  4. Test Adapter MercedesMe v0.0.x
    6.8k
mercedes
1.0k Beiträge 122 Kommentatoren 362.6k Aufrufe 107 Beobachtet
  • T tombox
    @BBTown Was passiert auf der Konsole bei ./iobroker url "https://github.com/TA2k/iobroker.mercedesme"
    BBTownB Offline
    BBTownB Offline
    BBTown
    @tombox sagte in [Aufruf] Mecedes me Adapter:
    Auf welcher Konsole?
    • T tombox
      BBTownB Offline
      BBTownB Offline
      BBTown
      @tombox Bitte nicht steinigen ... einmal kurz den PiHole deaktiviert und schon funktionierte das Update ... da werde ich wohl mal meine WhiteList ergänzen müssen 😕
        mrx
        Hallo
        also bei mir kommt nach dem starten
        host.raspberrypi 2019-05-10 18:28:55.492 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        Caught 2019-05-10 18:28:55.492 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
        Caught 2019-05-10 18:28:55.491 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
        Caught 2019-05-10 18:28:55.490 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
        Caught 2019-05-10 18:28:55.489 error by controller[0]: TypeError: Cannot read property 'val' of undefined
        mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        mercedesme.0 2019-05-10 18:28:54.368 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        mercedesme.0 2019-05-10 18:28:54.368 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        mercedesme.0 2019-05-10 18:28:54.368 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        mercedesme.0 2019-05-10 18:28:54.368 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
        mercedesme.0 2019-05-10 18:28:54.368 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
        mercedesme.0 2019-05-10 18:28:54.368 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
        mercedesme.0 2019-05-10 18:28:54.368 error TypeError: Cannot read property 'val' of undefined
        mercedesme.0 2019-05-10 18:28:54.367 error uncaught exception: Cannot read property 'val' of undefined
        und der adapter wird rot er hat sich aber einige daten gezogen.
        nodejs ist aktuell 1.5.8
        gruss
        stefan
        BBTownB 1 Antwort Letzte Antwort
        • M mrx
          Hallo
          gruss
          stefan
          BBTownB Offline
          BBTownB Offline
          BBTown
          schrieb am zuletzt editiert von BBTown
          @mrx ja, diese Fehler kommen bei mir ebenfalls
          [Nachtrag]
          und dann startet der Adapter auch neu durch
            tombox
            kannst du mal ein screenshot von den DOORLOCK_STATUS und PRECONDITIONING_DATA Objekten machen
            • T tombox
              SpS
              @tombox leider nein - hab auf V0.3 umgestellt und bekomme den gleichen Fehler wie @mrx .
                tombox
                @mrx said in [Aufruf] Mecedes me Adapter:
                205
                Bitte den Adapter neuinstallieren und nochmal probieren
                • T tombox
                  205
                  SpS
                  @tombox Auch nach Neuinstallation immer noch gleicher Fehler. Allerdings bekomme ich auch beim Login über Safari folgenden Fehler. Bei Firefox jedoch kann ich mich beim Mercedes.me Portal anmelden. Screenshot 2019-05-10 20.20.39.png
                  • S SpS
                    tombox
                    @SpS exakt der gleiche Fehler kann eigentlich nicht sein dann nochmal installiere
                    • T tombox
                      SpS
                      @tombox
                      host.RASPioBroker 2019-05-10 20:38:28.352 info Restart adapter system.adapter.mercedesme.0 because enabled
                      host.RASPioBroker 2019-05-10 20:38:28.352 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                      host.RASPioBroker 2019-05-10 20:38:28.352 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                      host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                      host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240)
                      host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                      mercedesme.0 2019-05-10 20:38:27.316 error TypeError: Cannot read property 'val' of null at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:
                      mercedesme.0 2019-05-10 20:38:27.314 error uncaught exception: Cannot read property 'val' of null
                      mercedesme.0 2019-05-10 20:38:20.838 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                      host.RASPioBroker 2019-05-10 20:38:16.310 info instance system.adapter.mercedesme.0 started with pid 813
                      host.RASPioBroker 2019-05-10 20:38:13.850 info instance system.adapter.mercedesme.0 terminated with code 0 (OK)
                      mercedesme.0 2019-05-10 20:38:13.796 info terminating
                      host.RASPioBroker 2019-05-10 20:38:13.785 info stopInstance system.adapter.mercedesme.0 killing pid 766
                      • S SpS
                        @tombox
                        tombox
                        @SpS Den Fehler habe ich auch abgefangen. Nochmal installieren. Aber irgendwas anderes stimmt da nicht.
                        Wie sehen deine Objekte für den Adapter aus?
                        • T tombox
                          SpS
                          @tombox
                          Adapter deinstalliert, ioBroker neu gestartet, Adapter neu installiert. Instanz angelegt und konfiguriert.
                          Objekte hab ich nur die oberste Ebene mit FIN/Autonummer
                          Logfile:
                          host.RASPioBroker 2019-05-10 21:14:51.717 info Restart adapter system.adapter.mercedesme.0 because enabled
                          host.RASPioBroker 2019-05-10 21:14:51.717 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                          Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                          Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          Caught 2019-05-10 21:14:51.716 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                          Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                          Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          Caught 2019-05-10 21:14:51.715 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                          Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                          Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                          Caught 2019-05-10 21:14:51.714 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                          Caught 2019-05-10 21:14:51.713 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                          Caught 2019-05-10 21:14:51.712 error by controller[0]: TypeError: Cannot read property 'val' of null
                          mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                          mercedesme.0 2019-05-10 21:14:50.660 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                          mercedesme.0 2019-05-10 21:14:50.660 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                          mercedesme.0 2019-05-10 21:14:50.660 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                          mercedesme.0 2019-05-10 21:14:50.660 error TypeError: Cannot read property 'val' of null
                          mercedesme.0 2019-05-10 21:14:50.658 error uncaught exception: Cannot read property 'val' of null
                          mercedesme.0 2019-05-10 21:14:43.702 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                          host.RASPioBroker 2019-05-10 21:14:39.695 info instance system.adapter.mercedesme.0 started with pid 1070
                          host.RASPioBroker 2019-05-10 21:14:09.669 info Restart adapter system.adapter.mercedesme.0 because enabled
                            tombox
                            bitte nochmal installieren
                            • T tombox
                              SpS
                              @tombox :-)
                              Jetzt hab ich keine Fehler mehr im Log und DoorLock auf/zu geht. Vorklimatisierung geht nicht (Wert wird nicht bestätigt und Standheizung geht nicht an).
                              • S SpS
                                @tombox :-)
                                tombox
                                @SpS kannst du mir ein screenshot von den objekten in PRECONDITIONING_DATA schicken auch als private nachricht.
                                Wie heißt der Punkt auf der mercedes me webseite? Programmierung Ladeeinstellungen und Vorklimatisierung?
                                • T tombox
                                  SpS
                                  schrieb am zuletzt editiert von SpS
                                  @tombox Objekt PRECONDITIONING_DATA gibt es bei mir nicht - Vermutlich gibt es das nur bei Elektrofahrzeugen und hat nichts mit Standheizung zu tun.
                                  Vorklimatisierung ist dort die Möglichkeit das Fahrzeug beim Laden auch im Innenraum zu Kühlen/Heizen.
                                  • S SpS
                                    tombox
                                    @SpS Aber DOORLOCK_STATUS hast du schon?
                                    Dann benötige ich Zugang zu einem Account oder per Fernwartung kurzen Zugriff auf ein Account
                                    Du kannst ja über die mercedes me webseite die standheizung einschalten oder?
                                      mrx
                                      also fehlermeldung ist weg und den punkt PRECONDITIONING_DATA hab ich auch nicht,
                                      DOORLOCK_STATUS hab ich
                                      • T tombox
                                        SpS
                                        @tombox
                                        Standheizung kann über die App ein-/ausgeschaltet werden und zusätzlich eine Startzeit programmiert werden.
                                        • S SpS
                                          @tombox
                                          tombox
                                          Ok für die Standheizung müsste ich kurz Zugang zu einem Account bekommen der das Feature hat bzw jemand mir Fernzugriff per Teamviewer gibt damit ich kurz gucken wie die Standheizung angesprochen wird.
