  4. Projekt WetterView von sigi234
    6.6k
wetter wetterview sigi234
497 Beiträge 60 Kommentatoren 195.7k Aufrufe 83 Beobachtet
  • H heli-wolf
    das hat nichts geändert. Im Skript wird folgendes ausgegeben.
    29.11.2019, 19:44:45.973	[info ]: javascript.0 Stop script script.js.common.uwz
    29.11.2019, 19:44:50.276	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
    29.11.2019, 19:44:50.277	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
            AreaChannelId=ChannelId+"."+warncellid[j];
    ERROR: Cannot find name 'AreaChannelId'. Did you mean 'AreaChannelID'?
                createState(AreaChannelId+".warning."+i+".ShortText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".LongText","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".object","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".begin","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".end","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".severity",0,forceInitStates,{type: 'number'});
                createState(AreaChannelId+".warning."+i+".type",0,forceInitStates,{min:0, max:11, type: 'number',states:UWZTypesArray});
    ERROR: No overload matches this call.
      The last overload gave the following error.
        Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.
                createState(AreaChannelId+".warning."+i+".uwzLevel",0,forceInitStates,{min:0, max:5, type: 'number'});
                createState(AreaChannelId+".warning."+i+".uwzColor",0,forceInitStates,{type:'number'});
                createState(AreaChannelId+".warning."+i+".HTMLShort","",forceInitStates,{type: 'string'});
                createState(AreaChannelId+".warning."+i+".HTMLLong","",forceInitStates,{type: 'string'});
            for (i=0; i<thedata.results.length; i++) {
    ERROR: Cannot find name 'i'.
                warnings.push(new processResultEntry(thedata.results[i]));
        dwmlog(JSON.stringify(warnings));
    ERROR: Expected 3 arguments, but got 1.
        for (i=0; i<numOfWarnings; i++) {
            if (i<warnings.length) {
                setState(AreaChannelId+".warning."+i+".LongText",warnings[i].LongText);
                setState(AreaChannelId+".warning."+i+".ShortText",warnings[i].ShortText);
                setState(AreaChannelId+".warning."+i+".object",warnings[i].object);
                setState(AreaChannelId+".warning."+i+".begin",warnings[i].begin);
                setState(AreaChannelId+".warning."+i+".end",warnings[i].end);
                setState(AreaChannelId+".warning."+i+".severity",warnings[i].severity);
                setState(AreaChannelId+".warning."+i+".type",warnings[i].type);
                setState(AreaChannelId+".warning."+i+".uwzLevel",warnings[i].uwzLevel);
                setState(AreaChannelId+".warning."+i+".uwzColor",warnings[i].uwzColor);
                setState(AreaChannelId+".warning."+i+".HTMLShort",warnings[i].HTMLShort);
                setState(AreaChannelId+".warning."+i+".HTMLLong",warnings[i].HTMLLong);
                setState(AreaChannelId+".warning."+i+".LongText","");
                setState(AreaChannelId+".warning."+i+".ShortText","");
                setState(AreaChannelId+".warning."+i+".object","{}");
                setState(AreaChannelId+".warning."+i+".begin","");
                setState(AreaChannelId+".warning."+i+".end","");
                setState(AreaChannelId+".warning."+i+".severity",0);
                setState(AreaChannelId+".warning."+i+".type",0);
                setState(AreaChannelId+".warning."+i+".uwzLevel",0);
                setState(AreaChannelId+".warning."+i+".uwzColor",0);
                setState(AreaChannelId+".warning."+i+".HTMLShort","");
                setState(AreaChannelId+".warning."+i+".HTMLLong","");
    var request = require('request');
    ERROR: Cannot redeclare block-scoped variable 'request'.
    ERROR: Cannot find name 'require'. Do you need to install type definitions for node? Try `npm i @types/node`.
                    dwmlog("AREA: "+getAreaFromURI(response.request.uri.href),4);
    ERROR: Expected 3 arguments, but got 2.
                    dwmlog("UWZ Body: " + body,4);
    29.11.2019, 19:44:50.278	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    crunchipC Offline
    crunchipC Offline
    #348
    @heli-wolf du hast ein typeScript erstellt, anstatt ein JS-Script
      sigi234S Online
      sigi234S Online
      #349
      @crunchip sagte in Projekt WetterView von sigi234:
      Ja, gerade gesehen
      • H Offline
        heli-wolf
        #350
        AHA, ich habe doch irgendwo gelesen, dass alle deine Skripte für dieses Projekt als TypeSkript erstellt wurden ???
        Deshalb habe ich dieses ausgewählt.
        Müssen alle anderen Skripte (Zeitplanung und Biowetter) auch in JS erstellt werden.
        Alle Skipte in JS und GLOBAL - Oder??
        NegaleinN sigi234S 2 Antworten Letzte Antwort
        • H heli-wolf
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #351
          @heli-wolf sagte in Projekt WetterView von sigi234:
          GLOBAL
          Nein, in COMMON
          ° Fixer ---> iob fix
          • H heli-wolf
            sigi234S Online
            sigi234S Online
            #352
            In JS und nicht in Global!
            Nur das POLLENSKRIPT ist ein TS Skript!
            • H Offline
              heli-wolf
              #353
              OK, vielen Dank!
              das habe ich jetzt einmal alles umgestellt, Adapter und PI neu gestartet und jetzt werde ich das ganze ein bisschen beobachten und hoffe, dass es jetzt richtig läuft.
              Andernfalls ersuche ich euch nochmals um eure Hilfe.
              Danke vorerst einmal !!
              • H Offline
                heli-wolf
                #354
                Das Pollenskript habe ich noch gar nicht implementiert, aber wo du es sagst.
                Ich habe ja 2 Skripte
                • pollen_css.txt
                • pollen_css_Ampeln.txt
                ich dachte dass ich die beiden in der Vis unter CSS einfügen muss?
                • H heli-wolf
                  • pollen_css.txt
                  sigi234S Online
                  sigi234S Online
                  #355
                  • pollen_css.txt
                  Vergiss die Skripte, es gibt einen Adapter
                  Pollen risk index
                  • H Offline
                    heli-wolf
                    #356
                    den Pollenflug Adapter habe ich schon installiert
                    • H Offline
                      Hoschi575
                      #357
                      Moin zusammen.... hab jetzt lange in diesem Forum gelesen und dieses geniale aber für mich etwas zu umfangreiche script von Sigi234 meinen Vorstellungen hin reduziert. Aber ich bekomme die Mondgrafiken einfach nicht angezeigt ... ich geb echt auf und brauche jetzt etwas Hilfe 😬
                      Danke im Vorraus (auch für die super Vorarbeit)
                      Gruss Hoschi
                      • H Hoschi575
                        Gruss Hoschi
                        sigi234S Online
                        sigi234S Online
                        #358
                        @Hoschi575
                        hast du in DasWetter Adapter den Icons Pfad angepasst?
                        • H Offline
                          Hoschi575
                          #359
                          Ja hab ich ... mir fällt gerade auf das bei dir 1.png steht und bei mir nur 1png .... aber warum und wie kann ich das ändern !?!?moon.JPG
                          • H Offline
                            Hoschi575
                            #360
                            auch wenn
                            ich unten .png hineinschreibe .... keine änderung
                            sigi234S K 2 Antworten Letzte Antwort
                            • H Hoschi575
                              auch wenn
                              sigi234S Online
                              sigi234S Online
                              #361
                              @Hoschi575 sagte in Projekt WetterView von sigi234:
                              auch wenn
                              Abwarten und neu starten, cron ausführen
                              • H Offline
                                Hoschi575
                                #362
                                hab neu gestartet aber ... nein geht noch nicht... wenn ich das richtig sehe besteht echt das problem mit dem . vor dem png ....
                                aber wo muss ich da ran 🙄
                                • H Hoschi575
                                  sigi234S Online
                                  sigi234S Online
                                  #363
                                  @Hoschi575
                                  Punkt eintragen und speichern.
                                  • H Offline
                                    Hoschi575
                                    #364
                                    ok ok .... jetzt warum auch immer geht es.... die zeit brauchts wahrscheinlich ....vielen dank für das verständnis und die hilfe
                                    H 1 Antwort Letzte Antwort
                                    • H Hoschi575
                                      Hoschi575
                                      #365
                                      • H Hoschi575
                                        sigi234S Online
                                        sigi234S Online
                                        #366
                                        @Hoschi575
                                        Na also, geht ja. 😀
                                        • H Hoschi575
                                          auch wenn
                                          klausiob
                                          schrieb am zuletzt editiert von klausiob
                                          #367
                                          @Hoschi575 Ich glaube bei den Adaptereinstellung bist Du für den Mond falsch. Du möchtest doch sicher die HD-Monddarstellung.
                                          Klicke mal auf das broken Image. Dann sollten die Eigenschaften für das widget "basic - Image 8" kommen. Als Schalter wählst Du
                                          daswetter.0.NextHours2.Location_1.Day_1.moon_symbol
                                          Hier stehen aber nur Zahlen von 0-28 drin. Deshalb mußt Du jeder Zahl ein Bild mit Pfad zuweisen. Unter Symbole z.B. für die Zahl 0 die URL
                                          /vis.0/Wettericons/Mond/1.png
                                          usw. bis 28. Dann sieht der Mond so aus, vorausgesetzt du hast die HD-Bilder von sigi234 in das Verzeichnis kopiert.
                                          Bild Text
                                          Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                                          node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
