  4. Projekt WetterView von sigi234
    6.6k
wetter wetterview sigi234
497 Beiträge 60 Kommentatoren 195.7k Aufrufe 83 Beobachtet
  • H heli-wolf
    nachdem mein raspberry immer wieder abstürzt habe ich mir jetzt einmal das Log angesehen und dabei einen Fehler im UWZ Skript entdeckt.
    Nachdem ich keine Erfahrung mit Skripten habe, stelle ich die Fehlermeldung mal hier rein. Vielleicht kann mir da bitte jemand weiterhelfen.
    29.11.2019, 18:18:53.488	[info ]: javascript.0 Stop script script.js.common.uwz
    29.11.2019, 18:18:54.389	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
    29.11.2019, 18:18:54.389	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
            AreaChannelId=ChannelId+"."+warncellid[j];
    ERROR: Cannot find name 'AreaChannelId'. Did you mean 'AreaChannelID'?
                createState(AreaChannelId+".warning."+i+".ShortText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".LongText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".object","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".begin","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".end","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".severity",0,forceInitStates,{type: 'number'});
                createState(AreaChannelId+".warning."+i+".type",0,forceInitStates,{min:0, max:11, type: 'number',states:UWZTypesArray});
    ERROR: No overload matches this call.
      The last overload gave the following error.
        Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.
                createState(AreaChannelId+".warning."+i+".uwzLevel",0,forceInitStates,{min:0, max:5, type: 'number'});
                createState(AreaChannelId+".warning."+i+".uwzColor",0,forceInitStates,{type:'number'});
                createState(AreaChannelId+".warning."+i+".HTMLShort","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".HTMLLong","",forceInitStates,{type: 'string'});
            for (i=0; i<thedata.results.length; i++) {
    ERROR: Cannot find name 'i'.
                warnings.push(new processResultEntry(thedata.results[i]));
        dwmlog(JSON.stringify(warnings));
    ERROR: Expected 3 arguments, but got 1.
        for (i=0; i<numOfWarnings; i++) {
            if (i<warnings.length) {
                setState(AreaChannelId+".warning."+i+".LongText",warnings[i].LongText);
                setState(AreaChannelId+".warning."+i+".ShortText",warnings[i].ShortText);
                setState(AreaChannelId+".warning."+i+".object",warnings[i].object);
                setState(AreaChannelId+".warning."+i+".begin",warnings[i].begin);
                setState(AreaChannelId+".warning."+i+".end",warnings[i].end);
                setState(AreaChannelId+".warning."+i+".severity",warnings[i].severity);
                setState(AreaChannelId+".warning."+i+".type",warnings[i].type);
                setState(AreaChannelId+".warning."+i+".uwzLevel",warnings[i].uwzLevel);
                setState(AreaChannelId+".warning."+i+".uwzColor",warnings[i].uwzColor);
                setState(AreaChannelId+".warning."+i+".HTMLShort",warnings[i].HTMLShort);
                setState(AreaChannelId+".warning."+i+".HTMLLong",warnings[i].HTMLLong);
                setState(AreaChannelId+".warning."+i+".LongText","");
                setState(AreaChannelId+".warning."+i+".ShortText","");
                setState(AreaChannelId+".warning."+i+".object","{}");
                setState(AreaChannelId+".warning."+i+".begin","");
                setState(AreaChannelId+".warning."+i+".end","");
                setState(AreaChannelId+".warning."+i+".severity",0);
                setState(AreaChannelId+".warning."+i+".type",0);
                setState(AreaChannelId+".warning."+i+".uwzLevel",0);
                setState(AreaChannelId+".warning."+i+".uwzColor",0);
                setState(AreaChannelId+".warning."+i+".HTMLShort","");
                setState(AreaChannelId+".warning."+i+".HTMLLong","");
    var request = require('request');
    ERROR: Cannot redeclare block-scoped variable 'request'.
    ERROR: Cannot find name 'require'. Do you need to install type definitions for node? Try `npm i @types/node`.
                    dwmlog("AREA: "+getAreaFromURI(response.request.uri.href),4);
    ERROR: Expected 3 arguments, but got 2.
                    dwmlog("UWZ Body: " + body,4);
    29.11.2019, 18:18:54.390	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    sigi234S Online
    sigi234S Online
    #336
    @heli-wolf sagte in Projekt WetterView von sigi234:
    AreaChannelId
    Hast du die auch Richtig eingetragen?
    Und das:
    • H Offline
      heli-wolf
      #337
      Bei mir schaut das folgendermaßen aus:
      Die zusätzlichen NPM Module habe ich nicht ??
      Wie komme ich zu diesen?
      • H heli-wolf
        sigi234S Online
        sigi234S Online
        #338
        reinschreiben, aber nur das Rot unterstrichene.
        request
        • H Offline
          heli-wolf
          #339
          habe ich gemacht, muss ich jetzt den PI neu durchstarten oder reicht es den javascript Adapter neu zu starten.
          Wie merke ich ob das der Fehler war?
          • H heli-wolf
            sigi234S Online
            sigi234S Online
            #340
            Beides und im Log
            • H Offline
              heli-wolf
              #341
              das hat nichts geändert. Im Skript wird folgendes ausgegeben.
              29.11.2019, 19:44:45.973	[info ]: javascript.0 Stop script script.js.common.uwz
              29.11.2019, 19:44:50.276	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
              29.11.2019, 19:44:50.277	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
              29.11.2019, 19:44:50.278	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
              • H Offline
                heli-wolf
                #342
                Modul jetzt erfasst.
                • H heli-wolf
                  sigi234S Online
                  sigi234S Online
                  #343
                  Ok, zeig mal dein Skript vom UWZ
                  • H Offline
                    heli-wolf
                    #344
                    Ok, sorry aber man lernt NIE aus !!
                    var debuglevel = 1;
                    var debugchannel = 'info';
                    function dwmlog( message, level, channel) {
                        if (typeof channel === 'undefined') {
                            channel = debugchannel;
                        if ( typeof level === 'undefined')
                            level = debuglevel;
                        if ( debuglevel >= level ) {
                            log (message, channel );
                    var AdapterId = "javascript."+instance;
                    var ChannelId = "UWZ";
                    var forceInitStates = false;
                    var numOfWarnings = 3;
                    var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
                    /********************* Hier die Warnzellen-Id's eintragen *****************************/
                    var warncellid = ['UWZAT01026'];
                    var UWZTypesArray=["n/a","unbekannt","Sturm/Orkan","Schneefall","Starkregen","Extremfrost","Waldbrandgefahr","Gewitter","Glätte","Hitze","Glatteisregen","Bodenfrost"];
                    function createStates(n){
                        var AreaChannelID = null;
                        for (var j=0; j<warncellid.length; j++) {
                            for (var i=0; i<n; i++) {
                    function getUWZLevel (warnName){
                        var result = -1; // -1 is an error!
                        var alert = warnName.split("_");
                        var colors = ["green","darkgreen","yellow","orange","red","violet"];
                        if (alert[0]=="notice") { result = 1; }
                        else if (alert[1] == "forewarn") { result = 2; }
                        else {
                            result = colors.indexOf(alert[2]);
                        return result;
                    function getUWZUrgency (warnName){
                        var result = 0;
                            result = 1;
                        else {
                            result = 2; // immediate;
                        return result;
                    function getLevelColor(uwzLevel) {
                        var uwzColor = [
                            0x00ff00, // 0 - Grün
                            0x009b00, // 1 - Dunkelgrün
                            0xffff00, // 2 - Gelb Wetterwarnungen (Stufe 1)
                            0xffb400, // 3 - Orange Warnungen vor markantem Wetter (Stufe 2)
                            0xff0000, // 4 - Rot Unwetterwarnungen (Stufe 3)
                            0xff00ff, // 5 - Violett Warnungen vor extremem Unwetter (Stufe 4)
                        if (uwzLevel>=0 && uwzLevel<=5)
                            return uwzColor[uwzLevel];
                        else
                            return 0;
                    function createHTMLShort(w){
                        var html = '<div style="background: #'+w.uwzColor.toString(16)+'" border:"10px">';
                        var theData = JSON.parse(w.object);
                        html += '<h3>';
                        if (w.uwzUrgency==1) html+="Vorwarnung vor "; else html+="Warnung vor ";
                        html += UWZTypesArray[w.type];
                        html +="</h3>";
                        html += "<p>Zeitraum von "+formatDate(new Date(theData.dtgStart*1000),"WW, DD. OO YYYY hh:mm")+" Uhr bis "+formatDate(new Date(theData.dtgEnd*1000),"WW, DD. OO YYYY hh:mm")+" Uhr </p>";
                        html += '<p>'+w.ShortText+'</p>';
                        html += "</div>";
                        return html;
                    function createHTMLLong(w){
                        html += '<h3>';
                        html +="</h3>";
                        html += '<p>'+w.LongText+'</p>';
                        html += "</div>";
                        return html;
                    function processResultEntry(w) {
                        this.object = JSON.stringify(w);
                        this.begin=formatDate(new Date(w.dtgStart*1000),"DD.MM.YYYY hh:mm");
                        this.end=formatDate(new Date(w.dtgEnd*1000),"DD.MM.YYYY hh:mm");
                        // dwmlog (formatDate(this.begin,"DD.MM.YYYY hh:mm"),4);
                        // dwmlog (formatDate(this.end,"DD.MM.YYYY hh:mm"),4);
                        this.LongText = w.payload.translationsLongText.DE;
                        this.ShortText = w.payload.translationsShortText.DE;
                        this.severity = w.severity;
                        this.type = w.type;
                        this.uwzLevel = getUWZLevel(w.payload.levelName);
                        this.uwzUrgency = getUWZUrgency(w.payload.levelName);
                        this.uwzColor = getLevelColor(this.uwzLevel);
                        var x = this;
                        this.HTMLShort = createHTMLShort(x);
                        this.HTMLLong  = createHTMLLong(x);
                    function processData(Area,data) {
                        if (!data) {
                           return;
                        var AreaChannelId=ChannelId+"."+Area;
                        var thedata = JSON.parse(data);
                        var warnings= [];
                        if (thedata.results.length>0) {
                        warnings.sort(function(a,b){
                            var asort = a.severity;
                            var bsort = b.severity;
                            return bsort-asort;
                            } else {
                    function getAreaFromURI(uri) {
                        var searchstr = "&areaID=";
                        var n = uri.search(searchstr);
                        var result = uri.slice(n+searchstr.length,uri.length);
                        return result;
                    createStates(numOfWarnings);
                    // processData(jsond2);
                    schedule ("3 * * * *", function(){
                        for (var i=0; i<warncellid.length; i++) {
                                request({
                                    uri: url.replace("XXXAREAXXX",warncellid[i]),
                                    method: "GET",
                                    timeout: 10000,
                                    followRedirect: true,
                                    maxRedirects: 10
                                }, function(error, response, body) {
                                    // dwmlog("UWZ Error" + error,2);
                                    // dwmlog("UWZ Response: " + JSON.stringify(response),4);
                                    if (response.statusCode == 200) {
                                        processData(getAreaFromURI(response.request.uri.href),body);
                    • H heli-wolf
                      var debuglevel = 1;
                              level = debuglevel;
                          else {
                          return result;
                          var result = 0;
                              result = 1;
                          else {
                          return result;
                          var uwzColor = [
                          else
                              return 0;
                          html += '<h3>';
                          html +="</h3>";
                          html += "</div>";
                          return html;
                          html += '<h3>';
                          html +="</h3>";
                          html += "</div>";
                          return html;
                          this.type = w.type;
                          var x = this;
                          if (!data) {
                             return;
                          var warnings= [];
                              return bsort-asort;
                              } else {
                          return result;
                                  request({
                                      method: "GET",
                                      timeout: 10000,
                                      maxRedirects: 10
                      sigi234S Online
                      sigi234S Online
                      #345
                      @heli-wolf
                      Getestet, bei mir geht es.
                      AHA!
                      Du hast es in common! Da gehört es nicht hin.
                      • sigi234S sigi234
                        @heli-wolf
                        AHA!
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #346
                        @sigi234 sagte in Projekt WetterView von sigi234:
                        meins läuft auch Common. Das passt normal schon so.
                        ° Fixer ---> iob fix
                        • NegaleinN Negalein
                          sigi234S Online
                          sigi234S Online
                          #347
                          @Negalein sagte in Projekt WetterView von sigi234:
                          Ja, verwechselt mit Global
                          • H heli-wolf
                            crunchipC Offline
                            crunchipC Offline
                            #348
                            @heli-wolf du hast ein typeScript erstellt, anstatt ein JS-Script
                              sigi234S Online
                              sigi234S Online
                              #349
                              @crunchip sagte in Projekt WetterView von sigi234:
                              Ja, gerade gesehen
                              • H Offline
                                heli-wolf
                                #350
                                AHA, ich habe doch irgendwo gelesen, dass alle deine Skripte für dieses Projekt als TypeSkript erstellt wurden ???
                                Deshalb habe ich dieses ausgewählt.
                                Müssen alle anderen Skripte (Zeitplanung und Biowetter) auch in JS erstellt werden.
                                Alle Skipte in JS und GLOBAL - Oder??
                                NegaleinN sigi234S 2 Antworten Letzte Antwort
                                • H heli-wolf
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #351
                                  GLOBAL
                                  Nein, in COMMON
                                  • H heli-wolf
                                    sigi234S Online
                                    sigi234S Online
                                    #352
                                    In JS und nicht in Global!
                                    Nur das POLLENSKRIPT ist ein TS Skript!
                                    • H Offline
                                      heli-wolf
                                      #353
                                      OK, vielen Dank!
                                      das habe ich jetzt einmal alles umgestellt, Adapter und PI neu gestartet und jetzt werde ich das ganze ein bisschen beobachten und hoffe, dass es jetzt richtig läuft.
                                      Andernfalls ersuche ich euch nochmals um eure Hilfe.
                                      Danke vorerst einmal !!
                                      • H Offline
                                        heli-wolf
                                        #354
                                        Das Pollenskript habe ich noch gar nicht implementiert, aber wo du es sagst.
                                        Ich habe ja 2 Skripte
                                        • pollen_css.txt
                                        • pollen_css_Ampeln.txt
                                        ich dachte dass ich die beiden in der Vis unter CSS einfügen muss?
                                        • H heli-wolf
                                          • pollen_css.txt
                                          sigi234S Online
                                          sigi234S Online
                                          #355
                                          • pollen_css.txt
                                          Vergiss die Skripte, es gibt einen Adapter
                                          Pollen risk index
