  4. Weatherunderground Reborn 3.0.0 Alpha
weatherundergroundwetteradapter
225 Beiträge 23 Kommentatoren 49.5k Aufrufe 30 Beobachtet
  • apollon77A apollon77
    @dos1973 Bitte mal die Einstellungen und ein Debug-Log von einem Lauf posten.
    dos1973
    #101
    @apollon77
    anbei das Log
    host.ioBroker	2019-04-07 12:51:05.115	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
    weatherunderground.0	2019-04-07 12:51:02.851	debug	all forecast values set
    weatherunderground.0	2019-04-07 12:51:02.851	debug	all current conditions values set
    weatherunderground.0	2019-04-07 12:51:01.278	debug	get WU legacy data: http://api.wunderground.com/api/606f3f6977348613/forecast/hourly/conditions/units:m/lang:DL/q/pws:IBADHOMB116.json
    weatherunderground.0	2019-04-07 12:51:01.278	debug	Use legacy API Key 606f3f6977348613
    weatherunderground.0	2019-04-07 12:51:01.278	debug	Use Legacy API
    weatherunderground.0	2019-04-07 12:51:01.278	debug	location has not changed, reuse extracted URLs
    weatherunderground.0	2019-04-07 12:51:01.262	debug	initialize Hourly Forecast Url: https://api.weather.com/v1/geocode/50.21/8.64/forecast/hourly/240hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
    weatherunderground.0	2019-04-07 12:51:01.260	debug	initialize Daily Forecast Url: https://api.weather.com/v1/geocode/50.21/8.64/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
    weatherunderground.0	2019-04-07 12:51:01.245	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IBADHOMB116&format=json
    weatherunderground.0	2019-04-07 12:51:01.241	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
    weatherunderground.0	2019-04-07 12:51:01.226	debug	initialize PWS Station Key: 606f3f6977348613
    weatherunderground.0	2019-04-07 12:51:01.143	debug	init forecast objects
    weatherunderground.0	2019-04-07 12:51:01.143	debug	init conditions objects
    weatherunderground.0	2019-04-07 12:51:01.143	debug	on ready: DL true true true true
    weatherunderground.0	2019-04-07 12:51:01.143	info	starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.0
    host.ioBroker	2019-04-07 12:51:00.028	info	instance system.adapter.weatherunderground.0 started with pid 16153
    und die Settings
    Besten Dank für die Hilfe
    • apollon77A Online
      apollon77A Online
      #102
      Das ist strange ... bei mir tut das alles. habe mal genau deins nachgestellt. Welches Admin? Welcher js-controller?
        dos1973
        #103
        anbei die Infos ✌
        admin: 3.6.0
        js script engine: 4.1.12
        Node.js: v8.15.0
        NPM: 6.4.1
        js Controller 1.4.2 (es steht es wäre 1.5.7 verfügbar, keine Ahnung wie ich das updaten kann)
        • apollon77A Online
          apollon77A Online
          #104
          Geh mal mit der Maus über das "Incalid date". Was sterht denn da in dem Popup was da kommt?
          (js.controller update auf Seite "Hosts" :-)
            dos1973
            #105
            so schaut aus...
              dos1973
              #106
              @apollon77
              Hast du noch eine Idee?
                dos1973
                #107
                aufgrund meiner Fehler mit dem Datum habe ich den Adapter, die Instanz und alle DP gelöscht und alles neu installiert.
                jetzt geht gar nichts mehr :-(
                jetzt erhalte nachfolgende FM, dabei spielt es keine Rolle, ob ich den Haken bei "ältere WU-API nutzen" setze oder rausnehme. Ich habe auch andere Mess Stationen verwendet -> aktuell "IFRANKFU924"
                host.ioBroker	2019-04-14 13:34:06.834	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                weatherunderground.0	2019-04-14 13:34:04.317	error	Error: this key does not exist, Reset Station Key
                weatherunderground.0	2019-04-14 13:34:04.066	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                weatherunderground.0	2019-04-14 13:34:03.558	error	Error: this key does not exist, Reset Station Key
                weatherunderground.0	2019-04-14 13:34:03.298	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                weatherunderground.0	2019-04-14 13:34:02.814	error	Error: this key does not exist, Reset Station Key
                weatherunderground.0	2019-04-14 13:34:02.528	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                weatherunderground.0	2019-04-14 13:34:00.865	info	starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.0
                klappt das bei euch noch?
                  dos1973
                  #108
                  ich bin jetzt wieder im Ausgangszustand... ich erhalte Werte aber immer "invalid date" beim Datum. Es spielt keine Rolle, welche Mess Station ich eingebe.
                  könnte jemand mal eine funktionierende Konfiguriert posten, also ein Bild des adapters. Danke
                  • D dos1973
                    anbei die Infos ✌
                    admin: 3.6.0
                    Node.js: v8.15.0
                    NPM: 6.4.1
                    dos1973
                    #109
                    @dos1973 sagte in Weatherunderground Reborn 3.0.0 Alpha:
                    anbei die Infos ✌
                    admin: 3.6.0
                    Node.js: v8.15.0
                    NPM: 6.4.1
                    den js Controller habe ich inzwischen auch auf 1.5.7 ugegradet, keine Änderung.
                    • apollon77A Online
                      apollon77A Online
                      #110
                      Das interessante ist das bei mir das Datum korrekt angezeigt wird. Ich kann das nicht nachstellen. habe mehreres Versucht bisher aber "Ohne Erfolg".
                      Stelle mal auf Debug Logging falls nichts mehr geht bei Dir
                      • crunchipC Offline
                        crunchipC Offline
                        #111
                        Ich habe bei mir in unregelmässigen Abständen vereinzelt diese Meldungen
                        Besitzer eines eigenen Api-key´s bin ich nicht
                        Fehler : weatherunderground.0 Wunderground hat einen Fehler gemeldet: null, 404
                        Fehler : weatherunderground.0 Wunderground hat einen Fehler gemeldet: null, 500
                        • apollon77A Online
                          apollon77A Online
                          #112
                          Ja bei mir auch, da scheint wohl die Webseite in dem Augenblick zu spinnen ... Man könnte die Fehler höchstens noch eher warnungen machen?!
                            dos1973
                            #113
                            Mein iobroker läuft in einem Docker Container... falls das relevant sein sollte.
                              dos1973
                              #114
                              @apollon77
                              Wäre denn ein Teamviewer session auf mein System hilfreich um den Fehler beizukommen?
                              • NashraN Offline
                                NashraN Offline
                                Nashra
                                Most Active Forum Testing
                                #115
                                Hm, bekomme jetzt nach dem ändern der Station auch nur noch
                                die Meldung: Error: this key does not exist, Reset Station Key
                                Ok gehen wir zurück auf die alte Station, mist, der selbe Fehler ☹
                                Gruß Ralf
                                Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
                                • NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  #116
                                  Fehler wohl gefunden...
                                  Bei "Ältere WU-APIs nutzen" war ein Haken gesetzt, diesen entfernt und schon liefert WU wieder Daten.
                                  Seltsam ist nur, das dieser Haken von Anfang an aktiviert war und es auch bis gestern funktioniert hat.
                                  Werde es mal im Auge behalten ob es auch weiterhin funktioniert.
                                  Gruß Ralf
                                  • apollon77A Online
                                    apollon77A Online
                                    #117
                                    Muss ich mal schauen, nicht das WU was geändert hat ... :-)
                                    • NashraN Nashra
                                      apollon77A Online
                                      apollon77A Online
                                      #118
                                      @Nashra Da würde mich der Debug Output vom Adapter mal interessieren. Kann es nicht nachstellen
                                      NashraN 1 Antwort Letzte Antwort
                                      • D dos1973
                                        @apollon77
                                        apollon77A Online
                                        apollon77A Online
                                        #119
                                        @dos1973 Danke für das Angebot. Weiss nicht ob das so viel bringen würde. Kanst DU mal eine andere Station versuchen ob es da geht?
                                          sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          #120
                                          @apollon77
                                          Hallo, also bei mir geht alles, Haken ist gesetzt und keine Stations ID eingetragen.........
                                          Immer Daten sichern!
