  4. Test Adapter MercedesMe v0.0.x
    6.8k
mercedes
1.0k Beiträge 122 Kommentatoren 362.6k Aufrufe 107 Beobachtet
    mrx
    Hallo
    also bei mir kommt nach dem starten
    host.raspberrypi 2019-05-10 18:28:55.492 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught 2019-05-10 18:28:55.492 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    Caught 2019-05-10 18:28:55.491 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
    Caught 2019-05-10 18:28:55.490 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
    Caught 2019-05-10 18:28:55.489 error by controller[0]: TypeError: Cannot read property 'val' of undefined
    mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    mercedesme.0 2019-05-10 18:28:54.368 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    mercedesme.0 2019-05-10 18:28:54.368 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    mercedesme.0 2019-05-10 18:28:54.368 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    mercedesme.0 2019-05-10 18:28:54.368 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    mercedesme.0 2019-05-10 18:28:54.368 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
    mercedesme.0 2019-05-10 18:28:54.368 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
    mercedesme.0 2019-05-10 18:28:54.368 error TypeError: Cannot read property 'val' of undefined
    mercedesme.0 2019-05-10 18:28:54.367 error uncaught exception: Cannot read property 'val' of undefined
    und der adapter wird rot er hat sich aber einige daten gezogen.
    nodejs ist aktuell 1.5.8
    gruss
    stefan
    • M mrx
      Hallo
      gruss
      stefan
      BBTownB Offline
      BBTownB Offline
      BBTown
      @mrx ja, diese Fehler kommen bei mir ebenfalls
      [Nachtrag]
      und dann startet der Adapter auch neu durch
      ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
        tombox
        kannst du mal ein screenshot von den DOORLOCK_STATUS und PRECONDITIONING_DATA Objekten machen
        • T tombox
          SpS
          @tombox leider nein - hab auf V0.3 umgestellt und bekomme den gleichen Fehler wie @mrx .
            tombox
            @mrx said in [Aufruf] Mecedes me Adapter:
            205
            Bitte den Adapter neuinstallieren und nochmal probieren
            • T tombox
              205
              SpS
              @tombox Auch nach Neuinstallation immer noch gleicher Fehler. Allerdings bekomme ich auch beim Login über Safari folgenden Fehler. Bei Firefox jedoch kann ich mich beim Mercedes.me Portal anmelden. Screenshot 2019-05-10 20.20.39.png
              • S SpS
                tombox
                @SpS exakt der gleiche Fehler kann eigentlich nicht sein dann nochmal installiere
                • T tombox
                  SpS
                  @tombox
                  host.RASPioBroker 2019-05-10 20:38:28.352 info Restart adapter system.adapter.mercedesme.0 because enabled
                  host.RASPioBroker 2019-05-10 20:38:28.352 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                  host.RASPioBroker 2019-05-10 20:38:28.352 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                  host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                  host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240)
                  host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                  mercedesme.0 2019-05-10 20:38:27.316 error TypeError: Cannot read property 'val' of null at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:
                  mercedesme.0 2019-05-10 20:38:27.314 error uncaught exception: Cannot read property 'val' of null
                  mercedesme.0 2019-05-10 20:38:20.838 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                  host.RASPioBroker 2019-05-10 20:38:16.310 info instance system.adapter.mercedesme.0 started with pid 813
                  host.RASPioBroker 2019-05-10 20:38:13.850 info instance system.adapter.mercedesme.0 terminated with code 0 (OK)
                  mercedesme.0 2019-05-10 20:38:13.796 info terminating
                  host.RASPioBroker 2019-05-10 20:38:13.785 info stopInstance system.adapter.mercedesme.0 killing pid 766
                  • S SpS
                    @tombox
                    tombox
                    @SpS Den Fehler habe ich auch abgefangen. Nochmal installieren. Aber irgendwas anderes stimmt da nicht.
                    Wie sehen deine Objekte für den Adapter aus?
                    • T tombox
                      SpS
                      @tombox
                      Adapter deinstalliert, ioBroker neu gestartet, Adapter neu installiert. Instanz angelegt und konfiguriert.
                      Objekte hab ich nur die oberste Ebene mit FIN/Autonummer
                      Logfile:
                      host.RASPioBroker 2019-05-10 21:14:51.717 info Restart adapter system.adapter.mercedesme.0 because enabled
                      host.RASPioBroker 2019-05-10 21:14:51.717 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                      Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      Caught 2019-05-10 21:14:51.716 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                      Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      Caught 2019-05-10 21:14:51.715 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                      Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                      Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                      Caught 2019-05-10 21:14:51.714 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                      Caught 2019-05-10 21:14:51.713 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                      Caught 2019-05-10 21:14:51.712 error by controller[0]: TypeError: Cannot read property 'val' of null
                      mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                      mercedesme.0 2019-05-10 21:14:50.660 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                      mercedesme.0 2019-05-10 21:14:50.660 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                      mercedesme.0 2019-05-10 21:14:50.660 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                      mercedesme.0 2019-05-10 21:14:50.660 error TypeError: Cannot read property 'val' of null
                      mercedesme.0 2019-05-10 21:14:50.658 error uncaught exception: Cannot read property 'val' of null
                      mercedesme.0 2019-05-10 21:14:43.702 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                      host.RASPioBroker 2019-05-10 21:14:39.695 info instance system.adapter.mercedesme.0 started with pid 1070
                      host.RASPioBroker 2019-05-10 21:14:09.669 info Restart adapter system.adapter.mercedesme.0 because enabled
                        tombox
                        bitte nochmal installieren
                        • T tombox
                          SpS
                          @tombox :-)
                          Jetzt hab ich keine Fehler mehr im Log und DoorLock auf/zu geht. Vorklimatisierung geht nicht (Wert wird nicht bestätigt und Standheizung geht nicht an).
                          • S SpS
                            @tombox :-)
                            tombox
                            schrieb am zuletzt editiert von tombox
                            @SpS kannst du mir ein screenshot von den objekten in PRECONDITIONING_DATA schicken auch als private nachricht.
                            Wie heißt der Punkt auf der mercedes me webseite? Programmierung Ladeeinstellungen und Vorklimatisierung?
                            • T tombox
                              SpS
                              schrieb am zuletzt editiert von SpS
                              @tombox Objekt PRECONDITIONING_DATA gibt es bei mir nicht - Vermutlich gibt es das nur bei Elektrofahrzeugen und hat nichts mit Standheizung zu tun.
                              Vorklimatisierung ist dort die Möglichkeit das Fahrzeug beim Laden auch im Innenraum zu Kühlen/Heizen.
                              • S SpS
                                tombox
                                @SpS Aber DOORLOCK_STATUS hast du schon?
                                Dann benötige ich Zugang zu einem Account oder per Fernwartung kurzen Zugriff auf ein Account
                                Du kannst ja über die mercedes me webseite die standheizung einschalten oder?
                                  mrx
                                  also fehlermeldung ist weg und den punkt PRECONDITIONING_DATA hab ich auch nicht,
                                  DOORLOCK_STATUS hab ich
                                  • T tombox
                                    SpS
                                    @tombox
                                    Standheizung kann über die App ein-/ausgeschaltet werden und zusätzlich eine Startzeit programmiert werden.
                                    • S SpS
                                      @tombox
                                      tombox
                                      Ok für die Standheizung müsste ich kurz Zugang zu einem Account bekommen der das Feature hat bzw jemand mir Fernzugriff per Teamviewer gibt damit ich kurz gucken wie die Standheizung angesprochen wird.
                                        mrx
                                        mhh gibbet hier keine pm funktion ?
                                          tombox
                                          Leider geht die Standheizung nur über die App und nicht über die Webseite, somit lässt sie sich vorerst nicht über ioBroker simulieren.
