Node.js v18.17.1, npm: 9.6.7,
                            JS-Controller: 5.0.16
                            • S sandro_gera
                              @dslraser
                              Also ich hab jetzt das Blocky mal gestartet da kommen haufenweise Warnmeldungen
                              2020-11-18 19:40:34.891 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.939 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.940 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.940 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.940 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:34.941 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.942 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.943 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.944 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.945 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.945 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.946 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.947 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.947 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.947 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                              2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.948 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.949 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.949 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.949 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                              2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.950 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.951 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.951 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.951 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                              2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.952 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.953 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.953 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.953 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                              2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.954 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.955 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.955 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.955 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                              2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.956 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.957 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.957 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                              2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.958 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.959 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.959 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                              2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.960 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.961 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                              2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.962 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.963 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                              2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.964 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.965 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.966 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                              2020-11-18 19:40:34.967 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.968 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.968 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                              2020-11-18 19:40:34.969 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.970 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.970 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                              2020-11-18 19:40:34.971 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.972 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.972 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                              2020-11-18 19:40:34.973 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.973 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.974 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.974 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                              2020-11-18 19:40:34.975 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.975 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.976 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.976 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                              2020-11-18 19:40:34.977 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.977 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.978 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.978 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.979 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.980 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.980 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.980 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.981 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.982 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.982 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.982 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.983 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.984 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.984 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.984 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.985 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.986 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.986 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.987 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.988 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                              2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.989 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.990 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.991 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.993 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                              2020-11-18 19:40:34.994 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.995 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.995 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                              2020-11-18 19:40:34.996 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:34.996 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.997 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.997 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:34.998 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:34.999 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:34.999 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:34.999 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.000 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.001 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.001 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.002 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.003 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.004 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.005 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:9)
                              2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.006 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.006 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.007 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:581:40)
                              2020-11-18 19:40:35.007 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.008 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.008 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.009 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.010 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.010 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.010 - warn: javascript.0 (30620) getState "alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.011 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.011 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.012 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.012 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_1_Bad" not found (3)
                              2020-11-18 19:40:35.013 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.014 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.014 - warn: javascript.0 (30620) getState "alias.0.Licht.Bad.Schrank_2_Bad" not found (3)
                              2020-11-18 19:40:35.015 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.016 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.017 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_1_Esszimmer" not found (3)
                              2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.018 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.019 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.019 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.019 - warn: javascript.0 (30620) getState "alias.0.Licht.Esszimmer.Schrank_2_Esszimmer" not found (3)
                              2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.020 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.021 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.021 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.021 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Deckenlampe_Flur" not found (3)
                              2020-11-18 19:40:35.022 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.022 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.023 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.023 - warn: javascript.0 (30620) getState "alias.0.Licht.Flur.Lampe_Verteilung" not found (3)
                              2020-11-18 19:40:35.024 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.024 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.025 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.026 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Sitzecke_Küche" not found (3)
                              2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.027 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.028 - warn: javascript.0 (30620) getState "alias.0.Licht.Kueche.Spuele_Kueche" not found (3)
                              2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.029 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.030 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_1_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.031 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.032 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_2_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.033 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.034 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.034 - warn: javascript.0 (30620) getState "alias.0.Licht.Schlafzimmer.Deckenlampe_3_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.035 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.036 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.036 - warn: javascript.0 (30620) getState "alias.0.Licht.Schuppen.Lampen-Schuppen" not found (3)
                              2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.037 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.038 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.038 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenfluter_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.039 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.040 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.040 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Deckenlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.041 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.042 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Tischlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.043 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.044 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.044 - warn: javascript.0 (30620) getState "alias.0.Licht.Wohnzimmer.Wandlampe_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Lichter_zaehlen (script.js.common.Test.Geräte_Zählen:589:10)
                              2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2326:7)
                              2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.045 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.046 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.071 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                              2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.072 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.073 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.073 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.073 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                              2020-11-18 19:40:35.074 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.074 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.075 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.076 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.077 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.078 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.079 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.083 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.084 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.085 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.085 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.086 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.087 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.088 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.089 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.089 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.090 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.091 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                              2020-11-18 19:40:35.092 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.092 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.093 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.094 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                              2020-11-18 19:40:35.095 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.095 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.096 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.097 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                              2020-11-18 19:40:35.098 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.098 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.099 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.100 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                              2020-11-18 19:40:35.101 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.101 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.102 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.103 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                              2020-11-18 19:40:35.104 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.104 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.105 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.105 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                              2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.107 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.108 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.108 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.108 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.110 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.110 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.111 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.111 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.113 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.113 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.114 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.114 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                              2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.116 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.117 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.117 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.117 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                              2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.119 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.120 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.120 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.120 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.121 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.122 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.123 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.123 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.124 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.124 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.125 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.126 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                              2020-11-18 19:40:35.127 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:9)
                              2020-11-18 19:40:35.127 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.128 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.129 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                              2020-11-18 19:40:35.130 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:470:43)
                              2020-11-18 19:40:35.130 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.131 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.132 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Abstellkammer.Steckdosenleiste_Abstellkammer" not found (3)
                              2020-11-18 19:40:35.133 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.133 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.134 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.135 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.136 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.137 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.138 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Arbeitszimmer.Computer_2_Arbeitszimmer" not found (3)
                              2020-11-18 19:40:35.139 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.140 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.141 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.141 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Esszimmer.Fernseher_Esszimmer" not found (3)
                              2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.143 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.144 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.144 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.144 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Fernseher-Kueche" not found (3)
                              2020-11-18 19:40:35.146 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.146 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.147 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.148 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Kueche.Kaffeemaschine_Kueche" not found (3)
                              2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.149 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.150 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.150 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.150 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schlafzimmer.Fernseher_Schlafzimmer" not found (3)
                              2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.152 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.153 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.153 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.154 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Schuppen.Pumpe_Schuppen" not found (3)
                              2020-11-18 19:40:35.155 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.156 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.156 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.157 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.157 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.158 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Media_Wohnzimmer" not found (3)
                              2020-11-18 19:40:35.159 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.159 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.160 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.161 - warn: javascript.0 (30620) getState "alias.0.Steckdosen.Wohnzimmer.Netzteil_Laptop" not found (3)
                              2020-11-18 19:40:35.162 - warn: javascript.0 (30620) at Steckdosen_zaehlen (script.js.common.Test.Geräte_Zählen:478:10)
                              2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:2470:7)
                              2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.163 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.164 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.175 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                              2020-11-18 19:40:35.176 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1005:76)
                              2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.177 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.178 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                              2020-11-18 19:40:35.179 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1006:471)
                              2020-11-18 19:40:35.179 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.180 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.180 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Esszimmer.Temperatur_Esszimmer_1" not found (3)
                              2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1007:76)
                              2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.182 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.183 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.183 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.184 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                              2020-11-18 19:40:35.185 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1005:76)
                              2020-11-18 19:40:35.185 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.186 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.186 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                              2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1006:471)
                              2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.188 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.189 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.189 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              2020-11-18 19:40:35.189 - warn: javascript.0 (30620) getState "alias.0.Temperaturen.Schlafzimmer.Temperatur_Schlafzimmer_2" not found (3)
                              2020-11-18 19:40:35.190 - warn: javascript.0 (30620) at Temperaturen_zaehlen (script.js.common.Test.Geräte_Zählen:1007:76)
                              2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at Object. (script.js.common.Test.Geräte_Zählen:3011:7)
                              2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                              2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at listOnTimeout (internal/timers.js:554:17)
                              2020-11-18 19:40:35.191 - warn: javascript.0 (30620) at processTimers (internal/timers.js:497:7)
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #974
                              @sandro_gera
                              welche Javascript Adapter Version hast Du installiert ?
                              • dslraserD dslraser
                                @sandro_gera
                                sandro_gera
                                #975
                                @dslraser
                                4.8.4
                                Master RPI4 8GB, Slave RPI3 1GB
                                Node.js v18.17.1, npm: 9.6.7,
                                JS-Controller: 5.0.16
                                • S sandro_gera
                                  @dslraser
                                  4.8.4
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #976
                                  @sandro_gera
                                  ähm, warte mal, laut Fehlermeldung werden Temperatursensoren (bei den Alias ) nicht gefunden.
                                    @sandro_gera
                                    sandro_gera
                                    #977
                                    @dslraser
                                    Also ich hab als Temperatursensoren meine Datenpunkte von den Heizkörperthermostaten genommen
                                    F 1 Antwort Letzte Antwort
                                    • S sandro_gera
                                      @dslraser
                                      FuXXz2
                                      #978
                                      @sandro_gera
                                      ich hatte diese Meldungen teilweise auch, während meiner Einrichtungsphase. Geholfen hat dann folgendes:
                                      Die vom Script erstellten Aliase löschen unter Objekten. Dann das Script neu starten. Die Aliase überprüfen, ob es wirklich alles stimmt und die Aufzählungen auch prüfen.
                                      Alle Fehler die bei mir kamen, resultierten nur aus dem Alias Script und meiner falschen Nutzung.
                                      Das Blocky Script hat nie Probleme gemacht.
                                      Anschließend im Blockly Script die Werte mit "Steckdosen verwenden, Lichter verwenden etc. auf falsch stellen. Dann sollte das Script alles löschen.
                                      Dann wieder auf wahr stellen und es ging bei mir.
                                      • F FuXXz2
                                        @sandro_gera
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #979
                                        @FuXXz2
                                        wir haben "alles" per Teamviewer geregelt, also mit @sandro_gera
                                          @FuXXz2
                                          sandro_gera
                                          #980
                                          @dslraser
                                          Ich möchte mich nochmals für deine Hilfe bedanken. Ohne dich wäre ich aufgeschmissen gewesen.
                                          Ich bin gerade dabei noch andere Aliasse zu erstellen.
                                          Zuerste geht es um einen Dimmer.
                                          Ich hänge etwas bei den Werten die dafür einzugeben sind
                                          createAlias('deconz.0.Lights.29.level'/*Deckenlampe-Arbeitszimmer level*/, 'Licht.Arbeitszimmer.Deckenlampe_Arbeitszimmer', undefined, 'Licht', 'number', undefined, undefined, 'Deckenlampe-Arbeitszimmer-Dimmwert', 'level.brightness', 'per Script erstellt', 0, 100, '%', undefined)
                                          Ich bin mir nicht sicher was ich da noch eintragen muss.
                                          Des weiteren benötige ich ja noch die Aliasse für dimm down und dimm up
                                          Kann mir dabei noch jemand helfen?
                                          Vielen dank im Voraus
