  4. Test Adapter MercedesMe v0.0.x
    6.8k
mercedes
1.0k Beiträge 122 Kommentatoren 362.6k Aufrufe 107 Beobachtet
  • S SpS
    Hallo Tombox,
    die Daten sind soweit plausibel, ich kenn aber weder die Türen öffnen/schließen, noch die Vorklimatisierung starten. Fahrzeug ist aktuelle V-Klasse.
    Feature Wunsch: Standheizung mit Startzeit aktivieren
    Gruß Stefan
    PS: seit Update auf Version 0.3 hab ich folgenden Fehler im Log:
    host.RASPioBroker 2019-05-10 17:19:44.761 info instance system.adapter.mercedesme.0 started with pid 2979
    host.RASPioBroker 2019-05-10 17:19:14.738 info Restart adapter system.adapter.mercedesme.0 because enabled
    host.RASPioBroker 2019-05-10 17:19:14.738 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
    host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
    host.RASPioBroker 2019-05-10 17:19:14.736 error Caught by controller[0]: TypeError: Cannot read property 'val' of undefined
    mercedesme.0 2019-05-10 17:19:13.696 error TypeError: Cannot read property 'val' of undefined at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter
    mercedesme.0 2019-05-10 17:19:13.695 error uncaught exception: Cannot read property 'val' of undefined
    mercedesme.0 2019-05-10 17:19:06.765 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
    host.RASPioBroker 2019-05-10 17:19:02.359 info instance system.adapter.mercedesme.0 started with pid 2932
    tombox
    @SpS kannst du mal ein screenshot von den DOORLOCK_STATUS und PRECONDITIONING_DATA Objekten machen?
    • BBTownB BBTown
      @tombox seltsam, ich bekomme nur die 0.0.2er installiert
      tombox
      @BBTown Browser Cache oder iobroker neustarten
      BBTownB 1 Antwort Letzte Antwort
      • T tombox
        BBTownB Offline
        BBTownB Offline
        BBTown
        @tombox sagte in [Aufruf] Mecedes me Adapter:
        das hat ihn beides nicht sonderlich beeindruckt
        • BBTownB BBTown
          tombox
          @BBTown Was passiert auf der Konsole bei ./iobroker url "https://github.com/TA2k/iobroker.mercedesme"
          BBTownB 2 Antworten Letzte Antwort
          • T tombox
            BBTownB Offline
            BBTownB Offline
            BBTown
            Auf welcher Konsole?
            • T tombox
              BBTownB Offline
              BBTownB Offline
              BBTown
              @tombox Bitte nicht steinigen ... einmal kurz den PiHole deaktiviert und schon funktionierte das Update ... da werde ich wohl mal meine WhiteList ergänzen müssen 😕
                mrx
                Hallo
                also bei mir kommt nach dem starten
                host.raspberrypi 2019-05-10 18:28:55.492 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught 2019-05-10 18:28:55.492 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                Caught 2019-05-10 18:28:55.491 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
                Caught 2019-05-10 18:28:55.490 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
                Caught 2019-05-10 18:28:55.489 error by controller[0]: TypeError: Cannot read property 'val' of undefined
                mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                mercedesme.0 2019-05-10 18:28:54.368 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                mercedesme.0 2019-05-10 18:28:54.368 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                mercedesme.0 2019-05-10 18:28:54.368 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                mercedesme.0 2019-05-10 18:28:54.368 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                mercedesme.0 2019-05-10 18:28:54.368 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
                mercedesme.0 2019-05-10 18:28:54.368 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
                mercedesme.0 2019-05-10 18:28:54.368 error TypeError: Cannot read property 'val' of undefined
                mercedesme.0 2019-05-10 18:28:54.367 error uncaught exception: Cannot read property 'val' of undefined
                und der adapter wird rot er hat sich aber einige daten gezogen.
                nodejs ist aktuell 1.5.8
                gruss
                stefan
                • M mrx
                  Hallo
                  gruss
                  stefan
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  schrieb am zuletzt editiert von BBTown
                  @mrx ja, diese Fehler kommen bei mir ebenfalls
                  [Nachtrag]
                  und dann startet der Adapter auch neu durch
                    tombox
                    • T tombox
                      SpS
                      @tombox leider nein - hab auf V0.3 umgestellt und bekomme den gleichen Fehler wie @mrx .
                        tombox
                        @mrx said in [Aufruf] Mecedes me Adapter:
                        205
                        Bitte den Adapter neuinstallieren und nochmal probieren
                        • T tombox
                          205
                          SpS
                          @tombox Auch nach Neuinstallation immer noch gleicher Fehler. Allerdings bekomme ich auch beim Login über Safari folgenden Fehler. Bei Firefox jedoch kann ich mich beim Mercedes.me Portal anmelden. Screenshot 2019-05-10 20.20.39.png
                          • S SpS
                            tombox
                            @SpS exakt der gleiche Fehler kann eigentlich nicht sein dann nochmal installiere
                            • T tombox
                              SpS
                              @tombox
                              host.RASPioBroker 2019-05-10 20:38:28.352 info Restart adapter system.adapter.mercedesme.0 because enabled
                              host.RASPioBroker 2019-05-10 20:38:28.352 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                              host.RASPioBroker 2019-05-10 20:38:28.352 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                              host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                              host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240)
                              host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                              mercedesme.0 2019-05-10 20:38:27.316 error TypeError: Cannot read property 'val' of null at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:
                              mercedesme.0 2019-05-10 20:38:27.314 error uncaught exception: Cannot read property 'val' of null
                              mercedesme.0 2019-05-10 20:38:20.838 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                              host.RASPioBroker 2019-05-10 20:38:16.310 info instance system.adapter.mercedesme.0 started with pid 813
                              host.RASPioBroker 2019-05-10 20:38:13.850 info instance system.adapter.mercedesme.0 terminated with code 0 (OK)
                              mercedesme.0 2019-05-10 20:38:13.796 info terminating
                              host.RASPioBroker 2019-05-10 20:38:13.785 info stopInstance system.adapter.mercedesme.0 killing pid 766
                              • S SpS
                                @tombox
                                tombox
                                @SpS Den Fehler habe ich auch abgefangen. Nochmal installieren. Aber irgendwas anderes stimmt da nicht.
                                Wie sehen deine Objekte für den Adapter aus?
                                • T tombox
                                  SpS
                                  @tombox
                                  Adapter deinstalliert, ioBroker neu gestartet, Adapter neu installiert. Instanz angelegt und konfiguriert.
                                  Objekte hab ich nur die oberste Ebene mit FIN/Autonummer
                                  Logfile:
                                  host.RASPioBroker 2019-05-10 21:14:51.717 info Restart adapter system.adapter.mercedesme.0 because enabled
                                  host.RASPioBroker 2019-05-10 21:14:51.717 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                                  Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  Caught 2019-05-10 21:14:51.716 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                                  Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  Caught 2019-05-10 21:14:51.715 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                  Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                  Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                  Caught 2019-05-10 21:14:51.714 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                                  Caught 2019-05-10 21:14:51.713 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                                  Caught 2019-05-10 21:14:51.712 error by controller[0]: TypeError: Cannot read property 'val' of null
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                  mercedesme.0 2019-05-10 21:14:50.660 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                                  mercedesme.0 2019-05-10 21:14:50.660 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                                  mercedesme.0 2019-05-10 21:14:50.660 error TypeError: Cannot read property 'val' of null
                                  mercedesme.0 2019-05-10 21:14:50.658 error uncaught exception: Cannot read property 'val' of null
                                  mercedesme.0 2019-05-10 21:14:43.702 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                                  host.RASPioBroker 2019-05-10 21:14:39.695 info instance system.adapter.mercedesme.0 started with pid 1070
                                  host.RASPioBroker 2019-05-10 21:14:09.669 info Restart adapter system.adapter.mercedesme.0 because enabled
                                    tombox
                                    bitte nochmal installieren
                                    • T tombox
                                      SpS
                                      @tombox :-)
                                      Jetzt hab ich keine Fehler mehr im Log und DoorLock auf/zu geht. Vorklimatisierung geht nicht (Wert wird nicht bestätigt und Standheizung geht nicht an).
                                      • S SpS
                                        @tombox :-)
                                        tombox
                                        @SpS kannst du mir ein screenshot von den objekten in PRECONDITIONING_DATA schicken auch als private nachricht.
                                        Wie heißt der Punkt auf der mercedes me webseite? Programmierung Ladeeinstellungen und Vorklimatisierung?
                                        • T tombox
                                          SpS
                                          schrieb am zuletzt editiert von SpS
                                          @tombox Objekt PRECONDITIONING_DATA gibt es bei mir nicht - Vermutlich gibt es das nur bei Elektrofahrzeugen und hat nichts mit Standheizung zu tun.
                                          Vorklimatisierung ist dort die Möglichkeit das Fahrzeug beim Laden auch im Innenraum zu Kühlen/Heizen.
