  4. Projekt WetterView von sigi234
    6.6k
wetter wetterview sigi234
497 Beiträge 60 Kommentatoren 195.7k Aufrufe 83 Beobachtet
  • H heli-wolf
    habe ich gemacht, muss ich jetzt den PI neu durchstarten oder reicht es den javascript Adapter neu zu starten.
    Wie merke ich ob das der Fehler war?
    sigi234S Online
    sigi234S Online
    #340
    @heli-wolf sagte in Projekt WetterView von sigi234:
    Beides und im Log
    • H Offline
      heli-wolf
      #341
      das hat nichts geändert. Im Skript wird folgendes ausgegeben.
      29.11.2019, 19:44:45.973	[info ]: javascript.0 Stop script script.js.common.uwz
      29.11.2019, 19:44:50.276	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
      29.11.2019, 19:44:50.277	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
              AreaChannelId=ChannelId+"."+warncellid[j];
      ERROR: Cannot find name 'AreaChannelId'. Did you mean 'AreaChannelID'?
                  createState(AreaChannelId+".warning."+i+".ShortText","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".LongText","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".object","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".begin","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".end","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".severity",0,forceInitStates,{type: 'number'});
                  createState(AreaChannelId+".warning."+i+".type",0,forceInitStates,{min:0, max:11, type: 'number',states:UWZTypesArray});
      ERROR: No overload matches this call.
        The last overload gave the following error.
          Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.
                  createState(AreaChannelId+".warning."+i+".uwzLevel",0,forceInitStates,{min:0, max:5, type: 'number'});
                  createState(AreaChannelId+".warning."+i+".uwzColor",0,forceInitStates,{type:'number'});
                  createState(AreaChannelId+".warning."+i+".HTMLShort","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".HTMLLong","",forceInitStates,{type: 'string'});
              for (i=0; i<thedata.results.length; i++) {
      ERROR: Cannot find name 'i'.
                  warnings.push(new processResultEntry(thedata.results[i]));
          dwmlog(JSON.stringify(warnings));
      ERROR: Expected 3 arguments, but got 1.
          for (i=0; i<numOfWarnings; i++) {
              if (i<warnings.length) {
                  setState(AreaChannelId+".warning."+i+".LongText",warnings[i].LongText);
                  setState(AreaChannelId+".warning."+i+".ShortText",warnings[i].ShortText);
                  setState(AreaChannelId+".warning."+i+".object",warnings[i].object);
                  setState(AreaChannelId+".warning."+i+".begin",warnings[i].begin);
                  setState(AreaChannelId+".warning."+i+".end",warnings[i].end);
                  setState(AreaChannelId+".warning."+i+".severity",warnings[i].severity);
                  setState(AreaChannelId+".warning."+i+".type",warnings[i].type);
                  setState(AreaChannelId+".warning."+i+".uwzLevel",warnings[i].uwzLevel);
                  setState(AreaChannelId+".warning."+i+".uwzColor",warnings[i].uwzColor);
                  setState(AreaChannelId+".warning."+i+".HTMLShort",warnings[i].HTMLShort);
                  setState(AreaChannelId+".warning."+i+".HTMLLong",warnings[i].HTMLLong);
                  setState(AreaChannelId+".warning."+i+".LongText","");
                  setState(AreaChannelId+".warning."+i+".ShortText","");
                  setState(AreaChannelId+".warning."+i+".object","{}");
                  setState(AreaChannelId+".warning."+i+".begin","");
                  setState(AreaChannelId+".warning."+i+".end","");
                  setState(AreaChannelId+".warning."+i+".severity",0);
                  setState(AreaChannelId+".warning."+i+".type",0);
                  setState(AreaChannelId+".warning."+i+".uwzLevel",0);
                  setState(AreaChannelId+".warning."+i+".uwzColor",0);
                  setState(AreaChannelId+".warning."+i+".HTMLShort","");
                  setState(AreaChannelId+".warning."+i+".HTMLLong","");
      var request = require('request');
      ERROR: Cannot redeclare block-scoped variable 'request'.
      ERROR: Cannot find name 'require'. Do you need to install type definitions for node? Try `npm i @types/node`.
                      dwmlog("AREA: "+getAreaFromURI(response.request.uri.href),4);
      ERROR: Expected 3 arguments, but got 2.
                      dwmlog("UWZ Body: " + body,4);
      29.11.2019, 19:44:50.278	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • H Offline
        heli-wolf
        #342
        Modul jetzt erfasst.
        • H heli-wolf
          sigi234S Online
          sigi234S Online
          #343
          Ok, zeig mal dein Skript vom UWZ
          • H Offline
            heli-wolf
            #344
            Ok, sorry aber man lernt NIE aus !!
            var debuglevel = 1;
            var debugchannel = 'info';
            function dwmlog( message, level, channel) {
                if (typeof channel === 'undefined') {
                    channel = debugchannel;
                if ( typeof level === 'undefined')
                    level = debuglevel;
                if ( debuglevel >= level ) {
                    log (message, channel );
            var AdapterId = "javascript."+instance;
            var ChannelId = "UWZ";
            var forceInitStates = false;
            var numOfWarnings = 3;
            var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
            /********************* Hier die Warnzellen-Id's eintragen *****************************/
            var warncellid = ['UWZAT01026'];
            var UWZTypesArray=["n/a","unbekannt","Sturm/Orkan","Schneefall","Starkregen","Extremfrost","Waldbrandgefahr","Gewitter","Glätte","Hitze","Glatteisregen","Bodenfrost"];
            function createStates(n){
                var AreaChannelID = null;
                for (var j=0; j<warncellid.length; j++) {
                    for (var i=0; i<n; i++) {
            function getUWZLevel (warnName){
                var result = -1; // -1 is an error!
                var alert = warnName.split("_");
                var colors = ["green","darkgreen","yellow","orange","red","violet"];
                if (alert[0]=="notice") { result = 1; }
                else if (alert[1] == "forewarn") { result = 2; }
                else {
                    result = colors.indexOf(alert[2]);
                return result;
            function getUWZUrgency (warnName){
                var result = 0;
                    result = 1;
                else {
                    result = 2; // immediate;
                return result;
            function getLevelColor(uwzLevel) {
                var uwzColor = [
                    0x00ff00, // 0 - Grün
                    0x009b00, // 1 - Dunkelgrün
                    0xffff00, // 2 - Gelb Wetterwarnungen (Stufe 1)
                    0xffb400, // 3 - Orange Warnungen vor markantem Wetter (Stufe 2)
                    0xff0000, // 4 - Rot Unwetterwarnungen (Stufe 3)
                    0xff00ff, // 5 - Violett Warnungen vor extremem Unwetter (Stufe 4)
                if (uwzLevel>=0 && uwzLevel<=5)
                    return uwzColor[uwzLevel];
                else
                    return 0;
            function createHTMLShort(w){
                var html = '<div style="background: #'+w.uwzColor.toString(16)+'" border:"10px">';
                var theData = JSON.parse(w.object);
                html += '<h3>';
                if (w.uwzUrgency==1) html+="Vorwarnung vor "; else html+="Warnung vor ";
                html += UWZTypesArray[w.type];
                html +="</h3>";
                html += "<p>Zeitraum von "+formatDate(new Date(theData.dtgStart*1000),"WW, DD. OO YYYY hh:mm")+" Uhr bis "+formatDate(new Date(theData.dtgEnd*1000),"WW, DD. OO YYYY hh:mm")+" Uhr </p>";
                html += '<p>'+w.ShortText+'</p>';
                html += "</div>";
                return html;
            function createHTMLLong(w){
                html += '<h3>';
                html +="</h3>";
                html += '<p>'+w.LongText+'</p>';
                html += "</div>";
                return html;
            function processResultEntry(w) {
                this.object = JSON.stringify(w);
                this.begin=formatDate(new Date(w.dtgStart*1000),"DD.MM.YYYY hh:mm");
                this.end=formatDate(new Date(w.dtgEnd*1000),"DD.MM.YYYY hh:mm");
                // dwmlog (formatDate(this.begin,"DD.MM.YYYY hh:mm"),4);
                // dwmlog (formatDate(this.end,"DD.MM.YYYY hh:mm"),4);
                this.LongText = w.payload.translationsLongText.DE;
                this.ShortText = w.payload.translationsShortText.DE;
                this.severity = w.severity;
                this.type = w.type;
                this.uwzLevel = getUWZLevel(w.payload.levelName);
                this.uwzUrgency = getUWZUrgency(w.payload.levelName);
                this.uwzColor = getLevelColor(this.uwzLevel);
                var x = this;
                this.HTMLShort = createHTMLShort(x);
                this.HTMLLong  = createHTMLLong(x);
            function processData(Area,data) {
                if (!data) {
                   return;
                var AreaChannelId=ChannelId+"."+Area;
                var thedata = JSON.parse(data);
                var warnings= [];
                if (thedata.results.length>0) {
                warnings.sort(function(a,b){
                    var asort = a.severity;
                    var bsort = b.severity;
                    return bsort-asort;
                    } else {
            function getAreaFromURI(uri) {
                var searchstr = "&areaID=";
                var n = uri.search(searchstr);
                var result = uri.slice(n+searchstr.length,uri.length);
                return result;
            createStates(numOfWarnings);
            // processData(jsond2);
            schedule ("3 * * * *", function(){
                for (var i=0; i<warncellid.length; i++) {
                        request({
                            uri: url.replace("XXXAREAXXX",warncellid[i]),
                            method: "GET",
                            timeout: 10000,
                            followRedirect: true,
                            maxRedirects: 10
                        }, function(error, response, body) {
                            // dwmlog("UWZ Error" + error,2);
                            // dwmlog("UWZ Response: " + JSON.stringify(response),4);
                            if (response.statusCode == 200) {
                                processData(getAreaFromURI(response.request.uri.href),body);
            • H heli-wolf
              var debuglevel = 1;
                      level = debuglevel;
                  else {
                  return result;
                  var result = 0;
                      result = 1;
                  else {
                  return result;
                  var uwzColor = [
                  else
                      return 0;
                  html += '<h3>';
                  html +="</h3>";
                  html += "</div>";
                  return html;
                  html += '<h3>';
                  html +="</h3>";
                  html += "</div>";
                  return html;
                  this.type = w.type;
                  var x = this;
                  if (!data) {
                     return;
                  var warnings= [];
                      return bsort-asort;
                      } else {
                  return result;
                          request({
                              method: "GET",
                              timeout: 10000,
                              maxRedirects: 10
              sigi234S Online
              sigi234S Online
              #345
              @heli-wolf
              Getestet, bei mir geht es.
              AHA!
              Du hast es in common! Da gehört es nicht hin.
              • sigi234S sigi234
                @heli-wolf
                AHA!
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #346
                @sigi234 sagte in Projekt WetterView von sigi234:
                meins läuft auch Common. Das passt normal schon so.
                ° Fixer ---> iob fix
                • NegaleinN Negalein
                  sigi234S Online
                  sigi234S Online
                  #347
                  @Negalein sagte in Projekt WetterView von sigi234:
                  Ja, verwechselt mit Global
                  • H heli-wolf
                    crunchipC Offline
                    crunchipC Offline
                    #348
                    @heli-wolf du hast ein typeScript erstellt, anstatt ein JS-Script
                      sigi234S Online
                      sigi234S Online
                      #349
                      @crunchip sagte in Projekt WetterView von sigi234:
                      Ja, gerade gesehen
                      • H Offline
                        heli-wolf
                        #350
                        AHA, ich habe doch irgendwo gelesen, dass alle deine Skripte für dieses Projekt als TypeSkript erstellt wurden ???
                        Deshalb habe ich dieses ausgewählt.
                        Müssen alle anderen Skripte (Zeitplanung und Biowetter) auch in JS erstellt werden.
                        Alle Skipte in JS und GLOBAL - Oder??
                        NegaleinN sigi234S 2 Antworten Letzte Antwort
                        • H heli-wolf
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #351
                          GLOBAL
                          Nein, in COMMON
                          • H heli-wolf
                            sigi234S Online
                            sigi234S Online
                            #352
                            In JS und nicht in Global!
                            Nur das POLLENSKRIPT ist ein TS Skript!
                            • H Offline
                              heli-wolf
                              #353
                              OK, vielen Dank!
                              das habe ich jetzt einmal alles umgestellt, Adapter und PI neu gestartet und jetzt werde ich das ganze ein bisschen beobachten und hoffe, dass es jetzt richtig läuft.
                              Andernfalls ersuche ich euch nochmals um eure Hilfe.
                              Danke vorerst einmal !!
                              • H Offline
                                heli-wolf
                                #354
                                Das Pollenskript habe ich noch gar nicht implementiert, aber wo du es sagst.
                                Ich habe ja 2 Skripte
                                • pollen_css.txt
                                • pollen_css_Ampeln.txt
                                ich dachte dass ich die beiden in der Vis unter CSS einfügen muss?
                                • H heli-wolf
                                  • pollen_css.txt
                                  sigi234S Online
                                  sigi234S Online
                                  #355
                                  • pollen_css.txt
                                  Vergiss die Skripte, es gibt einen Adapter
                                  Pollen risk index
                                  • H Offline
                                    heli-wolf
                                    #356
                                    den Pollenflug Adapter habe ich schon installiert
                                    • H Offline
                                      Hoschi575
                                      #357
                                      Moin zusammen.... hab jetzt lange in diesem Forum gelesen und dieses geniale aber für mich etwas zu umfangreiche script von Sigi234 meinen Vorstellungen hin reduziert. Aber ich bekomme die Mondgrafiken einfach nicht angezeigt ... ich geb echt auf und brauche jetzt etwas Hilfe 😬
                                      Danke im Vorraus (auch für die super Vorarbeit)
                                      Gruss Hoschi
                                      • H Hoschi575
                                        Gruss Hoschi
                                        sigi234S Online
                                        sigi234S Online
                                        #358
                                        @Hoschi575
                                        hast du in DasWetter Adapter den Icons Pfad angepasst?
                                        • H Offline
                                          Hoschi575
                                          #359
                                          Ja hab ich ... mir fällt gerade auf das bei dir 1.png steht und bei mir nur 1png .... aber warum und wie kann ich das ändern !?!?moon.JPG
