  4. Projekt WetterView von sigi234
wetter wetterview sigi234
497 Beiträge 60 Kommentatoren 198.6k Aufrufe 83 Beobachtet
  • H Offline
    heli-wolf
    #341
    das hat nichts geändert. Im Skript wird folgendes ausgegeben.
    29.11.2019, 19:44:45.973	[info ]: javascript.0 Stop script script.js.common.uwz
    29.11.2019, 19:44:50.276	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
    29.11.2019, 19:44:50.277	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
            AreaChannelId=ChannelId+"."+warncellid[j];
    ERROR: Cannot find name 'AreaChannelId'. Did you mean 'AreaChannelID'?
                createState(AreaChannelId+".warning."+i+".ShortText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".LongText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".object","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".begin","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".end","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".severity",0,forceInitStates,{type: 'number'});
                createState(AreaChannelId+".warning."+i+".type",0,forceInitStates,{min:0, max:11, type: 'number',states:UWZTypesArray});
    ERROR: No overload matches this call.
      The last overload gave the following error.
        Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.
                createState(AreaChannelId+".warning."+i+".uwzLevel",0,forceInitStates,{min:0, max:5, type: 'number'});
                createState(AreaChannelId+".warning."+i+".uwzColor",0,forceInitStates,{type:'number'});
                createState(AreaChannelId+".warning."+i+".HTMLShort","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".HTMLLong","",forceInitStates,{type: 'string'});
            for (i=0; i<thedata.results.length; i++) {
    ERROR: Cannot find name 'i'.
                warnings.push(new processResultEntry(thedata.results[i]));
        dwmlog(JSON.stringify(warnings));
    ERROR: Expected 3 arguments, but got 1.
        for (i=0; i<numOfWarnings; i++) {
            if (i<warnings.length) {
                setState(AreaChannelId+".warning."+i+".LongText",warnings[i].LongText);
                setState(AreaChannelId+".warning."+i+".ShortText",warnings[i].ShortText);
                setState(AreaChannelId+".warning."+i+".object",warnings[i].object);
                setState(AreaChannelId+".warning."+i+".begin",warnings[i].begin);
                setState(AreaChannelId+".warning."+i+".end",warnings[i].end);
                setState(AreaChannelId+".warning."+i+".severity",warnings[i].severity);
                setState(AreaChannelId+".warning."+i+".type",warnings[i].type);
                setState(AreaChannelId+".warning."+i+".uwzLevel",warnings[i].uwzLevel);
                setState(AreaChannelId+".warning."+i+".uwzColor",warnings[i].uwzColor);
                setState(AreaChannelId+".warning."+i+".HTMLShort",warnings[i].HTMLShort);
                setState(AreaChannelId+".warning."+i+".HTMLLong",warnings[i].HTMLLong);
                setState(AreaChannelId+".warning."+i+".LongText","");
                setState(AreaChannelId+".warning."+i+".ShortText","");
                setState(AreaChannelId+".warning."+i+".object","{}");
                setState(AreaChannelId+".warning."+i+".begin","");
                setState(AreaChannelId+".warning."+i+".end","");
                setState(AreaChannelId+".warning."+i+".severity",0);
                setState(AreaChannelId+".warning."+i+".type",0);
                setState(AreaChannelId+".warning."+i+".uwzLevel",0);
                setState(AreaChannelId+".warning."+i+".uwzColor",0);
                setState(AreaChannelId+".warning."+i+".HTMLShort","");
                setState(AreaChannelId+".warning."+i+".HTMLLong","");
    ERROR: Cannot redeclare block-scoped variable 'request'.
    ERROR: Cannot find name 'require'. Do you need to install type definitions for node? Try `npm i @types/node`.
                    dwmlog("AREA: "+getAreaFromURI(response.request.uri.href),4);
    ERROR: Expected 3 arguments, but got 2.
                    dwmlog("UWZ Body: " + body,4);
    29.11.2019, 19:44:50.278	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • H Offline
      heli-wolf
      #342
      Modul jetzt erfasst.
      • H heli-wolf
        sigi234S Online
        sigi234S Online
        sigi234
        #343
        @heli-wolf sagte in Projekt WetterView von sigi234:
        Ok, zeig mal dein Skript vom UWZ
        Immer Daten sichern!
        • H Offline
          heli-wolf
          #344
          Ok, sorry aber man lernt NIE aus !!
          var debuglevel = 1;
          var debugchannel = 'info';
          function dwmlog( message, level, channel) {
              if (typeof channel === 'undefined') {
                  channel = debugchannel;
              if ( typeof level === 'undefined')
                  level = debuglevel;
              if ( debuglevel >= level ) {
                  log (message, channel );
          var AdapterId = "javascript."+instance;
          var ChannelId = "UWZ";
          var forceInitStates = false;
          var numOfWarnings = 3;
          var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
          /********************* Hier die Warnzellen-Id's eintragen *****************************/
          var warncellid = ['UWZAT01026'];
          var UWZTypesArray=["n/a","unbekannt","Sturm/Orkan","Schneefall","Starkregen","Extremfrost","Waldbrandgefahr","Gewitter","Glätte","Hitze","Glatteisregen","Bodenfrost"];
          function createStates(n){
              var AreaChannelID = null;
              for (var j=0; j<warncellid.length; j++) {
                  for (var i=0; i<n; i++) {
          function getUWZLevel (warnName){
              var result = -1; // -1 is an error!
              var alert = warnName.split("_");
              var colors = ["green","darkgreen","yellow","orange","red","violet"];
              if (alert[0]=="notice") { result = 1; }
              else if (alert[1] == "forewarn") { result = 2; }
              else {
                  result = colors.indexOf(alert[2]);
              return result;
          function getUWZUrgency (warnName){
              var result = 0;
                  result = 1;
              else {
                  result = 2; // immediate;
              return result;
          function getLevelColor(uwzLevel) {
              var uwzColor = [
                  0x00ff00, // 0 - Grün
                  0x009b00, // 1 - Dunkelgrün
                  0xffff00, // 2 - Gelb Wetterwarnungen (Stufe 1)
                  0xffb400, // 3 - Orange Warnungen vor markantem Wetter (Stufe 2)
                  0xff0000, // 4 - Rot Unwetterwarnungen (Stufe 3)
                  0xff00ff, // 5 - Violett Warnungen vor extremem Unwetter (Stufe 4)
              if (uwzLevel>=0 && uwzLevel<=5)
                  return uwzColor[uwzLevel];
              else
                  return 0;
          function createHTMLShort(w){
              var html = '<div style="background: #'+w.uwzColor.toString(16)+'" border:"10px">';
              var theData = JSON.parse(w.object);
              html += '<h3>';
              if (w.uwzUrgency==1) html+="Vorwarnung vor "; else html+="Warnung vor ";
              html += UWZTypesArray[w.type];
              html +="</h3>";
              html += "<p>Zeitraum von "+formatDate(new Date(theData.dtgStart*1000),"WW, DD. OO YYYY hh:mm")+" Uhr bis "+formatDate(new Date(theData.dtgEnd*1000),"WW, DD. OO YYYY hh:mm")+" Uhr </p>";
              html += '<p>'+w.ShortText+'</p>';
              html += "</div>";
              return html;
          function createHTMLLong(w){
              html += '<h3>';
              html +="</h3>";
              html += '<p>'+w.LongText+'</p>';
              html += "</div>";
              return html;
          function processResultEntry(w) {
              this.object = JSON.stringify(w);
              this.begin=formatDate(new Date(w.dtgStart*1000),"DD.MM.YYYY hh:mm");
              this.end=formatDate(new Date(w.dtgEnd*1000),"DD.MM.YYYY hh:mm");
              // dwmlog (formatDate(this.begin,"DD.MM.YYYY hh:mm"),4);
              // dwmlog (formatDate(this.end,"DD.MM.YYYY hh:mm"),4);
              this.LongText = w.payload.translationsLongText.DE;
              this.ShortText = w.payload.translationsShortText.DE;
              this.severity = w.severity;
              this.type = w.type;
              this.uwzLevel = getUWZLevel(w.payload.levelName);
              this.uwzUrgency = getUWZUrgency(w.payload.levelName);
              this.uwzColor = getLevelColor(this.uwzLevel);
              var x = this;
              this.HTMLShort = createHTMLShort(x);
              this.HTMLLong  = createHTMLLong(x);
          function processData(Area,data) {
              if (!data) {
                 return;
              var AreaChannelId=ChannelId+"."+Area;
              var thedata = JSON.parse(data);
              var warnings= [];
              if (thedata.results.length>0) {
              warnings.sort(function(a,b){
                  var asort = a.severity;
                  var bsort = b.severity;
                  return bsort-asort;
                  } else {
          function getAreaFromURI(uri) {
              var searchstr = "&areaID=";
              var n = uri.search(searchstr);
              var result = uri.slice(n+searchstr.length,uri.length);
              return result;
          createStates(numOfWarnings);
          // processData(jsond2);
          schedule ("3 * * * *", function(){
              for (var i=0; i<warncellid.length; i++) {
                      request({
                          uri: url.replace("XXXAREAXXX",warncellid[i]),
                          method: "GET",
                          timeout: 10000,
                          followRedirect: true,
                          maxRedirects: 10
                      }, function(error, response, body) {
                          // dwmlog("UWZ Error" + error,2);
                          // dwmlog("UWZ Response: " + JSON.stringify(response),4);
                          if (response.statusCode == 200) {
                              processData(getAreaFromURI(response.request.uri.href),body);
          • H heli-wolf
            var debuglevel = 1;
                    level = debuglevel;
                else {
                return result;
                var result = 0;
                    result = 1;
                else {
                return result;
                var uwzColor = [
                else
                    return 0;
                html += '<h3>';
                html +="</h3>";
                html += "</div>";
                return html;
                html += '<h3>';
                html +="</h3>";
                html += "</div>";
                return html;
                this.type = w.type;
                var x = this;
                if (!data) {
                   return;
                var warnings= [];
                    return bsort-asort;
                    } else {
                return result;
                        request({
                            method: "GET",
                            timeout: 10000,
                            maxRedirects: 10
            sigi234S Online
            sigi234S Online
            sigi234
            #345
            @heli-wolf
            Getestet, bei mir geht es.
            AHA!
            Du hast es in common! Da gehört es nicht hin.
            • sigi234S sigi234
              @heli-wolf
              AHA!
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #346
              @sigi234 sagte in Projekt WetterView von sigi234:
              meins läuft auch Common. Das passt normal schon so.
              ° Fixer ---> iob fix
              • NegaleinN Negalein
                sigi234S Online
                sigi234S Online
                sigi234
                #347
                @Negalein sagte in Projekt WetterView von sigi234:
                Ja, verwechselt mit Global
                • H heli-wolf
                  crunchipC Offline
                  crunchipC Offline
                  #348
                  @heli-wolf du hast ein typeScript erstellt, anstatt ein JS-Script
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    #349
                    @crunchip sagte in Projekt WetterView von sigi234:
                    Ja, gerade gesehen
                    • H Offline
                      heli-wolf
                      #350
                      AHA, ich habe doch irgendwo gelesen, dass alle deine Skripte für dieses Projekt als TypeSkript erstellt wurden ???
                      Deshalb habe ich dieses ausgewählt.
                      Müssen alle anderen Skripte (Zeitplanung und Biowetter) auch in JS erstellt werden.
                      Alle Skipte in JS und GLOBAL - Oder??
                      NegaleinN sigi234S 2 Antworten Letzte Antwort
                      • H heli-wolf
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #351
                        GLOBAL
                        Nein, in COMMON
                        • H heli-wolf
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          #352
                          In JS und nicht in Global!
                          Nur das POLLENSKRIPT ist ein TS Skript!
                          • H Offline
                            heli-wolf
                            #353
                            OK, vielen Dank!
                            das habe ich jetzt einmal alles umgestellt, Adapter und PI neu gestartet und jetzt werde ich das ganze ein bisschen beobachten und hoffe, dass es jetzt richtig läuft.
                            Andernfalls ersuche ich euch nochmals um eure Hilfe.
                            Danke vorerst einmal !!
                            • H Offline
                              heli-wolf
                              #354
                              Das Pollenskript habe ich noch gar nicht implementiert, aber wo du es sagst.
                              Ich habe ja 2 Skripte
                              • pollen_css.txt
                              • pollen_css_Ampeln.txt
                              ich dachte dass ich die beiden in der Vis unter CSS einfügen muss?
                              • H heli-wolf
                                • pollen_css.txt
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                #355
                                • pollen_css.txt
                                Vergiss die Skripte, es gibt einen Adapter
                                Pollen risk index
                                • H Offline
                                  heli-wolf
                                  #356
                                  den Pollenflug Adapter habe ich schon installiert
                                  • H Offline
                                    Hoschi575
                                    #357
                                    Moin zusammen.... hab jetzt lange in diesem Forum gelesen und dieses geniale aber für mich etwas zu umfangreiche script von Sigi234 meinen Vorstellungen hin reduziert. Aber ich bekomme die Mondgrafiken einfach nicht angezeigt ... ich geb echt auf und brauche jetzt etwas Hilfe 😬
                                    Danke im Vorraus (auch für die super Vorarbeit)
                                    Gruss Hoschi
                                    • H Hoschi575
                                      Gruss Hoschi
                                      sigi234S Online
                                      sigi234S Online
                                      sigi234
                                      #358
                                      @Hoschi575
                                      hast du in DasWetter Adapter den Icons Pfad angepasst?
                                      • H Offline
                                        Hoschi575
                                        #359
                                        Ja hab ich ... mir fällt gerade auf das bei dir 1.png steht und bei mir nur 1png .... aber warum und wie kann ich das ändern !?!?moon.JPG
                                        • H Offline
                                          Hoschi575
                                          #360
                                          auch wenn
                                          ich unten .png hineinschreibe .... keine änderung
                                          sigi234S K 2 Antworten Letzte Antwort
