  4. Test Adapter wireless-mbus v0.10.x
mbuswirelesswm-buswmbus
576 Beiträge 69 Kommentatoren 255.6k Aufrufe 55 Beobachtet
  • R ratte-rizzo
    Moin @lvogt
    Irgendwie war das WE voller als gedacht, daher komme ich erst Heute zum Aktualisieren des Adapters. Vielen Dank dafür! Update verlief problemlos. Beim Starten gabs allerdings einen kleinen Fehler im Debug (drittletzte Zeile):
    2021-10-11 07:50:49.338 - info: host.himbeere "system.adapter.wireless-mbus.0" enabled
    2021-10-11 07:50:49.396 - info: host.himbeere instance system.adapter.wireless-mbus.0 started with pid 28005
    2021-10-11 07:50:49.745 - debug: wireless-mbus.0 (28005) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-10-11 07:50:49.763 - debug: wireless-mbus.0 (28005) Objects client ready ... initialize now
    2021-10-11 07:50:49.764 - debug: wireless-mbus.0 (28005) Objects create System PubSub Client
    2021-10-11 07:50:49.767 - debug: wireless-mbus.0 (28005) Objects create User PubSub Client
    2021-10-11 07:50:49.768 - debug: wireless-mbus.0 (28005) Objects client initialize lua scripts
    2021-10-11 07:50:49.778 - debug: wireless-mbus.0 (28005) Objects connected to redis: 127.0.0.1:9001
    2021-10-11 07:50:49.781 - debug: wireless-mbus.0 (28005) objectDB connected
    2021-10-11 07:50:49.781 - debug: wireless-mbus.0 (28005) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-10-11 07:50:49.787 - debug: wireless-mbus.0 (28005) States create System PubSub Client
    2021-10-11 07:50:49.787 - debug: wireless-mbus.0 (28005) States create User PubSub Client
    2021-10-11 07:50:49.835 - debug: wireless-mbus.0 (28005) States connected to redis: 127.0.0.1:9000
    2021-10-11 07:50:49.835 - debug: wireless-mbus.0 (28005) statesDB connected
    2021-10-11 07:50:50.031 - info: wireless-mbus.0 (28005) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.21.0, js-controller: 3.3.18
    2021-10-11 07:50:50.063 - debug: wireless-mbus.0 (28005) Created device of type: CUL (untested)
    2021-10-11 07:50:50.074 - debug: wireless-mbus.0 (28005) CUL: Error setting wMBus mode: response was 69BAACC8C788C9A322DFA9BB3046D2E06AB2A6C380C7830064935C90E8002
    bSMODE
    2021-10-11 07:50:50.108 - debug: wireless-mbus.0 (28005) connected set to true
    2021-10-11 07:50:50.151 - debug: wireless-mbus.0 (28005) connected set to true
    Ferner habe ich alle "fremden" Geräte gelöscht. Wenn sie im Laufe des Tages neu angelegt werden, schaue ich mal, ob es noch zu den Fehlermeldungen kommt. Danach werde ich sie dann auf die Blacklist setzen (Danke für den Tipp!!!).
    Bis später
    Daniel
    #105
    @ratte-rizzo
    node: v12.21.0
    Halt das aktuell.
    • A andibr
      @lvogt
      Vielen Dank für den Hinweis. Ich habe den ganzen Thread angeschaur aber leider nicht mal die hälfte verstanden, darum habe ich die Frage gestellt.
      Nun habe ich mir mal den i817 Stick bestellt und schaue mal was ich damit hinkriege.
      Vielen Dank für die Arbeit am Adapter.
      Soeben habe ich den Adapter installiert, verstehe ich das richtig, das ich für zwei verschiedene Mode auch verschiedene Stick brauche? Hintergrund der Frage ist eben das ich auch noch Wasserzähler mit WMbus habe. Die haben ein GWF RCM montiert. Da habe ich aber noch keine Ahnung welchen Mode verwendet wird.
      Ideal währe wenn ich dann natürlich gleich alle Zähler auf dem iobroker anzeigen kann.
      Gruss Andi
      andibr
      schrieb am zuletzt editiert von andibr
      #106
      @lvogt Hallo zusammen
      Soeben habe ich meinen heute erhaltenen Stick am Raspberry Pi 3+ eingesteckt und den Adapter auf 0.7.3 aktualisiert. Mein Raspberry ist ein Slave in einem Multihost und sollte eigentlich die Schnittstellen bedienen. Aus irgendwelchen Gründen hat der Adapter alle Einstellungen direkt gefunden und auch bereit etliche Zähler gefunden. Aber nach einem erneuten öffnen der Adaptereinstellungen ist alles wieder leer und ich kann keine Auswahl mehr machen.
      Es ist scheint irgendwie, wie wenn der Adapter eingefroren ist. Das einzige was man noch auswählen kann, ist die Baudrate. Was mache ich falsch?
      Edit: ich denke ich habe da was gefunden, mein Raspberry kann nicht IM817 und 1Wire Stick zusammen. Soweit ich bis jetzt gesehen habe gibt es da ein Konflikt mit dem ttyUSB0.
      L 1 Antwort Letzte Antwort
      • A andibr
        lvogt
        schrieb am zuletzt editiert von lvogt
        #107
        @andibr
        Dein "original" Post ist ja so, dass ich im Grunde gar keine Aussage treffen kann. Ein Log(auszug) oder sonst irgendwas wäre schon nötig. Durch deinen Post alleine hätte ich auch darauf getippt dass auf "Systemebene" irgendwas mit den Serialports hängt.
        Deine Ergänzung legt das nahe. Ich denke aber nicht dass nicht beide zusammen können, sondern du merkst gerade wie viele andere vor dir, dass die Nummerierung der /dev/ttyUSBn Devices nach einen Reboot sich ändern kann (ohne dass einer der USB Geräte aus- und wieder eingesteckt wurde).
        Ich würde dir daher empfehlen, in der Liste der Ports "Benutzerdefinierte Schnittstelle" auszuwählen und dann händisch einen Pfad anzugeben, der sich nicht ändert. Z.b was passendes unter /dev/serial/by-id/... oder einen Symlink der explizit für den wMBus Stick angelegt wird. Der 1-Wire Stick müsste dann natürlich auch entsprechend angesprochen werden...
        @ratte-rizzo
        Genau. Der für mich spannende Teil ist die Fehlermeldung. Allerdings werde ich nur bedingt schlau daraus.
        Das ist ja die Antwort die der CUL schickt: 69BAACC8C788C9A322DFA9BB3046D2E06AB2A6C380C7830064935C90E8002 und bSMODE.
        Erwartet hätte ich eigentlich nur SMODE. Wenn ich den Parser noch etwas verbessere, könnte ich den ersten Teil einfach verwerfen, aber das b vor SMODE verwundert mich schon etwas. Woher ist die Firmware die auf deinem CUL läuft?
        Im Zweifelsfall muss ich doch mal versuchen mich durch den culfw Code zu lesen...
        R A 2 Antworten Letzte Antwort
        • L lvogt
          @andibr
          @ratte-rizzo
          ratte-rizzo
          schrieb am zuletzt editiert von ratte-rizzo
          #108
          Moin @lvogt
          So, 24 Stunden später. Ich habe gestern ja alle "fremden" Objekte gelöscht. Ich stelle Heute Morgen jedoch fest, dass keine neuen (alten) Objekte angelegt wurden. Ich habe nichts in die Blacklist gesetzt. Soll das so? Meine Geräte werden nach wie vor brav aktualisiert.
          [Edit] Mittlerweile sind doch alle möglichen anderen Geräte da. Falscher Alarm!
          Zu den Logs. Beim Datum ärgert er sich immer noch etwas. Da gibts noch eine Fehlermeldung. Das ist bei glaub ich (fast) allen Geräten sehr ähnlich.
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) 2644653204891189350885047a0c0000000b6e0000004b6e000000428c576cbe26326cffff046d3705ab2aae1280
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) Short header
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 0
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9918 value calc 2021-06-30
          2021-10-11 06:54:52.257 - error: wireless-mbus.0 (18920) invalid date: 65535
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 65535 value calc 2128-03-31
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851063 value calc 2021-10-11 05:55
          2021-10-11 06:54:52.257 - debug: wireless-mbus.0 (18920) Updating device: LSE-89118904
          2021-10-11 06:54:52.262 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.1-0-VIF_HCA: 0
          2021-10-11 06:54:52.264 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.2-1-VIF_HCA: 0
          2021-10-11 06:54:52.266 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.3-1-VIF_TIME_POINT_DATE: 2021-06-30
          2021-10-11 06:54:52.268 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.4-0-VIF_TIME_POINT_DATE: 2128-03-31
          2021-10-11 06:54:52.270 - debug: wireless-mbus.0 (18920) Value LSE-89118904.data.5-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 05:55
          Es gibt aber auch Meldungen, die laufen problemlos durch:
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) 2644653235001289350843207a0c1800000b6e3200004b6e00000042c9ce6cbe26326ca326046d0504ab2a14a680
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) Short header
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 32
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_HCA: Value 0
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9918 value calc 2021-06-30
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE: Value raw 9891 value calc 2021-06-03
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715850757 value calc 2021-10-11 04:05
          2021-10-11 05:04:50.017 - debug: wireless-mbus.0 (18920) Updating device: LSE-89120035
          2021-10-11 05:04:50.022 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.1-0-VIF_HCA: 32
          2021-10-11 05:04:50.024 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.2-1-VIF_HCA: 0
          2021-10-11 05:04:50.027 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.3-1-VIF_TIME_POINT_DATE: 2021-06-30
          2021-10-11 05:04:50.030 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.4-0-VIF_TIME_POINT_DATE: 2021-06-03
          2021-10-11 05:04:50.033 - debug: wireless-mbus.0 (18920) Value LSE-89120035.data.5-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 04:05
          Dann noch die, wo der Hersteller unbekannt ist:
          2021-10-11 07:02:04.173 - debug: wireless-mbus.0 (18920) 4f4465b20192342533073f5f780dff5f3500825980356eae350e0a06af207c58030f89d077d7dd8e5929c22b6077f1bad917894aab852b8cb9b532100e026e201f5b09070f30c1bfdb708f84046d0206ab2af3690c7830064935c90e80
          2021-10-11 07:02:04.173 - debug: wireless-mbus.0 (18920) No header
          2021-10-11 07:02:04.173 - error: wireless-mbus.0 (18920) WARNING: Unkown manufacturer specific vif: 0x5f
          2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_TYPE_MANUFACTURER_UNKOWN: Value p[?A0 n259++J Yw`+B)Y]WwP X|
          5.n5Y
          2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851266 value calc 2021-10-11 06:02
          2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) VIF_FABRICATION_NO: Value 35490630
          2021-10-11 07:02:04.174 - debug: wireless-mbus.0 (18920) Updating device: LSE-25349201
          2021-10-11 07:02:04.180 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN: p[?A0 n259++J Yw`+B)Y]WwP X|
          5.n5Y
          2021-10-11 07:02:04.180 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN" has no existing object, this might lead to an error in future versions
          2021-10-11 07:02:04.223 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 06:02
          2021-10-11 07:02:04.223 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
          2021-10-11 07:02:04.267 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.3-0-VIF_FABRICATION_NO: 35490630
          2021-10-11 07:02:04.268 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.3-0-VIF_FABRICATION_NO" has no existing object, this might lead to an error in future versions
          Und schließlich noch ein Gerät, was im Log etwas gesprächiger war:
          2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) 4f4465b20192342533073f5f780dff5f350082598035b6690e87ccbca67ac13a3a8801b3d3a57ee758ced083b2238726e1ada80de29dc7652d9fe565fe5b11cd5d4dc5a3626f72ba8c061331046d0a06ab2affd60c7830064935c90e80
          2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) No header
          2021-10-11 07:10:34.173 - error: wireless-mbus.0 (18920) WARNING: Unkown manufacturer specific vif: 0x5f
          2021-10-11 07:10:34.173 - debug: wireless-mbus.0 (18920) VIF_TYPE_MANUFACTURER_UNKOWN: Value 1:rob#EM[~ee-eGb
          (-a#2PNXg~%S3::Adebug:="" wireless-mbus.0="" (18920)="" vif_time_point_date_time:="" value="" raw="" 715851274="" calc="" 06:10="" vif_fabrication_no:="" 35490630="" updating="" device:="" lse-25349201="" 07:10:34.177="" lse-25349201.data.1-0-vif_type_manufacturer_unkown:="" 1="" :rob#em[~ee-egb="" (-a#2pnxg~%s3::a:="" state="" "wireless-mbus.0.lse-25349201.data.1-0-vif_type_manufacturer_unkown"="" has="" no="" existing="" object,="" this="" might="" lead="" to="" an="" error="" in="" future="" versions="" 07:10:34.223="" lse-25349201.data.2-0-vif_time_point_date_time:="" 07:10:34.225="" "wireless-mbus.0.lse-25349201.data.2-0-vif_time_point_date_time"="" 07:10:34.267="" lse-25349201.data.3-0-vif_fabrication_no:="" "wireless-mbus.0.lse-25349201.data.3-0-vif_fabrication_no"="" 07:12:43.673="" 4f4465b20192342533073f5f780dff5f3500825980353c6ac1a62271a1390569a9f914af441c42d65eefd0e68d19c79636bf322177137deb64fb1383e6c1752d60d24973bbc32c07b94a59eb046d0c06ab2af1c70c7830064935c90e81="" 07:12:43.674="" header="" error:="" warning:="" unkown="" manufacturer="" specific="" vif:="" 0x5f="" vif_type_manufacturer_unkown:="" kyj9,c;si-uaf{dk}w!2?6="" fpo^vbd="" y)iq"&aj<5�y�="" 715851276="" 06:12="" 07:12:43.678="" 07:12:43.679="" 07:12:43.723="" 07:12:43.724="" 07:12:43.767="" 07:12:43.768="" 07:14:53.673="" 4f4465b20192342533073f5f780dff5f350082598035c7a34607f6cce78aacc5f23deaabcedfac3f0495e387b1ea6dc96ebf11a037b78781211d86a9a808e1be20257f2c9c149254f51cd7ef046d0e06ab2affc20c7830064935c90e80="" owut,="">a()!77 ?nj1c?,_N+j=rE,LvF#G5Y
          2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) VIF_TIME_POINT_DATE_TIME: Value raw 715851278 value calc 2021-10-11 06:14
          2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) VIF_FABRICATION_NO: Value 35490630
          2021-10-11 07:14:53.673 - debug: wireless-mbus.0 (18920) Updating device: LSE-25349201
          2021-10-11 07:14:53.677 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN: oWuT,>a()!77 ?nj1c?,_N+j=rE,LvF#G5Y
          2021-10-11 07:14:53.678 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.1-0-VIF_TYPE_MANUFACTURER_UNKOWN" has no existing object, this might lead to an error in future versions
          2021-10-11 07:14:53.719 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME: 2021-10-11 06:14
          2021-10-11 07:14:53.720 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.2-0-VIF_TIME_POINT_DATE_TIME" has no existing object, this might lead to an error in future versions
          2021-10-11 07:14:53.763 - debug: wireless-mbus.0 (18920) Value LSE-25349201.data.3-0-VIF_FABRICATION_NO: 35490630
          2021-10-11 07:14:53.764 - warn: wireless-mbus.0 (18920) State "wireless-mbus.0.LSE-25349201.data.3-0-VIF_FABRICATION_NO" has no existing object, this might lead to an error in future versions
          Und abschließend noch meine CUL FW Version: V 1.67 CUL868. Das ist angeblich die neueste "offizielle" Version.
          Dank & Gruß
          Daniel
          • L lvogt
            @andibr
            @ratte-rizzo
            andibr
            #109
            @lvogt
            Das merkwürdigste am ganzen ist eben, dass ich mit lsusb beide sehe. Noch kritischer finde ich aber das im syslog beide erkannt und protokoliert wird, das bei den Port ttyUSB0 zugewiesen bekommen haben sollen. Das kann kaum sein, obwohl es funktioniert eben beides nicht mehr. Kann es sein, dass der Rpi 3+ zuwenig RAM hat um beide Schnittstellen zu verwalten und ich auf einen Rpi4 wechseln muss?
            Ich versuche gerade die Sache mit dem Symlink zu machen, nur ist das etwas doof mit 1Wire hat keine Seriennummer um den Link zu fixieren.
            Gibt es eine Alternative um die 1Wire Fühler einzulesen. Ich weiss ich könnte ein ESP8266 nehmen, aber das ist im Keller neben dem iobroker Master auch etwas doof. Es sind 13 Fühler und 2 Impulszähler. Beim fhem konnte man direkt auf eine IP zugreifen ohne owserver, dafür habe ich mir eben mit einem DS24.. RS232to1w ein Interface gebaut.
            Andi
            • A andibr
              @lvogt
              Andi
              lvogt
              #110
              @ratte-rizzo
              Ich denke das liegt einfach daran, dass das Gerät das so sendet... ist halt ein undefiniertes oder maximal in der Zunkunft liegendes Datum... 🤷
              Der Hersteller ist nicht unbekannt, sondern der Hersteller hat sich entschieden die Daten mit Typen abseits der Spezifikation zu codieren. Manchmal gibt's in Handbuch Angaben zum Format - oft aber nicht...
              Falls das Geräte "von dir" sind, könnte ich evtl. bei Gelegenheit mal gucken ob ich was finde.
              Hm das taucht ja wieder auf. Hast du im Objektbaum Geräte gelöscht und dann den Adapter nicht neugestartet? Dann passiert sowas nämlich auch. Ich sollte das unbedingt mal in die README aufnehmen, dass man nach "herum löschen" im Objektbaum den Adapter neu starten sollte...
              Das ist ja interessant. Hast du das Log aus der Weboberfläche kopiert oder direkt aus der Datei? Werde ich mir bei Gelegenheit auf jeden Fall mal gucken, damit die Ausgaben nicht das Format zerschießen. Ansonsten halt wie oben auch: Der Hersteller kocht sein eigenes Süppchen.
              Merkwürdig. Ich habe mittlerweile auch mal in den CUL Sourcecode geguckt und bin immer noch nicht ganz schlau geworden... Im Zweifelsfall werde ich den "Initialisierungskrempel" einfach recht tolerant machen und dann passt das schon...
              Vielen Dank für deine ganzen Tests :)
              P.S.: Aus Neugier: Du wohnst nicht in Mitteleuropa, oder? 😇
              @andibr
              Wenn das wirklich so ist, dann hat dein zugrunde liegendes Linux System (oder zumindest udev) ein ernstes Problem. Wenn überhaupt kann ich mir vorstellen, dass irgendwo ein Hardware Problem vorliegt, wodurch erst nur das eine und dann nur das andere USB Gerät gefunden wird und daher beides (kurzzeitig) als ttyUSB0 zugewiesen wird. (Defekt könnte ja sowohl auf Seite der USB Geräte als auch auf Seite der Schnittstelle liegen...)
              Grundsätzlich ist das mit Sicherheit nicht der Fall. KA was du alles so auf dem RPI laufen hast...
              Ich habe den 1-wire Adapter schon eine Weile nicht mehr verwendet, aber in meiner Erinnerung kann der auch auf einen 1-wire Server zugreifen.
              Grundsätzlich scheint dein Problem gerade aber eher allgemeiner Natur als spezifisch zum wireless-mbus Adapter zu sein.
              • L lvogt
                @ratte-rizzo
                @andibr
                ratte-rizzo
                #111
                Moin @lvogt
                Ich wohne in Hamburg. Weiß nicht, wie mittig das in Europa ist 🙃
                Also, ich hab gerade nochmal den gesamten (!) Objektbaum gelöscht und dann den Adapter neu gestartet. Mal gucken, ob er jetzt noch meckert. Ist ja etwas nervig, dass das immer so lange dauert, aber ich will mal dankbar sein.
                Ein Gerät von mir ist unter den unknown Meldungen glücklicherweise nicht dabei. Von daher musst Du Dir meinetwegen keine Arbeit machen. Allerdings habe ich auch (noch) keine Wasserzähler. Aber da ich in meinem Baum auch schon welche sehe, gehe ich davon aus, dass wir das selbe Modell bekommen.
                Zum Abschluss noch einmal das Log vom gesprächigen Gerät. Ich meine, ich hatte es beim letzten Mal auch direkt aus der Datei kopiert, aber zur Sicherheit noch einmal. Wenn die Forensoftware das hier verdriesknaddelt, schicke ich es Dir sonst noch auf anderen Kanälen.
                Dank & Gruß
                Daniel
                • R ratte-rizzo
                  Moin @lvogt
                  Dank & Gruß
                  Daniel
                  lvogt
                  #112
                  @ratte-rizzo
                  Hm, ich hatte irgendwie aus den Uhrzeiten und Inhalt deiner Posts auf "weiter weg" geschlossen 🤷
                  Es gibt jetzt eine Version 0.7.4 die deutlich großzügiger mit der Initialisierung des CULs umgeht und nicht mehr das Log zerschießen sollte ;)
                  Auch wenn es sich anders liest, sind das beides eigentlich nur visuelle Änderungen. Aber es wirkt ja so, als ob der Adapter mit dem CUL auch funktioniert...
                  Nochmal vielen Dank für deine ganzen Tests und Logauszüge. Und ich hoffe mal der Adapter läuft stabil :)
                  R 1 Antwort Letzte Antwort
                  • L lvogt
                    @ratte-rizzo
                    ratte-rizzo
                    #113
                    Moin @lvogt
                    Also, erst einmal vielen Dank für das letzte Update. Das Starten funktioniert nun reibungslos!
                    Eine Frage habe ich aber noch bezüglich der Blockierliste: Was genau muss ich dort eintragen? Und was muss ich sonst beachten? Welche Geräteadresse muss da genau rein?
                    • LSE-25342905
                    • wireless-mbus.0.LSE-25342905
                    • etwas anderes?
                      Und wenn ich den Eintrag dann gemacht habe? Datenpunkt löschen und dann Adapter neu starten?
                    Und noch eine Verbesserungsidee: Könnte man die "Unkown manufacturer specific" und "invalid date" Meldungen vielleicht als Warning machen und nicht als Error? Dann könnte ich nämlich das Log-Level auf Error setzen und diese (bei mir) ständigen Meldungen herausfiltern.
                    Ist nur so eine Idee, weiß ja nicht, wie das Log bei anderen Nutzern aussieht.
                    Ein schönes WE wünscht
                    Daniel
                    • L lvogt
                      @ratte-rizzo
                      @andibr
                      andibr
                      #114
                      @lvogt
                      Alles Richtig, ich habe ein Hardware-Problem mit dem 1-Wire USB-Adapter. Da ich es bis jetzt nicht geschafft habe, diesen doofen blauen 1Wire-Adapter so einzubinden, dass er kein Ärger mit dem IM871 macht, läuft da nun halt ein alter Ppi2 mit Raspian und owfs zusätzlich. Ich denke das 1-Wire Zeugs werde ich nach und nach ersetzen und rauswerfen, ausser die Temperaturfühler, die werde ich dann wohl mit einem ESP und ESPEasy und MQTT in den Iobroker übernehmen.
                      Der W-Mbus läuft einwandfrei und erkennt nun auch die Zähler, jetzt muss ich nur noch auf den AES Schlüssel vom EVU/Wasserwerk warten.
                      Gruss aus der Schweiz
                      Andi
                      • R ratte-rizzo
                        Moin @lvogt
                        • LSE-25342905
                        • etwas anderes?
                        Daniel
                        lvogt
                        #115
                        @ratte-rizzo
                        ja die Einträge müssen wie die Keys vom Typ LSE-25342905 sein. Wenn du die Blockliste speicherst wird der Adapter ja sowieso neugestartet. Danach kannst du dann einfach den LSE-25342905 Knoten im Objektbaum löschen und es sollte nie wieder auftauchen.
                        Eine Hinweis bzw eine Ausname gibt es noch: Manche Telegramme senden unter der ID eines externen wMBus Sendemoduls die Telegramm und erst im "Application Layer" steht die eigentlich ID des Geräts. Im Objektbaum taucht die "eigentliche ID" auf, aber zum blockieren muss die "erste ID" angegeben werden. (Das gilt übrigens auch für AES Schlüssel.)
                        Der Haken: Im Moment kann man ohne selbst Hand anzulegen die ID nicht in ioBroker sehen. (Bei AES Schlüsseln ist das einfacher - da wird ja automatisch der "UNKNOWN" Key Eintrang angelegt...)
                        Die geänderten Loglevel sind wahrscheinlich keine schlechte Idee. Werde mir bei Gelegenheit nochmal insgesamt die Logausgabe vornehmen.
                        • A andibr
                          @lvogt
                          Andi
                          andibr
                          #116
                          @lvogt
                          Also ich habe jetzt auch die AES Schlüssel bekommen, und die Daten aus dem Wasserzähler (GWF Encoder mit RCM) bekomme ich auch angezeigt. Bis jetzt habe ich aber noch keine Muster gesehen, dass er Werte automatisch aktualisieren würde. Kann man mit dem Adapter auch explizit ein Aufrufen anstossen?
                          @Lenny-CB
                          Ich habe hier auch einen Easymeter mit aufgesetztem W-Mbus Adapter, dazu habe ich einen Metering Code mit 33 Stellen bekommen, aber damit verabschiedet sich der iob-Adapter gleich. Darf ich dich fragen wieviele Stellen hat das bei dir? Auf nachfrage bei meinem EVU bekamm ich zur Antwort: "Ach, das wissen wir auch nicht, das haben wir als funktionierendes System eingekauft". Nur damit weiss ich noch nicht wieviele Stellen es nun wirklich braucht.
                          Bei mir gibt es sehr viele Fehler, sprich mein Slave (Mutlihost) mit dem IM871A dran, sagt was von Fehler beim AES Code. Ist ja aber logisch, denn der AES vom Easymeter wir ja nicht erkannt. Ich hoffe das damit nachher fertig ist.
                          Gruss Andi
                          A L 2 Antworten Letzte Antwort
                          • A andibr
                            @lvogt
                            @Lenny-CB
                            Gruss Andi
                            Al Bundy
                            #117
                            @andibr
                            Hi Andi
                            Ich habe auch ein GWF Wireless M-Bus Modul bei meinem Gaszähler, den ich mit dem IM871A bei meinem RasPi4 (Master) auslese (ebenfalls das RCM Funkmodul):
                            Sowohl bei diesem, wie such bei dem Wasserzähler (Apator ultrimis W UL4, siehe Post weiter oben) sind die Sendeintervalle aufgrund des Batteriebetriebs eingeschränkt. Für Durchflüsse wäre dies ungeeignet, diese werden bei mir aber schon gar nicht ausgegeben (also nur m³ und nicht ³/h).
                            Der Wasserzähler sendet etwa alle 1-5 min Daten. Das GWF Funkmodul aber ist da deutlich unregelmässiger und sendet von 1min Intervall, aber auch schon mal 3 Tage nichts. Da ich den Gasverbrauch auch bei meiner Heizung sehe, habe ich bislang noch nicht wirklich genau dahin geschaut oder Auswertungen gemacht. Das werde ich aber bei Gelegenheit auch mal nachholen (z.B. Tagesverbräuche, Visualisierung in Grafana und ähnliches).
                            • A andibr
                              @lvogt
                              @Lenny-CB
                              Gruss Andi
                              lvogt
                              #118
                              @andibr
                              Die meisten Geräte können sowieso keine Nachrichten empfangen. Manche S-Mode Geräte lassen sich tatsächlich auf "Anfrage" auslesen - aber der Adapter kann das nicht.
                              Es gibt einige Zähler (meistens ältere) die zwar "oft" senden aber zB nur einmal am Tag auch wirklich neue Daten liefern...
                              Zum AES Key. Der muss 16 Byte lang sein. Heißt also das es entweder ein 32 Zeichen langer Hexstring oder als 16 Zeichen langer "ASCII String" sein muss. 33 Zeichen ist definitv falsch.
                              • L lvogt
                                @andibr
                                andibr
                                #119
                                @lvogt
                                Vielen Dank für die Information, so kann ich nämlich nochmals bei meinem EVU nachfragen und auch etwas lässtig sein. In dem Fall, ist das, was ich erhalten habe irgendwas anderes aber sicher nicht das richtige.
                                @Al-Bundy
                                Genau das habe ich eben auch festgestellt, dass erkennen im iob hat sensationell geklappt und nachdem ich dann auch den richtigen AES bekommen habe, wurde innert kürze die Werte auch angezeigt. Nur ist seither nichts mehr nachgetragen worden. Der mechanische Teil des Wasserzähler hat aber schon weitergezählt. Bei uns ist es so, das eben das Wasserwerk 1x im Jahr mit dem Auto an den Häusern vorbei fährt und die Zähler so aufnimmt. Die warten da ja auch nicht bis sich das RCM Modul per Zufall mal meldet. Also wird das GWF Auslesetool schon irgendwie eine Art Broadcost/Callback Funktion aufrufen können.
                                Es ist klar, das mit dem Wasser ist bei mir einfach so eine "nette spielerei nebenbei". Für die Durchflüsse und Mengen habe ich private Wasserzähler mit Impulsgeber die ich via 1-Wire im Iobroker auslese. Ist auch klar, so gehen immer mal wieder Impulse verloren, aber für das aufzeigen der "Verschwendung" genügt es.
                                Vielen Dank für die Infos
                                Andi
                                  Simps
                                  #120
                                  Hi zusammen,
                                  nun habe ich Euren extrem spannenden Threat auswendig gelernt und trau mich, zwei Fragen zu stellen (die die Suche nicht beantwortet):
                                  Hat jemand von Euch Heizkostenverteiler in Betrieb, die er sich selbst aussuchen konnte? Ich würde mir gerne welche von zaehler-plattform.de holen, die wireless MBUS haben. Muss ich da auf was aufpassen? Wie sind die Erfahrungen von Euch mit den Heizkostenverteilern?
                                  Der Adapter unterstützt ja einige USB-Sticks. Ich habe einen Raspy 4, gibt es da eine Preferenz von Euch, welcher am besten funktioniert?
                                  Freue mich sehr über Antwort. Mega Threat! Danke!
                                  Stefan
                                  • S Simps
                                    Hi zusammen,
                                    Stefan
                                    Simps
                                    #121
                                    Sorry, vmtl. ist das eine zu blöde Frage, aber wie installiere ich den Adapter?
                                    Ich lese oben, er ist auf github und npm, aber im iobroker bekomme ich ihn unter dem nmp oder dem github-Reiter (im Expertenmodus) einfach nicht angezeigt. 😵
                                    • S Simps
                                      lvogt
                                      #122
                                      @simps
                                      Hi Simps,
                                      grundsätzlich habe ich beim Entwickeln sehr viel mit dem Amber Stick getestet. Die meiste Zeit im T Mode, da fand ich ihn sehr stabil. Später musste ich dann feststellen, dass er im C Mode gerne mal "abstürzt" (also der Stick selbst), sodass einmal aus dem USB Port ziehen, kurz warten, wieder einstecken nötig war.
                                      Ich selbst verwende den Adapter allerdings schon eine ganze Weile nicht mehr.
                                      Zum HKV kann ich nicht wirklich was sagen. Auf den ersten Blick behaupten die HKV auf der von dir verlinkten Seite sie würde OMS konform senden, das sollte heißen, dass der Adapter damit auch was anfangen kann - garantieren kann ich dir das natürlich nicht. Grundsätzlich möchte ich aber auch nochmal darauf hinweisen, dass du damit ja keine direkten Verbräuche oder Energien messen kannst.
                                      Ja das Installfenster im ioBroker finde ich auch nicht besonders gelungen. Die beiden von dir versuchten Varianten (so weit ich das verstanden habe) erlauben dir nur einen Adapter, der sich bereits in der ioBroker Adapter Liste befindet, wahlweise von GitHub oder npm zu installieren.
                                      So lange dieser Adapter also noch nicht in die Liste aufgenommen wurde, musst du "Benutzerdefiniert" in dem Fenstern auswählen. Als "URL" kannst du entweder nur "iobroker.wireless-mbus" angeben, dann wird der Adapter von npm installiert, oder du gibst den ganzen Pfad zum github Repository an. Sollte am Ende aber aufs gleiche rauskommen.
                                      S sonnenscheinS 2 Antworten Letzte Antwort
                                      • A andibr
                                        @lvogt
                                        @Al-Bundy
                                        Andi
                                        Al Bundy
                                        schrieb am zuletzt editiert von Al Bundy
                                        #123
                                        @andibr Hi Andi
                                        Habe mal die Logfunktion des GWF RCM meines Gaszählers angepasst und alle Daten aufgezeichnet (Haken raus bei "nur Änderungen aufzeichnen").
                                        Es ist nicht so, dass das Funkmodul nicht sendet. Daten kommen regelmässig an.
                                        Es scheint aber so, dass die Daten nur einmal pro Tag angepasst werden. Es muss also kein Aktivierungscode oder ähnliches gesendet werden. Die Werte werden wohl Zwischengespeichert.
                                        Dazu folgende Grafiken:
                                        Grün und Skala links ist der effektive Zählerwert in m³. Er ändert nur 1x täglich um etwa 01:30 Uhr (Zählerwert bei etwa 6'400 m³). Gelb und Skala rechts ist der Zählerwert pro Tag, ebenfalls in m³ (etwa 3m³):
                                        Meine Heizung errechnet ebenfalls den Gasverbrauch in kWh. Die m³ des Gaszählers wird gemäss Abrechnung mit dem Faktor 10.545 errechnet. So kann ich diese vergleichen (dabei ist mir bekannt, dass die Heizung um etwa 15% zu tiefe Werte anzeigt).
                                        Hier die Grafik: gelb nochmals die Tageswerte des Zählers umgerechnet in kWh und blau die Verbrauchswerte der Heizung:
                                        Hier schön zu sehen, dass die Werte des RWS nur 1x pro Tag geändert werden, obschon durch den Tag Gas bezogen wird und auch, dass diese immer leicht höher sind, als die Verbrauchswerte der Viessmann Heizung.
                                        Denke mal mehr Daten wird es vom RCM Modul nicht geben. Für die Drive-By Zählerauslesung ist es ja auch egal, wenn nur alle 24h der Wert aktualisiert wird. Um Tagesverläufe oder gar Durchflussmessungen zu realisieren, muss wohl näher am Zählerwerk gelesen werden...
                                        • L lvogt
                                          @simps
                                          Hi Simps,
                                          Simps
                                          #124
                                          @lvogt Super, vielen Dank, ich probiere das alles aus, das hat mir schon mal geholfen!
