  4. Test Adapter wireless-mbus v0.10.x
    5.9k
mbuswirelesswm-buswmbus
576 Beiträge 69 Kommentatoren 248.9k Aufrufe 55 Beobachtet
  • R ratte-rizzo
    Verflixt... Logs vergessen!
    2021-10-05 18:30:04.938  - info: wireless-mbus.0 (20405) starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.21.0, js-controller: 3.3.18
    2021-10-05 18:30:04.977  - debug: wireless-mbus.0 (20405) Created device of type: CUL (untested)
    2021-10-05 18:30:04.987  - debug: wireless-mbus.0 (20405) CUL: Receiver set data reporting with RSSI
    2021-10-05 18:30:05.034  - debug: wireless-mbus.0 (20405) connected set to true
    2021-10-05 18:30:07.993  - debug: wireless-mbus.0 (20405) CUL: Message response timeout
    2021-10-05 18:30:43.152  - debug: wireless-mbus.0 (20405) sendTo "listReceiver" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 18:30:43.153  - debug: wireless-mbus.0 (20405) sendTo "needsKey" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 18:30:43.219  - info: wireless-mbus.0 (20405) List of port: [{"manufacturer":"busware.de","pnpId":"usb-busware.de_CUL868-if00","vendorId":"03eb","productId":"204b","path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    2021-10-05 18:30:43.220  - debug: wireless-mbus.0 (20405) sendTo "listUart" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 18:32:14.688  - debug: wireless-mbus.0 (20405) 443043313030343644323031314135324142304534383032
    2021-10-05 18:32:14.688  - error: wireless-mbus.0 (20405) Frame type null is not implemented!
    2021-10-05 18:32:19.804  - debug: wireless-mbus.0 (20405) 23446532390012893508546e7aeb0000008b046e05000082046cbe2995d301fd0c10046d2011a52ab0e480
    2021-10-05 18:32:19.804  - error: wireless-mbus.0 (20405) Frame type null is not implemented!
    2021-10-05 18:34:03.771  - info: host.himbeere stopInstance system.adapter.wireless-mbus.0 (force=false, process=true)
    2021-10-05 18:34:03.777  - info: wireless-mbus.0 (20405) Got terminate signal TERMINATE_YOURSELF
    2021-10-05 18:34:03.815  - info: host.himbeere stopInstance system.adapter.wireless-mbus.0 send kill signal
    2021-10-05 18:34:03.779  - info: wireless-mbus.0 (20405) terminating
    2021-10-05 18:34:03.779  - info: wireless-mbus.0 (20405) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-05 18:34:04.362  - info: host.himbeere instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-05 18:34:06.870  - info: host.himbeere instance system.adapter.wireless-mbus.0 started with pid 24588
    2021-10-05 18:34:07.199  - debug: wireless-mbus.0 (24588) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-10-05 18:34:07.216  - debug: wireless-mbus.0 (24588) Objects client ready ... initialize now
    2021-10-05 18:34:07.270  - debug: wireless-mbus.0 (24588) Objects create System PubSub Client
    2021-10-05 18:34:07.271  - debug: wireless-mbus.0 (24588) Objects create User PubSub Client
    2021-10-05 18:34:07.271  - debug: wireless-mbus.0 (24588) Objects client initialize lua scripts
    2021-10-05 18:34:07.280  - debug: wireless-mbus.0 (24588) Objects connected to redis: 127.0.0.1:9001
    2021-10-05 18:34:07.283  - debug: wireless-mbus.0 (24588) objectDB connected
    2021-10-05 18:34:07.284  - debug: wireless-mbus.0 (24588) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-10-05 18:34:07.289  - debug: wireless-mbus.0 (24588) States create System PubSub Client
    2021-10-05 18:34:07.289  - debug: wireless-mbus.0 (24588) States create User PubSub Client
    2021-10-05 18:34:07.339  - debug: wireless-mbus.0 (24588) States connected to redis: 127.0.0.1:9000
    2021-10-05 18:34:07.339  - debug: wireless-mbus.0 (24588) statesDB connected
    2021-10-05 18:34:07.505  - info: wireless-mbus.0 (24588) starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.21.0, js-controller: 3.3.18
    2021-10-05 18:34:07.535  - debug: wireless-mbus.0 (24588) Created device of type: CUL (untested)
    2021-10-05 18:34:07.541  - debug: wireless-mbus.0 (24588) CUL: Receiver set data reporting with RSSI
    2021-10-05 18:34:07.579  - debug: wireless-mbus.0 (24588) connected set to true
    2021-10-05 18:34:07.623  - debug: wireless-mbus.0 (24588) connected set to true
    2021-10-05 18:34:10.542  - debug: wireless-mbus.0 (24588) CUL: Message response timeout
    2021-10-05 18:44:07.410  - debug: wireless-mbus.0 (24588) 38464332454243324238384446393035353130303943443637383842323931353536443334313941453331373544323838464644423445354432363236424446413142344646343635304242343834434643363944463035303034364432433131413532413542383830433738333030363439333543393045383030
    2021-10-05 18:44:07.411  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 18:57:02.517  - debug: wireless-mbus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a0a3f202832343839313442464242384544464546393036414237393543413234443444435620697320756e6b6e6f776e2920557365206f6e65206f66204120422062204320652046204720682069204b206b204c206c204d206d204e205220542074205520752056205720582078205920
    2021-10-05 18:57:02.521  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 18:59:03.642  - debug: wireless-mbus.0 (24588) 4f4465b20192342533073f5f780dff5f350082388035f23fa3547dfa4cc943120a2caa906818c98e1b348863115eefe40d34fc5abb6250fbfb70191b8e4a0e5e829a4871d0f51afc9390b8d4046d3b11a52ade7e0c7830064935c90e80
    2021-10-05 18:59:03.645  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 18:59:08.523  - debug: wireless-mbus.0 (24588) 3f20283f20697320756e6b6e6f776e2920557365206f6e65206f66204120422062204320652046204720682069204b206b204c206c204d206d204e205220542074205520752056205720582078205920
    2021-10-05 18:59:08.523  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 18:59:21.649  - debug: wireless-mbus.0 (24588) 3f20283f20697320756e6b6e6f776e2920557365206f6e65206f66204120422062204320652046204720682069204b206b204c206c204d206d204e205220542074205520752056205720582078205920
    2021-10-05 18:59:21.649  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 18:59:31.775  - debug: wireless-mbus.0 (24588) 3f20283f20697320756e6b6e6f776e2920557365206f6e65206f66204120422062204320652046204720682069204b206b204c206c204d206d204e205220542074205520752056205720582078205920
    2021-10-05 18:59:31.776  - error: wireless-mbus.0 (24588) Frame type null is not implemented!
    2021-10-05 19:20:01.541  - debug: wireless-mbus.0 (24588) sendTo "listReceiver" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 19:20:01.548  - debug: wireless-mbus.0 (24588) sendTo "needsKey" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 19:20:01.692  - info: wireless-mbus.0 (24588) List of port: [{"manufacturer":"busware.de","pnpId":"usb-busware.de_CUL868-if00","vendorId":"03eb","productId":"204b","path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    2021-10-05 19:20:01.692  - debug: wireless-mbus.0 (24588) sendTo "listUart" to system.adapter.admin.0 from system.adapter.wireless-mbus.0
    2021-10-05 19:24:49.567  - debug: wireless-mbus.0 (24588) 4f4465b20192342533073f5f780dff5f350082388035188832437978a38e9a8b4f4465b20192342533073f5f780dff5f350082388035b1f7fb406a65829f675d0c10046d0412a52a9b8482
    lvogt
    #101
    @ratte-rizzo
    Es gab schon mal an paar wenige andere Tester, aber da ich den CUL Support ohne eigene Hardware ausprobiert habe, gestaltet es sich etwas schwierig (und ich habe auch sehr lange nichts am Adapter gemacht...)
    Um ehrlich zu sein, bin ich überrascht, dass bei den Logausgaben überhaupt Geräte angelegt werden... Ich muss mir das nochmal in Ruhe angucken, könnte evtl. aber bis zum Wochenende dauern.
    Ich hätte noch eine Frage: Du willst wirklich den S-Mode (und nicht den T-Mode)?
    Und könntest du mal gucken ob du im Log eine Stelle findest wo korrekt ein Telegram verarbeitet wurde. Da müsste dann so eine Zeile ala Updating device: XXX-12345678 auftauchen. Einen Logausschnitt ab ca .5 Sekunden früher bis eine Sekunde später wäre nicht schlecht (nur Ausgaben von wireless-mbus reichen natürlich).
    R 1 Antwort Letzte Antwort
    • L lvogt
      @ratte-rizzo
      ratte-rizzo
      #102
      @lvogt
      Also ich bin bisher sehr zufrieden mit dem Adapter. Alles, was in meiner Wohnung verbaut ist, wird korrekt angezeigt. Ich habe zur Zeit aber nur Heizungsmessgeräte. Wobei angeblich die Rauchmelder auch funken, aber die hab ich in FHEM auch nicht gesehen. Aber die funken auch seltener, laut Broschüre.
      Und ja, der S-Mode ist der richtige (ich habe ehrlich gesagt den T-Mode gar nicht probiert, weil der S-Mode schon das ausspuckt, was ich suchte). Mein Einstiegspunkt war das FHEM Forum mit diesem Beitrag, wo meine Heizungszähler auch mit S-Mode ausgelesen wurden. Ich hab da halt nach der Marke geschaut.
      https://forum.fhem.de/index.php/topic,24517.msg990047.html#msg990047
      Ich habe Dir mal das Log von 3 Geräteupdates mitgeschickt. Die waren zufälligerweise alle 3 direkt hintereinander. Und die waren auch erfolgreich mit Updating device.
      Egal wie lang es dauert: Dankeschön!
      2021-10-06 14:56:17.468 - debug: wireless-mbus.0 (18920) 23446532899611893508a6027af00000008b046e00000082046cbe29531001fd0c10046d380da62acd7c80
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) Short header
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 0
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 10686 value calc 2021-09-30
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) VIF_MODEL_VERSION: Value 16
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715525432 value calc 2021-10-06 13:56
      2021-10-06 14:56:17.469 - debug: wireless-mbus.0 (18920) Updating device: LSE-89119689
      2021-10-06 14:56:17.474 - debug: wireless-mbus.0 (18920) Value LSE-89119689.data.1-8-VIF_HCA: 0
      2021-10-06 14:56:17.475 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89119689.data.1-8-VIF_HCA" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:17.519 - debug: wireless-mbus.0 (18920) Value LSE-89119689.data.2-8-VIF_TIME_POINT_DATE: 2021-09-30
      2021-10-06 14:56:17.520 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89119689.data.2-8-VIF_TIME_POINT_DATE" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:17.563 - debug: wireless-mbus.0 (18920) Value LSE-89119689.data.3-0-VIF_MODEL_VERSION: 16
      2021-10-06 14:56:17.564 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89119689.data.3-0-VIF_MODEL_VERSION" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:17.607 - debug: wireless-mbus.0 (18920) Value LSE-89119689.data.4-0-VIF_TIME_POINT_DATE_TIME: 2021-10-06 13:56
      2021-10-06 14:56:17.608 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89119689.data.4-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:21.443 - debug: wireless-mbus.0 (18920) 234465329288118935085d537af00000008b046e12000082046cbe297c9001fd0c10046d390da62af64c80
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) Short header
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 12
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 10686 value calc 2021-09-30
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) VIF_MODEL_VERSION: Value 16
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715525433 value calc 2021-10-06 13:57
      2021-10-06 14:56:21.444 - debug: wireless-mbus.0 (18920) Updating device: LSE-89118892
      2021-10-06 14:56:21.462 - debug: wireless-mbus.0 (18920) Value LSE-89118892.data.1-8-VIF_HCA: 12
      2021-10-06 14:56:21.463 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118892.data.1-8-VIF_HCA" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:21.507 - debug: wireless-mbus.0 (18920) Value LSE-89118892.data.2-8-VIF_TIME_POINT_DATE: 2021-09-30
      2021-10-06 14:56:21.507 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118892.data.2-8-VIF_TIME_POINT_DATE" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:21.551 - debug: wireless-mbus.0 (18920) Value LSE-89118892.data.3-0-VIF_MODEL_VERSION: 16
      2021-10-06 14:56:21.551 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118892.data.3-0-VIF_MODEL_VERSION" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:21.595 - debug: wireless-mbus.0 (18920) Value LSE-89118892.data.4-0-VIF_TIME_POINT_DATE_TIME: 2021-10-06 13:57
      2021-10-06 14:56:21.596 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118892.data.4-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:50.318 - debug: wireless-mbus.0 (18920) 234465320389118935086ea97af00000008b046e02000082046cbe29759d01fd0c10046d390da62af64c80
      2021-10-06 14:56:50.318 - debug: wireless-mbus.0 (18920) Short header
      2021-10-06 14:56:50.319 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 2
      2021-10-06 14:56:50.319 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 10686 value calc 2021-09-30
      2021-10-06 14:56:50.319 - debug: wireless-mbus.0 (18920) VIF_MODEL_VERSION: Value 16
      2021-10-06 14:56:50.319 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715525433 value calc 2021-10-06 13:57
      2021-10-06 14:56:50.319 - debug: wireless-mbus.0 (18920) Updating device: LSE-89118903
      2021-10-06 14:56:50.324 - debug: wireless-mbus.0 (18920) Value LSE-89118903.data.1-8-VIF_HCA: 2
      2021-10-06 14:56:50.325 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118903.data.1-8-VIF_HCA" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:50.367 - debug: wireless-mbus.0 (18920) Value LSE-89118903.data.2-8-VIF_TIME_POINT_DATE: 2021-09-30
      2021-10-06 14:56:50.368 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118903.data.2-8-VIF_TIME_POINT_DATE" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:50.411 - debug: wireless-mbus.0 (18920) Value LSE-89118903.data.3-0-VIF_MODEL_VERSION: 16
      2021-10-06 14:56:50.412 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118903.data.3-0-VIF_MODEL_VERSION" has no existing object, this might lead to an error in future versions
      2021-10-06 14:56:50.455 - debug: wireless-mbus.0 (18920) Value LSE-89118903.data.4-0-VIF_TIME_POINT_DATE_TIME: 2021-10-06 13:57
      2021-10-06 14:56:50.456 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-89118903.data.4-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
      L 1 Antwort Letzte Antwort
      • R ratte-rizzo
        @lvogt
        lvogt
        #103
        @ratte-rizzo
        Hm ich verstehe immer noch nicht wie das ganze zusammenhängt. Ich habe aber mal noch ein paar Kleinigkeiten angepasst (und hoffentlich verbessert ;) ).
        Das ist jetzt als v0.7.3 auf github und npm zu finden. Mit der Version nehme ich dann nochmal gerne einen Logauszug vom Start des Adapters.
        Noch was (vermutlich) anderes:
        In deinen letzten Log gab es Meldunge dieses Typs:
        Das spricht auch dafür dass zwischendurch mal irgendwas schief gelaufen ist. Wenn die auch nach einen Adapter Neustart weiterhin auftauchen - und auch nach Löschen der Geräte im Objektbaum (falls das für dich in Frage kommt und nicht irgendwelche Skript oä. zerlegt) weiterhin auftaucht, muss ich da auch nochmal nach gucken.
        P.S. Die ganzen "Nachbarschaftsgeräte" kannst du in der Konfiguration ja auch blockieren, wenn du sie nicht "haben" willst.
        • L lvogt
          @ratte-rizzo
          ratte-rizzo
          #104
          Moin @lvogt
          Irgendwie war das WE voller als gedacht, daher komme ich erst Heute zum Aktualisieren des Adapters. Vielen Dank dafür! Update verlief problemlos. Beim Starten gabs allerdings einen kleinen Fehler im Debug (drittletzte Zeile):
          2021-10-11 07:50:49.338 - info: host.himbeere "system.adapter.wireless-mbus.0" enabled
          2021-10-11 07:50:49.396 - info: host.himbeere instance system.adapter.wireless-mbus.0 started with pid 28005
          2021-10-11 07:50:49.745 - debug: wireless-mbus.0 (28005) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2021-10-11 07:50:49.763 - debug: wireless-mbus.0 (28005) Objects client ready ... initialize now
          2021-10-11 07:50:49.764 - debug: wireless-mbus.0 (28005) Objects create System PubSub Client
          2021-10-11 07:50:49.767 - debug: wireless-mbus.0 (28005) Objects create User PubSub Client
          2021-10-11 07:50:49.768 - debug: wireless-mbus.0 (28005) Objects client initialize lua scripts
          2021-10-11 07:50:49.778 - debug: wireless-mbus.0 (28005) Objects connected to redis: 127.0.0.1:9001
          2021-10-11 07:50:49.781 - debug: wireless-mbus.0 (28005) objectDB connected
          2021-10-11 07:50:49.781 - debug: wireless-mbus.0 (28005) Redis States: Use Redis connection: 127.0.0.1:9000
          2021-10-11 07:50:49.787 - debug: wireless-mbus.0 (28005) States create System PubSub Client
          2021-10-11 07:50:49.787 - debug: wireless-mbus.0 (28005) States create User PubSub Client
          2021-10-11 07:50:49.835 - debug: wireless-mbus.0 (28005) States connected to redis: 127.0.0.1:9000
          2021-10-11 07:50:49.835 - debug: wireless-mbus.0 (28005) statesDB connected
          2021-10-11 07:50:50.031 - info: wireless-mbus.0 (28005) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.21.0, js-controller: 3.3.18
          2021-10-11 07:50:50.063 - debug: wireless-mbus.0 (28005) Created device of type: CUL (untested)
          2021-10-11 07:50:50.074 - debug: wireless-mbus.0 (28005) CUL: Error setting wMBus mode: response was 69BAACC8C788C9A322DFA9BB3046D2E06AB2A6C380C7830064935C90E8002
          bSMODE
          2021-10-11 07:50:50.108 - debug: wireless-mbus.0 (28005) connected set to true
          2021-10-11 07:50:50.151 - debug: wireless-mbus.0 (28005) connected set to true
          Ferner habe ich alle "fremden" Geräte gelöscht. Wenn sie im Laufe des Tages neu angelegt werden, schaue ich mal, ob es noch zu den Fehlermeldungen kommt. Danach werde ich sie dann auf die Blacklist setzen (Danke für den Tipp!!!).
          Bis später
          Daniel
          • R ratte-rizzo
            Moin @lvogt
            bSMODE
            Bis später
            Daniel
            #105
            @ratte-rizzo
            node: v12.21.0
            Halt das aktuell.
            • A andibr
              @lvogt
              Vielen Dank für den Hinweis. Ich habe den ganzen Thread angeschaur aber leider nicht mal die hälfte verstanden, darum habe ich die Frage gestellt.
              Nun habe ich mir mal den i817 Stick bestellt und schaue mal was ich damit hinkriege.
              Vielen Dank für die Arbeit am Adapter.
              Soeben habe ich den Adapter installiert, verstehe ich das richtig, das ich für zwei verschiedene Mode auch verschiedene Stick brauche? Hintergrund der Frage ist eben das ich auch noch Wasserzähler mit WMbus habe. Die haben ein GWF RCM montiert. Da habe ich aber noch keine Ahnung welchen Mode verwendet wird.
              Ideal währe wenn ich dann natürlich gleich alle Zähler auf dem iobroker anzeigen kann.
              Gruss Andi
              andibr
              schrieb am zuletzt editiert von andibr
              #106
              @lvogt Hallo zusammen
              Soeben habe ich meinen heute erhaltenen Stick am Raspberry Pi 3+ eingesteckt und den Adapter auf 0.7.3 aktualisiert. Mein Raspberry ist ein Slave in einem Multihost und sollte eigentlich die Schnittstellen bedienen. Aus irgendwelchen Gründen hat der Adapter alle Einstellungen direkt gefunden und auch bereit etliche Zähler gefunden. Aber nach einem erneuten öffnen der Adaptereinstellungen ist alles wieder leer und ich kann keine Auswahl mehr machen.
              Es ist scheint irgendwie, wie wenn der Adapter eingefroren ist. Das einzige was man noch auswählen kann, ist die Baudrate. Was mache ich falsch?
              Edit: ich denke ich habe da was gefunden, mein Raspberry kann nicht IM817 und 1Wire Stick zusammen. Soweit ich bis jetzt gesehen habe gibt es da ein Konflikt mit dem ttyUSB0.
              • A andibr
                lvogt
                schrieb am zuletzt editiert von lvogt
                #107
                @andibr
                Dein "original" Post ist ja so, dass ich im Grunde gar keine Aussage treffen kann. Ein Log(auszug) oder sonst irgendwas wäre schon nötig. Durch deinen Post alleine hätte ich auch darauf getippt dass auf "Systemebene" irgendwas mit den Serialports hängt.
                Deine Ergänzung legt das nahe. Ich denke aber nicht dass nicht beide zusammen können, sondern du merkst gerade wie viele andere vor dir, dass die Nummerierung der /dev/ttyUSBn Devices nach einen Reboot sich ändern kann (ohne dass einer der USB Geräte aus- und wieder eingesteckt wurde).
                Ich würde dir daher empfehlen, in der Liste der Ports "Benutzerdefinierte Schnittstelle" auszuwählen und dann händisch einen Pfad anzugeben, der sich nicht ändert. Z.b was passendes unter /dev/serial/by-id/... oder einen Symlink der explizit für den wMBus Stick angelegt wird. Der 1-Wire Stick müsste dann natürlich auch entsprechend angesprochen werden...
                @ratte-rizzo
                Genau. Der für mich spannende Teil ist die Fehlermeldung. Allerdings werde ich nur bedingt schlau daraus.
                Das ist ja die Antwort die der CUL schickt: 69BAACC8C788C9A322DFA9BB3046D2E06AB2A6C380C7830064935C90E8002 und bSMODE.
                Erwartet hätte ich eigentlich nur SMODE. Wenn ich den Parser noch etwas verbessere, könnte ich den ersten Teil einfach verwerfen, aber das b vor SMODE verwundert mich schon etwas. Woher ist die Firmware die auf deinem CUL läuft?
                Im Zweifelsfall muss ich doch mal versuchen mich durch den culfw Code zu lesen...
                R A 2 Antworten Letzte Antwort
                • L lvogt
                  @andibr
                  @ratte-rizzo
                  ratte-rizzo
                  schrieb am zuletzt editiert von ratte-rizzo
                  #108
                  Moin @lvogt
                  So, 24 Stunden später. Ich habe gestern ja alle "fremden" Objekte gelöscht. Ich stelle Heute Morgen jedoch fest, dass keine neuen (alten) Objekte angelegt wurden. Ich habe nichts in die Blacklist gesetzt. Soll das so? Meine Geräte werden nach wie vor brav aktualisiert.
                  [Edit] Mittlerweile sind doch alle möglichen anderen Geräte da. Falscher Alarm!
                  Zu den Logs. Beim Datum ärgert er sich immer noch etwas. Da gibts noch eine Fehlermeldung. Das ist bei glaub ich (fast) allen Geräten sehr ähnlich.
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) 2644653204891189350885047a0c0000000b6e0000004b6e000000428c576cbe26326cffff046d3705ab2aae1280
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) Short header
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 0
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9918 value calc 2021-06-30
                  2021-10-11 06:54:52.257 - error: wireless-mbus.0 (18920) invalid date: 65535
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 65535 value calc 2128-03-31
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851063 value calc 2021-10-11 05:55
                  2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) Updating device: LSE-89118904
                  2021-10-11 06:54:52.262 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.1-0-VIF_HCA: 0
                  2021-10-11 06:54:52.264 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.2-1-VIF_HCA: 0
                  2021-10-11 06:54:52.266 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.3-1-VIF_TIME_POINT_DATE: 2021-06-30
                  2021-10-11 06:54:52.268 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.4-0-VIF_TIME_POINT_DATE: 2128-03-31
                  2021-10-11 06:54:52.270 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.5-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 05:55
                  Es gibt aber auch Meldungen, die laufen problemlos durch:
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) 2644653235001289350843207a0c1800000b6e3200004b6e00000042c9ce6cbe26326ca326046d0504ab2a14a680
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) Short header
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 32
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 0
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9918 value calc 2021-06-30
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9891 value calc 2021-06-03
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715850757 value calc 2021-10-11 04:05
                  2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) Updating device: LSE-89120035
                  2021-10-11 05:04:50.022 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.1-0-VIF_HCA: 32
                  2021-10-11 05:04:50.024 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.2-1-VIF_HCA: 0
                  2021-10-11 05:04:50.027 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.3-1-VIF_TIME_POINT_DATE: 2021-06-30
                  2021-10-11 05:04:50.030 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.4-0-VIF_TIME_POINT_DATE: 2021-06-03
                  2021-10-11 05:04:50.033 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.5-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 04:05
                  Dann noch die, wo der Hersteller unbekannt ist:
                  2021-10-11 07:02:04.173 - debug: wireless-mbus.0 (18920) 4f4465b20192342533073f5f780dff5f3500825980356eae350e0a06af207c58030f89d077d7dd8e5929c22b6077f1bad917894aab852b8cb9b532100e026e201f5b09070f30c1bfdb708f84046d0206ab2af3690c7830064935c90e80
                  2021-10-11 07:02:04.173 - debug: wireless-mbus.0 (18920) No header
                  2021-10-11 07:02:04.173 - error: wireless-mbus.0 (18920) WARNING: Unkown manufacturer specific vif: 0x5f
                  2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_TYPE_MANUFACTURER_UNKOWN: Value p[?A0 n259++J Yw`+B)Y]WwP X|
                  5.n5Y
                  2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851266 value calc 2021-10-11 06:02
                  2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_FABRICATION_NO: Value 35490630
                  2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) Updating device: LSE-25349201
                  2021-10-11 07:02:04.180 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN: p[?A0 n259++J Yw`+B)Y]WwP X|
                  5.n5Y
                  2021-10-11 07:02:04.180 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN" has no existing object, this might lead to an error in future versions
                  2021-10-11 07:02:04.223 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 06:02
                  2021-10-11 07:02:04.223 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
                  2021-10-11 07:02:04.267 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.3-0-VIF_FABRICATION_NO: 35490630
                  2021-10-11 07:02:04.268 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.3-0-VIF_FABRICATION_NO" has no existing object, this might lead to an error in future versions
                  Und schließlich noch ein Gerät, was im Log etwas gesprächiger war:
                  2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) 4f4465b20192342533073f5f780dff5f350082598035b6690e87ccbca67ac13a3a8801b3d3a57ee758ced083b2238726e1ada80de29dc7652d9fe565fe5b11cd5d4dc5a3626f72ba8c061331046d0a06ab2affd60c7830064935c90e80
                  2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) No header
                  2021-10-11 07:10:34.173 - error: wireless-mbus.0 (18920) WARNING: Unkown manufacturer specific vif: 0x5f
                  2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) VIF_TYPE_MANUFACTURER_UNKOWN: Value 1:rob#EM[~ee-eGb
                  (-a#2PNXg~%S3::Adebug:="" wireless-mbus.0="" (18920)="" vif_time_point_date_time:="" value="" raw="" 715851274="" calc="" 06:10="" vif_fabrication_no:="" 35490630="" updating="" device:="" lse-25349201="" 07:10:34.177="" lse-25349201.data.1-0-vif_type_manufacturer_unkown:="" 1="" :rob#em[~ee-egb="" (-a#2pnxg~%s3::a:="" state="" "wireless-mbus.0.lse-25349201.data.1-0-vif_type_manufacturer_unkown"="" has="" no="" existing="" object,="" this="" might="" lead="" to="" an="" error="" in="" future="" versions="" 07:10:34.223="" lse-25349201.data.2-0-vif_time_point_date_time:="" 07:10:34.225="" "wireless-mbus.0.lse-25349201.data.2-0-vif_time_point_date_time"="" 07:10:34.267="" lse-25349201.data.3-0-vif_fabrication_no:="" "wireless-mbus.0.lse-25349201.data.3-0-vif_fabrication_no"="" 07:12:43.673="" 4f4465b20192342533073f5f780dff5f3500825980353c6ac1a62271a1390569a9f914af441c42d65eefd0e68d19c79636bf322177137deb64fb1383e6c1752d60d24973bbc32c07b94a59eb046d0c06ab2af1c70c7830064935c90e81="" 07:12:43.674="" header="" error:="" warning:="" unkown="" manufacturer="" specific="" vif:="" 0x5f="" vif_type_manufacturer_unkown:="" kyj9,c;si-uaf{dk}w!2?6="" fpo^vbd="" y)iq"&aj<5�y�="" 715851276="" 06:12="" 07:12:43.678="" 07:12:43.679="" 07:12:43.723="" 07:12:43.724="" 07:12:43.767="" 07:12:43.768="" 07:14:53.673="" 4f4465b20192342533073f5f780dff5f350082598035c7a34607f6cce78aacc5f23deaabcedfac3f0495e387b1ea6dc96ebf11a037b78781211d86a9a808e1be20257f2c9c149254f51cd7ef046d0e06ab2affc20c7830064935c90e80="" owut,="">a()!77 ?nj1c?,_N+j=rE,LvF#G5Y
                  2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851278 value calc 2021-10-11 06:14
                  2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) VIF_FABRICATION_NO: Value 35490630
                  2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) Updating device: LSE-25349201
                  2021-10-11 07:14:53.677 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN: oWuT,>a()!77 ?nj1c?,_N+j=rE,LvF#G5Y
                  2021-10-11 07:14:53.678 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN" has no existing object, this might lead to an error in future versions
                  2021-10-11 07:14:53.719 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 06:14
                  2021-10-11 07:14:53.720 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
                  2021-10-11 07:14:53.763 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.3-0-VIF_FABRICATION_NO: 35490630
                  2021-10-11 07:14:53.764 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.3-0-VIF_FABRICATION_NO" has no existing object, this might lead to an error in future versions
                  Und abschließend noch meine CUL FW Version: V 1.67 CUL868. Das ist angeblich die neueste "offizielle" Version.
                  Dank & Gruß
                  Daniel
                  • L lvogt
                    @andibr
                    @ratte-rizzo
                    andibr
                    #109
                    @lvogt
                    Das merkwürdigste am ganzen ist eben, dass ich mit lsusb beide sehe. Noch kritischer finde ich aber das im syslog beide erkannt und protokoliert wird, das bei den Port ttyUSB0 zugewiesen bekommen haben sollen. Das kann kaum sein, obwohl es funktioniert eben beides nicht mehr. Kann es sein, dass der Rpi 3+ zuwenig RAM hat um beide Schnittstellen zu verwalten und ich auf einen Rpi4 wechseln muss?
                    Ich versuche gerade die Sache mit dem Symlink zu machen, nur ist das etwas doof mit 1Wire hat keine Seriennummer um den Link zu fixieren.
                    Gibt es eine Alternative um die 1Wire Fühler einzulesen. Ich weiss ich könnte ein ESP8266 nehmen, aber das ist im Keller neben dem iobroker Master auch etwas doof. Es sind 13 Fühler und 2 Impulszähler. Beim fhem konnte man direkt auf eine IP zugreifen ohne owserver, dafür habe ich mir eben mit einem DS24.. RS232to1w ein Interface gebaut.
                    Andi
                    • A andibr
                      @lvogt
                      Andi
                      lvogt
                      #110
                      @ratte-rizzo
                      Ich denke das liegt einfach daran, dass das Gerät das so sendet... ist halt ein undefiniertes oder maximal in der Zunkunft liegendes Datum... 🤷
                      Der Hersteller ist nicht unbekannt, sondern der Hersteller hat sich entschieden die Daten mit Typen abseits der Spezifikation zu codieren. Manchmal gibt's in Handbuch Angaben zum Format - oft aber nicht...
                      Falls das Geräte "von dir" sind, könnte ich evtl. bei Gelegenheit mal gucken ob ich was finde.
                      Hm das taucht ja wieder auf. Hast du im Objektbaum Geräte gelöscht und dann den Adapter nicht neugestartet? Dann passiert sowas nämlich auch. Ich sollte das unbedingt mal in die README aufnehmen, dass man nach "herum löschen" im Objektbaum den Adapter neu starten sollte...
                      Das ist ja interessant. Hast du das Log aus der Weboberfläche kopiert oder direkt aus der Datei? Werde ich mir bei Gelegenheit auf jeden Fall mal gucken, damit die Ausgaben nicht das Format zerschießen. Ansonsten halt wie oben auch: Der Hersteller kocht sein eigenes Süppchen.
                      Merkwürdig. Ich habe mittlerweile auch mal in den CUL Sourcecode geguckt und bin immer noch nicht ganz schlau geworden... Im Zweifelsfall werde ich den "Initialisierungskrempel" einfach recht tolerant machen und dann passt das schon...
                      Vielen Dank für deine ganzen Tests :)
                      P.S.: Aus Neugier: Du wohnst nicht in Mitteleuropa, oder? 😇
                      @andibr
                      Wenn das wirklich so ist, dann hat dein zugrunde liegendes Linux System (oder zumindest udev) ein ernstes Problem. Wenn überhaupt kann ich mir vorstellen, dass irgendwo ein Hardware Problem vorliegt, wodurch erst nur das eine und dann nur das andere USB Gerät gefunden wird und daher beides (kurzzeitig) als ttyUSB0 zugewiesen wird. (Defekt könnte ja sowohl auf Seite der USB Geräte als auch auf Seite der Schnittstelle liegen...)
                      Grundsätzlich ist das mit Sicherheit nicht der Fall. KA was du alles so auf dem RPI laufen hast...
                      Ich habe den 1-wire Adapter schon eine Weile nicht mehr verwendet, aber in meiner Erinnerung kann der auch auf einen 1-wire Server zugreifen.
                      Grundsätzlich scheint dein Problem gerade aber eher allgemeiner Natur als spezifisch zum wireless-mbus Adapter zu sein.
                      • L lvogt
                        @ratte-rizzo
                        @andibr
                        ratte-rizzo
                        #111
                        Moin @lvogt
                        Ich wohne in Hamburg. Weiß nicht, wie mittig das in Europa ist 🙃
                        Also, ich hab gerade nochmal den gesamten (!) Objektbaum gelöscht und dann den Adapter neu gestartet. Mal gucken, ob er jetzt noch meckert. Ist ja etwas nervig, dass das immer so lange dauert, aber ich will mal dankbar sein.
                        Ein Gerät von mir ist unter den unknown Meldungen glücklicherweise nicht dabei. Von daher musst Du Dir meinetwegen keine Arbeit machen. Allerdings habe ich auch (noch) keine Wasserzähler. Aber da ich in meinem Baum auch schon welche sehe, gehe ich davon aus, dass wir das selbe Modell bekommen.
                        Zum Abschluss noch einmal das Log vom gesprächigen Gerät. Ich meine, ich hatte es beim letzten Mal auch direkt aus der Datei kopiert, aber zur Sicherheit noch einmal. Wenn die Forensoftware das hier verdriesknaddelt, schicke ich es Dir sonst noch auf anderen Kanälen.
                        Dank & Gruß
                        Daniel
                        • R ratte-rizzo
                          Moin @lvogt
                          Dank & Gruß
                          Daniel
                          lvogt
                          #112
                          @ratte-rizzo
                          Hm, ich hatte irgendwie aus den Uhrzeiten und Inhalt deiner Posts auf "weiter weg" geschlossen 🤷
                          Es gibt jetzt eine Version 0.7.4 die deutlich großzügiger mit der Initialisierung des CULs umgeht und nicht mehr das Log zerschießen sollte ;)
                          Auch wenn es sich anders liest, sind das beides eigentlich nur visuelle Änderungen. Aber es wirkt ja so, als ob der Adapter mit dem CUL auch funktioniert...
                          Nochmal vielen Dank für deine ganzen Tests und Logauszüge. Und ich hoffe mal der Adapter läuft stabil :)
                          • L lvogt
                            @ratte-rizzo
                            ratte-rizzo
                            #113
                            Moin @lvogt
                            Also, erst einmal vielen Dank für das letzte Update. Das Starten funktioniert nun reibungslos!
                            Eine Frage habe ich aber noch bezüglich der Blockierliste: Was genau muss ich dort eintragen? Und was muss ich sonst beachten? Welche Geräteadresse muss da genau rein?
                            • LSE-25342905
                            • wireless-mbus.0.LSE-25342905
                            • etwas anderes?
                              Und wenn ich den Eintrag dann gemacht habe? Datenpunkt löschen und dann Adapter neu starten?
                            Und noch eine Verbesserungsidee: Könnte man die "Unkown manufacturer specific" und "invalid date" Meldungen vielleicht als Warning machen und nicht als Error? Dann könnte ich nämlich das Log-Level auf Error setzen und diese (bei mir) ständigen Meldungen herausfiltern.
                            Ist nur so eine Idee, weiß ja nicht, wie das Log bei anderen Nutzern aussieht.
                            Ein schönes WE wünscht
                            Daniel
                            • L lvogt
                              @ratte-rizzo
                              @andibr
                              andibr
                              #114
                              @lvogt
                              Alles Richtig, ich habe ein Hardware-Problem mit dem 1-Wire USB-Adapter. Da ich es bis jetzt nicht geschafft habe, diesen doofen blauen 1Wire-Adapter so einzubinden, dass er kein Ärger mit dem IM871 macht, läuft da nun halt ein alter Ppi2 mit Raspian und owfs zusätzlich. Ich denke das 1-Wire Zeugs werde ich nach und nach ersetzen und rauswerfen, ausser die Temperaturfühler, die werde ich dann wohl mit einem ESP und ESPEasy und MQTT in den Iobroker übernehmen.
                              Der W-Mbus läuft einwandfrei und erkennt nun auch die Zähler, jetzt muss ich nur noch auf den AES Schlüssel vom EVU/Wasserwerk warten.
                              Gruss aus der Schweiz
                              Andi
                              A 1 Antwort Letzte Antwort
                              • R ratte-rizzo
                                Moin @lvogt
                                • LSE-25342905
                                • etwas anderes?
                                Daniel
                                lvogt
                                #115
                                @ratte-rizzo
                                ja die Einträge müssen wie die Keys vom Typ LSE-25342905 sein. Wenn du die Blockliste speicherst wird der Adapter ja sowieso neugestartet. Danach kannst du dann einfach den LSE-25342905 Knoten im Objektbaum löschen und es sollte nie wieder auftauchen.
                                Eine Hinweis bzw eine Ausname gibt es noch: Manche Telegramme senden unter der ID eines externen wMBus Sendemoduls die Telegramm und erst im "Application Layer" steht die eigentlich ID des Geräts. Im Objektbaum taucht die "eigentliche ID" auf, aber zum blockieren muss die "erste ID" angegeben werden. (Das gilt übrigens auch für AES Schlüssel.)
                                Der Haken: Im Moment kann man ohne selbst Hand anzulegen die ID nicht in ioBroker sehen. (Bei AES Schlüsseln ist das einfacher - da wird ja automatisch der "UNKNOWN" Key Eintrang angelegt...)
                                Die geänderten Loglevel sind wahrscheinlich keine schlechte Idee. Werde mir bei Gelegenheit nochmal insgesamt die Logausgabe vornehmen.
                                • A andibr
                                  @lvogt
                                  Andi
                                  andibr
                                  #116
                                  @lvogt
                                  Also ich habe jetzt auch die AES Schlüssel bekommen, und die Daten aus dem Wasserzähler (GWF Encoder mit RCM) bekomme ich auch angezeigt. Bis jetzt habe ich aber noch keine Muster gesehen, dass er Werte automatisch aktualisieren würde. Kann man mit dem Adapter auch explizit ein Aufrufen anstossen?
                                  @Lenny-CB
                                  Ich habe hier auch einen Easymeter mit aufgesetztem W-Mbus Adapter, dazu habe ich einen Metering Code mit 33 Stellen bekommen, aber damit verabschiedet sich der iob-Adapter gleich. Darf ich dich fragen wieviele Stellen hat das bei dir? Auf nachfrage bei meinem EVU bekamm ich zur Antwort: "Ach, das wissen wir auch nicht, das haben wir als funktionierendes System eingekauft". Nur damit weiss ich noch nicht wieviele Stellen es nun wirklich braucht.
                                  Bei mir gibt es sehr viele Fehler, sprich mein Slave (Mutlihost) mit dem IM871A dran, sagt was von Fehler beim AES Code. Ist ja aber logisch, denn der AES vom Easymeter wir ja nicht erkannt. Ich hoffe das damit nachher fertig ist.
                                  Gruss Andi
                                  A L 2 Antworten Letzte Antwort
                                  • A andibr
                                    @lvogt
                                    @Lenny-CB
                                    Gruss Andi
                                    Al Bundy
                                    #117
                                    @andibr
                                    Hi Andi
                                    Ich habe auch ein GWF Wireless M-Bus Modul bei meinem Gaszähler, den ich mit dem IM871A bei meinem RasPi4 (Master) auslese (ebenfalls das RCM Funkmodul):
                                    Sowohl bei diesem, wie such bei dem Wasserzähler (Apator ultrimis W UL4, siehe Post weiter oben) sind die Sendeintervalle aufgrund des Batteriebetriebs eingeschränkt. Für Durchflüsse wäre dies ungeeignet, diese werden bei mir aber schon gar nicht ausgegeben (also nur m³ und nicht ³/h).
                                    Der Wasserzähler sendet etwa alle 1-5 min Daten. Das GWF Funkmodul aber ist da deutlich unregelmässiger und sendet von 1min Intervall, aber auch schon mal 3 Tage nichts. Da ich den Gasverbrauch auch bei meiner Heizung sehe, habe ich bislang noch nicht wirklich genau dahin geschaut oder Auswertungen gemacht. Das werde ich aber bei Gelegenheit auch mal nachholen (z.B. Tagesverbräuche, Visualisierung in Grafana und ähnliches).
                                    • A andibr
                                      @lvogt
                                      @Lenny-CB
                                      Gruss Andi
                                      lvogt
                                      #118
                                      @andibr
                                      Die meisten Geräte können sowieso keine Nachrichten empfangen. Manche S-Mode Geräte lassen sich tatsächlich auf "Anfrage" auslesen - aber der Adapter kann das nicht.
                                      Es gibt einige Zähler (meistens ältere) die zwar "oft" senden aber zB nur einmal am Tag auch wirklich neue Daten liefern...
                                      Zum AES Key. Der muss 16 Byte lang sein. Heißt also das es entweder ein 32 Zeichen langer Hexstring oder als 16 Zeichen langer "ASCII String" sein muss. 33 Zeichen ist definitv falsch.
                                      • L lvogt
                                        @andibr
                                        andibr
                                        #119
                                        @lvogt
                                        Vielen Dank für die Information, so kann ich nämlich nochmals bei meinem EVU nachfragen und auch etwas lässtig sein. In dem Fall, ist das, was ich erhalten habe irgendwas anderes aber sicher nicht das richtige.
                                        @Al-Bundy
                                        Genau das habe ich eben auch festgestellt, dass erkennen im iob hat sensationell geklappt und nachdem ich dann auch den richtigen AES bekommen habe, wurde innert kürze die Werte auch angezeigt. Nur ist seither nichts mehr nachgetragen worden. Der mechanische Teil des Wasserzähler hat aber schon weitergezählt. Bei uns ist es so, das eben das Wasserwerk 1x im Jahr mit dem Auto an den Häusern vorbei fährt und die Zähler so aufnimmt. Die warten da ja auch nicht bis sich das RCM Modul per Zufall mal meldet. Also wird das GWF Auslesetool schon irgendwie eine Art Broadcost/Callback Funktion aufrufen können.
                                        Es ist klar, das mit dem Wasser ist bei mir einfach so eine "nette spielerei nebenbei". Für die Durchflüsse und Mengen habe ich private Wasserzähler mit Impulsgeber die ich via 1-Wire im Iobroker auslese. Ist auch klar, so gehen immer mal wieder Impulse verloren, aber für das aufzeigen der "Verschwendung" genügt es.
                                        Vielen Dank für die Infos
                                        Andi
                                          Simps
                                          #120
                                          Hi zusammen,
                                          nun habe ich Euren extrem spannenden Threat auswendig gelernt und trau mich, zwei Fragen zu stellen (die die Suche nicht beantwortet):
                                          Hat jemand von Euch Heizkostenverteiler in Betrieb, die er sich selbst aussuchen konnte? Ich würde mir gerne welche von zaehler-plattform.de holen, die wireless MBUS haben. Muss ich da auf was aufpassen? Wie sind die Erfahrungen von Euch mit den Heizkostenverteilern?
                                          Der Adapter unterstützt ja einige USB-Sticks. Ich habe einen Raspy 4, gibt es da eine Preferenz von Euch, welcher am besten funktioniert?
                                          Freue mich sehr über Antwort. Mega Threat! Danke!
                                          Stefan
