  4. Test Adapter MercedesMe v0.0.x
    6.8k
mercedes
1.0k Beiträge 122 Kommentatoren 362.6k Aufrufe 107 Beobachtet
  • T tombox
    @SpS Den Fehler habe ich auch abgefangen. Nochmal installieren. Aber irgendwas anderes stimmt da nicht.
    Wie sehen deine Objekte für den Adapter aus?
    SpS
    @tombox
    Adapter deinstalliert, ioBroker neu gestartet, Adapter neu installiert. Instanz angelegt und konfiguriert.
    Objekte hab ich nur die oberste Ebene mit FIN/Autonummer
    Logfile:
    host.RASPioBroker 2019-05-10 21:14:51.717 info Restart adapter system.adapter.mercedesme.0 because enabled
    host.RASPioBroker 2019-05-10 21:14:51.717 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
    Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught 2019-05-10 21:14:51.716 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught 2019-05-10 21:14:51.715 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    Caught 2019-05-10 21:14:51.714 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    Caught 2019-05-10 21:14:51.713 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
    Caught 2019-05-10 21:14:51.712 error by controller[0]: TypeError: Cannot read property 'val' of null
    mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    mercedesme.0 2019-05-10 21:14:50.660 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    mercedesme.0 2019-05-10 21:14:50.660 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    mercedesme.0 2019-05-10 21:14:50.660 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    mercedesme.0 2019-05-10 21:14:50.660 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    mercedesme.0 2019-05-10 21:14:50.660 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    mercedesme.0 2019-05-10 21:14:50.660 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
    mercedesme.0 2019-05-10 21:14:50.660 error TypeError: Cannot read property 'val' of null
    mercedesme.0 2019-05-10 21:14:50.658 error uncaught exception: Cannot read property 'val' of null
    mercedesme.0 2019-05-10 21:14:43.702 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
    host.RASPioBroker 2019-05-10 21:14:39.695 info instance system.adapter.mercedesme.0 started with pid 1070
    host.RASPioBroker 2019-05-10 21:14:09.669 info Restart adapter system.adapter.mercedesme.0 because enabled
      tombox
      bitte nochmal installieren
      • T tombox
        SpS
        @tombox :-)
        Jetzt hab ich keine Fehler mehr im Log und DoorLock auf/zu geht. Vorklimatisierung geht nicht (Wert wird nicht bestätigt und Standheizung geht nicht an).
        • S SpS
          @tombox :-)
          tombox
          @SpS kannst du mir ein screenshot von den objekten in PRECONDITIONING_DATA schicken auch als private nachricht.
          Wie heißt der Punkt auf der mercedes me webseite? Programmierung Ladeeinstellungen und Vorklimatisierung?
          • T tombox
            SpS
            schrieb am zuletzt editiert von SpS
            @tombox Objekt PRECONDITIONING_DATA gibt es bei mir nicht - Vermutlich gibt es das nur bei Elektrofahrzeugen und hat nichts mit Standheizung zu tun.
            Vorklimatisierung ist dort die Möglichkeit das Fahrzeug beim Laden auch im Innenraum zu Kühlen/Heizen.
            • S SpS
              tombox
              @SpS Aber DOORLOCK_STATUS hast du schon?
              Dann benötige ich Zugang zu einem Account oder per Fernwartung kurzen Zugriff auf ein Account
              Du kannst ja über die mercedes me webseite die standheizung einschalten oder?
                mrx
                also fehlermeldung ist weg und den punkt PRECONDITIONING_DATA hab ich auch nicht,
                DOORLOCK_STATUS hab ich
                • T tombox
                  SpS
                  @tombox
                  Standheizung kann über die App ein-/ausgeschaltet werden und zusätzlich eine Startzeit programmiert werden.
                  • S SpS
                    @tombox
                    tombox
                    Ok für die Standheizung müsste ich kurz Zugang zu einem Account bekommen der das Feature hat bzw jemand mir Fernzugriff per Teamviewer gibt damit ich kurz gucken wie die Standheizung angesprochen wird.
                      mrx
                      mhh gibbet hier keine pm funktion ?
                        tombox
                        Leider geht die Standheizung nur über die App und nicht über die Webseite, somit lässt sie sich vorerst nicht über ioBroker simulieren.
                        • cashC Offline
                          cashC Offline
                          cash
                          Das muss neu sein. Im letzten Winter habe ich die Standheizung öfter auch über das Portal aktiviert. Jetzt kommt tatsächlich nur noch der Hinweis mit der App.
                            Marcus P
                            Ich habe den Adapter installiert. Steht auf GRÜN.
                            In der Instanz sind die korrekten Zugangsdaten eingetragen.
                            Ich bekomme jedoch kein Objekt angezeigt, um Daten auszulesen.
                            Im Log wird gemeldet, dass kein Fahrzeug gefunden wurde
                            2019-05-11 16:33:43.890 - info: mercedesme.0 starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.16.0
                            2019-05-11 16:33:48.371 - warn: mercedesme.0 No vehicles found
                            Was kann ich tun?
                            Danke vorab für die Hilfe.
                            Beste Grüße
                            Marcus
                            • M Marcus P
                              Was kann ich tun?
                              Beste Grüße
                              Marcus
                              tombox
                              @Marcus-P
                              Kannst du über das mercedes me Portal dein Fahrzeug kontrollieren und einstellen?
                              Ich habe dir noch eine PN geschrieben
                                tombox
                                Ich habe mal eine 0.0.4 veröffentlicht die besser mit der vis zusammarbeitet wenn man die türen oder fenster öffnet.
                                Man kann außerdem manuell die FIN eintragen falls sie nicht automatisch erkannt werden.
                                  dpomt
                                  habe eben die aktuelle Adapterversion installiert. Leider bringt der Adapter beim Starten einen Fehler:
                                  2019-05-15 23:10:53.996 - info: host.abc instance system.adapter.mercedesme.0 started with pid 13856
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: C:\abc\ioBroker\node_modules\iobroker.mercedesme\main.js:20
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: ...options,
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: ^^^
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: SyntaxError: Unexpected token ...
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: at createScript (vm.js:56:10)
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: at Module._compile (module.js:549:28)
                                  2019-05-15 23:10:54.183 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at Module.load (module.js:494:32)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at Module.runMain (module.js:611:10)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at run (bootstrap_node.js:394:7)
                                  2019-05-15 23:10:54.184 - error: Caught by controller[0]: at startup (bootstrap_node.js:160:9)
                                  2019-05-15 23:10:54.184 - error: host.abc instance system.adapter.mercedesme.0 terminated with code 1 ()
                                  2019-05-15 23:10:54.184 - info: host.abc Restart adapter system.adapter.mercedesme.0 because enabled
                                  An was könnte das liegen?
                                  Danke+Gruß
                                  Dieter
                                  • D dpomt
                                    Danke+Gruß
                                    Dieter
                                    tombox
                                    @dpomt deine node version ist zu alt. minimum node 8
                                    • T tombox
                                      dpomt
                                      @tombox said in [Aufruf] Mecedes me Adapter:
                                      Danke, das war es!
                                      Vielen Dank für den Adapter, klasse, all die Werte zu sehen. Auf-/abschließen hat eben funktioniert :)
                                      • cashC Offline
                                        cashC Offline
                                        cash
                                        Mal eine Frage an die Nutzer dieses Adapters: Was genau macht Ihr jetzt damit?
                                        Meine derzeit einzige Idee wäre jetzt erstmal über ein Script die Heizung am Wochenende einzuschalten sobald sich die Feststellbremse löst. Konkret wenn wir am Wochenende weiter weg fahren lasse ich per Geofence die Heizung absenken. Nachteil Geofency reagiert erst wenn ich die Homezone betrete (5km vorher). Jetzt könnte ich einfach auf die Feststellbremse abfragen. Ob es wirklich funktioniert muss ich dann testen. Aber erst im Winter.
                                        Was ich mir noch vorstellen könnte wäre das Auto automatisch nachts abzuschließen falls ich es mal vergesse (Garagenwagen).
                                        Was habt Ihr so für Ideen?
                                        • J Offline
                                          jrudolph
                                          Ich hatte bis heute die Version 0.0.3 in Betrieb. Sie hatte bis 04.06. die Daten erfolgreich eingesammelt. Seitdem sind keine Daten mehr gekommen. Habe daraufhin den Adapter neu gestartet --> ohne Erfolg. Habe Update auf 0.0.8 vorgenommen --> ohne Erfolg. Die FIN wird nicht mehr automatisch ermittelt, also habe ich sie manuell eingegeben. Trotzdem kein Erfolg.
                                          mercedesme.0 2019-06-07 20:58:17.437 warn Vehicle detection service not available please enter VIN/FIN manualy in the settings
                                          mercedesme.0 2019-06-07 20:58:14.110 info starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.14.0
                                          mercedesme.0 2019-06-07 20:52:04.311 error Error getting Vehicle Location via VHP
                                          mercedesme.0 2019-06-07 20:52:04.310 error Error getting Vehicle Infos via VHP
                                          mercedesme.0 2019-06-07 20:52:04.306 warn Vehicle detection service not available please enter VIN/FIN manualy in the settings
                                          mercedesme.0 2019-06-07 20:52:04.304 error Error getting Vehicle Details via VHP
                                          mercedesme.0 2019-06-07 20:52:00.356 info starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.14.0
                                          mercedesme.0 2019-06-07 20:50:25.353 warn Vehicle detection service not available please enter VIN/FIN manualy in the settings
                                          mercedesme.0 2019-06-07 20:50:21.366 info starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.14.0
                                          mercedesme.0 2019-06-07 20:49:02.739 warn Vehicle detection service not available please enter VIN/FIN manualy in the settings
                                          mercedesme.0 2019-06-07 20:48:59.367 info starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.14.0
                                          Hat sich möglicherweise die API seitens MB geändert?
                                          Meine Hauptanwendungsfälle sind:
                                          Anzeige von Kilometerstand, Tankfüllstand, Reichweite, Reifendruck in VIS
                                          Permanente Aufzeichnung der Position des Fahrzeugs in SQL DB und Anzeige der Fahrtroute mittels Grafana
                                          Beste Grüße
